Subaru Legacy/Outback Wagons Maintenance & Repair
19293959798170
  • zman3zman3 Member Posts: 857
    In Minneapolis I would guess the going dealer labor rate is somewhere between $80-$100 but I don't know that for certain.
    My bill would look like this:
    Parts, $230
    Labor (2 units), $170
    Environmental Fee, $10
    Subtotal $410, 5% tax means total would be around $430.
    -juice
    I've never blead (is that a word?) my brakes myself but I have replaced the pads. I can't image swapping out a caliper being that difficult. I think I would tend to figure out how to bleed the brakes and just do it myself. Spending $165 + a few hours time beats $430.
    Yeah, I have to replace my Miata's top and the shop wanted $85 per hour, 4-5 hours too. So I'm doing it myself, even got a rivet gun. Wish me luck. LOL
    -juice
    Spell check missed that one. I tried. I knew it didn't look right but spell check did not offer the correct spelling. Oh well.
    I must be OLD... I can't stand using spell check...LOL... I keep a dictionary on the desk!
    But back to my purpose... CHAT NIGHT!!
    PF Flyer
    News & Views, Wagons, & Hybrid Vehicles
    The Subaru Crew Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
  • gotnogogotnogo Member Posts: 3
    Thanks for the extra input-I will delve into the matter hopefully this weekend. The starts are not all cold. Can be sitting for 45 min after a drive(engine warm) and won't start. ;)
  • xwesxxwesx Member Posts: 17,697
    The problem I was having was related ONLY to warm starts (anywhere from 5 to 60 minutes after shutoff or stall). So, if it is cold-start related as well, then the problem may be elsewhere or more extensive.
    Good Luck!
    -Wes-
  • nielsennielsen Member Posts: 1
    my daughter is having big trouble w/ her car. I wanted to run computer codes but can not locate the plugs to do so, the local dealer was no help w/ this information anyone out there know where it is located. I also need information on the throttle position sensor,what should the readings be on that? thanks for the help.
  • fibber2fibber2 Member Posts: 3,786
    Unfortunately, a '93 vehicle is not going to be OBD-II compliant, as that did not phase in until a year or two after. I am sure that it has a plug somewhere (Toyota, for instanced, had them somewhere under the hood near the firewall), but most of OBD-I apps were of a proprietary interface that few consumers have access to.
    Wonder if Mike (paisan) would know???
    Steve
    I'm going to guess, but check near the underhood fuse box. Should be near there.
    -juice
  • rossarossa Member Posts: 1
    I have a 1999 Subaru Legacy wagon that has developed a problem at least 6 months ago and as of yet is not resolved.
    The problem is this: when you fuel upm the car doesn't want to start. This only happens immediately following the fuelling process. The only way to get it to start is to depress the accelerator until ignition occursm after which you may have to pump the accelerator to keep the engine from stalling. You can shut the engine off one (1) minute later & it will start fine. Very cold weather has no effect on starting.
    The only time the problem arises is when I or a family member has to gas up.
    Has anyone seen this before?
    Any advice would be greatly appreciated.
    The spark plugs and fuel filter have been replaced but there is no improvement.
    Rossa
    Solution: Never add fuel again, and you won't have any problems starting (at least for a while...). :)
    OK, seriously... One possibility that comes to mind is that something is messed up in the evaporative emissions system. Pumping the 'gas' really doesn't get you more fuel, but more air, as you are moving the throttle plate, and a sensor is then telling the engine computer how long to open the injectors. So it sounds like some signals are getting disrupted.
    Most people 'top off' the tank, and on some GM and other cars this has caused the emissions systems to log a code, and even disrupt normal operation. Have you tried maybe filling up only 3/4 of the way, or something short of full? This would be a good first test. If it runs well, we can then look deeper into the tank venting and monitoring systems.
    Steve
  • brickdriverbrickdriver Member Posts: 1
    My wife bought a new Legacy wagon and wants to pull a utility trailer. I said, "no problem, I can install that." It's so easy to say... I checked the price online for a plug-n-play trailer wiring kit and went to the local parts store. I bought a class II hitch, bolted it on and it fit like a glove. I didn't buy a wiring kit because they said they could only get a generic one that I'd have to splice in.
    When I re-checked online, I found out that I can only by a trailer wiring kit for a Legacy OUTBACK wagon and not a plain legacy wagon. Unfortunately the parts guy at the Suba dealer was surprised to learn the same thing. Is this a marketing thing? Does anyone know if the '05 Outback wiring kit is compatible with it's lower ground clearance sibling?
