Visitor Agreement.
any vibration when going around high-speed bends in either direction?
I've taken it to the dealership with no results.
Can you let me know what became of you taking your S40 in? Do you still have the wobble/shake?
how many miles on your car? i hope he is wrong. if he says tranny, i might be inclined to get a 2nd opinion, personally.
So that's the way to test out this "theory".
I have a 1999 S-80 T-6 with only 58,000 miles. At the last minor service, a "Software Upgrade" was done while the car was in for service. Since then, the car runs very rough for the first half mile or so, and then is fine. I had the car back at the dealer, who left the car out overnight, and, naturally, the problem did not happen. The car is normally garaged, and, of course, the rough running is back. Any clues about the recent software issues for this car? Thanks in advance.
mjdrph
I honestly wouldn't put any faith in CRs raitings as they used to give corporate cousings/badge engineering efforts vastly different ratings when in reality the two vehicles were exactly the same except for the badge on the hood.
I wouldn't be surpised if the categories that CR has the S60 AWD rated below average are...
1. Fuel
2. Brakes
The AWD model is going to get worse fuel economy then the FWD model and the AWD model is going to eat up brakes faster then the FWD model.
ONLY CR members who own the car in question are surveyes.
Since Volvo sells far fewer AWD S60's than FWD ones, any negative comments will unduly affect the AWD car.
In short, new right cv shaft, new brakes...mechanic says front struts checked ok...changed top motor mount last week, bottom ones looked ok...not sure what to look at next?
Any suggestions appreciated.
randy
the other CV joint
bad front suspension alignment caused by loose/broken control arm bushing? (ever push a shaking supermarket cart? That's from a bad caster angle, or wheel alignment).
If the bend to the right produces the noise, then it is the left side (weight is on the left as you turn right).
randy
Hope one of the suggestions gets it right......the new cv shaft cost me 675 dollars....with a discount! If it's the other side....wow, talk about breaking the bank..... I bought the car in Florida...blew an ignition coil on the way home, with new plugs, 550 dollars.....then needed new brakes to pass the safety.....675 dollars, new cv shaft, 1000 dollars....this is really starting to hurt! I paid 6375 for it....thought I had a good deal at the time!
Thanks again
randy
This might be good to know if you got ahold of an engine without flywheel or balancer, or if you want to swap flywheels or balancers.
Some engines are balanced externally because there is no room inside the crankcase to weight the crank itself.
Is there any other way to diagnose/remedy this problem?
Marc
Marc
well, here's the thing. Those 70-series have a faulty ABS module. Odds are, that's the culprit. Its an expensive fix if you go to the dealer or buy a new one ($700-$800). search these volvo boards for ABS module and you'll get lots of info. It COULD be a sensor ... but given the fact that these modules will fail at some point in their life, I'm putting my money on that. I pulled mine and mailed it to a gentleman in Cali who rebuilt it for $180. Worked great!
marc
what exactly happened with the valves? Was this caused by a busted timing belt?
Let me get this straight, you bought a used Volvo with 145,000 miles and you were surprised that it needed work?
Obviously, whoever had it before you didn't take care of it.
Bearings don't just go, unless there has been some abuse and a severe lack of maintenance.
I hate to say it, but when you buy a car with those kind of miles on it, you have to expect these things to happen.
Especially a car as complex as a V70 XC.
Comparing it to a 240 is silly, the 240 was little better than a Model T in automotive complexity.
MOST cars don't live to see anywhere near 150k.
My advice is to take the car to a competent Volvo mechanic, and get the system fixed, unless you don't mind doing without the ABS and stability systems.
Toddio
Marc
ask and ye shall receive: http://home.earthlink.net/~vicrocha/
good luck!
Marc
