*I believe it was only several weeks into the '61 model year when DeSoto dealers got, "Hi, don't order any more cars because this'll be a short model run, wasn't it?" letters.
By the way, I had never had occasion to top up the OEM fluid, so it was not an issue of contaminting it with my hard water or a different brand antifreeze. For anyone intending to service his cooling system, the drain plug is a red plastic affair on the driver's-side of the bottom radiator shell. It's hidden by a full-width black plastic air dam held on by five 10mm hex screws. Be careful not to lose the black nitrile rubber sealing washer that may or may not come off with the plug. (and may or may not remain with the plug if it does come off with the plug...)
at highway speeds.
The car came with michelin energy mxv4 tires.
The vibration is very rythymic and is only
noticeable abve 55 mph.
Other than this vibration at around 3500 miles the car has been flawless.
I have checked tire pressures and all are correct
at 30 psi cold per the owners manual.
I have had bad experiences with michelins in the
past and would never buy them by choice.
My question is should I take the car to my dealer
and have them look at it or take it to my local
frame and alighnment shop that Ive used for years with
an excellent reputation.
The dealers almost alway's give you a hastle and
rarely fix the problem.
Are the tires covered under warranty by hyundai
or are they covered by michelin?
If the tire or tires are bad what can I expect from the hyundai dealership?
thanks, Rick.
After taking the car to a michelin tire dealer,
the front tire had severe sidewall damage as well
as both passenger side alloy rims were bent bad
enough to also need to be replaced.
The rims are $253 dollars each through my local
hyundai dealer, OUCH!
I asked my wife to please be more carefull in the
future.
BTW, michelin gave me a 65% credit towards a new
tire even though I had no road hazard coverage as
a good will gesture as they called it in a reply
to an email I sent them.
Real decent if you asked me.
Only issue I have now is with warped front brake rotors. A perennial issue. I've had them machined twice. I'm going to replace them next year when I put on new brake pads. They just don't make brake rotors like they should, and this includes most marques.
It’s time for me tell my story.
I got my Sonata GL V6 (in Canada it’s V6 with no leather and moonroof) in December 2001. I’ve been driving this car for 3 years, 50k, aggressive driving style. Here are the problems I had:
1. Fuel sensor
2. O2 sensor
That would be all. So my point is that the car was great and practically flawless.
Still the original breaks. I had to change the tires at 36k though. First tried TOYO but always got vibration after 100Km/H. Replaced two sets of 4 and didn’t help. Then I got Michelin Harmony 215/60/16. These are great. Nice and quiet ride. I would recommend them to go with.
Let me give some of you a few advices how NOT to get into the troubles that you posted on this board:
1. Do not roll down the windows when it’s cold and especially if there is ice or snow on the window. Warm up the car significantly.
2. Do not play CD when it’s cold. Warm up the car. Can use the radio though.
3. Do regular maintenance as scheduled. Don’t try to save a few bucks. Otherwise it’ll turn into hundreds.
4. Change transmission oil every 36k if you do mostly city driving. Use only Hyundai oil, as Ray advised.
5. Use A/C wisely. If you go uphill for extended period of time, turn it off for a while. Your engine will thank you for this.
6. Do not idle longer then 5 minutes.
7. Use the wipers wisely. Don’t run them like a crazy. In the winter time make sure that they can move freely. Don’t be lazy; clean the windshield with the scraper.
8. Wash the car more often.
9. Wax it.
10. After washing I recommend to wipe out all rubbers around the doors, the door frames and the trunk rubber. It’s a good idea to spray all weather strips with silicon.
11. In the winter time give the engine extra 30-60 seconds to warm up.
12. In the winter time after long parking drive moderately for at least couple of Kms. This is good for transmission and suspension.
If you care about your car, if you want to keep it for long time, if you don’t want to spend hours in a shop do those simple things (it’s not that awfully hard to do so) and your car will respond you the same way. I treat all my cars like a horse, and they served me with loyalty.
Good luck to all of you.
*The last time I was at my dealer's for a minor warranty/recall item in the fuel system, I counted 12 exchange transmission shipping containers awaiting return to Hyundai's rebuild center in the U.S. I asked the service writer if that was unusual. He replied that it wasn't for Hyundai automatic transaxles.(!) The reader can make of that as he/she wishes, but I treat his unguarded candor as a wakeup call.
I wouldn't be too hard on Hyundai. For past decade or so BMWs have become notorious for catastrophic AT failure in the 80-120,000 mile range. Lots of marques have AT issues. TCMs, etc.
Seems like ATs and brake rotors have become problematic over the past 15-20 years for nearly all marques.
I called service department of the dealer and was told this type of situation is rarely covered under warranty.
I have 13,000 miles on the car. Why wouldn't this be covered?
GLS. I replaced front disc pads with Ceramic pads (less dust generated/build up on wheels) at approx. 59000 miles; shortly after that the rotors warped. Replaced the rotors with ones purchased at AutoZone. Approx. 2000/3000 miles later these rotors warped. Rotors were covered by warranty. Replaced again and not having any problems as of yet. Only have 1000 miles on these rotors. As Ray mentioned, it's probably not the rotors, but maybe a problem with calipers hanging up; ,(heat build up by some means) although mine are fine so far. By the way, rotors were only $40.00. Ceramic pads are living up to their expectations. Tom
I agree with you that auto manufacturers, as any manufacturer, are not in it make products, though. They're all definitely in it to make money. Products are simply a means to that end.
Sometime during the 2003 model run, Hyundai began installing a smaller diameter pulley on the alternator to increase the alternator's output at idle by increasing its rotational speed. Too late for me, but yours most assuredly has that running improvement. Even at that, I'm over two years on the original battery and it's lived through two very hot SoCal summers - and I'm addicted to AC!
*Not necessarily anything to worry about. Certain Honda and GM engines with short piston skirts are known for piston slap - and they still run for several hundred thousand miles reliably only to eventually die of something entirely unrelated.
