I have a '99 EX 5 speed that I regularly get 25 mpg around town and 28+ mpg highway, better than the EPA estimates. Others with the same year and model, but with an automatic transmission, have reported as low as 17 mpg.
I drive very conservatively, including rarely exceeding the posted speed limit. In the vehicle I owned prior to the CR-V (another small 4 cylinder powered SUV) I drove from Indianapolis, IN to Houston, TX using major highways and toll roads where the posted speeds were 65 or 70. Crossing Texas from Houston into New Mexico I drove secondary highways, where the posted limit was 55. My gas mileage crossing Texas was over 20% higher than the leg from Indy to Houston, only because I was driving slower.
Driving conditions, temperature, and your personal driving habits dramatically affect the gas mileage you will get. Accelerate slowly, anticipate having to stop, and keep your top speed down. I was once told that you should imagine an egg between your foot and accelerator and try not to break the egg. I'm not quite that conservative, but I also don't mash the accelerator to the floor.
YMMV
1. Turn the ignition, step on brakes, release hand brake, shift shifter from park(P) to drive(D). As soon as I get to D, the RPM counter goes up, (from about 700rpm to about 1500rpm) and the car hesitates to move at this point. I have to wait for the RPM needle to drop back to the idle range(700rpm) before I step on the gas. This fluctuation in the RPM needle only takes about 2 seconds, but its driving me nuts, and it didn't do that before when I first got the car. My experience with other cars is when you shift from P to D, its smooth and the RPM needle barely moves, maybe from 700 to 900 if that much. I have my CRV less than a month now and about 1600 miles on it.
2. Sometimes when I step on the gas from a stop(like at a traffic light or stop sign),it would 'skip' then go. The 'skip' is hard to explain, its like a sudden 'jerk' forward, then the transmission would engage and the car would move normally.
3. Going about 40mph and taking my foot off the gas pedal, the car begins to slow down(which is normal), but I feel a bit of friction(like if i'm applying the brakes) although i'm not. Its like the car goes into a sluggish state.
Has anyone out there experienced similar problems on their new CRVs? and what was the fix? Other than these problems, I absolutely love my CRV, and I have accessorise it with the front splash guards, side steps, roof rack, wheel locks, and i'm thinking about the fog lights.
Thanks much,
Moe
Moe
I am considering purchasing a used '97 CRV. I've done a lot of research and I am pretty sure this is what I want. I wasn't as crazy about the Forester or Rav. Anyway, I currently have a '98 2-door Civic Hatchback that I love, but am having a baby and need something bigger. Plus I own a dog.
Anyway, this CRV has high miles (140k!) but I am on a budget. It is extremely clean. The only issue is that while turning the rear near the tires make a clunking noise, like "clunk, clunk, clunk...". The dealer just got the vehicle in and they haven't investigated yet, but they say they WILL fix it. We hear the noise turning left and right. The CRV is only $7,900. I won't be putting many miles on it so I am not too worried about the high mileage. Hondas are generally great cars and go for a long time.
So, I'm wondering if any of you know what this noise could be? They said something about perhaps the wrong fluid being used? I don't know what that means. Any help is greatly appreciated!
Chris
I bought a 2002 CRV EX last December and its my first time to smell a burning-like smell under the hood. It was very strong the first time but time passed and its less now. Unfortunately, the smell is still there. The dealer told me that this is just the smell of the burning metal because its new. I though it was a leak on the exhaust. The dealer checked it and the exhaust is fine. I was told to give it a few thousand miles for it go away. Its been three months now since I bought the CRV and the mileage is 3000+ (went to Vegas) but the smell is still there. It wasn't as bad as before though. Has anyone had this experience? Is this normal?
/ron
the burning smell is most likely what the dealer told you, the painted metall parts geting hot and producing the smell. it is kind of the new car smell, most alot of people buy the "new car smell" air fresheners just to get that sensation :-)
I just signed on to this CR-V board. It's really cool to be able to learn and share with folks who have a vehicle like yours. Mine is a 2002 CR-V EX.
How do you respond to a message?
mike phuvie
Hope this helps.
Moe
The reason I ask is this. I seem to get a loud amount of road noise on all surfaces. Little less on tightly compacted asphalt. I know that road noise was a big concern on previous CR-Vs and that my '02 was suppose to have a lot less. Have any of you out there replaced the stock Bridgestones with a higher quality passenger type tire and have these tire lessened the road noise? The tread design on the stock tires seem a little blocky, like truck type. Or, is road noise a condition that one must live with.
Any comments?
I have Goodyear Auquatred 3's on mine. I had the BFGs prior to the change. There's only a slight improvement in road noise, but I got them because for their decent marks for wet weather and all season ability. It's a must where I live.
http://www.hparts.com/pdf/21706.pdf
You can decide for yourself if it's too much work to remove/replace the bumper. Looks like lots of bolts/screws to remove but otherwise straight forward.
The bumper fascia looks to be less than $160 but it wouldn't be painted to match your SE. You'd have to have a body shop do the painting, or just go with all black.
Good luck, take pictures, and let us know how it goes!
Dealers still report 'no problems' but then most vehicles they see in my part of the world do not have that much mileage.
At least you know the symptoms and solution so that will save you time and money should the problem occur.
Now as to your query about the oil filters: Is the filter on your CR-V the original one from the factory? If so, then the answer lies in the difference between nations. Honda itself doesn't make oil filters, but licenses its name for use on "Genuine Honda" supplies like these. In Japan (where your car was almost certainly made), Honda uses filters from a manufacturer somewhere in Asia. In North America, Honda places its imprimatur on filters from two companies, one in the USA and the other in Canada. All the filters should be interchangeable and should meet Honda standards, but each manufacturer's filter will have a separate part number for identification purposes. I think the part number you have the Canadian one.
Other examples: Factory tires for the CR-V are either BF Goodrich Touring T/A or Bridgestone Dueler H/T. Spark plugs are either NGK or NipponDenso. "Multisourcing" can be a good business strategy for Honda because it won't become too dependent on one supplier for parts.
If you want others in one discussion to see your question/comment in another discussion within the Town Hall, right click on the post number and choose "copy link address". Paste the link into the other discussion. It will appear like the one above. When they click on it, it will take them to that discussion.
If you have any other questions, let me know!
KarenS
Owners Clubs
Karen Thanks I will use the "copy link" when needed.
I think you'll have to see what the dealer mechanic has to say.
www.visualimpressions.ca/switch
After hitting my head up against a brick wall trying to get someone to listen and acknowledge this deadly fault, it appears the word has been spread far and wide and action is finally being taken.
I've got a '98 CRV "all wheel" drive. When I make a fairly sharp turn, for instance doing a U-turn or driving into a parking spot, there's a low-pitched squeal. It doesn't do it consistently every turn, but it is quite frequent. I *think* it's coming from the rear. It's definitely not the sound if you hear if you turn the steering wheel as far as it can go one direction.
Any ideas what it could be?
