Visitor Agreement.
I don't listen to much that CU has to say. CU was found in court to have made false statements concerning the Trooper in a 1996 story. Based on that and other cases, IMHO their opinions may not be completely unbiased. Hey, I moved up from a Jeep Grand Cherokee. The Envoy XL (in my opinion) works better for us and with the extended warranty to cover most repairs I don't feel too much at risk. With all the gizmos, gadgets, electronics and computers I'm getting a little nervous about owning a vehicle without some kind of coverage.
Some QUALITY pads actually are packaged with stainless steel "shims" that are intended to "shim out" the play in the pads between the stops. I still have a plastic baggie full of various width shims for my Dodge Dakota front pads. Anytime I replace the pads, I go thru the trouble of fitting the shims that result in the least play between the stops. (while still allowing the pads to slide freely on the greased stops.)
I have a 99 Quest withone heck of a odd problem. Recently my father and I changed the front brakes and rotors as the pads were very low and the rear shoes as they were getting low as well. Yet there is a weird problem that not one person has been able to figure out...including the Nissan dealer.
After putting on the rear shoes on both sides we put on the drums and reversed the lug nuts so the flat side would be touching the drum (no tire at this poitn) and tightened them just finger tight.. Then we spun the drum to see if everything was moving freely before putting the tires back on. Well the passenger side was fine but the drives side would only spin for 1 revolution and then the lug nuts in the 4 to 5 o'clock positions would become so tight you couldnt loosen them without the lug wrench and the nut in the 10 to 11 o'clock position would be away from the drum about a 1/32 or so, enough to easily see the space gap.
So we adjusted the tension screw to bring the shoes all the way in with no luck.
We filed the metal edges of the shoe down because we thought they might be dragging because we saw some shiney non-black areas after the first couple of spinning attempts but no luck.
So we thought the shoes were not the same but both sides match in length and width and match the old ones except in length the new ones are about 1 inch longer.
So we thought the drum might be out of round so we swapped drums and again no problem on the passenger side but the same problem on the drivers side so the drum is ok.
So we took the shoes off, checked behind them etc and there was no debris and we checked the backer plate which seemed ok so we put the shoes back on again and still the same drivers side issue.
So then we thought the bearing had been extened too far and had wedged itself sideways in the shaft so we took a look at that and all seemed ok. We did not take the bearing out because then you must replace it and it is self-contained and cant be "repacked" or so we were told by Nissan dealer. But there were not burnt areas and it seemed in the correct position.
So we put everything back together, drum still stuck but I drove the thing down the road anyway and the wheel did turn and the brakes worked but the drivers side drum gets REALLY hot as compared to the passenger side drum.
So because we ran out of ideas we have put the old shoes back on the drivers side and are looking for some...any... ideas. The local parts guy made me promise to tell him what it turns out to be as they are quite intrigued at this point.
One thing is that when you beat (and I mean really hard on the drum) with a hammer after you reach the "no more turning freely point" you can get the drum to turn another 1/4 turn or so with "each beating" but it is very difficult to turn and only my father can turn it I am not strong enough. When you first tighten up the lug nuts finger tight you can get one full revolution but then no more unless you really wail on it to get the xtra 1/4 turns.
We are at this point thinking the back plate or axle is off but it works fine/spins-freely when we put the old almost spent brake shoes on, which are the same width as the new shoes but an inch shorter than the new ones.
We didnt notice any undue wear on the inside face of the drum either. But we did notice that the shoe in the most rear position was wearing funny on the bottom side, the innermost area on the pad (at the very bottom closest the backing plate) is worn about 1/2 inch up in an excessive manner but on the outermost bottom area is worn 1.5 inches up the pad in an excessive manner like it has been sheared off or someone filed it...but you can see the wear lines so it wasnt "sheared" per se.
We seem to have stumped everyone we have spoken to in our area and any thoughts are greatly appreciated.
Jenn
PS Also the front brakes get very hot now and smoke when I drive through puddles of water. Is this normal? (The pads were very low before so that may be why I never noticed before and the calipers are functioning fine ie not stuck open from formerly low pads etc)
Also, have you checked the runout on the spindle? you did not say if you marked the spot that sticks and if it is the same position on the spindle (even if you remove the drum and put it back on in a different positoin)... I am willing to bet that it is!
Now that you have driven it for awhile with the problem, you may be able to remove the drum and look for evidence of where things are binding/rubbing. That may clue you into the problem.
