Oil Filters, whose is best, and Why?
tom
Oil filter paper (and paper for most other filter applications) is grooved to help keep the pleats separated and provide a channel of flow for the oil (or whatever fluid is being filtered). Also, grooving stiffens the paper in the direction that the grooves run, helping to keep the pleats oriented properly. A third advantage is the extra surface area that you get with pleated paper vs. unpleated paper (this is a small factor in oil filters, because we get don't depend on strictly surface filtration- there is depth filtration in an oil filter, meaning that dirt is trapped and held inside the paper, not just on the surface).
tom
Thanks again for all the info.,,
tom
What brand do you use on personal cars or do you just go to quick lube or dealers for the change???????
OK, I will reward your persistence, but you will be disappointed with my answer.
I have used filters from all of the major manufacturers over the years. I have "spread my business around." Up til now, I have never used a "premium" filter! Just the average, everyday filter that can be bought at a Walmart.
Often, as you guessed above, armtdm, I have just taken vehicles to a quick lube, and whatever they put on for a filter is what I got. This is mainly on my wife's car and my son's car: I just stay after them to be sure to have their oil changed on time, and they go to a quick lube.
For my own vehicle, I usually buy my own oil and filter and have the oil changed at a GM dealer in the town where I work. They change the oil and do a lube job for $5.95, when you have your own oil and filter. (Great deal, huh?) I have recently learned that the little shop just down the road about half a mile from my house will do the same for $7.00, and they are open on Saturdays, so I will probably start going there.
I just bought my first ever premium filter and will use it on the next oil change on my '89 S-10 pickup that has 138K miles on it.
I also bought some Valvoline Max Life oil, which is supposed to be good for high mileage engines. That will be my first experience with that stuff.
It's not that I haven't thought premium filters were a good idea, nor was I just too cheap to pay a few extra bucks for one (although I am cheap): it's just that I haven't seen them sold at Walmart. That's where I usually buy my oil, and I have been too lazy to make an extra stop at an auto parts store to pick up a premium filter.
tom
Actually, I may tend to agreee with that. The large particles of wear material say over 20-30 microns are what cause wear and would be caught by the cheapest filter. The small stuff, 10 micron or so, only become a problem when the total particle count gets so high (as a % of volume) that it affects lubrication. Changing the oil often with a cheap filter does the trick of removing wear particles which is probably why (given the vast majority of consumers change every 3000 miles) that Fram can still have devouted followers and sell crap! Perhaps a filter only makes a difference if you go beyond 3000 miles>
Again, I remember in the 50s cars with no filters but the oil was changed every 1000 miles. We could probably go 3000 today with better oils and no filter and still get the same longevity.
So, comments????????
"It would appear then that in the overall lubrication process and life of an enigine you basically don't believe that the quality of the filter makes any difference, that it is primarily the oil and how often you change it that counts."
Of course the quality of the filter makes a difference! It's just that I believe several manufacturers make good quality filters. I haven't bought "junk" for my vehicles.
I think filter makers for the most part have three categories of filters: bargain basement "economy" filters, "top quality" filters, and then the "premium" filters, which are not really better in the quality of their construction but will trap smaller particles because of the media that is used.
I have always bought the top quality filters and have just now decided to try the premiums. I am not sure that the extra efficient filtering in the small particle sizes will contribute to the life of the engine, but it sure couldn't hurt. Like you said, a lot depends on the drain interval.
I am a big believer in changing the oil frequently. I would rather do a little overkill than wonder later if I could have gotten more miles out of my engine by the inexpensive habit of changing my oil more often.
tom
I guess the "premiums" ARE worth the extra money.
Let's hear more about it when you have the chance.
tom
tom
When I say "brands" I'm talking the brand label on the box, not the actual manufacturer.
tsjay, I'm guessing your "top quality" category includes filters such as Purolator Pure One, AC Delco Ultragard Gold, etc.????
Actually, the filters you mentioned are the ones I was referring to as "premium." The Pure One, Ultraguard Gold, Mobil 1, etc. are what I consider the premiums. You pay extra for these, and they trap the smaller particles of dirt at a much higher efficiency than the standard filters.
The "top quality" filters I referred to are usually the ones that carry the manufacturer's name brand on them. I guess you would say they are the manufacturer's major product, or top-seller, I guess you could say. These are very good filters, but they just don't get the smaller particles like the "premiums" do.
I wasn't aware that Fram made a $10 filter. It's probably fine, but I just wasn't aware that they had one that expensive. Do they advertise it much?
tom
tom
Sorry to get off topic.
Pure Ones are available near me for $5 each. To me, that's good value-- not that much more than the "standard" filters available in the $3-4 range. I can't justify twice the price of Pure One for Mobil 1 b/c I'm not convinced it performs measurably or noticeably better.
