Hyundai Sonata Care and Maintenance
Just had my 2000 light moss GLS detailed yesterday at a shop. I get it detailed once every year to keep it in top shape. So far so good. There were a few minor stains on the cloth seats, but the steam cleaner had no problem getting them out. The mats seem to be easy to clean as well. Despite all the mud accumulated into the mats during the winter, they are as good as new now. No cracking or other nasties on the dash. The car has aged real well so far despite 27,000 miles and 2 Wisconsin winters.
Thanks "
Please go here I posted your question here...
http://pub12.bravenet.com/forum/show.php?usernum=950089089
1. Cooling System Flush
2. Replaced Air Filter
3. Perform Oil flush**
4. Oil Change and Body Chassis Lube
5. Driver's Side Headlamp Replacement+++
6. 4 Wheel Balance/Tire Rotation
7. Transmission Flush Service.
I was told the oil was very dirty and opaque due to "inferior oil used at places like Jiffy Lube"(I was shown under the car and mechanic dripped the oil for me) and he said an oil flush was needed to clean out the gunk. I opted for the transmission flush because I was told it was needed to be done after 30,000 miles in order to keep the car in tip top shape. The headlamp did burn out and needed replacement.
Were these rates acceptable? Was I "had?" Was all of this really necessary? Comments are appreciated.
I assume your oil changes were with Pennzoil, which has one of the best spec. sheets for a dino. oil. Quaker State and SuperTech (not applicable here) have adequate spec. sheets and only Wolf's Head is sub-par.
If you were doing 11,000 oil change intervals, however, with dino. you were letting things go WAY to long and your oil probably was dirty. I change at 4000 mile intervals, I believe Hyundai has a 7500 mile change cycle in non-severe service. Most cars are in severe service. If you are using an 11K change cycle you may have voided your warranty. Certainly would have if it was a Toyota.
If you had 2 Jiffy-Lube changes and 3 others from other places, your dealer's full of it and was scamming you based on your oil change sticker.
Just wanted to express my sadness. Last week I was in a car accident, I rear ended a non moving 96 Toyota Avalon in Los Angeles last week. Luckily I have car insurance. But a damage cost is incredible. The Toy suffered it appears minor damage to the visual eye to the rear bumper. Driver with whiplash!
My 2001 Black Sonata V6 with 11K miles suffered considerable front end damage. The grill slammed into the radiator. Front hood crinkled. Does not look like any frame damage. The drivers air bag did go off. Etc. Auto Repair shop estimates costso far to be $7700 with no promise that more may be need. The car cost about $17K. When would it be considered a total loss instead of re-building????.
The low resale value is one of the gambles with a Hyundai. Your car might be out, but at least you're ok.
Unfortunately, the rear car in a rear end collision usually suffers the most, especially if you put on the brakes. The front of the car tends to dive and expose vulnerable points of the car. It's not uncommon for the front bumper to go completely under the rear bumper of the car in front, and there goes your protection. Also, the front of your car generally has more "crush" in it than the rear, so things can look even worse.
Did you ever hear somebody brag about how tough his/her car is when someone hit 'em? Many times it's somebody who got rear ended. "You shoulda seen the guy who hit me!" If the roles were reversed, they wouldn't be bragging.
The main thing is you're safe and your car protected you. I'm guessing they'll repair it, and even though some people would look askance at a repaired car, you'll be getting back a faithful friend who gave it up for you.
but, about to make appointment with dealer for 30000 mile maintenance...and was wondering what i can expect cost wise. if anyone cares to share with me i would be grateful. car is sonata 2000 v6. thanks, joe.
I am in the military and currently stationed in Belgium. I recently tried to get some warranty work performed and was told that the warranty was only good in the USA, because that's where I purchased the car. They said they would fix it and bill me and then I would have to recover the cost by going through Hyundai USA.
I find this really hard to believe and I'm wondering if anybody has any experience or ideas on this matter.
FYI...the reasons I brought it in are for the following:
1) The left rear power window is broken. The cable mechanism inside the door needs to be replaced.
2) The front brakes act as if the rotors are warped. When slowing down from high speeds, the brakes are not smooth. I know pads aren't covered, but the pads are fine.
Richard W. King
Also, on 6/2002, I was also hit on the Driver's side by the gate access of the apartments where I used to live. The gate hit almost just past the front tire, making a nice dint into the driver's side door, and scratching the car all the way to the rear end. At this time, the front side air bags did not deployed either. Few weeks later, I got a recall notice from Hyundai advising me to bring the car for the sensor to be repair because the side air bags will not deploy.
