It is indeed a good question.... Trying to determine the torque that was previously applied by using a 'click type' wrench is very difficult to do. You can get a much better indication by going back into your tool box for your old standard 'beam type' and taking the reading off the deflection gauge. Tug until the lug just moves a fraction, and read off the value.
Steve
Steve
I'd go back to the dealer, their work is guaranteed for a full year, FWIW.
-juice
Dealer claims to have never heard of this!!!
Anyone have any experience of this?
The '94 Legacy 5 speed I traded had no such problem.
This makes driving in slow " stop/go "traffic unpleasant.
-juice
HTH, Owen
I have an issue here that is starting to drive me batty.
I currently have a 2001 LL bean. I drove out to see family in Arizona (from WI) in March. While going through Colorado, I started to notice a subtle rattle in the engine compartment. I thought maybe injectors so when I got to Phoenix I took my car in.
It had about 59800 miles on it when I drove onto the lot so I thought that if it were powertrain related it would still be covered under warranty.
It turned out that the timing chain tensioners/pullies were bad and they had to replace them. After 6 days of them having the car, they finally replaced these parts, under warranty.
On the drive home (again in Colorado) I noticed a thunk under the hood while going up a hill on the highway. It only happened once, and the car seemed to be driving fine. However, I stopped at the next exit to check it out. When I was at idle, I noticed a rythmic sound coming from the engine. A check showed that the power steering pully was EXTREMELY Bent. I took off the soundproofing and saw that the bolts holding the pump were loose and that one was missing (obviously had come out and bent the pulley as it did). The nearest Subaru dealer couldn't see it until the next week so I took it to a GoodYear garage. It would take 3 days and $600 to get the part.
Now my assumption and theirs was that the bolts were not tightened/torqued when the dealer in Arizona put the car back together. I also didn't have the time to sit in CO and wait for parts as I had already been delayed in AZ. So they took the pump out and beat the pully back into alignment (kinda) and told me it could fail at any moment.
Fortunately the pump and the pulley made it back home and I took it to Subaru in Waukesha. They refused to fix it and said that the pully was "operating within specs." I called the dealer in AZ and they initially said they would have it fixed and then reversed that when they talked to the dealer in Waukesha whom told them it was "operating within specs." Now they are refusing to return my calls and to fix the pump.
Now, wether or not it is operating within specs or not, you don't fix a part like this by flogging it with a hammer. I feel this should be fixed but I don't know where to go next. The "responsible" dealer is 2000 miles away and I don't see the point in sticking too much money into getting them to fix it as I could just replace it myself. Any info would be helpful
Patti
No matter how tight I manually tighten my lugs I haven't warped my rotors due to it, with an impact I believe you could do it though. What we do at our shop is use impact on the lower setting to snug up the lugs, then we hand torque them down after it's on the ground.
-mike
But no, I don't think I'd pre-emptively sell your car at 80k miles when the gaskets have been fine so far. I have a '98 with 63k miles and it's been fine. In total there are 5 subies in my family, currently, and all 10 of those head gaskets are fine.
When they do go people tend to complain loudly and it might make you think "they all do that", but then how could all 10 head gaskets we own be perfectly fine?
cargeekish: where are you seeing rust? The car is approaching 10 years of age, but I don't recall what the rust perforation warranty covered (perhaps 10 years?). Is it just on the surface or all the way through the sheet metal?
In the pre-galvanized steel days it used to be common, but not so much any more. Most of the panels on your Legacy are galvanized. Did you have any body repairs done, perhaps with aftermarket panels? Or a new paint job?
-juice
-juice
I can't back this up with statistics, but based on the amount of grumbling going on over head gaskets I tend to think that the numbers probably bear out the claim.
-mike
-juice
The car is in the shop today having the rear differential replaced under warranty, the warranty expires next month. (july 2004)
Is this a common problem with Subaru?
It seems strange to me to have a rear diff fail before the tires or brakes are worn out.
I am soooo glad that it went before the warranty expired.
I know there are at least 2 ways of dsiconnecting the DRLs, but I have not done it yet. Anybody out there who is mechanically inclined on how to disconnect the DRLs from 2000 Subaru Legacy Outback Wagon? BTW, I had to have both headline bulbs repalce on 2 different occasions, costing me $47 total. Subaru should really think about the customer first!!! I also have a web link for those who HATE Daytime Running Lights:
www.petitiononline.com/BANDRLs
Karl
Toyota has 'em now, GM has been using them for years, Subaru has them on all models now too. There's probably a discussion on Edmunds where you can debate the pros/cons of them.
There usually is a relay under the dash or in the engine area that controls the DRLs.
FWIW, my 2000 Outback had 'em too and I never burned a bulb out in the 4 years I had the DRLs on. YMMV.
-Brian
-mike
I really believe that DRL's save lives. Even the drunk who comes down the road at 2AM at least has his DRL's on so you have a chance to get out of his way.
This vehicle has been excellent, this is the first problem since purchase, never back to the dealer for anything except the recall for the brake master cylinder back in 99.
Symptom was whining noise in the drive train when using power or coasting, take out of gear (manual tranny) and noise went away. I felt sure it was a u-joint. I was concerned that if it was a u-joint, it would NOT be covered by warranty, but it should since the u-joints are not servicable, must replace whole drive shaft which is balanced, this is moot because they determined the noise was the rear diff.
Sam.
-mike
As for DRL's, I take it one step further and just keep my headlights on whenever I am driving. This is even easier with the auto-off feature for the headlights. I had a problem at the beginning of this year when I had the bulbs go within a month of each other, but since switching to the European bulbs (that I beleive Ken was kind enough to tell me about) I have had no problems.
Mark
other than the transmission concern I am pleased with my new Subaru.
DJB63
p.s. Monday I am going to replace the break in oil with Mobil One.
Craig
With the MT, you can check the gear oil level for the tranny, it's way, waaaaaay down behind the engine. It is bright yellow, at least. ATF is probably in a similar location.
Call 800-SUBARU3 just in case to register a complaint, if it fails at 60,001 miles you should be safe.
-juice
DaveM
Who knows how it was delivered or test driven before you bought it, but clearly their habits may have been different than yours.
-juice
The car is shifting, It just doesn't shift smoothly. IMHO one should not have a thunk/clunk when shifting.All shift points should be seamless. Listening to the engine you should know when the shifting is occurring but you should not feel a thunk/clunk during shifting.
Will re-setting the ECU effect the rough shifting??
DJB
I would still at least register a "customer says" complaint with 800-SUBARU3 in case it becomes a problem in the future.
-juice
Thanks, for the input.. I have re-set the ECU (no discernable difference IMO) but I'll give it a few hundred miles to adjust to my driving style. For the next few hundred miles I will be the only driver and we will see what happens.. DJB
So you should be fine.
Having said that, 29k miles on an RE92 probably means they're far from being in their best condition, and they're not great tires to begin with. So I'd still consider a new set, anyway.
-juice
-mike
-mike