Damn that Laettner dude!
tom
Saddle up, and ride for Waldomart.
So Kentucky and the Carolinas actually play, what, basketball?
What is the depth filtration capacity of that hoop net?
Most of the good, but less than premium, oil paper grades have no micro glass. I just happened to pick one that does have a tiny bit of glass when I showed the performance data a few posts back.
The premiums can have up to 25% micro glass. We use several different glass fibers with a variety of fiber diameters. (Better not get too specific here.)
The glass and the poly are both in the form of fibers, not continuos strands. Both the poly and the glass end up in the slurry of fibers that is delivered to the paper machine where the sheet is formed.
When the pulp slurry is delivered to the forming fabric on the paper machine, the consistency is 0.3%. So, there's only 3 pounds of fiber in a thousand pounds of slurry! Lots of water has to be drained to form a sheet of paper.
Our consistency is actually high compared to those of a lot of other paper machines making other types of paper products.
The water that is drained is captured and re-used to dilute more pulp in a closed loop. When the paper is at about 70% to 75% water, it is a wet mat that has enough strength to be taken off the paper machine's forming fabric and sent through the steam cans for drying. The paper is just barely past the point where you can squeeze any water out of it with your hand at the point where the sheet leaves the paper machine's forming fabric and goes into the dryers.
Obviously, we lose some water via evaporation in the steam can sections, so we need make-up water coming into the system.
If you have never seen a paper machine in operation, you ought to go take a tour somewhere. It's a pretty neat process.
tom
As a matter of fact, O.J. Simpson was trying to get to Lexington when he was in that white Bronco. He knew no one would ever look for a Heisman winner in Lexington!
tom
Regardless of the end use application, whether it is oil, hydrualic, air, or fuel, we measure the sheet's AIR permeability. It's a lot cleaner and easier to test air permeability than to do flow tests with oil or fuel or whatever.
A paper sample is placed in the test stand, and air is pulled through the paper until a 0.5 inch (inches of water) pressure drop is reached. The volume of air in cubic feet per minute per square foot of surface area that flows through the paper at the 0.5" pressure drop is what we call the sheet's "CFM" (cubic feet per minute) or "Air Flow."
Fuel sheets can be as low as one or two CFM, and auto air sheets are often 120 to 150 CFM. Oil sheets are in the range of 20 (the "tight" sheets for the premium filters) to about 70 to 80 CFM. Most of the oil sheets are from 35 to 55 CFM.
tom
BTW The article about the GM test is a Diagnetics article by James C Fitch P.E. It states:
" In a related study on both diesel and automotive engines, General Motors reports, :compared to a 40 micron filter, engine wear was reduced by 50% with 30 micron filtration. Likewise , wear was reduced by 70% with 15 micron filtration."
We have a variety of wood fibers that we use. The combinations of the right fibers gives the desired performance for any sheet. We have the big southern pine fibers for bulk and permeability, and then at the other end of the spectrum are the northern hardwoods that are much smaller fibers and will give the sheet a tighter structure for efficiency. There are lots of fibers whose diameters are in between these extremes.
Typically, there will be at least three or four different types of cellulosic fibers in a given grade of paper, and the premium sheets will also have glass and some poly.
Now, about that study, I would think that the details of how the tests were conducted would be important to know before conclusions can be drawn.
How long the same oil was allowed to be in the engine during the tests would be important. Did it simulate the normal oil change interval?
tom
I have no problem believing that a high efficiency filter contributes to engine protection, but, like anything else, there has to be a point where going any further just doesn't gain anything. I don't know where that point is.
What's the definition of a "40 micron" filter? I think it has to be 95% or 99% efficient at the nominal particle size, right? In other words, to be considered a 40µ filter, a filter would have to trap 95% or 99% of the 40µ particles. Well, ANY filter is gonna be at least a 40µ filter, so they are using an unrealistic base line for their comparison.
Look at that table I posted. Just the standard filter was 99.99% efficient at 30µ. So, for all practical purposes, any decent filter you might buy would be a 30µ filter. That same standard filter in the table is 89% efficient at 20µ, so it almost qualifies as a 20µ filter. Well, OK, these are flat sheet multipass results and not filter tests, but the efficiencies in the actual filter should be about the same.
tom
Something else about the GM study just occurred to me: they went all the way from 30µ to 15µ. They showed that the 30µ filter reduced wear from that of the 40µ filter by 50% and that the 15µ filter reduced it by 70%.
How do we know that a 20µ filter wouldn't also show about the same 70% reduction as the 15µ filter?
tom
I have a question, though. Have you seen a filter company (I know you won't name names) who's filter has a high build quality (the canister, valve, gasket, etc ... are all really well made and sturdy) but then specs out a rather cheap/poor-performing filter media?