I called Hyundai, they told me they will be mailing me some brochures about air bags, they would not discuss it over the phone.
any feedback on this issue?
Sally
The recall on the side airbags wasn't for non-deployment, it was for premature deployment (ie someone forcefully slamming the door shut), I had my '02 sonata done.
Hope this helps.
I posted this link to help everyone understand the theory behind the airbag(s).
The front airbags should deploy if your vehicle is hitting an object with the force of slamming into a brick wall at 10 to 15 mph, or approximately 15 - 22 feet per second into something that won't move.
The side airbags will deploy if and an object hits the side at 10 mph, 15 feet per second.
If an airbag doesn't deploy, you probably didn't need it. Airbags deploy at approx 200 mph. The idea is for the airbag to get between you and the car in the event that your going to get hurt.
2 months ago, my stereo was not working at all. I got t new battery, not it is ok, except cd player works when it feels like it(luckily, I have cassettes/and player in my 99 gls).
I called Hyunai and asked about a radio replacement/cost. First Thing the guy said was "it's under warranty". I told him I had 90,000 muiles and he said,"No, th warranty on that expired at 60,000 miles"...Not 36K, like your crooked dealership told you.
Either that, or the 2 dealerships here in Ohio are just nice guys who want to fix things for free ;-)
That's a direct quote from the Hyundai "2003 Owner's Handbook & Warranty Information" booklet. Whether previous model years differ could only be verified by access to earlier editions.
http://www.hyundaiusa.com/ --> “Owners” --> “Maintenance” --> Scroll down the page and click on “Hyundai Webtech” --> This opens a new session of your browser. Now choose your Hyundai model, year, and engine at the top. --> An outline format listing of topics with “book” icons to the left will appear momentarily. Clicking on a listing of interest will bring up a sub-listing of more “book” icons and topics. Maneuvering through these will eventually bring up listings of “document” icons. Clicking these will open the salient page(s) of the topic you’ve selected with full on-screen text and graphics. This site contains the various complete Hyundai Shop manuals as near as I can tell as far back as 1986 (the first Excels to reach the US). Furthermore, if you look towards the top of the page, you’ll notice in faint gray “TSB”. Clicking on this will open numerical listings for various models and years’ technical service bulletins. These listings contain the text of the selected bulletins, so you can keep up with service advisories that may pertain to your vehicle. Also in this same area of the page you’ll find in faint gray, “TechNet”. This is another nugget. It contains service notes that Hyundai techs get throughout the year for hints and tricks, but, more importantly the TSB topics with their individual numbers that you’d need to investigate in the “TSB” section mentioned above. Two other “gray” listings are “TS” and “ETM”. Unsure of the former – nothing came up for my Sonata, but “ETM” brings up the “Electrical Technical Manual” (I guess that’s what the initials stand for ) with various schematic diagrams for the electrical systems on the car.
None of this will make you an instant certified Hyundai technician, but it is a treasure trove of official information if you do your own maintenance and want an indication of the complexity of a procedure before you tear into an unfamiliar job, or just want a no-cost reference source if you have a dispute with a dealer’s service department. (Might even find out they were right! <grin>) The bad news is that I was unable to do a cut-and-paste into my word processor (Word 97 - It choked and required closing and restarting the program.). Maybe you’ll have better luck, but I suspect that Hyundai buggered their pages to prevent wholesale printing of their shop manuals. Can’t blame ‘em for that since the material –is- copyrighted.
With the glove bin and inner chamber out of the way, you can replace the glove box light if it ever burns out. Or, you can add an in-cabin air filter to the HVAC system to the base Sonatas or replace one included from the factory on the GLS and LX models. The filters run about $35.00 U.S. at the dealer. Champion Labs ("Lee") makes in-cabin replacement air filters, but they don't appear to make one for Sonatas. Yet. The Hyundai filter I bought appears to be a HEPA-type filter, though there's no evidence of activated charcoal to control odors. (Rats!) There's a door covering the filter chamber on the blower case. The molded-in latch is at the bottom. You may think you need some offset pliers to get adequate leverage to unlatch it. In reality if you just press inward with sufficient force against the door simultaneously, you should find you're able to unlatch the door without resorting to the pliers. Swing the filter door up and off its hinge at its top. The filter has a little handle and a protrusion molded in the plastic end cap and there are corresponding wells molded in the door to accomodate them. Just slide the filter into chamber with its protrusion located at the bottom so the door will fully close. To properly latch the door, you'll need to simultaneously press in against the door again. Carefull with the hinge plate when re-attaching the bin. There's a sharp enough corner at its left end that I gouged the left inner footwell trim piece slightly when the hinge plate scraped against it. With 20/20 hindsight, putting some tape over that hinge-plate-corner-that-eats-trim-pieces would be a good idea. (The tape would be completely invisible once everything is back together.)
