Dodge Ram: Problems & Solutions
I have a new 2006 Ram 1500 ST and mine did just about the same thing. I turned the ignition switch and the lights started flashing, the horn honked one long continuous blast for about 15 seconds, the interior and cargo lights came on and could not be shut off and finally the "door ajar" light came on and would not go out! The truck was doing all this even after I removed the key from the ignition. My truck doesn't have an alarm either. Incidentally, this has happened twice in the last three days. It was a freaky deal to say the least. Anyway, I had to disconnect the positive battery cable to restore everything to normal. I called the dealership and talked to the service guy and he didn't have a clue as to what was going on. I went and checked to see if there were any recalls on my truck, but there were none. You may wanna google for any recalls on yours. I'm thinking it has something to do with the computer, but I'm not sure. I just wanted to let you know that you are not alone with this issue.
If anyone else has had this or a similar problem, please tell me how to fix it. Thanks
I would also suggest going back to the places where you had your oil changed. They may have computer records on their customers and they could give you duplicate receipts. It is worth a try anyway. If they are too far away, call them.
-Brett
I don't know what you mean by the 545RFE "has been dissed," but I'm here to tell you that this transmission is one of, if not the most reliable LD truck automatic on the market. Complete failures are almost non-existent and non-debilitating problems are also quite rare. My transmission guy tells me he's fixed one 545RFE in a 2000 Grand Cherokee, and that was two years ago (broken sun gear).
I'll tell you that the 545RFE is tough, durable, and more reliable that anything from GM, Ford, Toyota, Nissan, or Honda.
Dusty
There is a TSB that calls for a new fan, motor,shroud, A/C recharge,wiring harness, and computer reset. After computer reset the condenser fan runs all the time when the defroster is on.
Thanks for the reply. Appreciate your comments.
First, we need to clarify the subject. The TorqueShift transmission I believe your referring to is the five-speed 5R110. That transmission was introduced in the Super Duty line in 2004. Like the 545RFE was for Chrysler, this model is a new transmission design and I believe only available on the F350, or it might be an option on the F250. I'm not sure.
Today and since '97, the F250 gets the four-speed 4R100 as standard equipment. Before 1997 the F250 & F350 transmission was the E4OD. Until the introduction two years ago of the 5R110, the 4R100 was also the transmission found in the F350.
So, if we are talking about the 5R110, this transmission is too new to have established anything but a good record, so far. I have not heard of one incident of complaint regarding this new model. I believe there was at least one TSB issued for 2-3 flare, but I also think that was computer related and not a problem with the hardware. From what little I know it is a heavy duty transmission that bears respect. Time will tell.
The 4R100 is a different story. While I agree it's a very heavy design, there is a one problem that is not uncommon and extremely debilitating. The torque converter clutches on this model are prone to over heating. When they get hot enough they come apart and flood the front pump with debris. The front pump shuts down and within a minute the clutches are destroyed. Of course, without a front pump there is not enough line pressure to operate forward motion.
While the basic archetecture of the transmission is solid, this one weakness in the 4R100 design makes for catastophic failures that are common enough. For this reason I see a number of failures and rebuilds of 4R100s.
Comparatively the 545RFE, which is used on RAM 2500/3500s, have seen hardly any failures or even problems for that matter. Is the 545RFE as beefy as the 4R100? Probably not quite, but used behind their current gas engines in the RAM series they have proven to be far more than adequate and far more reliable. (The 545RFE is 70% overrated behind the 4.7 motor.) The maximum torque handling capability transmission in Dodge trucks is currently the 48RE, which is only used behind the Cummins motor.
Chrysler halted work on a high torque 545RFE variant a while ago, their plan was to use that behind the Cummins which today does not have a five-speed automatic in a Dodge LD pickup. However, I have reason to believe they shifted gears (pun intended) to design a six-speed heavy duty series based on the 545RFE that could be used across the entire RAM line, gas or diesel, as well as their new line of medium trucks that will be introduced in the near future.
Best regards,
Dusty
The 545RFE HAS a dependable track record. I simple feel that it hasn't the beef to handle serious towing loads in the heavy duty lineup. The G56 manual with an aluminum housing is 50# heavier than the 545RFE. Normally the manual in any powertrain configuration is lighter than the automatic. Like I said, I'm not knockin' the 545RFE reliability at all
I think you'll find the 4R100 four-speed is still available in the F250. Just saw one in a 2006 yesterday.
