That's my story and I'm sticking to it.
Very true as after my truck was taken by Toyota I saw there were things not listed I had done.
But I found out when buying used you can call up the manufacturer too and they will tell you what was repaired/done.
And Hyundai will tell you all. They want their cars sold and if there is something wrong with the used vehicle and it turns out to be a lemon, well..... I doubt they would not tell what was done on this Elantra. Especially now that some car sales are slacking.
It would benefit Hyundai Motors to tell all they have on record for this vin# on this used car he is looking at I would think.
And I don't know about anyone else, but I really think I will have all my maintenance done at Hyundai just in case they get a Tech Bulletin and they have to fix something. I usually don't do this, but I want to make sure with the PZEV engine I get all done that comes out about it. :shades:
In my personal opinion, a CarFax report is not worth the paper it is printed on.
At least the oil change was free.
When I changed the rears on my '05, I tried to get semi-metallic but found that no one made anything but organic for that application.
Side note: When changing the rear pads on these, the piston doesn't just push back in. You need a special tool (available at Harbor Freight for like $3) that attaches to a 3/8 ratchet and allows you to push while turning the piston. For want of a better term, they sort of screw back in.
Very simple brake job, takes less than an hour for both sides.
I was wondering what people's opinions of this model are and how much repairs usually cost.
I have read on reviews for this car on websites like CarSurvey.org or KBB.com. They seem to suggest that repairs are usually expensive and that the car has problems with the transmission and interior issues like the power windows not working.
What are people's opinion on these things?
http://www.carsurvey.org/reviews/hyundai/elantra/2000/
http://www.kbb.com/KBB/UsedCars/ConsumerRatings/2000_Hyundai_Elantra_Sedan_Priva- te%20Party_Good.aspx?Mileage=76400
For more extensive stats, you can look at Consumer Reports. I can't link to it, as it's for subscribers only, but I can summarize some of the findings for the Elantra 2000.
CR rates things Better--->Above Average----->Average----->Below Average---->Worse
For the Elantra 2000, it lists categories of:
1)Engine Minor - Worse Than Average
2)Engine Major - Better Than Average
So it means, you'll have some minor engine problems, but no major engine problems - not good, IMHO.
3)Transmission Major - Worse
4)Transmission Minor - Worse Than Average
This is bad - real bad. Transmissions are very, very expensive to fix. I'd stop considering the car just based on this, frankly.
5)Drive System - Worse
That's it, game over, IMHO.
6)Fuel System - Average
Also not good - you want better than average.
Other problem areas: paint/trim, body hardware.
Overall verdict - Average.
Personally, I'd stay away. You want most of the categories Better or Better Than Average. Here, most are Average or Worse Than Average.
You don't want an Average rating overall - you want Better Than Average.
Just based on the transmission, I'd run. Sure you can get lucky and get a car that will never have a problem, but you gotta look at the numbers. There's no way to tell if a transmission will have a problem ahead of time (you can examine fluid, but a dealer will change the fluid so even that can't tell you much). If you know that the trannies on this model are bad - that's too big a risk. You won't fix it for much under $1000 should you develop a problem, more likely $1200-1400. Too risky.
In summary, I'd look elsewhere. Of course, all IMHO.
Interestingly, it's pretty much the same story if you look at J.D. Powers long term reliability too:
http://www.edmunds.com/used/2004/hyundai/elantra/100342729/ratings_jdpower.html
On a scale of 1-5, with 5 being best, the Elantra 2004 stands out as the best bet for Long Term Dependability not falling below 2.5 on any score, with most in the 3-3.5 range. That's better than any other year Elantra, and the individual scores otherwise are VASTLY better than the 2005, which really falls down totally, with most scores at 2! Wow, that's one year to avoid! Meanwhile J.D. Powers doesnt' score Long Term Dependability for 2005 or more recent because not enough time elapsed to make a judgment.
Bottom line: if you go by statistics, the Elantra to buy is 2004, with 2005 to avoid and more recent too recent to tell. Now, that's statistics FROM TWO DIFFERENT scoring agencies (CR and JD Powers) - not anecdotal stories from random people - and that means very, very reliable.
Of course, again, the individual car is the most important factor - I'm sure there are very happy Elantra 2000, or 2005 owners, and very unhappy 2004 owners, but the statistics tell you what you can expect by the numbers.
Cars get redesigned for big years (2001 and 2006 for the Elantra), but they also get tweaked a bit every year - mostly to improvement, sometimes not (2005 - boo!), but the stats is what counts - this is what large numbers of owners report.
Personally, I'd avoid the year 2000 for an Elantra.
