Craig
and low maintenance. I’m open to Honda, or Subaru, or Toyota (or any other
make). I just want a car that will give me minimal problems for the first 100,000
miles, and be reasonable after that. Thanks to this board, I finally have a clutch
that works in my car. I appreciate postings that helped me solve problems with
my car. Thank you for the helpful posts. Emma
last fall I had the cam positioning sensor and the knock sensonr replaced. What might it be? The o2 sensor? I am certain that it is not the gas cap.
Steve
AutoZone will check codes for free.
bit
Rotors - Craig was right - wheel over-torquing can contribute to the problem. Please call the 800 number if you have a consistant problem. Also, it might help if you ask your dealer to give you the measurements from the rotors. Is it all wheels? Are they using an on-the-car lathe? It makes a big difference. All dealers are required to have an on-the-car lathe (as a required tool) by Subaru. It may help you if you ask them if they are using one on your Subaru.
Dealers - I really think that vast improvements are on the horizon. The "Subaru Difference" standards are having a great positive impact on the survey scores we are seeing for the dealers that are going through the certification process. I know it's an issue. I'm feeling pretty confident that customer's will see some impact soon.
Patti
This isn't the first standard I've owned. I think I know what I'm doing.
Finally, in December 2002, a redesigned clutch kit was made available from Subaru and my dealer called me to schedule mine to be the first one to receive the new parts. I had the work done and the car's behavior was entirely transformed. No more violent bucking through intersections, no more teeth rattling pulls into traffic. I put about 13K miles on the car after getting the clutch fixed and the shuddering never once returned. I traded the car in July for a 2004 WRX.
If your dealer isn't cooperating, find a different dealer or call a regional rep for help. There IS a fix out there, and you should not be responsible for paying for it. Good luck, I know how frustrating it can be!
Brian
Looks like there's enough info here to approach/corner my dealer with.
Hopefully they don't give me any nonsense about these fixes not applying in the Great White North.
Mark
If your dealer is not cooperative, call Subaru. This is a known issue and they really should take care of you.
By the way, the car never exhibited this problem when I drove it in VA, but cropped up in colder weather in CT. It got worse and worse with time, until it was even an issue in warmer weather.
Thanks again to Patti for her help!
Craig
Other than having the brake rotors resurfaced at about 12,000 miles, my LL Bean has been absolutely perfect. I just did the 30,000 mile checkup a couple of weeks ago, and replaced the engine belt for good measure (it was looking a little tired). Otherwise, I feel really good about the car, and it is holding up very well. I will probably do the whole wash/wax routine this weekend.
Otherwise, this decision probably depends a lot on your personal finances, so you're the only one who can make the decision!
Craig
I have leased 3 times and gone both ways, depending on the deal (bought the Toyota, returned the other two). $16.8k is within about $9k of what you could probably do on a new '04 Bean from one of the volume dealer, given the incentives, etc. Assuming you will take out a used car loan for the buyout, you might be able to get better terms on a new car loan, and if you were willing to add a year, could probably keep the payments flat. In exchange you get a 3 year newer car, zero miles, full warranty, lower maintance costs, potentially less bugs than were present at the start of the model run, etc. You got 44k good miles from the current car. At $9k to move up, your depreciation cost is reasonable ($0.20 per mile or so). I think there is good economic justification for moving on.
Steve
I won't address the financial considerations either way, as only you know where your priorities are there. But, you commented that you were leaning to buy but reading these posts had raised doubts.
Try to remember that people come to a board like this to find answers to problems, and tend not to post when there are no problems. Therefore, most posts deal with some problem. But for every post about a problem, there are millions (or maybe "just" hundreds of thousands) of others out there not having problems and not posting on a message board.
Every board for a specific make or model reads like this -- even Subaru, even Honda, even Toyota. One key is whether the problems are confined to a couple or several well-known and discussed issues (typical of makes and models with generally good quality control/design) or whether the problems are wide and varied (typical of makes and models with quality control/design problems). (Go read about Chrysler minivan transmissions to really get your eyes opened!)
--K9Leader
2000 OB Ltd (that I bought in March 2003 from a guy who had just bought it off a 3 year lease and then his wife decided she wanted a different color).
Kind of boring, actually. I miss going to the dealer to try and work out problems with my cars. "I love the smell of grease in the morning."
Well, actually the light for my passenger seat heater went out w/in the last month. I wish the driver side would go out too so I can feel more in balance..
Ralph
P.S. After a quarter of its life, my only true complaint with the LLBean is that it leans way too much when corning. Too much lean on the Bean...
LOL!
Lovermont - do you have a bug deflector on your car?
IdahoDoug
It sounds like the mass air sensor is confused and is not telling the computer what is going on. It may also be an engine vacuum sensing problem which would also fail to inform the computer that you want some added power made by the motor.
When you step on the gas, you're really stepping on the "air" mostly. The throttle opens and the engine vacuum draws more air in. The mass air sensor and/or the engine vacuum sensor notices this and directs the injectors, through the car's computer, to supply more fuel to mix with the added air that you allowed in with your right foot. The added air and the added fuel make the engine rev up.
