Anybody buy an CR-V LX recently and what did you pay (including $490 destination fee?)
Read someplace that Honda never discounts but don't know if that's true. I can't find any info about Honda giving dealers money back on 2004 leftovers.
With the invoice at $18,700 + destination charge, should I expect to be less?
I don't need ABS function much, so can I turn the light off even though the ASB is not functioning? If yes, will my CR-V pass the inspection in NJ?
Thanks for your help.
Elissa
Outrageous.
That's why you need to have used cars properly inspected before you buy.
For better or worse, the vehicle is equipped with ABS, and it is an integral part of your safety system. It is always nice to be sure the car is going to stop when you hit those brakes... and not stop when you don't.
How would you feel if one of your four wheels suddenly started cycling the brakes while you were cruising at highway speeds, while the other three wheels weren't braking?
Crawfish may not care if his CRV has ABS or not. for a whole lot of people especially those who live in mild climates, ABS isn't a big deal at all. A lot of happy people running around in LX CRV's that don't have ABS and the owners couldn't care less.
Still, it can't be assumed it's a sensor simply because that was the problem three years ago. It could be a loose wire or something much more expensive than a 200.00 sensor.
If it were my car I would definatly get it fixed and not try to ignore the problem by unhooking the warning light!
And, by all means, if you do do this, MAKE SURE you inform the new owner! Of course, at that point, they probably would pass on the car and for good reason!
HOWEVER, this needs to be fixed. You can drive without ABS, as cavemen have done for thousands of years, but disconnecting the light is just wrong.
regards,
kyfdx
Are the ABS sensors used in the EBD system?
I am fed up with Honda's ABS quality. I know the fix could cost way upto $1200 for this ABS system if it is not just the sensor.
I just did a tune up and my 97' V with only 37k miles runs like cream. I fully intend to keep my car for a considerable long time. However, driving only 2 miles a day still rewarded me with this annoying ABS problem --- it just drives me nuts.
ABS is not a vital part of the car. I want to live without it like many people out there. However my V's inspection is due in August. That's the only concern I have. I think I am entitled to drive legally without ABS -- am I right?
I would be really happy if someone with DMV connection can tell me that my V will pass the inspection with this ABS light on...;-(
Just want to share my unfortunate experience with others here. My post here about the fire was back on Jan 07, 2004. If you are interested.
good luck.
#1422 of 1452 Ha, ha, ha, ha, ha, ha by edgeta Jul 21, 2004 (3:56 pm)
I get it ..."fan the flames"...
I pick up my new CRV today. Told the manager if it catches on fire, he has to rewax it.
If you turn the light off and plan to keep the car for a "considerable long time" it will be very easy to "forget" that you disconnected the ABS light in several years from now when the car is going to a new owner.
You should have the car checked to see what the problem is instead of guessing that it would cost $1200 to fix.
If the diagnosis shows that the brakes will work perfectly other than not having ABS ability, then they should be able to give you that in writing in case the inspectors want to know why the light is on.
Somehow you guys get an impression that I am going to cheat the next owner... that's a funny story. My intention is not to turn off the light, but to use the car without the ABS. Think what if my CRV doesn't have ABS...
I of course will get the car checked.
Please no more discussion on this issue. To be frank, I feel offended. Once again, I would not post this here if I have some immoral thoughts in my mind -- if that would be true, I would have got under the car and cut the light's wire without letting anybody (including people here) know.
I appreciate your guys' advices. But as Bible says "don't judge people because you will be judged"
But, I see no reason why in the world a non functioning ABS system would cause a car to fail inspection.
A whole lot of cars have no ABS and they pass. same difference isn't it?
That said, none of us are ASE certified mechanics. A couple of phone calls to reputable service departments should give you a positive answer. I'm not sure if I would pay $1200 either, if I was only driving 2 miles per day.
regards,
kyfdx
P.S.: Don't ever feel offense at anything you read on this forum.... That is what the scroll button is for. If it is particularly egregious, the hosts will take care of it.
This hides the fact that there is some problem with the ABS.
The whole scenario certainly sounds like they are trying to hide the problem from the upcoming state inspection.
It easy to see this by just reading the previous posts. Who knows if malfunctioning ABS is worse than no ABS at all.