    Is there a valid reason why we shouldn't tow a utility trailer with this car?
    If I opt to splice in to the tail light wires, are there any precautions I should take to make sure this isn't my most expensive option?
    I am kind of surprised that they didn't address this on the new '05 body style, as this was a source of irritation on the '00-'04 versions as well. OBW's came prewired (you still had to add the interface to drive type 1157 taillight bulbs found on utility trailers), but it was simply plug and play to a connector in the right rear fender well. Regular Legacy wagons required splicing.
    The real problem, IIRC, was that in addition to the signal wires, you needed a fresh +12v supply capable of driving all of the trailer lights (something like 10 amps). I believe that the interface unit also acts as a buffer. It draws almost nothing from the cars lights - just a signal that something is happening, and creates a fresh drive on the 4 pin plug using the new +12v supply. If you simply 'tap' directly into the taillights without this, you might load them down, and some electrical systems really don't like that! Plus, you would have to change the trailer to match the separate turn signals not mated to the brake lights.
    Steve
  • calberscalbers Member Posts: 1
    2001 Outback, 50k miles. After hearing noises when turning sharply (parking spots etc.) brought the car to the dealer in Philadelphia. Diagnosed as leaking DOJ boot... they ordered the part (under warranty) only to find the axle joint needed to be replaced. They ordered the new part and supposedly repaired the axle (also under warranty). My wife noticed the car was still making noises when turning sharply. We brought it back. Service mgr drove it with my wife and said "something is definitely wrong." So they had a look, tightened something (??) up... and said "it's safe, it's normal... blah blah" Now it's two days later, sound is almost as loud as when we first brought it in. And it makes considerable noise on a routine U-turn... no need to turn the steering wheel to the maximum. This next time will be the 7th time I've taken it in in 2 weeks, things are getting time consuming and frustrating. Has the problem been misdiagnosed? Is this a common problem? Are there any possible alternative problems that I should mention to the service techs? Should I take it to a different (and even more inconvenient) dealership? Wife is 7 months pregnant and we're wondering about safety issues as well. Any help would be much appreciated.
  • gearhead4gearhead4 Member Posts: 122
    I agree with fibber2. I have seen this problem before. The temporary solution is, as fibber says, fill the tank no more than 3/4 full.
    The evaporative emissions control systems captures fuel vapors from the fuel tank and stores them in a charcoal canister until the engines draws the vapors into the intake system to be burned. If the the vapor tube pulls liquid fuel from the fuel tank into the charcoal canister, it can cause "flooding" when you start the engine after a fill up.
    The question is Why is fuel getting into the vapor line going from the fuel tank to the charcoal storage canister? On some vehicles there is a purge control valve that could cause this problem. Sometimes, the charcoal canister needs to be replaced.
    A good certified fuel system mechanic will know what to do. The 1999 Legacy is a good, reliable automobile. Many of them have 150,000 miles and are still rolling. It's worth investing in a few new parts.
    Jim W.
  • u_r_a_busu_r_a_bus Member Posts: 3
    I have a 94 Legacy wagon with those pesky automatic shoulder restraints. Both of them have stopped working. My mechanic has quoted me $600 per seatbelt to fix them. Is this a repair that i should be able to do myself? I have found replacement motors for around $200 each. Would it generally only motor the fail? Or are there other parts that commonly fail on these belts? Does anyone have experience with this? Any help appreciated!
    Steve
  • suboutsubout Member Posts: 15
    I have Outback 2005 3.0L VDC. In the morning when it is cool around 50F and I startup the car 1st thing in thing morning. I notice the first few minutes a strong exhaust smell outside of the car if I go outside of the car. This dose not happen on a warm morning. The smell goes away after a few minutes. None of my old cars ever did this. This is the 1st time I own a 6 cylinder with dual exhaust, is that why? Is this normal? Any feedback would be appreciated. Thanks...
  • rprossilrprossil Member Posts: 62
    I'm considering buying an '02-'04 OBW but can't get a completely comfortable driving position because the center armrest is too low. Does anyone know if there is an extension available like for the Foresters or if the one for the Forester or Impreza will fit? I like the vehicle but I need to figure out a way to solve this. Thanks.
  • lfdallfdal Member Posts: 679
    I posted this yesterday, somewhere, but apparently not here????
