-juice
It may be some of the pad material itself actually came off and adhered to the rotor. I've seen this before on drum brakes, but never on a disc. If so, those pads were kinda sketchy quality, I'd say.
Juice - are you thinking of the anti - squeal goo? Must be. Anyhow, never put any type of lubricant on brake pistons, other than the special piston lube that comes with them. Most lubes will attack and destroy the rubber piston seals and dust boot in short order, which is why there's a special caliper piston lube.
IdahoDoug
I have been reading posts here for some time and thought it was time I participated. Of course I waited until I had a problem! If anyone can help I would appreciate it. We own a 1999 Legacy L Sedan with the 2.2 engine and automatic tranny. We purchased the car new in December 1998, and it now has almost 61,000 kilometers. The car seems to be setting the CEL on during warm up. As the temp gauge rises, just before it reaches the normal operating point (after running for 3-5 minutes), the car loses power and surges for a minute, setting the CEL. The light has gone off a couple of times, but repeating the cold start/warm up ritual has set it on 3 times now. I do not have a scan tool to read codes, so I expect to take it in for repair, but I was hoping for some enlightenment first. Any thoughts?
Paul B
-mike
Interestingly, when my car was new, the shifter would start a very noticeable buzzing whenever I hit 75 mph on the expressway. This lasted for a couple months, but eventually went away without me doing anything.
Greg
-mike
The vibration felt through the gear change is a result of the very direct connection between the gear shift and the trasnmission. In your former cars, the linkage would involve a system of cables that tend to dampen the feel, and the control inputs. This makes them imprecise but reduces any vibration in the car. With the Subaru, the linkages are essentaill direct, meaning more precise movement but also more feel for the vibration in the gearbox.
Cheers
Graham
Thanks Graham!
Patti
If you're not happy with what the dealer has told you, why not call the customer service center at 1-800-SUBARU3? A Rep. can follow-up with your dealer to find out what they've done and see if they need some diagnostic help. While the Customer Service Rep. can't help with the diagnosis, they can get some resources to the dealership.
Let us know?
Patti
Patti's comment is valid. If you push or pull while resting your hand on the shifter ball, you are moving the fork that holds the synchro engaged.
Steve
Greg
Paul B
PaulB
Greg
Anyone know the correct procedure? Thanks.
IdahoDoug
-mike
Gradually, the MPG in my wife's 2000 Legacy L deteriorated from 20-24 (when new) to 18-20 (a year ago) to 14-15 MPG now. Mostly city driving with very light (0-10%) towing. This must be a sub with absolutely the worst fuel efficiency. Maintenance is by the book, BTW.
Recently, I started using synthetic engine, AT, and differential oils.
I also detected 3.9% fuel in oil. Complained about this and milage to the dealership (still drivetrain warranty). I was told the car was OK it it was normal for an old (sic!) car. However, the service refused to put my complaint and their assessment in writing.
The only recommendation I was given was to switch to 5W30 oil. I currently use synthetic 5W40 because 5W30 is permitted only up to 100F and not recommended for towing (I live in south US).
I still think there is something wrong with the car, even though the engine light stays off.
Is there a way to convince dealership to do any diagnostic work?
Jacek
I want to clear the "learning" it has done with the transmission shifting.
Jacek: I'd bet money you have leaky head gaskets. Call 800-SUBARU3 and describe the syptoms. Ask them to open a "Customer Says" call, so that it is documented before the powertrain warranty runs out. They cover it, that's the good news.
They may not do anything right now, but you'll got records. Also, organize your service receipts, just in case.
-juice
I am looking at a used 2001 base Outback w/ MT. I've read discussions about phase 1 vs phase 2 engines - should I stay away from either and how can I tell which this car has? Also, is there anything else about this year that I should know and lookout for?
Thanks in advance for your advice.
The Phase II started being used in 2000. It's been reliable, actually gasket failures are more of an issue on the 95-99 models and generally do not affect the newer ones.
Things to look for? Crawl under neath and check the block for oil stains, just in case. Any leak would be under warranty, though, and like I said on the Phase II that's not common.
Check the clutch for smooth operation. If it chatters, there is a TSB so technically you could get it replaced, but it's good to know.
Overall, 2001 is a good year. 2000 was the version 1.0 for that design, so they'd worked out the bugs. It should still have some warranty left on it.
My dad has a Limited from that year, he loves it. He had squeeky brakes but they fixed it for free, no other problems.
-juice
Joseph
1)I notice an intermittent "metallic ping" or "clicking" (hard to describe)when up shifting between gears. It also seems to do it (again intermittent but less obvious)when I take my foot off the gas when in the high rpm range of a gear. I've tried changing my shifting patterns to see if I'm just no completing each gear change quickly enough or at sufficient rpm range(I generally shift between 3,000 & 3,500 rpm's), but this doesn't seem to be the answer. If this is just an annoyance then I can live with it. If this is a symptom of a possible bigger problem, then I'd like to know now.
2) When operating cold, I notice that I get quite a bit of shuddering in first and second gear. Is this due to the fact the car hasn't reached normal operating temperature,trans./differential fluid temp. (it was checked and is at the proper level), weak clutch plate, other reasons?? Again, if its just an annoyance then no problem.
Oh yeah, I've also noticed that after driving for a period of time (35 minutes over 32 miles)and make a quick stop at a store, the acceleration after startup is rough and not smooth(herky-jerky changes in acceleration and de-acceleration).
Otherwise, I've been very happy with my Subbie. Great gas mileage, super handling in the winter slop, excellent capacity for packing camping stuff. Wind noises are there, but are no big deal to me. No brake or tire problems either.
Thanks in advance to all reply's.