Also, I have seen a sticking parking-brake cable cause goofy problems with drum brakes. You can try REMOVING the parking brake cable from that side and see if that changes the problem. (at least you could rule-out that as the problem)
I just completed a front brake pad and rotor replacement on my 99 Protege. It was the first time I have done anything on a car other than changing the oil. In the course of working on the left side (after I finished the right side) I realized that I had only installed the single anti squeal shim on the right set of pads, and no other shims. On the left set of pads I wound up installing one shim on each pad. The end result is that I have 2 shims on the left side, and one on the right side. Will this cause uneven braking? When I press the brake pedal do the calipers "squeeze" the same amount/distance? If so, is my uneven thickness (1 shim v 2 shims) inside of each caliper going to change how much braking is occuring? Thanks for your help.
I know that it's straight forward, but is there any special tools that I will need?
I will be changing my girls pads at her place, so I will be hauling my tools to her house. I just don't want to be stopping every 5 minutes to go to the parts store for a tool.
Thanks to anyone who has some answers or suggestions. have a nice day!!!!
http://www.autozone.com/images/cds/gif/medium/0900823d801e10b4.gif
Took it to the dealer several times while it was under warranty and got the same answer that the brakes are fine and the metal pads tend to squeak when it's wet out. (Just for info, they sqeak ALL the time, wet or dry.) So, assuming that's accurate, is there anything that I can do to address this...at this point I'm willing to change out the brakes even if they're not worn out yet, but I don't want to put a stock brake in that I'm going to have the same problem with in 20k miles.
Any suggestions?
Certainly installing quieter pads would help.
I am more concerned that your rotors may be "grungy". Have you tried "letting the smoke out" of the pads? This consists of several VERY HARD stops to get the brakes hot enough to get smelly. This should be IMMEDIATELY followed up with at least 20 minutes of continous non-stop driving to cool things down. Often this will quiet down noisy brakes. I find that I have to do this every couple months to keep my rotors clean. (my normal driving habits do not use the brakes very much.)
If I do choose to have quieter pads put on, how would I know what to select? What's "safe" on an A6? I'm afraid that if I take it to a mechanic and ask to have the brakes changed without knowing what I should be asking for, I'll end up with the same problem...or worse.
Thanks again...I'll let you know about if the HARD stops work.
Another thing I like about the Raybestos QS pads is that they are CERAMIC based pads. This means that they will not leave nearly as much black crud on your wheels as the metallic pads do.
Here is a link to the Raybestos website so you can read about them.
http://www.raybestos.com/
Could it be the "warning" device that tells you your brake pads as getting worn down?
I need to replace the disc brake pads on a 99 Jetta. Is this a simple job as it appears, or should I take it to a shop? Any tips/experience/advise would be appreciated. Thanks, Jim
We have put new brakes on it- and they worked fine for about a year- then one day i was driving and the brake pressure was completely gone i pumped them and still nothing. We were told it could be the master cylinder- we replaced it and bled the lines as we were supposed to. Still didn't solve the problem. When i start my car, i will pump the brake pedal before i start it to get pressure- then i'll start the car, and all the pressure is gone. Or i'll pump them, then step on them again, and it's gone. Some people are telling me it could be my vacuum/power booster.
I'm about to go crazy as I really need my car!!!!! Can anyone help me?
Jennessa from Valparaiso IN
You either have air in the lines (improper bleeding), a hydraulic leak at some place other than the master cylinder, or another bad master cylinder out of the box (it happens).
So first check everywhere, at all the wheel and at the Master Cylinder, for fluid loss. If you have no fluid loss, POWER bleed the system. If that doesn't work, replace the master cylinder again.
OC
Please tell us WHY you have researfaced twice and replaced once the rotors?
I have been working on my own brakes for over 20 years and have lived thru the headaches of trying to save a buck by installing el-cheepo rotors. In the long-run, it costs MORE because they will either warp or rust within a couple years.
SUGGESTIONS:
1) Make sure that QUALITY rotors get installed. (Raybestos, Bendix..etc)
2) Make sure that wheel lugnuts are always tighted with a torque wrench to spec.
3) Make sure you take the time to "season" the rotors before "bedding" the pads.( http://www.shotimes.com/brakes/part1.html )
Raybestos "QS" pads would be my choice. (QS means "Quiet Stop") The "bonus" is that the "QS" pads are CERAMIC BASED... so they do not make nearly as much black dust on the wheels.
Here is the Raybestos website: http://www.raybestos.com/usa/brakepads.htm
Oh, I'm in the Minneapolis, MN area, Galant is 2001 ES 2.4
