I have a 2006 Sonata, with 2200 miles. I just noticed that all four rotors are covered with ugly rust. My last three cars had 4 wheel disc brakes, and the rotors were always a shiny silver, as is the Honda CRV I currently own.
Questions are: Is this condition normal? Does anyone else have this? Is it harmful to the brakes? Why do these rotors rust when none of my other cars did?
Ooooh, the heartbreak of ugly rust! Brake rotors are iron. It's the nature of iron to rust when exposed to oxygen. Air is about 40% oxygen. Just drive the car normally. As the pads continue to fully seat-in, they'll remove the rust you've noticed along the pad contact area. A layer of rust outside the pad contact area is normal for any make car with disc brakes.
"ONLY NOW creates a HUMMING/VIBRATION between 2500 & 4000 R.P.M., CAN ANY ONE THROW SOME LIGHT HERE, thank you."
Access Hyundai WebTech and look up in the online shop manual for your year car the torquing sequence and values for the engine-transmission mounts. Try the easy way first by loosening the mount again that you removed and retorque to the proper value. If that doesn't cure the vibration, you'll need to loosen all of the mounts and retorque in the proper order and amount.
I didn't have your type of problem with my Tucson. I bought my 2005 Tucson in Feb of 2005 and now have about 14,500 miles on it. It has been running real well, and I just got back from Florida Nov. 2005- (I live in Conn).and also drove to Florida and back in May, 2005. I really like the car, and feel very secure in it. However, I noticed at about 12,000 miles, when going up a hill I am getting a type of "thrumming" noise from the engine. It doesn't affect the power, or performance, and I'm not sure why its doing this. It doesn't seem like something the dealer can fix. Maybe its just something to live with. Maybe the car needs a fifth gear. Any ideas?
when going up a hill I am getting a type of "thrumming" noise from the engine... Maybe the car needs a fifth gear. May be you should try to use a lower gear going uphill and see if it makes any difference. I don't think it needs a fifth gear for climbing a hill... but rather down shifting to 3rd!
The fact that the thrumming noise began around 12,000 total vehicle miles is sufficient reason to run the issue past your dealer's service department. Don't be bashfull about contacting Toyota USA if the dealership tries to brush you off, either.
I have a 2006 Sonata with about 2200 miles on it. It is a V6 GLS without a sunroof. I am getting a very noticeable rattle from the mid to passenger side dash area. Has anyone else had this problem and how was it resolved?
I know all cars have rattles but this one is extreme. The kind of rattle that if someone else was in the car they couldn't help but mention it.
Just took delivery of my new 06 LX Sonata and I am noticing that the transmission likes to downshift and upshift frequently in hilly terrain with approx. 3 to 7 degree incline. I try to maintain a tach reading of 1500 to 1800 RPM (approx 40-50+ MPH). Invaribly in this tach range the tranny downshifts with RPM increasing to approx 2200 RPMs and upshifts again to 1500 to 1800 about midway up a hill. This behavior repeats itself over and over on seemingly small inclines. Anyone else experiencing this behavior. It sounds like the computer controlled shifting algorythm may not know how to handle hilly terrain any other way.
Many reviewers of the 5 Speed Shiftronic mentioned this: they call it "tranny fishing". Since it is a new A/T this year it probably needs a fix/tuning. They had the same experience every time they had to go up a hilly terrain!
I just noticed you're in India, hmm..if the shop had never worked on that type of engine prior to the timing belt change, the balance shaft is probably out of phase and I don't think this is something they can handle, so you need to tell them politely to get help from a Hyundai mechanic...good luck.
I've been looking all over and cannot get any info. Please, HELP!!!! I have 1996 Sonata GLS 4 cylinder 1.8L SOHC MFI engine. It is built in Belgium. Exhaust manifold is cracked and O2 sensor that is sitting on top of it damaged. I tried many dealer and they all say it is non USA engine, Sorry... All US engines w/ 1.8L are DOHC, my is SOHC.I would like to change Fuel injectors, thermostat, water pump, O2 sensor and Exhaust Manifold. I wonder if any1 knows if 1.5L SOHC engine is the same engine is 1.8L SOHC except the displacement. I am in SF, CA & I have the car in France, so I cannot take parts off to get part numbers. It is impossible to get any parts in France.It took them 3 weeks to get an alternator for me and it was $900( no labor) a year ago, imagine what it would cost now! Double!.Please, SAVE ME. Any1 has any info I Greatly appriciate.