As for CR's, all it takes is a fraction of a point either way to move a car from Above Average to Average, or vice-versa, so the variations between 2004-6 are explainable at least. To me, a car having an Average reliability score from CR is not a reason by itself to avoid it. If so, I suppose buyers would need to avoid buying new cars like the Camry and Altima, because CR says their predicted reliability is only Average. We are talking about very small differences in number of defects per car here.
As to CR - I don't know, not being privy to their numbers, if it's true that their stats are worthless due to statistical noise. I'd merely note, that I find that hard to believe - though not impossible - because these guys understand statistics, and would presumably account for elementary things like *margin of error*. I mean, a first year student of statistics gets that, so how can the CR folks miss that? Not likely. And what makes me even more suspicious, is that the findings dovetail with JD Powers. That's very, very telling. If two completely different surveys, using different methodology come to the same conclusions, odds are - they are measuring something real, and not statistical noise (which would be random).
Regardless, you can always ignore all the data in favor of... I don't know what... speculation? Gut feel? Anecdotes? Uncle Charlie's musings?
As politicians say: "whom are you gonna believe, me, or your lying eyes?" Personally, I stick by the stats, even if partisans or fans of whatever try to convince me to forego solid evidence right in front of your eyes. But that's just me. Your milage may vary
Stats are useful, but can be misleading. We know, for example, that CR's reliability categories are based on numerical data. They don't publish their cutoffs for each category, but there must be cutooffs. So let's say for example the upper-end cutoff for Average is 55 and the lower end cutoff for Above Average is 56. Suppose also the 2004 Elantra scored a 56 and the 2005 a 55, and the 2006 scored 56. Numerically and statistically a very small difference. But it appears to be a big difference due to the categorization.
Also, in the 2008 CR Auto Issue, the 2003-5 Elantras were rated Above Average in predicted reliability. The 2002 was rated Average. The 2006 and 2007 Elantras were rated Much Better than Average. A consistent pattern, with improvement over time, but inconsistent with the data you posted, which I assume is more recent.
BambuListener: your advice about the car was pretty spot on. I took a test drive of the car and it seemed to have significant transmission problems. I took it on the highway and it wouldn't go above 40 mph! It seems that the transmission couldn't shift into high gear. Also, I noticed that the tranny fluid was somewhat brownish.
-So in general, do people find Consumer Reports and JD Power reviews among the most reliable compared to other car review sites?
-And what are people's opinions about the repair costs for Hyundais in general?
I have gotten a lot of conflicting information. Some of the reviews I read online have said that Hyundais are expensive to repair, while other people have stated they are relatively cheap.
re: costs of repairs of Hyundai. This is a very hard question to answer. For routine fixing of things like breaks, hoses, alternators and what have you - I don't think it's very expensive, since for the most part it doesn't require specifically trained Hyundai mechanics (the way some foreign cars do, like Volvos, or say VW), and the parts are not exorbitantly priced (unlike, f.ex. VW parts). On the other hand, every car has its pecularities where fixing *certain* things DOES require specialized training or familiarity by mechanics. Hyundai being a relatively smaller presence in the market (compared to, say, Toyotas, Hondas, Nissan etc.), you may have a hard time locating a Hyundai mechanic. In fact that's kind of disaster: look over threads here and pleas from people in as huge a car market as Los Angeles, for recommendations for Hyundai mechanics - only to be met with silence or derision... in other words, FAIL. That leaves you with Huyndai dealerships - which at least in the Los Angeles area have a *terrible* reputation. So if you should need to fix a more Hyundai specific or complex issue, you are going to be in trouble. Not good. You simply don't have the options a Toyota or even Volvo owners have. There are many, many, many, independent (i.e. not stealership) shops for Volvo/Saab, VW etc. - but not really Hyundai (at least in Los Angeles, which is a HUUUUUGE car market).
So bottom line, it depends on the kind of problem you have - if you have a simple problem that can be addressed by a generic car mechanic, it should be pretty cheap, considering the parts are not too expensive. But if you have a more complex Hyundai specific problem, you may be out of luck due to very, very, very miserable situation as far as the number of trained *Hyundai* mechanics... and off to a dealer you go - where you WILL be ripped off (at least in LA). So I think that accounts for why you get both opinions ("cheap" and "expensive") when it comes to cost of fixing. Again, that's speaking about used cars not under warranty.