What percentage of the manufacturing cost of a given filter is the media? I know this must vary ... but can you give a range and an average?
I guess what I'm getting at is that I look at the build quality (not the marketing hype) of a filter as a general indicator of it's ability to do its job. Have you even known this NOT to be the case? And, if so, to what degree?
--- Bror Jace
The high efficiency premium filters aren't necessarily any better in construction than the standard filter from the same manufacturer, but the paper is more expensive and more pleats are used per element.
I'm not sure how much of the total cost of the filter the media represents in relation to other components. I think labor is probably the biggest factor in the cost of manufacture.
There really hasn't been all that much automization in the auto oil filter manufacturing industry. There are still lots of people on the assembly lines.
Most large filter manufacturers make their own metal parts, which includes the canisters, the center tubes, the end caps, the springs, and the base plates.
I know of at least one large manufacturer that makes their own plastisol.
That's pretty much how the components break down: metal parts, paper, and plastisol. How they compare as far as cost per filter, I couldn't tell you.
tom
A customer may have us develop a sheet for a specific filter, and we would normally know which filter that is. The customer often will take that same grade of paper and use it in another filter without our knowledge. That's their business, and we have no need to know what they are doing with the paper, unless they are trying to blame the paper for a performance problem that is actually a misapplication of the paper.
tom
Thanks TSJAY for this interesting information.
The glass is of such a fine diameter and is so nice and round in cross-section that it makes a lot of small pores. I guess you get lots more paths for the oil to flow through, but the paths are smaller diameter so that the larger dirt particles can't pass through.
Imagine two pieces of ribbon that lie across each other as compared to two soda straws that cross each other. A structure composed of criss-crossed ribbons will be less permeable than one composed of criss-crossed soda straws. This is an exaggeration of the difference between the cellulose fibers (more like the ribbons) and the glass fibers (more like the soda straws).
Cellulose fibers are not as two-dimensional as the ribbons in my example, but they are not as nice and round as the glass fibers.
Realize that when we speak of "pores" in the paper, we are using an inaccurate term, but I gues we just don't know what other term to use. When I think of pores, I think of cylindrical openings that are continuos from one side of an object to the other. This is certainly not the case with paper. There is just a network of fibers oriented in every conceivable direction and they are not even in the same plane. The material being filtered has to change directions many times to find its way through the maze.
We think this "torturous" path has a lot to do with the deposition of dirt particles in the fiber network. As the oil hits a "dead end" and has to change directions, it leaves behind some of the suspended dirt particles.
I will try to find some pictures taken through a microscope of a sheet of filter paper to post.
As far as the poly, it tends to be round in cross section like the glass, but it is of much larger diameter. It is usually included in the sheet for the purpose of increased "toughness" for the paper, so that the flex fatigue and burst strength of the paper are enhanced. Remember, the filter paper spends its life in hot engine oil, and it could become brittle over time, making it susceptible to rupture or tear.
tom
If you get the idea that there's a lot about the mechanics of filtration that we just don't understand, you're right.
tom
So, post your questions while I'm gone, and I'll try to answer them when I get back.
Several of you seem very interested in this stuff, and all I can say is... get a life!
Seriously, I am surprised that you are so interested in this stuff. I am interested because I make my living at it, but I didn't think anyone else would find it interesting. I'm glad you do enjoy it, though, and I will share what I can with you.
You guys be good and I'll be talkin' to ya when I get back.
tom
Now, I see Bosh brand filter for about $5.50 (it says fiberglass/paper) and Mobile1(fiberglass with up to 10 micron at about 96%).
The question is use two Bosh filters (change at 3000 miles) or use one Mobile1 (6000 miles).
I am using Mobile1 syn oil. I think using two Bosh filters are way to go than one Mobile1, what do you think?
If the pleats are nice and straight and evenly spaced around the center tube, then you have a well made filter. Also, try to see if the paper is torn where it is anchored in the plastisol at the top and at the bottom. There shouldn't be any tears, obviously.
tom
I won't say your info is wrong on the efficiency of the Mobil 1, but I am sceptical about the 96% efficiency at 10µ. The filter may have 96% efficiency on the J806 test, which does not classify by particle size, but I doubt that they claim to be 96% efficient at 10µ.
The J806 test (I think they have renamed it now) circulates contaminated oil through the filter like the multipass test does, but the efficiency is determined gravimetrically and not by particle counting as in the multipass test.