Anyway, there is nothing to debate either way. They are going to do what they are going to do. So, future used car buyers, beware.
FYI the first oil change is not to be done before 7000 miles per your owners manual.
It's hard to be all things to all people.
I wouldn't be surprised to see ABS become standard on everything at some point down the road.
Everyone is assuming that the ABS is simply shut off when the light is active, but remember it is an assumption. If it is a faulty sensor, it could malfunction. Not likely, but possible. Obviously, it's up to the owner to take their chances, or not.
I was harboring no ill thoughts about disabling the light (re:future owners). I'm just concerned about braking systems showing fault lights and not repairing them... especially since i'm not sure if the ABS sensors are used in the EBD.
In your case the fire (IMO) is a Honda issue that should be covered under warranty. This is Sabrina's point as well. They should have fixed your V, given you a comparable V or a new one. So I ask again, if I may be so bold...did you suffer a loss.
I don;t speak for splitor, but as for me, I expected a new or comparable vehicle at ZERO cost. The warranty is repair or replace, not take whatever I get from insurance company and shut up. Remmber, Honda gave me ZERO. I got NOTHING more than what my insurance company reimbursed me (not even personal property lost). Therefore, no warranty was used. That is my point. I might as well not had any warranty.
I understand you have had a traumatic experience, and it may still turn out to be Honda's fault. But, your financial loss is nearly zero. You got the use of a brand new CR-V for six months for around $2K. If it turns out that it is their fault, you may have other claims (emotional distress?), but in actual property loss, it is minimal.
Please understand, I'm not trying to say who was at fault, or to minimize your experience. Just looking at it from a financial perspective.
regards,
kyfdx
http://www.detnews.com/2004/autosinsider/0407/27/d02-223482.htm
Seriously, it's true that a warranty claim should include repairs or replacement at zero cost to the buyer. But there's nothing in the warranty to suggest that technician error is covered. So the warranty doesn't apply to those fire cases where stacked or pinched gaskets are found.
But the Q is this...
It has been almost 3 weeks since the Post broke the story, almost 4 weeks since NHTSA closed their investigation, almost 18 motnhs since the first reported oil leak (february 03), 17 months since the fist fire (March 03), and 10 months since my fire. Forget about fault for a minute.
HAS ANYONE ON THIS FORUM SEEN ANYTHING FROM HONDA WARNING THEIR TECHS ON THIS ISSUE
A failure to warn is an actionable cause and I would not eb surprised to see the class action people use it. Honda's delays only hurts more.
So, a lack of notification is not "actionable" as I would interpret the word.
I do agree that that it would be reckless had they not taken that action, or if they promised to contact everyone and then failed to carry out the plan. But that does not appear to be the case
I'll let the lawyers decide whether the failure to warn occured. I doubt it matters whether a warning was forced or not. I think more of a concern would be WHEN the warning occured. Voluntary warning could certainly be a defense, but not sure if it would excuse. That a q for the judge.
I am not convinced they have carried out any plan. I have not seen anyone say they saw anything on Honda stationery.
Who have you asked?
The warning would most likely be registered as a TSB. See if your lawyers can dig those up.
-elissa
The fact that they didn't issue a TSB is a little strange though.
Also, they were supposed to be contacting Jiffy Lubes, Grease Monkeys, and other retailers. I doubt they receive dealer newsletters.
Yes, especially if Honda were concerned about PR, litigation, public perception, or (low and behold) about NON-Honda shops doing the job correctly and limiting vehicle destruction. A TSB is more public and accessible.
Suppose they do recall it for a fix? How is that a bigger problem?
Also, Hope my oil doesn't get changed by the guy who was out sick that day.
Did the Honda rep mention the "modified" o/c only applied to 03/04 vehicles and ONLY to CRVs, not civics, accords, elements. It may apply to 05's but we don't know that yet, but definitely not to 02 and not 97-01 and that it only applied for the first oil change, unless of course they get back to them if there are fires on 2nd and 3rd o/cs, in which case it would apply, but definitely not to 02's, which may look identical, but clearly is not since there are no fires on that.
Did he remember all that? Would have preferred some paper, thanks
Sabrina, they don't have to modify the oil change routine, they simply need to do it as they learned in Auto Shop 101. Or, even just read the instructions on the side of the filter.