Three years ago my wife had a run-in with a curb during a blizzard; the curb won. Somehow the car was still drivable even though one front alloy wheel was shredded, but it didn't steer right. Took it to the Hyundai dealer, since I knew I needed a new wheel. They could replace the wheel, but they said the car needed an alignment and some front-end work--which they couldn't do! So I took it to a local tire store to get four new tires (which cost less than 2 new OEM tires), and they referred me to a nearby repair shop that focuses on import cars--all import cars. They had no problem fixing the Elantra. I have a feeling (which I hope I never have to confirm) that they could do anything else needed on that car, even replacing a transmission or engine. I will probably check with them when it's time for the Elantra's 60k service, which is the most complex and costly servicing due to timing belt replacement etc.--see what they will charge vs. the dealer. I use the dealer for warranty work and oil changes, since they give me free oil changes, and to buy parts like light bulbs.
Gee, I don't know - I guess there's no reason then to have shops and mechanics who are dedicated to just Volvo/Saab or VW or whatever brand, huh? Wonder why they exist then
And getting back to the earlier issue of models 2004 vs 2005 etc. Yes, indeed, it happens pretty much 100% of the time that the manufacturer changes *some* suppliers from year to year even on exactly the same model (if for no other reason than that some suppliers may go out of business etc, etc. etc.). Only very small specialty brands (like f.ex. Ferrari) may pretty much recreate exactly the same cars from one year to the next. For large scale brands, that is almost NEVER the case. Not to mention that even staying with the same supplier doesn't guarantee the exact same result, since the supplier in turn may change processes the effect of which don't turn up until they're put into play for several months. There are always variations year to year whether in materials, suppliers, quality control or a million other issues. Same design - different manufacture variables from year to year (often on economic grounds), which can give you a different result on long term reliability stats. Elementary reality of manufacturing complex products
I understand the elementary reality of manufacturing complex products. But you don't know for a fact which if any key components--the ones that affect reliability--were changed on the Elantra from 2004-5 and 2005-6, do you?
Anyway, if you look closely at the JD Power reliability scores that you posted the link to earlier, you will see how suspect they are. For example, notice that the Mechanical ratings, the ones that directly relate to reliability, are very close between 2004 and 2005. In fact, there is only one difference: 2004 has 4.0 on interior, and 2005 has 4.5. That difference could easily be explained by the problematic audio system used in the 2004 Elantra GT, and only in that year. That issue is reflected in CR's ratings also. But then notice the "Design" scores. The design of the 2004 and 2005 Elantra was the same. But the JD Power scores are different, on Interior design (and therefore overall as well). How can that be, when the design was the same for both model years? Then look at the Overall Performance and Design ratings. They are markedly different between 2004 and 2005, in all categories: Performance, Comfort, Features and Instrument Panel, and Style. We're not talking about component quality here, but performance, design, and style. And the 2004 and 2005 model years were the SAME in those regards. Same powertrains, same interiors, same exteriors. Yet the 2004 scored much higher there than the 2005. How can that be, if these ratings are objective? Well, it's because they aren't objective. In fact, the major difference in the JD Power IQS scores between the 2004 and 2005 Elantra are due to subjective measures, not on reliability considerations. Notice also how the design-related scores shot up for 2006--but it was the same car design as for 2005! And the subjective measures like performance and style changed for 2006 too. That's not surprising, since they are subjective.
Finally, keep in mind that the JD Power ratings for 2004-6 that you posted the link to are for initial quality, not long-term quality. That is, for the first 90 days of ownership. The only model from 2004-6 old enough to have JD Power Long-Term Reliability scores is the 2004.
As to whether I know "for a fact" which if any key components were changed on the Elantra - of course I don't. However, neither do you - see how that works? Only here's the difference: the burden of proof is on you, not me. The reason is because *you* made a claim that 2004 and 2005 being the same design, must mean that JD Power stats are invalid. I merely reported the stats. You made a claim. I pointed out that the fact of the same design in 2004 and 2005 does NOT by that fact alone guarantee that the reliability would be identical, and I cited some examples of how that is possible (different suppliers, different QC practices etc.). I pointed out ways of how your argument doesn't hold water. But that does not alter the fact, that it is YOU who has to show how the same design MUST result in the same stats. I showed how that's not necessarily right - gaping holes in your argument. Stats are there from JD Powers. You have to show why they are wrong - and the argument you made ("same design") doesn't hold water. The burden of proof is on you. Until then, the stats stand presumed valid, absent proof to the contrary.
I am not an expert in Elantras. Maybe there were tiny differences between the interior design of the 2004 and 2005 which affected "comfort" etc. For example, the 2000 has massive power window problems, which would not be externally visible, and a change would fix it - also not visible. So it might look like the same design but there may be tiny changes which impact operation, even if not visually.
