Dodge Ram: Problems & Solutions
The problem is that the ABS wheel speed sensor's electrical connections are open or corroded, rusted or not making a proper electrical circuit to the ABS electronic system. The Dodge Ram 2500 1996 manual states that the ABS system is an option. Your brakes will still work without this feature. The only thing that bugs me is the dash warning lights are on. The ABS system will not work when this condition exists.
Dave
Anyhow, the truck seems to run fine, but I find I'm constantly looking at the DUMMY LIGHTS to see if they dim. Think I'll try the other suggetions I've read here regarding the Speed Sensors, etc.
Bob
Here are a couple of links that may be helpful. http://www.swedishbricks.net/700900FAQ/BrakesABS1.html
The first is a VOLVO link but lists a lot of good info. Especially for my very rusty rear wheels! I noticed while driving over a large hole this summer that my ABS warning light problems disappeared, for a while! Anyway, now I'm thinking rust & metal fragments contaminating the magnetic wheel sensor's ability to send a proper reading to the computer.
http://autorepair.about.com/library/faqs/bl923f.htm
As to the rear axle gearing and limited slip, open the glove box door and you should see a label affixed to the inside. This lists all major mechanic equipment.
Dusty
I once owned a Ford F-350 dually with the 6.0L diesel. On one trip home from the construction site, the truck started to make strange noises (whomp-whomp). I was on the I-90 Mass Turnpike and no way of stopping. So I drove about another 3 miles to pull over on the shoulder. As I did this, the truck completely died. Mind you this was a 5-month old truck. One of my employees was also coming down the pike and he pulled over to see what was wrong. He and I couldn't determine what intially happened, so I had the truck towed home. The dealership was closed, so I couldn't take it there. The very next morning, I phoned the dealership and they said that they will come and tow it in. So at about 4 pm that day, the service manager called and said that I "locked-up" my engine. WHAT!!!!!!!!!!!?????????????
"Yes SIr, your motor is destroyed and the estimated repair bill is about $18,900" No way. I told him were you aware that I just got my truck serviced from you guys 2-days ago? He was not. But he said even so, they weren't responsible . So to make a long story short, I got in touch with the district guy. Didn't work. Got in touch with the head of service at Ford. Didn't work. Called International who supplied the diesel to no avail. So I invoked the lemon-law. Within 2 days, Ford said they were ready to settle this matter. They were willing to install a new diesel but use the same old turbo. NO WAY. For all I know, it could have been turbine failure that caused the engine to go kaput. They didn't want to put a new turbo on, so I told them that I was moving forward with my suit. 1 day later, they were ready to repay all monies that I paid for the truck($48,988) plus all ownership cost in the previous months($3718).
So my advice to you is to get tough with these people. Hope this helps.
Axle ratio, differential size in inches, and limited slip
Dusty
Pull the ABS fuse and see if the problem remains.
Dusty
P.S. Nice looking RAM!
Two weeks ago, I, was driving home from Bloomington, Illinois and the transmission quit working. It did not make any noises or anything. I have tried to get it to shift into any gear, but all forward, reverse and park does not engage.
What happen to your transmission? I have a 2000 4X4 Dodge Ram 1500. I have also heard that Dodge knows about this transmission problem and is failing to notify about it, (this could be just a rumor). Also have heard that a worm gear goes out in the rear section of transmission due to a snap ring or cotter pin breaking in the gear.
A friend of ours had also the same experience with his 4X4 Dodge Ram, the transmission quit while driving down the road.
Answer to your question; (Yes, this might be a Lemon :lemon: Law problem and some indepth research needs to be done into this).
BassMan (Central Illinois)
Thanks Travis
More to your diagnosis. Can you detect fuel pressure(?) or flow from the tank pump?
Is the vehicle fuel injected or carburated? Fuel injection rails have high pressure fuel lines requiring a 40-70 PSI fuel gauge. Carburation takes lesser pressure 6-10 PSI fuel gauge.