Bests,
Dusty
My truck shifts into second and then goes right into 3rd.
I does not want to stay in Second. It downshifts into first way too easy and also if you put the truck manualy into second gear whether upshifting or downshifting, It stays in first gear with the exception being that it coasts. it doesn't downshift. it coasts untill you step on the gas and the revs come up to where you would be in first gear. So manualy
there is no second gear. Letting it shift by itself there is second gear, but it won't stay there long before it goes into third. It shifts into third like its sliding into third, but it does not slip if I floor it.
Anyone run into this weird problem. Just bought the truck last year. and it just started doing this.
I could not get any error code, but I may not be doing it right.
If someone can tell me the correct way, that may help also.
Paul
Paul
I also have a 2003 2500quad cab 4x4 CTD long bed, I am also having this problem usualy between 50 mph and 80 mph but only happens once in a while the shaking from side to side is so violent the only way to stop it is to pull over and stop. I also am looking for a solution.
Thad
You have a 46RE transmission. Based on the symptom set you wrote, a number of things could cause this:
1. Low transmission fluid level
2. Partially clogged anti-drain back valve
3. Dirty transmission filter
4. Throttle linkage out of adjustment or binding
5. Throttle position Sensor irratic or defective
6. Gear shift cable loose, binding, or out of adjustment
7. Sticking or defective shift solenoid
8. Dirty valve body (various components sticking or inoperative)
9. More serious stuff: front band, clutches worn, sticking servo plunger, weak pump.
I would suggest that you have a dealer scan the computer for codes. This may tell you something.
Good luck,
Dusty
FROM TIME TO TIME I GET A VERY VIOLENT BOUNCE FROM SIDE TO SIDE seems to happen at highway speeds and only on the highway there is no pattern the only way to stop the bounce is to stop the truck not even slowing down stops the bouncing
any one had a simular problem? and if so how did you correct this ?
I have had it to the dealer a few times and they cannot find a problem.
This dont happen all the time but when it happens it is very very bad almost as if the wheels are coming off the ground..
The problem is that the clutch disk material is perishable. A really bad driver (not you) can destroy a clutch in a matter of weeks. It's like brakes. Some people can nurse them 40,000 miles, some others (same car) onlyl 15,000 miles. Taxi cabs in big cities wear them out in 6 weeks!
By competent I don't mean WalMart,Firestone,Goodyear etc....find a shop that does nothing but suspension and alignment.
I've had several people say that the trannys in these trucks have problems. Is there a history of this? Is it the case with both manual and automatic trannys? Is it a problem in only certain years or is it across the board???
Thank you for the information. I wonder if you have an answer for my problem with the Dodge 484E transmission on my 04 Cummins Ram. At 65 MPH it seems to drop into a lower gear or out of overdrive. The RPMs go up from 2100 to over 2500 and the truck slows down. My truck has 37000 miles and this has been going on for 10,000 miles. There was a serivce bulletin on this and last November my dealer made some sort of adjustment inside the transmission while they were doing the 30,000 mile service. I don't exactly know what they did but it only worked for a month. Now they cannot reproduce the symptom and probably think I'm nuts. I am not a mechanic and don't understand what the problem was supposed to be when they "fixed" it. The truck is serviced at all recommended intervals by the dealer. Any help.
Ken
How have the trucks been maintained? Do you know the service and maintenance history on both vehicles? Have you obtained Carfax report on them?
Why does you mechanic say the Dodge will be a hassle? Has he inspected both vehicles or does he just happen to be a Ford fan?
As for auto versus manual.....consider the hassle of driving a manual in stop-go traffic in a daily commute if you have that situation. Also, in 45 yrs of vehicle owner ship I can tell you that I have had exactly 2 automatic transmissions rebuilt and even by taking my shoes off I can't count the number of clutches and pressure plates I have replaced
It seems that the vent system only circultes air if the fan is running. Manual says there are settings to allow free flowing air and exhausts somewhere behind the rear seat. I've tried all possible settings and can't get any flow w/o fan.
