Compare what they did and what was required in the manual.
-Brian
If you didn't authorize the timing belt replacement... they can't bill you for it.
-mike
Dealer coupons in the bay area were running around $500 for the 60k service.
Jim
Greg
This is a pricey region, DC suburbs, that is.
Might be worth me driving up to NY to visit paisan, LOL.
-juice
--jay
Had an '02 with no problems - got a good deal on an '04 and bought it. The very day I got the car I noticed/felt a minor shudder/vibration in the front end when accelerating slowly from a stop. The dealership said that this was just a new car and needed to be broken in. During the second week of ownership I was coming to a stop to turn around and go in the opposite direction. I came to a full stop, shifted into reverse and stepped on the accelerator and there was a clunking noise and perceptable movement/ shudder of something transmission related underneath and up front of the car. I then shifted into drive and stepped on the accelerator and the same noise and shudder occurred. I have not had a similar experience in the 9,000 miles since then, HOWEVER,there is still a minor shudder/vibration in the front end when accelerating slowing from a start and, MORE IMPORTANTLY, when I am at a full stop - with wheels turned to the left for a left hand turn - when I step on the accelerator, slowly, the right front wheel feels as if it is slipping or not grabbing initially.This is not typical of any other '04 that I have tested. The service dept. and lead technician tell me there is nothing "out-of-spec" and if there is something wrong - I'll have to wait till it outright fails--------------because, it is too expensive for them to take apart and search for the problem. I've called Subaru headquarters and they replied that when they contacted the dealership the response was that there was absolutely nothing wrong with the car. Any suggestions as to what the problem may be and what I may do to get Subaru to stand behind this six month old car? The dealership is not interested in keeping me as a customer.
I know the SoA folks post on this board. I would like to solicit their opinion. I am very fond of both our Outback and Forester, but this experience has definitely ticked me off. What (if any) is my recourse from here? I feel like I've been duped out of a few hundred $$$.
That dealer needs one in 3 foot high letters that says Dealer Recommended Service Isn't What the Manufacturer Says is Required!
-mike
There are still lots of dealer tricks out there that not everyone has heard of.
Here's another place to vent, Martijnh (and anyone else who wants to vent about dealers, lawyers, or stale donuts):
pf_flyer "Our Software! Your Questions Answered..." Apr 8, 2004 6:04pm
Constructive comments welcome. Thanks!
I definitely would take issue with the dealer not at least Calling you to say "hey we found the belt to be bad, we are gonna replace it, is that ok?"
-mike
After they reply, you next question(s) could be: "Really? Exactly how many have you seen fail and what does SOA say about all these failures?" or "But if SOA says 105k it doesn't make sense to change it at 60k 'just to be safe' perhaps 90k but not 60k. I feel like I've been ripped off."
BTW would you email me the name of the dealer that did this so that I can avoid them? (I do my own service but I'll still avoid them for parts or anything else.)
Jim
You have to remember that the reason for inspecting the part is to determine whether it is won and replace if needed. Thereofer there is a fair chance that it will require replacement. Frankly, I would rather pay for replacement rather than have a failure. they are very exciting and expensive!
Cheers
Graham
I have a low mileage (<5000 miles) 03 Legacy Wagon which behaves somewhat like yours. I frequently feel a minor shutter when starting out, and when changing from reverse to drive. My first thought was it was still breaking in, but after 5000 miles, it is probably not going to get better by itself.
I don't experience the left front wheel problem you describe... but I also don't understand what you are saying. If you are on slippery pavement, the left front wheel will normally slip, because there is no limited slip differential on the Legacy SE, and the 4EAT trans has a Front Wheel Drive bias until it loses traction to both front wheels. Then it gradually applies power to the rear wheels.
That being said, I still think you and I are experiencing similar behavior that I do not consider normal. I suggest you visit the dealer again. I plan to visit my dealer to address the problem. I will let you know what happens.
Jim (jim.walsh@pop.net)
Anything other than that will be something I haven't seen before, which is certainly possible.
Do the brakes feel good - even stopping, no pulling, no squeaking or squealing, does the pedal stay up?