I had a 94 Ford Thundebird I bought new. Black, sun roof, leather I loved it. It had a button to push to keep the tranny from overshifting (going high to low too often) on hilly terrain. Maybe the Sonata needs that feature.
Instead of a button, the LX has the shiftronic 5 speed trans. so if you move the lever over to the manual side and select 4th gear, it should stop the hunting between 4th and 5th when you are going up hill or a series of hills. I do it but the problem I have is forgetting to shift back into 5th when the hill has been topped. Not good for gas mileage!
Sir may i thank you, for the precious advice, YES you are absolutely correct in your diagnosis, did align the balance shaft properly & WELLA ! the vibrations disappeared as smooth as ever, however on talking to some owners came to know that the BANDO timing belt cracking & wearing off problem is very prominent, that many a owners have faced the same problem with major head & valve damage....thanks a lot once again.
I am looking for some help or feedback regarding a vibration problem with my brand new 2005 Sonata GL 4 cyl. When sitting at a light or at a stop with the car in gear, the whole car vibrates. Can be felt in the steering wheel, brakes, floor, doors dash.... everywhere. it's not violent vibrating but enough to wear down your patience after buying a brand new car! after about 3k miles the problem started and occasionly gets bad enough that some interior parts even rattle. UNREAL!!! I took it in for the rough idle which is causing the vibration and a hard starting problem. Hard starting had a technical service bulletin so they upgraded the software and I guess that corrected it. As for the idle, they said that it's STANDARD and it's a CHARACTERISTIC of the motor!!! I couldn't believe it, Anyone else having this problem???? I am going to take this as far as I can till they fix it or I get a new car. Cause in my eyes... I smell a LEMON!!! ANY HELP IS APPRECIATED!!!!
"When sitting at a light or at a stop with the car in gear, the whole car vibrates. Can be felt in the steering wheel, brakes, floor, doors dash.... everywhere. it's not violent vibrating but enough to wear down your patience after buying a brand new car!
I had until a month ago a GL 2001 Sonata 4cyl. Never vibrated at a stop or otherwise for 4 years and 50k.
"As for the idle, they said that it's STANDARD and it's a CHARACTERISTIC of the motor!!
BS. .. A 4cyl engine has a distinct sound, not vibration! Take it back and demand a written write up every time you take it in - that is your only proof if you ever fight it as a Lemon! There is a time limit on the Lemon law thing... here in Florida they just overhauled the law and extended it.
If that fails... contact Hyundai... Don't wait too long... until the time limit expires!
Four-cylinder engines are never as theoretically smooth at idle as their six-cylinder counterparts. However, most four-cylinder engines in current production, including Hyundai's, have a pair of counter rotating balance shafts to dampen the vibration of the firing pulses. They're pretty effective, so somethin's definitely not right with your car's engine. (It might not even by anything serious - a misfiring spark plug will have a dramatic effect on a four cylinder engine's smoothness at idle.) Before you file a lemon-law case*, call Hyundai at 1-800-633-5151 (hint - it's in your warranty supplement booklet that I bet you never bothered to crack), explain the problem, report your selling dealership's service department's lack of interest in investigating the matter, and request a Hyundai zone rep meet you at the dealership to witness and discuss the matter in your presence. His decision will override the service manager's. Alternatively, try another Hyundai dealership if one is within reasonable driving distance. You're NOT required to have warranty work performed by your selling dealership's service department, and not all car dealership service departments are created equal. Some actually give a rat's behind.
*Once filed, lemon-law cases (a form of civil action) can drag out for YEARS in "discovery". (Hyundai's not going to be in any particular hurry to settle - it's not at all in their interest to do so.) Even if your hypothetical case is ultimately settled in your favor, your "buy-back" award will have fair market value depreciation deducted for the entire time the car is in your possesion (during which, by the way, you'll still be legally obligated to continue making loan or lease payments - nothing's put on hold during the process). Given Hyundais' abysmal depreciation rates, your final settlement check would likely be a bitter joke.