In the J806 (or whatever it is called now), samples are taken upstream and downstream of the filter, and the oil is diluted in petroleum ether and strained through a millipore filter to catch all the dirt. The weight of the dirt contained per unit volume of oil is compared for the upstream and downstream samples. No attempt is made to segregate the particles by size.
tom
The person who did this seem to do a pretty good job making a comparison between the various brands but where I think he went off the reservation is in criticising OEM Honda, made-in-America Filtech filters. He admits they are well made but you you look at his whining about the "fuzzy" filter media and see if his opinion has any merit?
I've found these to be of excellent build quality and they are my #1 choice for my Honda vehicles.
http://www.ntpog.org/reviews/filters/filters.shtml
I'd appreciate Tsjay and all others' comments.
--- Bror Jace
The guy IS off base in complaining about "fuzzy" media. Fuzzy is good.
Filter paper has one side that is much softer and more irregular than the other, or, in other words, "fuzzier." When the sheet is formed, the bottom of the sheet is in contact with the forming fabric, and as the water drains through the sheet it pulls the sheet down against the forming fabric. We get drainage by gravity when the slurry first flows out onto the forming fabric, but we also apply vacuum, so there is more than just gravity pulling the sheet down against the forming fabric. The upper surface of the sheet is never in contact with anything as the sheet forms, so it is less compacted and has a rougher surface. (This is true for our type of paper machine, anyway. I think it would apply to any machine making filter paper, but other types of paper are sometimes made on machines that might form the sheet with some fabric on each side of the sheet.)
The tighter, more regular bottom side of the sheet is called the "wire side." In the old days, everyone used a woven bronze wire as their forming fabric, but now almost everyone uses a woven plastic fabric. The term "wire" is still used, even though in most cases the fabric is plastic and not actually wire.
The rougher, fuzzier side of the sheet is called the felt side. I don't know why it's called that, because both sides of the sheet make contact with felts in the steam can dryer sections. (Felts are used to hold the sheet snuggly against the suface of the dryer cans, so that there is effective heat transfer from the hot metal surface of the dryer cans to the water in the paper. The water then boils off as steam.)
It can cause as much as 30 to 40 percent loss in dirt holding capacity if the paper is oriented so that the flow of oil goes from wire side through the sheet and out the felt side. You want the dirty oil to see the felt side of the paper first and flow out the wire side. Most oil filters flow from outside to inside, so you want the filter paper to have the felt side out and the wire side in against the center tube.
It just makes sense that the nice soft, fuzzy side of the paper will catch and hold more dirt than the slick, tighter wire side. Think of paper towels vs writing paper. Which one absorbs a spilled liquid better? (That's a bit of an exaggeration, since there really isn't THAT much difference in the two sides of the sheet, but it illustrates the principle.)
Although it is very unusual now, some of our customers in the past have actually asked us to saturate only the wire side of the sheet and leave the felt side without resin or with only spotty resin coverage. This can add both efficiency and capacity to the filter.
The flow direction would tend to pull these loose fibers into the sheet and not pull them out of the sheet. They are actually not completely loose anyway, but are anchored mostly on one end.
So, the guy is worried about nothing.
tom
tom
The holes in the inside tube are smaller than the Kmart version ,not sure if that would cause more backpressure or not , and the anti-backflow valve is different. If the Walmart Supertech is the same, I'd say it is a pretty good $2 filter compared to the Kmart version of the AC-PF52!
OK back to the discussion.
(Be careful, though, cause sometimes that warm, fuzzy feeling only means that you have soiled your pants.)
tom
I remember the pl24011 is the alternate for the pf52, I thought it was the same size though? The pf47 is a replacement for the pf52 (the pf47 is longer?)? If it is , I have plenty of room for a longer filter as long as it is not much (if any) wider..I'll probably be checking it in the next couple days I'm sure,
thanks for the heads up
The AC Filter I saw disassembled at AutoZone was much like the one in the MoPar filter study, i.e. few but quite deep pleats. I assume they buy non-GM filters from a variety of sources and label them AC.
Without saying what's good and bad, does this conform to your understanding of the filter market, Tom?
I don't know about the specs for the Delphi vs. the Champion Labs as far as pleat height, pleat width, and pleat count (square inches of media, in other words). I would assume the performance specs for efficiency and capacity are the same.
Did you guys know that there are up to three sets of specs for a particular filter? There are original equipment- engine plant specs, original equipment, and replacement filter specs for some filters. I am not totally sure about the details, but I know that the original equipment- engine plant filters have the highest specs, and these, as you would guess, are the filters installed on the engines at the factory. The original equipment filters are the ones you get through car dealers, and the replacement filters can be bought at auto parts and discount stores.
The filters would all look the same on the outside, I believe. Maybe there is some code or something to distinguish them.
If someone out there can shed some light on this, please jump in here. Maybe I have something mixed up here.
I'm sure that even the replacement filters are very good filters, because a big name auto maker isn't going to let crummy filters carry their brand name.
tom
