Dodge Ram: Problems & Solutions
Any advice would be greatly appreciated.
Now the question - can I tighten/adjust this rod or is it best left to dealer/warranty work? if simple I will try it, otherwise I am planning on an appt next week, since thats what a warranty is for anyway.
Thanks for any replies on this,
Ahasher
Good luck,
Dusty
I am having the same problem with my 03 Ram 1500. A whistling noise is coming from underneath the truck. This has been happpening for close to three months now. The dealership does not know what it is...any ideas? Vacuum leak? The noise only occurs when I accerlate, it is very annoying.
What is the play in the clutch fan?
Tony
The noise only happens when i am accelerating, it is loud, and it is driving me crazy.
Can annyone help me? Vacuum leak?
HELP!
kcram - Pickups Host
Also, I have a question about the tranny (big surprise). The stock 318 is a total slug and when I use the O/D, it kills what's left of my power. Am I doing harm by not using the O/D? The only time I can stand to use the O/D is on level roads and there aren't any of those around here. As soon as I get into a climb of any grade, it drops down into passing gear and at 12.5 mpg, I'm not willing to give up much more to lack of power. So I end up driving everywhere without O/D and it seems fine. Plenty of power, responsive and not lugging. Any comments?
One question though, I use Mobil 1 and I am wondering how long do you have to wait to change it. I mean the oil itself seems to be in one color off brown, meaning not too dark and not too light. I have put about 5 thousand miles on it, should I change it. My brother was telling me I should wait till it reachs 7-9 thousand miles before I should change it. Any thoughts are appreciated.
After 2001 all Dodge truck transmissions must use ATF+4 (not ATF+3). I'm suspicious that Dexron-Mercon was used instead. Don't wait to resolve this. Continued driving on the wrong fluid will end up with a transmission failure.
Good luck,
Dusty
You beat me to it! Such a common problem. You must have it flushed with ATF+4, not just drained and refilled. Treat this very seriously.
I will say that one local independent has a sign visibly displayed at their shop advising people of the special fluid for Mopars.
Best regards,
Dusty
What did you find out...I do not see any answers to your issues. We have the same issue and are absolutely baffled! Both of our most excellent mechanics can find nothing wrong. I drive this van with 4 kids in it and we love it. When this happens though...it freaks us out. It is completely arbitrary. May happen one day and then not for 3 weeks. May happen two days in a row. It usually starts again within 15 minutes but last time it took overnight. We are deperate for answers. Happens when driving 40 mph or sitting at a stoplight. Have you discovered any answers?????
We have a 1999 ram 1500 w/60,000 miles. Runs great but dies periodically without warning. Will restart after 10-15 minutes. Not fuel pump issue, our mechanics can find nothing wrong. May happen one day and then not again for 2 weeks. We are baffled as well and desperate for answers.
We are having similar issues and it is freakin' us out! Also 1999 Ram 1500 - has 60,000 miles. It runs great - but may just up and die at any time...while driving 50 mph or stopped for a train...we never know. May happen one day and then not again for two weeks. Both of our stellar mechanics can find nothing wrong. Fuel pump is good, has been replaced, engine tuned, well maintained. It rund great except for this issue. Any info you have would be so appreciated!
I am wondering about the Ram 1500 cutting off. I saw your initial response to a similar question noting that the problem could be the fuel pressure regulator, timing chain, PCM problem. Both of our most stellar mechanics can find nothing and the fuel pump is fine. You mentioned an inlet strainer - would that be something a mechanic would check automatically when looking at the fuel pump?
We have a 1999 with 60,000 miles. It runs great but loses power arbitrarily...could be driving 50 mph, could be sitting at a light. It may happen once that week or not for a month. It is unpredictable. It typically start right up after waiting 5-10 minutes.
I am interested in the NO BUS conversation I saw. We do not get this as our odometer is not digital - but it makes me wonder about the computer related issues. We do not want to get screwed by a dealer on the costs of fixing this problem but would like to appear educated on this possibility.
Do you - or anyone- have any insights?
The van was just not right after that. It would cut out everytime I turned left onto a new street that had lightpoles similar to the one I hit. Stupid van dying out forced me to stop eating while driving cause I had to be ready to harness that sucker when all power cut out.
My mechanic said he thought the van was afraid of lightpoles and that's why it cut out. Hope this helps out.
Dan
Florida
Now I've got a new one. Check Engine light is on as well as "oil can" indicator light. Oil pressure is fine, getting a 12 ,14 & 15 code. With all these things at once I suspect the computer. :-( any ideas??
I've got a couple of creases on my right rear door I'd like to remove
1) how hard is it to access the metal by removing the interior door assembly?
2) are those paintless dent repair kits worth trying?
Thanks for any tips.
Has anyone every replaced their factory gauge faceplate with an after market one. I purchased the reverse glow (white face during the day, black face with lit up gauges during the night) for something different to look at. Is this a pain in the neck to switch out? Any information would be greatly appreciated.
Thanx,
TO
PS: this is a '98 2500 w/cummins diesel and Dana 80 rear end.
There are a number of things that could be causing your problem. It would be nice to know if this vehicle is producing a trouble code or illuminating a "Check Engine" lamp.
Dusty
Good luck,
Dusty
Rocio
Have a problem that hopefully someone can help me out with. Here recently for some reason the air flow when the air conditioner is turned blows very little out of the vents and seems to come out the floor more than anything. Just curious if anyone might have some insight as to where I might start to troubleshoot this problem. The sound of the air conditioner when turned on sounds the same as it always has but just no real air flow coming from the vents. For those that live down here in the south know how hot it gets and summer is just about on top of us and would like to get it taken care of. Any and all help is appreciated.
:confuse:
