2002 Chevrolet Silverado 1/2 & 3/4 Ton Pickups
I am about to order a 2002 Silverado LT 1500 and would like to know if anyone knows if there are going to be any differences from the 2001 models. The local dealer does not have any brochures or information yet(at least not any they are sharing). Any info appreciated.
Crew cab, 4 full size doors, 6.5 foot bed. Bigger than Supercrew though. Advantage of Supercrew with short bed, it fits in the garage. 1500HD has 10,000# tow capacity too. Basically, it's the 2500 (8600 GVWR) stretched.
Dear Mr. Vogel,
Thank you for communicating with the GM Internet Response Center and for your interest in GMC.
The following are new features, changes and deletions for the model year 2002 for the GMC Sierra
2500 HD pickup.
New Features for 2002
New trim level content (1SA-Standard, 1SB-SL, 1SC-SLE, and 1SD-SLT)
Bigger, bolder Sierra tailgate badge
Automatic door locks, lock when out of park, unlock in park (with automatic transmission only)
Sunshade extender, LH sunshade has pocket instead of storage clip
7-way to 4-way trailer adapter incl. with Z82 Trailering Pkg.
T96 Fog lamps now incl. with SLT
PY0 Aluminum Wheels available on SL
UN0 sound system now incl. with SLM
AJ1 deep tinted glass now incl. with SLE and SLT
DF5 inside rearview electrochromic mirror now incl. with SLE
C60 Air conditioning now incl. with SL
PCM Cold weather group: incl. DL8 heated power exterior mirror and C49 rear window defogger
PDC Interior lock group: incl. AU3 power door locks and remote keyless entry SL
Changes for 2002
Carpet delete RPO changes from BG9 to PDP
K47 air cleaner no longer standard, but is now optional
1SA contains no 'SL' B-pillar badge
Deletions for 2002
UM6 AM/FM cassette
VF7 Rear Spare Bumper delete
71 Sunset Orange Metallic
Thank you again for contacting the GMC Internet Response Center and for your interest in GMC
products. If you wish to speak to a representative in our GMC New Product Information Center,
please call 1-888-988-7267 between the hours of 7 am and 10 pm Central time.
Sincerely,
William Moore
Customer Relationship Manager
Compare the sticker and invoice pricing for the GMC Allison transmission versus the Chevy version. The GMC pricing is $1032 / $1200 (invoice / sticker) while the Chevy is $1974 / $2295. Quite a difference for the same chunk of metal, I think.
Furthermore...
On Chevy 2001 HD models, I actually saw both pricing schemes on similarly equipped Chevrolet 2500HD crew cabs. Unfortunately they weren't on the same lot at the same time or I would have had fun with the salesman!
The bottom line is:
1)If you buy a Chevy with the higher sticker price, did you really buy two transmissions?
or
2)It makes the bottom line of a GMC 2500HD diesel/8.1 gas comparable, if not slightly cheaper than a similarly equipped Chevy.
Go figure. I like the styling of the Chevy better but can I find a Chevy not only with the right equipment but with the right sticker? With this difference and the generally higher resale of the GMC, the "professional grade" truck may make more cents...
in the base price. Chevy is not.
That explains the price difference when
you go to the Allie auto....
If you're truck is scheduled for build next tues. when did they say you should expect to take delivery of it?
there was having problems with the front end
too low with his new HD. He has a 9 ft diamond
on it. Directed him to www.timbren.com
they have some helper device that he got and
it took care of his sagging problem. He posted
it works well and easy to install.........
I have a new 01 ld 2500 with a 7 1/2 western
ultra mount and no sagging problems. The 7 1/2
is fine for my usage. My last western outlasted
3 new 1/2 ton GM trucks (10 yrs) LOL...........
Check out www.plowsite .com Lots of plowheads
over there to help out.................Geo
I looked at the 2001 Yukon's, they have the full blown extendable mirrors that even light up. Oh also...though I paid for the Deep Tint package, the rear window was not tinted and was explained to me without reason except if you order Defroster package, you dont get rear window tint
Dale
-- Don
When my local dealer wouldn't p/u the truck, I call GM customer svc and had them use the vin# to locate the dealer that had the truck and worked with them.
I should have my truck back Friday with a new Boss 7.5 SD plow.
Good Luck
I like the regular 1500 extended cab with 5.3 engine but think it would be better if it came in the full crew cab with slightly more room and full size rear doors.
If so, please let me know how well this option works?
thanks,
rcoos
and want to tow a 24 ft Jayco tandem axle travel trailer that has a GVW rating of 6000 lbs and empty weight of 4000 lbs , 500 lb hitch weight and of course a equalizer hitch and torsion bars. does anyone have experience with the 5.3 liter 8 cyl engine in a similar consit. I want something that will pull the mountains in Pa and W.Va.
mike b
My question is, should I get the 3.42 ratio or the 3.73 ratio? The SLE comes with the 4.8L V8 & automatic transmission. The 4.8L V8 is fine for me.
Thanks Ralph Coos
Currently with my 4.8L 3.73 (std on 4wd) 4wd Reg Cab Longbed I'm getting 17-18 in town and 22-24 on the highway. That's about 3mpg better than when it was new. 27,000 miles.
Mike L
Definitely worth the money (I think it was about $250 when I ordered my truck.)
Hans
This is the first Full Size truck I owned since High School, since the kiddies are grown and gone I thought I would splurge, it sure beats driving a Nissan.
Ray T.
I want to purchase a 2002 silverado 2wd ext cab but need good fuel economy because I commute. Can any owners help me pick the right engine.
jefcal
I have a 4x4 1500 Reg Cab Longbed 4.8 5spd 3.73 and I get 17-18 around town and 22-24 on the highway. I'm not the first one away from a stoplight, nor do I drive less than 5 mph over the speed limit.
Mike L
Any Ideas how my truck will do?
I am going to purchase a leveling hitch. I also purchase an active suspension for the rear.
Has anyone pulled a trailer that big with the same truck?
Tom
MR
I didn't want a 3/4 ton because the ride is better unloaded for a 1/2 ton, but I think I either need to get a smaller trailer or a 3/4 ton truck. Thanks.
Ray T.
I have looked at a few 30 foot trailers that only weigh 4,500 pounds -6,000 seems way heavy.
If the total weight of the trailer and gear is 6,000 pounds and you are planning on towing 4 times per year - I would keep the 1/2 ton. So what if it takes you 45 minutes longer to get to the camp site.