It is also possible that your throttle linkage is not a real metal linkage but rather a "drive by wire" set up that is basically a software communication where the relative position of the gas pedal is communicated to the throttle linkage "motor" and something has gone wrong there.
You may not have a mass air sensor but you have something like it. MAS's work by having a heated element in the air stream and something measuring the heat coming from it. When more air flows in, the heated element needs more electricity to produce the same amount of heat at the heat measurement site. The increase in the amount of electricity required to maintain that heat level is reported to the engine management system and it goes to a table that tells it how much air is coming in and it then directs the injectors to deliver the appropriate amount of fuel. Injectors are highly pressurized and deliver more or less fuel depending how long the circuit is left open, that is, how long are they flowing fuel. An injector squirting fuel for a 1/2 second delivers twice the fuel of an injector squirting for a 1/4 second.
You probably have the latest setup which is injection directly into each cylinder rather than injection into a manifold just upstream from the cylinder.
The dealer has probably seen this before and will provide revised software for the EMS (Engine Management System) computer. My Lincoln had several EMS updates and even a software update for the computer that controls the auto tranny.
This has been the most expensive and troublesome car I have ever owned - other makes have improved their models Subaru has not!!-worse than wifes 96 and I am going to get rid of this problem before they are worthless due to the bad publicity that is starting to develop!!
Good luck everybody!
What is the story of the bad publicity? Do you have specifics on publications that speak of Subaru reliability problems?
Worthless Subarus? Unlikely. Tell me where I can buy a cheap Subaru that hasn't been wrecked.
gearhead4
Was the level just at or below the LOW?? If it was just a little below I doubt its a big problem. I don't think you will have much of a case asking for a whole new tranny if it runs fine and it was only a little on the low side but you could always take it up with SOA.
And run as fast as you can away from that dealer who obviously know diddly squat!
Your dad sounds like he knows his stuff - well done. But I wanted to add / modify a few points:
The hot wire mass flow controllers have a reputation for being somewhat fragile. I believe Subaru (and others) have gone to a less precise but more robust 'lookup table' system for first order fuel approximation based on throttle position. There are dire warnings in the Subi shop manual about never touching the throttle position sensor! Fine tuning then probably comes from oxygen sensor feedback.
Almost all gasoline engines place their injectors in the low pressure manifold, and spray at the backside of the valve. Gas direct injection into the high pressure cyl (like diesels) is still in its infancy.
Steve
Contact SoA about your head gasket failure. Unfortunately it is a known problem on both the older DOHC and the newer SOHC design. They may be willing to help you as by both time and mileage you are not too far out of the 5yr/60k plan. But remember - attitude is everything. We welcome you to these boards to tell us your problems and ask for help. You are more likely to get satisfaction if you show less aggression!
Steve
Had it happen one on of my Mercurys' automatics - the case "wept fluid" Also saw it listed on one of the limbs in a diagnostic "tree" of transmission leaks. So it really can happen.
FWIW - I'd insist on a new transmission - I can't imagine them swapping the case without messing something up.
Larry
-mike
Good question. The individual giving me the incorrect advice was a weekend Customer Service Rep (ie. Counter Person). The dealer actually has a good reputation as far as I know. I've discount the person on the other end of the phone and am giving the dealer's mechanics the bennifit of the doubt. The second reason is I bought the car there and I though I may have more leverage with them instead of some other dealer who didn't sell the car. They have one chance to do right by me.
-mike
Steve
Any insight would be GREATLY appreciated.
If its tsill under warranty and the dealer tells SOA its bust, SOA will fix it, period.
-mike
Folks - if a dealer is fixing something under warranty, and for free, don't complain! :-) You're getting new, zero mile parts for free, whatever they happen to be.
mike: you're 100% correct, my friend. The axle boots on our 626 ripped, and the grease shorted out the 02 sensor and even tripped a check-engine light! We were able to clean the rest of the mess, but it was still a very costly failure.
-juice
beginning to doubt my senses. Has anyone else had this problem? If so I would like to hear about your experience and whether you've found a
fix for it. Again, the hesitation or lurch is upon deceleration, not upon acceleration.
Has the dealer even driven the car? You should get them to reproduce the problem.
Craig
I can even feel this lurch even in my 2002 Forester S with auto transmission.
Here is the cause: newer ECUs are programmed to squeeze the last bits of fuel efficiency and reduce pollution. When you remove your foot from the accelerator, it will agressively cut the fuel. This is less obvious with an automatic because of the torque converter, but it is really annoying and obvious with a manual transmission.
-mike
Since the mid 90's it has been highly recommended by owners of manual trannies fitted to V8 Rovers and Triumphs made during the 80's. Not only does the transmission oil pump last longer, but also it fixes a baulky 1-2 sychromesh. Many people have used it with great success for years, even in autocross and racing applications.
But having said that, I don't think I'd want to put it in any other car unless it was an emergency and it was all I had. And I'd get it flushed out and replaced asap.
Any suggestions?
Craig