Any in line filter you can open to see if fuel is moving? An electric pump will push fuel without the engine cranking. A mechanical pump needs the engine cranking. I had a Chevy diesel suburban that had an electric pump in the tank and a mechanical pump at the engine block. Push/Pull. I had a pinhole in the bottom of the mechanical pump and the electric pump would force fuel out in a strong stream with just Ignition on. (That too was a warranty claim)
Can you hear the tank pump run up pressure? when you turn the key from "off" to "run" before engaging the starter?
My thought is once you run them dry, Chrysler, has no confidence in tank pump.
Dusty
First time forum user, so please forgive my ignorance in advance. I have a 2001 Dodge Ram 2500, with what appears to be a trip computer problem. At any time, the trip computer will error out with a "C Cd" on the display (for all of the display options) and then go back to the normal display (for all the display options). I have tried to correlate this with a specific action or time, but it is totally random, but seems to be happening more and more often. Any help would be appreciated. Thank you!
It turns over fine but will not fire
my mechanic found out if you turn the key on and wait till the lights and alarms go off you hear a clicking noise, when it stops then start the truck.
well that worked last spring. it was ok all summer, but now I have the same problem when it's cold.
we replaced a relay but same problem.
Anybody know what's wrong?
Ron
I sorry that it has been a few days before I could send this to you. I was wondering what fuse to pull because I don't have any I don't think. I have made a Fuse and Relay diagram for you so that maybe you could help me out. Thanks for the help and I hope to hear from you. :shades:
P.S. The one's with stars next to them are the places were there is a fuse or relay.
Bought it used 7 months ago.
Started out driving to work today no problems. Stopped and turned truck off. After 10 min tried to restart truck and it turned over and tried to run but acted like it had no fuel... chug, chug chug, die. After a few attempts it was a lost cause.
Checked a bunch of stuff and then Called a friend and chain towed it home, got it to the house and now when I try to start it, it will roll over but no chug, chug at all... just rolls and rolls.
I have checked fuses, relays and made sure I had fuel in the tank.... I am thinking it is the fuel pump or sending unit. I don't have a book and can not afford the $25.00 they want for one. Looking for any other ideas or suggestions.
New pump costs near $225.00 at autozone...
Anyone do this replacement before? is it something a handyman can do? I can not afford the cost to have the shop do the work but am pretty handy if I can find a cheap How to book (checking the library tomorrow) or know what to watch out for. I would figure someone on the world wide web would have published a step by step on this but I can not find one.
Any help, suggestions or advice would be great.... I can walk the 8 miles to and from work for a while but with bad weather on the way I need to get this truck fixed.
Thanks in advance,
Chance
sensor? I have the same problem as big_jt, only I have a '98 1500Ram. My ABS and Brake light both went on at the same time, and my speedometer does not kick in until I reach 25 mph. Also, hard is replacing this part? Please reply as soon as possible, as I only have one week to find a sollution before I am forced to sell my truck...and I DO NOT!!!! want to sell it. 'Only' has 110,000 miles on it, and I love it with a passion!
in the mean time, heres a few pictures. *cry* i will miss my truck if I have to sell it.
awww, the good and bad memories alike...
ohhh ok Ill stop. who knows, maybe someone will find pity in my poor soul and help me out. Well...thanks!
The RAM has a 4100 to 8850 pound towing capacity to the Tacoma’s 3500 to 6500, and a bed length of 75.9 inches to 98.3 compared to the Tacoma’s 60.3 to 73.5 inch bed. You could’ve put that little truck up against a RAM 3500 for all we know. Heck, even the V6 RAM is rated to tow a Tacoma behind it. Comparing a 265 HP Tacoma to a 345 HP RAM is comparing apples to oranges, a sphere-like shape being the only common feature.
But as one other poster mentions, most RAM owners bought them to be a truck, meaning to haul things bigger or heavier than the capabilities of a Tacoma. The Hemi engine in the RAM was designed for power, not necessarily speed. The fact that the RAM when compared to other FULL SIZE trucks does so well in performance is an artifact that cannot even be measured in Tacoma terms, and a justifiably proud tribute to Dodge-Chrysler engineers.
Dusty