So after owning my wonderful 2000 Sonata (V6) for 4 years it's finally crapping out on me. I have numerous codes that have popped and am looking for advice on which to look into first based on what your cars have needed... P0335: Crankshaft position fault P1372: Segment time acquisition problem (related to above code?) P0305: Misfiring cylinder #5 P0740:Lock up torque converter solenoid Lastly 2 undocumented codes: U3118 and C0307 Last November I had the mass air flow sensor replaced and joy for me they put it in backwards...but the car ran fine for the next 10 months without popping the check engine light...can this cause any other problems that might pop one of the above codes? Right now my car runs poorly and I would rather take a bus or taxi to get where I need to go regardless of how much the ride will cost. When cold and first being started, it will die if put into reverse, but every additional time there after it will go into reverse just fine. Also while driving it is as if it loses power and dips very low in RPMs and occasionally stalls in the process. Sitting at an idle, it feels like a diesel truck idling and 1 out of 5 times will stall at red lights... Any ideas would be great seeing as how I'm just "a stupid lady taking her car to the dealer and have no idea what should be normal for my car." Thanks in advance
I know this sounds crazy but my 05 Sonata with the 4 cylinder whistles occasionally from under the hood while driving and when it is parked. Sometimes the sound is louder that other times, and sometimes U do not hear it at all. Occasionally it resembles the sound of an alarm. Of course the day I brought it in for service it did not do it. Would appreciate any suggestions or if anyone else has this problem. Thanks
M'am, you have a five year old make of automobile that at the time it was built was not known for exceptional long-term reliability. Sitting on your duff will not solve the mechanical problems the codes are related to, and may cause more. Either get it fixed or trade it in on a new car. (Ask me why my 2003 Sonata V6 is probably my last Hyundai product...)
Having just finished A lemon lawsuit with Ford I agree with previous post about what to do except one thing. Here in NJ the depreciation on car is frozen at the point that problem you are suing for is first reported. In my case the truck had 1200 miles on it the first time I reported problem so depreciation was almost nothing.
yes I have the same thing all of a asudden I get the check engine light on and then I lose all power and very little power for take off let me knowwhat you came up with
I have a 2000 sanota that will loose it's power with asudden jerk some times and sometimes no,But i will have no pick up off the line and no passing gear at higher speeds.Someone shead some light on this for me.
Hello I am repling to you message.I have a 2000 sanota as well am suffering with the same problem as you are with the lose of power,but mine does not stall yet.I have been told that there is a filter at the back of the car that regulates the pressure in the gas tank, If this filter becomes plugged then you can get problems with the gas supply,maybe causing this problem of stalling. they say that it comes fromoverfiling you gas tank therfor wetting this filter and if you travel in dusty area's then this filter can become plugged. As to the problem I am having did the power failure come with sometimes a ajerk and sometimes not, no passing gear,and lose of power off the line, please let me know. Dean
I recently bought a 2005 Sonata. My car has the same exact symptoms as described by mvanine. My car vibrates while in gear at stops. It is a strong vibration in the steering wheel, seat floor and in the passenger side seat as well. I get a vibration in my arm, back feet and legs. So far I have been told it is the characterist of the car. Bull, There is something wrong with the car. Has anyone been lucky enough to get a dealer to fix this problem.
:confuse: I wish I had a answer for you Doowopal, But my Sonata 2005 6 cylinder is doing it also I disconnected the Alarm its on the inside passenger fender wall behind the Windshield Wiper fill tube. Can someone tell me what it is and what the purpose for this sensor?