*This is a bit of trick engineering Hyundai went to in itself. The other end of the cord is attached to a spring-loaded plastic "piston" in a transluscent plastic "cylinder". Apparantly the idea is that trapped air in the cylinder acting againt the cord-activated piston will restrict how quickly the glove bin drops to its normal open position. It only seems to have an effect on an empty bin on my car as far as I can tell. The weight of the owner's manual packet, alone, seems to negate any practical retarding of opening speed. I reconnected everything, but in my opinion this was one area where Hyundai could save some unnecessary expense. I'm sure the assembly guys would appreciate it, too
http://www.geocities.com/sonatafan/filtpage1.htm
Sorry, I didn't see your post until now. Otherwise I could have saved you a lot of trouble.
Besides getting rid to the critters, what can I do to prevent this happening again since the dealer bills me for accessing the blower motor housing and cleaning it out. Thanks for your help. Jsnowe
My battery went caput at 54K in 32 months.
I've never had battery die this early(?) b4.
This is my 4th vehicle.
At first, I had to call for roadside assistance not realizing that it was a battery problem. The dome light and other electrical accessories were working. They jump started the car no prob & advised me to drive around for a recharge. I did as told & parked the car overnite in the driveway.
The following morning, the car wouldn't start so I had to jump start again to get to work. Then again at work.
So I thought it may be the alternator that was not working properly to charge the battery & dropped off the car at the dealer for service.
The next morning I called the service dept & the guy tells me the car started fine, but he'll check for any problems! Go figure.
Later, they told me that the battery was shot & charged me $135.58 (46-labor, 79.95-battery, 7.68-tax) for the replacement battery. It was another Hyundai battery (without the eye to check for the status) and had HUGE "48 Month" written on it.
Obviously, had I known it was the battery, I would've replace it myself & saved the aggravation of jump starting & some $$.
So here are some questions I have:
1. Would it have been possible for me to tell whether it was totally dead battery vs. an alternator problem?
2. What are life expantancies for the batteries? Are most 48 months?
3. What particular brand of replacement batteries do you recommend? Or are they all same like consumer AA batteries? Thx.
josephm2, you DO have that bolt (nut?) as referenced in step 8. It's recessed from the inner plastic chamber behind that rectangular hole. (You may have actually seen it and mistakenly concluded it couldn't possibly be related to removing that inner plastic chamber from the dash - I almost did myself!) Get some light on it and you'll see what I mean. It's been awhile since I installed a cabin air filter, so I'm not certain whether that 10 mm fastenrer is in the form of a bolt, or possibly a nut screwed onto a threaded stud. The step-by-step I referred you to was for a '99, I believe, and my Sonata is an '03, so this has been a running glove box removal procedure for this model's entire run, so far. Have another go at it.
Re: Dead battery
Battery life can be affected by climate and driving conditions. (Hot and cold weather are both very hard on battery life, as is short hops.) You could have a bad alternator. Most auto parts stores can test your alternator in the car and report if you have any blown diodes. Whether your Hyundai dealer would accept their report is another matter. There's a very detailed procedure in the Hyundai Sonata shop manual that service techs are supposed to follow in assessing the health of an alternator, but, personally, I question whether many of them follow it. It's possible to have one or more blown diodes and still show at least limited, but insuficient, charging taking place. If the dealer tech starts the car and merely notes that the battery "icon" on the dash is not illuminated, he could get a very false impression that all is well. ALL defintely may NOT be well. I found this out the hard way on a Toyota truck I owned through an error in hooking up cables to jump another car's battery. I blew two diodes in the alternator, but according the dash's charge indicator, all was well. The truck wouldn't start four days later...
Is this normal??
*minus a couple of unintentional forays to nearly 65 mph briefly before I realized I was going that fast. These suckers do wanna cruise...
thx. -- Alice
(I'm looking at an out the door price of $18,850 for a 2003 LX Sonata with leather, moonroof, etc. etc. etc. -- tax, lic. registr., rebate included).