The dealer let me test drive the car overnight. Wife and I put about 100 miles on it and were quite pleased with performance. Also had an opportunity to speak on phone with previous owner and she couldn't say enough good things about the car. She told me that most miles were hwy - going to see kids on east coast and 4 trips to florida from iowa.
Just wanted some suggestions about what to take into consideration on high-mile late-model unit. Put it up on ramps while at home - only things I really noticed were:
1) what looked like possible leak on front driver's differential (though differential oil level was acceptable)
2) a little more rust on exhaust than I would expect on an '01 - had completely rusted thru spot weld on heat shield.
3) some gunk around transmission, but not excessive
4)slight rattle in driver's door
dealer has the service records, but wouldn't show them to me without a solid offer on the car, but said that at 54,000 they replaced serpentine, flipped and resurfaced rotors, and put on new pads.
Anything else you can think of as it approaches 100K? How about the timing belt (I know it is supposed to be done every 60K on my Toyota). What about valve clearance?
The car would get only about 10-12K per year, but mostly on short trips to work (12 miles one way). I think I could get the car bought for about $11,000 solid cash. Seem reasonable?
Thanks for your help. I might be going back to dealer on Mon or Tues, so any timely advice would be much appreciated. Sorry that my first post is such a long one. Hope to join the "Subaru Crew" soon.
corey
I failed to mention in the first note #1817 that my Legacy is about a year old and has 4200 miles on the odo. I use only Chevron gasoline "mid" grade and it has had an oil service every three month despite the very low miles.
I like the gentleman in post #1818 have that
"herky-jerky" on accel and decel. Patti what do you think? Maybe you can help me and Tony619.
Thank You,
Joseph
I have a 2001 OBW and love it.
You can see the maintenance schedule on the subaru web site.
http://www.subaru.com/owners/care/schedules/middle.jsp
Your right about the timing belt (100k miles). Otherwise there have been 2 recalls. NOTHING major here. One to re-program the copmuter to make the 'Check Engine Light' a little less sensitve and another to re-undercoat some suspension parts.
$11,000 seems a bit high given Subaru has $2000 cash back on new, and the high miles. But not too bad.... A new 03 Forester X can be about $19K and the 03 Baja has been in the $18K range in some cases.
--jay
Make sure that transmisson has been serviced - otherwise it's fried.
If it's been well cared for, though, I would not hesitate to recommend the car. Mine served me well for the time I had it.
Brian
We were doing ~70 mph on straight flat road (of course, it was OK). The tires had 50K on them, with some wear on the edges, but no belts or anything of the like showing. All of the tires had been regularly checked for inflation, and in retrospect the tire that blew had lost about 2 psi on the previous check, and refilled.
Has anyone heard of this happening on their OB Wilderness tires? Like others, I had checked with Subaru when the whole Explorer stink had come out, and was assured that the tires on the OB were completely different. I'm concerned that others with aging tires may start to experience similar problems.
Jeff
Thanks for the input on the hi-mile '01 OB I described. Your thoughts have helped me curb my enthusiasm for jumping at an OB too quickly, I will take some more time to look.
I wanted to stay around $10k on this particular one, but was willing to go up to $11k if they replaced timing belt, plugs wires and maybe pads. Kelly, NADA and Edmunds all put the dealer retail value for this car at about $15k (that's including high mileage deduction of $1800-$2100), and the trade in value at around $11,000, so i thought maybe it wasn't too bad a price (used subs are kinda tough to come by in these parts).
However, if even you Subaru fans are a little put off by the miles, perhaps I should be too.
Any suggestions of what $10-$12K will buy in a used Sub? I really want to stay in that area b/c it is our second car, mainly needed for winter driving.
OK - since this IS the problems/solutions board, I better ask such a question.....I noticed that Subaru recommends you change out your brake fluid annually. I have never heard any other manufacturer suggesting such a thing. All our farm vehicles have original brake fluid still in them and have never had a problem. Does anybody know Subaru's reasoning for this? Can your average mechanic perform this, or is it something you want to go to a dealership for? Any idea on labor costs?
Thanks again for all your help. You guys are great! I appreciate it.
Corey
I had the car in the shop (for the third time) and the mechanic found that the AC was overcharged with freon. He drained a little and symptom is gone.
Jeez.
-mike
My owner's manual says 3 years or 30K miles. (2001 Outback)
please reply if you have an opinion on the Overfill of oil issue.
THanks
But oil getting into the cooling system could only happen one way - by a failed head gasket allowing oil ports and cooling ports to mix their fluids. You have such an issue.
Why did you write : "Car runs, no cooling problems once radiator hose replaced, no overheating problems"? Did you have an overheating condition on this engine due to an aged rad hose?
IdahoDoug
Hope this helps.
You may have a clutch affected by that TSB, making matters worse. They should work on that for you, though.
Our A/C works fine and has no affect on drivability.
The gaskets may have failed due to the elevated temps, then the oil and coolant mixed up. That engine might just be toast. Did it overheat for a long time? An alloy block isn't going to respond nicely to that.
-juice
Still, anybody know the reasoning on changing out the brake fluid? I have never heard of it before on other makes.
The reason? Brake fluid is Hydroscopic aka absorbs moisture. When moisture becomes absorbed into the brake fluid, and the fluid is heated up above the boiling point of water, under heavy braking situations, the water boils and creates air bubbles in the line (the heat is from the friction of the pads against the rotors, that then travels to the calipers to the fluid in the lines)
Once you have air bubbles in your lines, then the pedal will feel "mushy" and will not provide satisfactory braking power. A friend had a 10 year old XT6 that he thought had major brake problems, changed out pads, rotors and still no better, finally I told him to flush the fluid and it was as good as new.
So you should definitely change it out 1x every 2 years IMHO on "average" drivers, for me I change it out every 10-12 months on my daily driver cars, and every 6 months on the race/track cars.
-mike
