The first thing you notice is that every weekend, someone you know (relatives, friends, people who want to make friends because they need you...) will need your truck to move something. Sometimes, the really bold ones will want (expect) you to come with the truck. Set your "I don't lift furniture, haul antiques, or tow farm implements" policy early, and stick to it.
Obviously, with 80K miles in two years, I've spent quite a bit of time in the truck. It works well in traffic, is comfortable on the highway, and really handles O.K. It's a bit harder to find parking, but you'll adjust. The gas mileage sucks, but you have to have already figured that out. The rear wheels spin on wet surfaces at takeoff sometimes, which will be another adjustment in driving style.
The incentives are great on these now, and they're really quite affordable. I'm about to move back into the sports sedan category, but it hasn't been a bad couple of years with the truck (although my back is still aching from the weekend chores of my friends).
Good Luck.
Just a reminder that our Town Hall chat happens on Wednesday (5-7pm Pacific/8-10 pm Eastern). This week, our topic will be:
Import Trucks: Can they compete with domestics?
http://www.edmunds.com/townhall/chat/newsviews.html
PF Flyer
18- 3.08
19- 3.55
26- 3.73
27- 3.31
H9- 3.55LS
B6- 3.73LS
18- 3.08
19- 3.55
26- 3.73
27- 3.31
H9- 3.55LS
B6- 3.73LS
Sometimes I've seen this sticker not have the axle code listed.. There's also a tag on the rear diff as well..
Thanks Everyone!!
We are looking for another truck but since its been so long with this truck, we are not sure if we should stick with a Ford because of the great luck or possibly buy a Chevy.
Anyone have any opinions? We are listening.
GMC/ Silverado seem to be the "King of the Vibrators". The mediocre reliability of Dodge pretty much rules it out. Good luck.
I've never had the shakes in my Chevy cept when it was heavily loaded. When loaded the rear half of the drive shaft is at a bad angle to the pinion gear. It does seem like a bad design to me. I've read that the shakes seem to be in more 4x4 GM trucks than the 4x2's.
I lowered my Super Crew 2 inches front and back. i did have to correct the pinion angle to stop a vibration in it.
The Tundra has been great so far, plenty of power and runs real smooth. I hope it lasts as long as my 86 F150 did.
How is the reliability? (Visits to shop)
How is the ride? (Esp on highways)
Comfort (Ive noticed the 60/40 bench seats are horrible)
Any thoughts on pros/cons on F-150 over Chevy, Dodge, and Toyota would be appreciated.
Thanks in advance!
Quite happy with both trucks. I am a GM guy for 4 decades. I beleive I like the Ford over the Chevy now. The ford is a Lariat which has a higher level of options than the Chevy.
The chevy averages about 1 mpg better than the Ford. The Chevy will out pull the Ford, but the chevy has a lower rear end gear(3.73 vs 3.55 Ford).
Both trucks ride about the same. I did lower the Ford 2 inches front and rear.
We have the bucket seats in the Ford and they sit us real well. We are not tall people though. I am 5' 7" soaking wet and my wife is 2" shorter.
The Ford's adjustable pedals are great for us. We can leave the power drivers seat in nearly the same spot and my wife moves the pedals closer and she is set.
We have the bucket seats in the chevy too. They are comfortable, cloth not leather stuff like the Ford.
THe chevy(25k miles) has only been to the dealer for the little recall stuff they mail to you. The Ford(10k miles) has only been back to get a new key ($78.00 transponder type)that must be programed to the trucks computer system.
If you BUY a new Ford truck get and extra key programed to the truck so you have "3" good keys!! The truck's on board system will program a new key IF you have TWO functioning keys. loose a key and only have ONE key.... you must go to Ford to get a key.
After market locksmiths may have the computer system to program a new key like Ford, but the guys I called wanted $150.00 and up for a new key that cost $78.00 from Ford. For regular dupicate key the locksmiths want around $25-30.00 if you have TWO good keys for your truck.