    Anyway, does anyone have an idea on how much I should expect to spend for a set of plugs installed for an 03 OBW 2.5L? Just trying to get a sanity check before I take it in for some of its 30000 mile work. Also, is there a way to inspect the timing belt w/o disassembling the engine?
    Lastly, where is the PCV valve located on this engine? I think its on top of the intake manifold, toward the back left side of the center. But confirmation's been hard to come by.
    TIA
    Larry
  • bkaiser1bkaiser1 Member Posts: 464
    Most of the dealers near Sarcamento wanted around $80 to do the spark plugs on my WRX...I'd imagine your OB would be roughly the same.
    Brian
    Plugs are not hard on that car, much easier than on the more narrow Forester and Impreza. You have more clearance on the sides of the engine. You do need to remove some intake plumbing and the windshield washer fluid reservoir.
    I'm not sure about your PCV valve, but on my '98 Forester it's pictured below.
    -juice
  • ji11ji11 Member Posts: 3
    I have a 2000 Outback Limited w/72,000 miles and was told today I need a new transmission. The transmission doesn't want to go into drive. Once it gets into gear it shifts fine but it doesn't want to get into drive especially on an incline. Is this odd? I can't help but think that this is a little early for a new transmission. Car has had all maintenance work done by Subaru dealership, including all oil changes. Any ideas or suggestions would be greatly appreciated!
    2003 OBW with 28k - transmission changed due to internal seal failure.
    At least the $ 4200 was covered under warranty.
    juice and Brian - Thanks for the quick response.
    Larry
  • litmanslitmans Member Posts: 1
    i dont have any ideas but i do have the same problem - but for both left and right turns. exact same symptoms - only happens after driving for 30 minutes or so. ive taken it to the shop twice now and they havent found anything.
    Have 2005 Outback Wagon 3.0. It came with Perimeter Alarm from factory.
    Dealer said if I want to add a shock sensor to it, it is a subaru add on.
    I called another dealer & they said perimeter alarm already includes shock sensor.
    I then called a few other dealers & some said it is a add on & others said it's included. Does anybody know the correct answer? Please advise?
    I even called Subaru 800# & got 2 different answers?
    Silly suggestion, but have you tried thumping the windows hard enough to simulate a shock? A couple of taps should be enough to settle the matter, especially if you've had another vehicle with a shock sensor in it.
    Another option is to physically look for the module, but I'm sure you'd rather not be climbing around under the dash just yet :D
  • tbru00tbru00 Member Posts: 2
    I also have a 00 Outback with 73k miles and the transmission that went out earlier this week. I drove the car (no problems) to pick up a friend at a Ford dealership and when we got back in the car it would not go into gear. This sounds like more than just an anomaly. The car has been fully serviced AT the dealer since I bought it. This is very ODD! The subaru rep said they would pay 1/2 but I am still not happy. I wonder how often this happens?
    Call the number above and see if they'll pay for the other half. ;)
    -juice
    Mine ('96 OBW) is often stubborn about shifting to D on inclines... and sometimes well after....
    But, it has done this for the past 100K miles and it has never become any worse, so I don't know any better than to just let it be and deal with the higher RPMs on the occasion when it happens. Usually it is in the same place.... on an overpass after a stop light on the expressway. I stop at the light. Go on green.... am usually at 60 mph by the time I reach the apex of the overpass, and it just hangs out in 3rd until I am part way down the other side of the overpass before shifting to D. If I think about it, I will often manually shift through the gears as I accelerate from the light (2 - 3 - D) and it usually responds immediately to my commands unless I am accelerating rapidly just before I shift to D for some reason.
    When is the last time the tranny fluid was changed out?
    Larry,
    My '02 OBW should be identical. The timing belt cover is split, enabling you to remove a section over the drivers side head. From here, you can inspect about 6" of the belt at a time. Make a chalk mark so you know where you started. You will need a socket (pretty big - like 1.25" ???), a 4" extension, and a breaker bar to slowly crank over the engine a quarter rotation at a time. Then with a flashlight and an inspection mirror, you will be able to see both sides of the belt, and the teeth.
    As Juice said, I had to remove some of the intake tract, and the washer bottle. The job took me a solid hour, so figure labor rate, plus your dealer's markup on plugs. I'll bet $80-$100....
    On my engine, the PVC was not at the end Juice's photo suggests. I have just a nipple there. One of these days, I need to take off the other end and finish the job.