Leaky places to check for include the calipers on the front, the wheel cylinders on the rear (does it have rear drums?), a weeping brake line - although those tend to leak a lot once they fail, the master cylinder which can occasionally leak back into the power brake unit such that you can't see it but normally the fluid goes down pretty quick and will occasionally get into the passenger compartment.
Is there any way you can give the car a really good look-see (pop the wheels / drums etc) and check for a fluid leak? In 15K of driving, our OBW has gone from being level with the 'Max' line to being less than 3/8's of an inch below it. Still well above the 'Min' line before I topped it off.
I did notice the fluid in the OBW was starting to get dark at 15k, which is sooner than I'm used to seeing that happen. I had the brake fluid replaced (its only $30 for the dealer to do the full flush, not just bleed them).
I would think even if the ABS pump was internally leaking, the brake fluid has to go somewhere. The fact that it happened after the second service (front brakes) would make me wonder if one of the calipers has a slow leak (I'm assuming front disc?).
Also, why were they messing with the seal on the brake fluid reservoir? Was it previously leaking or did they fix it as part of the service? I'm not used to seeing that seal ever fail on any car. I wonder if they were power flushing the lines and over pressurized the seal. I've seen the one man bleeder systems and they're normally low pressure.
Just some thoughts - HTH
Larry
Steve
Anyone with similar problems?
Is this a transmision problem?
Is this under warranty (powertrain)?
I would be very disappointed with the car if this requires an expensive fix and would consider trading it in for another brand...
Any advice welcome.
Don't know where in NYC you're at, I'm in Brooklyn and I take my car in to Metric Subaru in Huntington, LI [appt needed]. I've been very satisfied with their service; you could give them a try for second opinion.
-Dave
Also, with the 60,000 mile maintenance coming soon, does this car have a timing belt, or chain? If a belt, was is Subaru's recommendation for replacement?
I wonder if the PS is covered by the powertrain warranty. Call 800-SUBARU3 and ask.
-juice
-mike
The first steps when there is a problem with a retail transaction is to express your dissatisfaction with the Manager of the dept. (in this case - the Service Manager). If you do not feel that your concerns are addressed appropriately, send a certified letter to the General Manager. Also, let us know. We do report on problems like this throughout the company, but also to the regional offices who discuss the issue with the dealership. Our actions are more related to long term improvement at the facility, but it doesn't do much to help with the specific situation.
The Rep. in CDS will call the dealer and ask them how they intend to address the problem. Most dealers try to do the right thing and resolve the problem. In fact, there are very few that I have dealt with that didn't try to set things right.
So - let us (SOA) know? I am sorry for the situation. It does matter to us and I hope it is eventually resolved.
Patti
Greg
-mike
Greg
Craig
For daily use I just suggest getting stockers (Brembo or Mountains) and replace as necessary, they are relatively inexpensive.
-mike
-juice
-juice
While I had the vent grille out, I moved some electrical connectors away from the supply tube. Through either the former or latter fix the sound went away.
Patti
Tonight as I was putting "olive" to bed, she again would not release the key!!
Has anyone experienced this hell and any ideas on the cause of the problem? Since our car has it's original battery, do you think its battery related?
It's probably one of two things:
1.) There may be pressure on the ignition switch from the steering wheel (from the mechanism that locks the steering wheel when the key is removed). Try moving the steering wheel to the right or left to relieve pressure off the ignition switch, and see if it make it easier to remove the key.
2.) There's a mechanism that will not allow the key to be removed if the vehicle is not in Park (or neutral?). This is most likely the cause since your husband was able to remove the key after playing around with the gears.
-juice
-mike
-juice
Steve
As it turned out, as mike said, I blew the horn/hazzards fuse.
Tell tale signs:
1 - key will not release.
2 - steering wheel will not lock
3 - key in ignition chime [reminder] will not sound when door is open.
4 - hazzards will not work.
-Dave
note to SoA: Add that troubleshoot in Owner's Manual.
It does not happen at any one speed, and the sound cuts in sharply, lasts just under a second then goes away. Sometimes it repeats itself during the commute. There is no change in the way the car feels, or a noticable change in engine speed.
The only sound I could compare it to would be one that the starter makes when you turn the ignition to "start" with the engine running, but quieter.
If anyone has any thoughts, please let me know. I will be calling the dealer tomorrow to make an appt.