But even if there weren't, even if they were identical, there's still the stats from CR regarding problem areas (and indeed in my previous posts I pointed out that JD Powers hasn't yet done a long term reliability for 2005 and up). They are all mechanical, and all devastating for 2005 compared to 2004. The burden of proof of why they are wrong - CR with their teams of experienced testers vs "backy". The burden of proof is on "backy". I like and trust "backy", but I trust CR more, absent direct proof to the contrary. That's the rational attitude, no? Otherwise we're at the mercy of anyone's anecdote. That's the whole point of the existence of testing from independent consumer organizations like CR. No?
FWIW, I know the Gen 3 Elantra (2001-6) extremely well, at least wrt design, having owned two of them and driven samples from every model year.
And I am not an Elantra specialist. I own a 2004 which I purchased used. And I've driven 2007 and 2008 Elantras, but by no means do I consider myself qualified to speak authoritatively on these cars (though I do have my opinions). What I try to do is be an informed consumer, that's all. And when looking for data, I try to look for data that is reliable. JD Power and CR may not be the Platonic ideal - nothing is. But it is a lot better than one random person's opinion. Just the facts, ma'am.
You seem to be putting great emphasis on the individual anecdotal feedback of one person who drove an Elantra with a bad tranny. :confuse:
I agree surveys like CR's are valuable. But I think they need to be seen for what they are, e.g. JD Power's IQS is a reflection on short-term reliability plus other factors, including what owners think of the car's design, its performance, its style, its features---attributes that have nothing to do with reliability. In other words, it's largely an opinion poll.
Actually, it's not. Have you taken the CR reliability survey before? I have. It requires each respondee to make a value judgement, i.e. it asks them to note problems that in their opinion were signficant. What is signficant to you or me may not be significant to someone else. Because of the large sample size of CR's survey, I think the results are still useful, but it's in no way a "simple statistical survey."
It seems you are putting a lot of faith into two surveys in which you have no idea what methodology is used to obtain the results.
It's also interesting to me that you have no problem backing your opinion with one person's anecdotal experience, but dismiss other anecdotal experience that is contrary to your opinion.
The CR survey results I looked at, from the 2008 Auto Issue, do not show any sort of "catastrophic deterioration" in the Elantra's reliability from 2004 to 2005, and in fact as I noted previously, the predicted reliability for both years was the same: Above Average.
But you know what, there's an entire discussion in Town Hall on the JD Power and CR surveys, so if you want to continue this thread, I suggest we take it there.
As to the overall verdict of 2004 vs 2005 - I don't know about the 2008 Auto issue. I'm going by what's on their website right now - and anyone who has access to CR online is welcome to verify it. And there it is: on the overall verdict, which they call "Used Car Verdicts", it shows 2004 as "better than average" (red half circle), and for 2005 it shows "average" (plain black circle). Here a link, but you may have to be a subscriber:
http://www.consumerreports.org/cro/cars/models/used/hyundai/elantra/reliability.- htm
Thus there is deterioration from 2004 to 2005 (then picks up again for 2006) - according to CR. I'm just reporting on what I'm seeing.
As to the one person's experience with the tranny - the only reason I cited it, is not to say "that proves that 2000 trannys are bad", rather "that's why it can be useful to see what is being said by surveys", because in *this case* it mirrors the findings. And that's a fact - the mirroring; now what that implies is up to your choice as a consumer. I'm merely reporting on the FACT that this particular experience *mirrored* the survey finding, which is an objective fact (after all, it did).
http://townhall-talk.edmunds.com/direct/view/.f106481/566
Hope this helps!
Any thoughts on the timing belt, Backy?
Of course, if the timing belt breaks after 5 years and before I change it at 60k miles, Hyundai could deny a warranty claim. So there is some risk there. You have to decide if you are willing to accept that risk.
I was wondering if any one else is having this kind of trouble with this model or maybe this is just a rarer occurrence for this model.
We have a 2007 Elantra Limited which is great - there are only three small problems. One of them is making me question my memory.
If I recall, when the car was new, the dome light would come on after withdrawing the key from the ignition. Now it does not. The light still works and is set to the same position (door). I cannot find any mention of the courtesy light in the owner's manual, so now I am thinking "was that feature always there, or did I imagine it for the past two years?"
I just want to know if this feature exists before I ask the dealer to fix it.
Thanks so much!
http://www.mombu.com/asian_cars/asiancars/t-hyundai-elantra-batteries-hard-to-fi- nd-outside-of-dealers-where-they-are-expensive-and-special-1297801.html
So that's a bust. Looks like I'm out of luck - the mysterious super complicated Hyundai battery
FYI, they are the only one that lists one for that vintage Elantra. I checked Advance, Napa, and Interstate, so it is a difficult to find battery.