    Steve
    Hey thru00,
    Thank you for your input. I hate to ask, but would mind telling me the name of your dealership so I can ask mine if they'll do the same? My dealership made me no such offer and I wonder if they would if I told them about your dealership. I'm sorry your transmission is broken like mine. I don't know how often this happens, but the company I work for has a 99 Forrester that had a new transmission put in at around 80,000. At the time I figured it was just a lemon and never imagined I would be in the same situation in a couple months.
    Thanks and best regards,
    Jill
    Greensboro, NC
    I checked the transmission fluid level and it was fine. The last time it was changed? Hmm. I would guess either the big 60,000 service (at the latest) or one of the three services I've had since. I'm not sure and unfortunately I left the maint. book in the car. Does changing your transmission fluid make it shift better? Thank you for your response.
  • tickmantickman Member Posts: 16
    I had the same problem. One of the brake lights stays on even with the key off. It turned out that the harness was defective. The car supplies +12V to the trailer harness even with the key off. It appears that the converter box (stuck to the side of the spare tire well) shorted out internally, and started feeding +12 to one of the brake lights.
    If your dealer installed it, they should fix it. I bought mine from an online dealer, and didn't save the receipt. My local dealer offered to replace the harness if I could produce the receipt. Since I didn't want to spend $90+ for the Subaru harness, I bought a converter at WalMart for $15, and spliced it to the 6-conductor cable that connects to the car wiring. Works great.
  • kat95kat95 Member Posts: 49
    I do wonder about the headgaskets failing. Is this a common issue among the 2.5
    liter engines. Do subaru headgaskets fail more readily than other vehicle? What are the signs to look for? I had a 95 impreza with 88,000 which I sold last year and had no gasket problems. I now have an 05 Legacy and hope that I will get many happy miles with it. I do love Subaru, they have gotten me through many
    bad winter. :)
    Call Subaru America at 1-800-Subaru3 get customer service on the phone. They will give you a case number and also call your dealer. That is how I worked it out. They were very helpful and professional on the phone. I expressed that I was VERY upset but I was not rude or yelling.
    Your 95 Impreza probably had the 2.2l engine, only the 2.5l was affected. Even then, it was mostly 99-02 model years, and those are covered under an 8 year 100k mile warranty if you use a conditioner the dealer supplies.
    We haven't seen a pattern of had head gaskets from MY2003 and later, so I think you'll be fine.
    -juice
  • digobwdigobw Member Posts: 4
    It must also be noted that some 2002 head gaskets changed over to the improved gasket. If you have a 2002 and did not receive a notice, pass your VIN to Subaru and verify if you are lucky. My 2002 OBW falls into that category.
    Well, not changing the transmission fluid can allow impurities to build up as well as the integrity of the fluid itself to break down. If any towing, heavy loads, large grades, or extreme temperatures were involved, the problem could be exacerbated. If you don't know that the tranny fluid has been replaced, you might consider doing it just for the heck of it. It takes about 30 minutes and 6 quarts of fluid and most of that time is spent allowing the unit to drain. This is not a flush, mind you, but will renew ~50% of the fluid.
    At this point, I am not sure whether you have a problem or not.... problem meaning that tranny failure is imminent. If you can rule out certain possibilities as the cause then it just makes diagnosis that much easier. And, if you happen to find the cause by sheer dumb luck, WOHOOO!!!! :D
    I like garandman's approach of replacing the head gaskets pre-emptively. Had I found this forum before all the work I did on my engine at 145K, I would have done the same thing (considering I already had the engine out and the head gaskets were provided as part of a full gasket/seal replacement kit that cost me $390!!!!). Eh. Hopefully I can eek another few years out..... 184K and counting.
  • garandmangarandman Member Posts: 524
    do wonder about the headgaskets failing. Is this a common issue among the 2.5 liter engines.
    96-99 2.5 - yes.
    Yes and there are twice as many of them as on an inline four....
    Swings in engine temperature. Bubbling in coolant overflow tank after hard driving. Presence of combustion byproducts in overflow tank and coolant. Cost ranges from $1,200 if it's just the headgsket to $1,600 to replace the seals that often fail as well, to $3-4,000 for a rebuild if the block cracks.
    The engines so problematic are the DOHC 2.5l engines, not sure of the SOHC engine you have will prove problematic. That engine is moving a lot of weight.
    I think our 2002 wagon might also fall under the revised gasket material, because we never got a notice. I should call to make sure.