Hello: I could of been the writer to your text! I have the exact situation with my BRAND NEW 2005 Sonata. I have taken it to two differenct dealers. They all say the same thing. "It's just how the car is" Well, I dont believe that. I have had more than one time a dealership service person ask me what kind of car have I been driving in the past and that I cant compare those cars to this one. I stopped one guy before he could start with this idiotic remark and told him I was not there to discuss any other car but the one I have which has a vibration problem. I havent been able to figure out why the dealerships are avoiding this problem. And I do mean I think they are avoiding the fix. I recently had the car in to another dealership and was told , this is how the car is and they know that because they had another car with the same complaint. I have called Hyundia, and am filing a case with them, I am also making an appointment with a zone rep and will get the dealership owner involved and state attorney if I have to. I will not back down. Please let me know what is going on with your actions to get your car fixed
I have almost 4000 miles on my 06 Hyundai Sonata LX and love it. Great mpg so far (20-21 in city and 30 highway) in the Detroit area, rides great in snow and slush.
However... try to sit in it, engine on, without the seatbelt on and wait for your wife to come out of the store and the seat belt beeper will drive you nuts. Unbuckle your belt to reach the ATM and it will beep VERY loud, etc. Is there a way to silence this?
After we got rid of our 2001 Sonata money pit, we heard that the crank shaft blade should be shimmed to steady it. I said it sounded like a swarm of bees. I am still alarmed at all the crank shaft sensor sounding problems still being discussed on here. Sorry to say, I finally paid off our dealer repair with our Christmas bonus. Yes, this car still bothers me, and we got rid of ours in Sept. I would still like some recourse for the hell we went through. I can not tell you how good it is to go out, start the van, run errands, and come home without being towed.
I also own a 2000 sonata GLS that the check engine light is on and it has the same symtoms as described in item 54. It runs rough, small back fires and also down shifts to lower gear, sometimes extremely rough. The dealer replaced the timing belt and said crank sensor was ok, also replaced plugs and plug wires, and number two fuel injector. Need help please. Any solutions will be appreciated.
Am I the only one with the sound of a bowling ball rolling around in the trunk. only happens when tank is 3/4 to full. Most pronounced at low speeds and stop/start conditions.
I have been chasing a secondary thumping in the trunk area after going over a bump. Have not noticed your symptom but have seen some early posts on your issue. When did you take delivery on your 06 Sonata LX? Just wondering if there were some corrections made by the factory on the fly.
It almost sounds like the baffles which should be in the gas tank to prevent the sloshing sound of gas were left out of some tanks.
I would make sure that the exhaust pipe is not hitting the under carriage at some point. I had this on a new VW GTI and when I would go over certain kinds of pavement bumps it would bang in the trunk area. Simple bracket change fixed it.
No, I also have those sounds when I fill up the gas tank. Once tank gets down to 3/4, the sound goes away.Only at slow speeds, braking, etc.
I wonder if they will repair this at some point? I've bought 5 Hyundai's, maybe they will do it to keep me happy!!!
Love the car (06 GLS-V6), not sure why some feel it is a bland exterior, I think it is one of the best looking cars out there, but i guess everyone has their own tastes.I do wish the dash would flow down into the console, that would be the one thing that would improve the interior....
I heard the same kind of sounds that you are discussing here for 2006 Sonata LX when its gas tank is almost filled up. I do not consider it is a problem. Lexus ES300 and Honda Odyssey EX have the same type of sounds after their gas tanks are filled up. The sound from Honda Odyssey EX is much louder. I simply ignored it.
I just bought a 2006 Sonata LX (like yesterday), and am generally happy with it, but I noticed that it doesn't automatically lock the doors once you put it in drive. I checked the owner's manual, and on page 7 it says some Sonatas have this feature, i.e. "if installed". It's not on my window sticker, and I can't find it on the Hyundai website. My dealer pleads ignorance. Does anybody know if this feature is standard on the LX, or how I could go about finding out if my car has this? Thanks!
P.S. I haven't noticed any problems with excess vibration or noise, and in fact I find it quieter than my 2005 Sienna. So, whoever got told "that's how this car is" is being given the runaround...
own.
Anyone out there know?
Dave
For a Hyundai?
From The Florida Lemon Law site:
DO NOT DELAY in reporting a problem as this may cost valuable time and protection.
For more:
http://myfloridalegal.com/pages.nsf/4492d797dc0bd92f85256cb80055fb97/a510d1364b1- 5502a85256cc9005da68a!OpenDocument
Well anyway, that sensor is a bugger.
Lunchmom
mail. It says the car has automatic door locks,
but they must be activated by the dealer.