Hope did not confuse you. 78 bucks for a new ignition key was a tough one for this middleaged guy to handle. It's the first car key my wife of 29 years has ever lost. Of course she looses the expensive one.
We never looked at Dodges. THe Tundras are a bit too small for us and the beds are shallower than a full size GM or Ford. Toyota quality is second to none, so it depends on what vehicle you need......
I've got a 99 F-150 supercab Lariat with the 5.4 V8, and have 80K on the odometer. With the exception of the brakes, it's been trouble free. After I had the tires replaced at about 50K miles, the pads started wearing out every 5K. I've had the rotors replaced (twice), but I've still got a bit of vibration when braking. I suspect that something warped in the tire exchange, so I don't necessarily hold this against Ford. (This is apparently a very common problem with Chrysler/Jeep products, as well).
The bucket seats are reasonably comfortable, and I did quite a bit of highway cruising in it. I previously had a 97 GMC full size which unfortunately was not as reliable. Mulitple transmission problems starting at 50K miles which were very difficult and expensive to repair. In addition, the previous GMC/Chevy trucks had to have special parts for a front wheel alignment which made this otherwise routine procedure somewhat expensive.
If you need less of a work truck & more of a daily driver, the Toyota is an excellent choice. Great Reliability & Superior Crash Test Scores, but slightly less towing capacity, if I'm not mistaken.
Will answer more specific question if you've got em. Good Luck with whatever you choose.
So...Do you know which type it is? If so I'm tring to find out if it is a good truck or not. The dealer is asking $5,250 (thay wanted $6000 at first).
Thanks for any help.
Mary
mfminahan@yahoo.com
You forgot to mention whether its a 4x2 or 4x4.. For only 6k, I would have to assume its either a 4x2 in decent shape or a 4x4 thats only in fair condition.
Not seeing the vehicle, it's difficult to judge, but 5,000 seems very reasonable..
Do you know how long or how many miled a F150 can last for? I am wondering at 105K miles if this is the breaking point?
Mary
Mary
I've got a '95 F150, 5.0L V8, with ~170K miles on it. It's still running strong, and not as pretty as it used to be, but it was well taken care of. Did a lot of highway miles, but always had oil changed at ~ 3000 mile intervals. I had to replace tranny at around 125K. It's needed a new starter, and a throttle position sensor, but every thing else has been normal maintenance items - tires, shocks, belts, hoses, etc.
Are there any maintenance records with vehicle? Is the dealer a Ford Dealer - he could probably run the VIN # and see if it has a service record. You can also run Vin # through Autocheck (?) to find out if it's ever been in accidents, or had comprehensive insurance claims against it (vandalism, flood, etc.). Do you have a private auto mechanic that you trust? If so, ask dealer if you can have your mechanic inspect the truck as a condition of sale. Check phone book, some areas have used car inspection services that go over vehicle from top to bottom and give you a report. The $100+ cost would be worth it if they save you from making a $$$ mistake.
As far as mileage goes, my 5.0L is not great (its an extended cab, long bed, 4x2). It gets approx. 12 mpg around town, 15-17 on highway depending on how fast/hard you drive.
Good Luck.
Wp
If possible you should check maintenance, particulary the auto tranny. It needs to be maintained properly, drained, and flushed. Check the tranny fluid, it shouldn't look or smell burned at all. Burned would be a brownish color, not a nice red.
I see lots of these in the 6 - 8k range but most are 4X4. Add another 1500 or so for that option. We're partial to 4X4's out here.
I'd say at $5,200, it could be a decent price depending at least these things.
Mine served very well. The oxygen sensor would fail about every 40k miles which is fairly normal I'm told. Overall I was very satisfied. Have a 2001 Superduty Powerstroke Diesel today. The
F-150 was good enough that I decided to stay Ford.
jerry
PS - Anyone know where I can get some info on the next generation F150's?
Any help would be nice, that engine would be sweet in an F-150.
I don't think that the front end of an F150 could carry the extra weight of full-sized diesel motor.