    2005 and laters models are actually lighter, not heavier.
    -juice
    Ho many miles have you driven yours so far? What kind of mpg have you averaged?
    You bought the "lighter weight" Press Release, I see.
    From various sources, and there are likely different number out there.
    1997 Subaru Outback Wagon Auto curb weight: 3,230
    2000 Subaru Outback Wagon Auto curb weight: 3,480
    2005 Subaru Outback Wagon Auto curb weight: 3,310
    Of course, the 2005 also has three more horsepower, and those horsepower might be bigger, since they cost more.....
    As an aside, despite the porky 200-2004 weight performance didn't seem to suffer much. I did a "roll-on" with a co-worker's 2001 OBW versus my 1997. From about 50 to about 80 mph the two cars were virtually even. The 2005 might be faster at speed because it's a little sleeker, at the expense of smaller interior volume than the 97. You can tell the two on the highway from the rear because the 95-99 OBW rear glass is straight across the bottom and the 00-04 are angled up a bit.
    The OBW has perfectly adequate performance with a couple passengers or loaded around town: I've driven two different 97's over 225,000 miles and I've learned to live with the limited thrust. Loaded on the highway it works much harder and mpg drops. The suspension, however, handles full loads beautifully. Our Yakima RocketBox costs exactly 1.1 mpg, based on a back-to-back trip we took with and without.
  • philliesfan2philliesfan2 Member Posts: 14
    I'm looking for some answers (or reassurance) regarding something that has happened this past week.
    I just had my 03 Legacy Wagon into my mechanic for it's 60K servicing.
    The other day, as I was driving, I noticed the Check Engine light had come on. It stayed on that day and on the ride to work the next day, but when I went out to lunch, it was no longer on.
    Is this something I need to worry about and have checked out or just one of those quirks?
    Thanks in advance for your answers.
    David
  • thallbergthallberg Member Posts: 18
    Does anybody have any information on headgasket failure rate on the 6 cylinder subarus?
    David,
    OBD-II will light the CEL (MIL) and log a code if emissions exceed 1.5x normal. If the event is a one timer, the light will stay on for usually 3 'drive cycles', then go off. The code remains in the log, along with a snapshot of the conditions at the time of the event, for 40 cycles. If it never comes on again, you can probably ignore it, and the log will clean itself out with time. If it repeats, you should get it read out. Possibly something done at the time of servicing is triggering it.
    Check obvious things, like gas cap and oil cap on tight, dip stick properly inserted, vacuum hoses all on tight, etc.
    Steve
  • freeagent10freeagent10 Member Posts: 2
    Hi Everyone:
    I own a 2004 Outback (manual shifter) with 16k miles on it. Since about two months I am hearing a strange vibration while coasting, especially at 4th and 3rd gears.
    When the engine is sufficiently warm, if I am on 3rd or 4th gears and I accelerate to about 30 mph (on 3rd gear) or 45 mph on 4th gear and I release accelerator and coast, I hear a faint but distinct continuous vibration from under the hood (more like "krrrrrrrr"), somewhat like when one holds a leaf against fast rotating fan blades. The noise continues for a while and when I hit the accelerator again, the noise disappears but returns while coasting. In fact I have rolled down the driver's side windows and repeated it and I could hear that vibration on the outside! The car has had no mechanical problems since we bought it new.
    Just wondering if anyone else has experienced this phenomenon.
    Raghu.
  • yessiryessir Member Posts: 2
    Hi everyone,
    I own an 93 Legacy with 145k miles that stalls whenever I take it above 55 Mph. It also stalls if I'm going up a steep incline and the engine needs to work hard. My mechanic checked out the car and can't figure out what the problem is (nothing obvious, I guess). Any Ideas on what could be causing it?
    H6 has been very reliable. There was one single person, suspicously troll-like, that complained about a coolant leak.
    Early one some others experience the coolant level dropping mysteriously, but none of those ever became a problem, and we tracked it for a long time.
    So I would not hesitate to recommend the EZ30 H6, in fact it's one of Subaru's better engines, and definitely more reliable than the EJ25.
    yessir: spark or fuel is usually the cause. I'd guess your ignition wires are old and need to be replaced. I'd look at those first, then the plugs, then the distributor cap and rotor (if that year still had one).
    Miata spark plug wires usually last 30k miles, so at your mileage I'd be on my 5th set by now!
    -juice
