Anyway, the tach on an automatic may very well be there for marketing purposes, but I find it quite useful nonetheless and appreciate it being there. You can still shift an automatic. And since cars have gotten much quieter and smoother over the years, just listening to or feeling the revs is not always helpful.
Sorry to vent.
But I'd trade the tach for being able to manually select 4th (rather than just 3rd) like in the MDX.
- Mark
- all-season floor mats: anyone have recommendations on what to get? Do the Honda ones have a good lip around the edge to prevent leakage of salty/muddy water onto the carpet?
- door edge guards: not a listed accessory from the dealer (can't imagine why not). Anyone use something that has worked well given that the outline of the door is not very straight?
You will have to trim the WeatherTech mats a bit, but they are designed for trimming, and the fit is great. I think they were about $100.
As far as door edge guards, check out the hondapilot.org site. There is a gentleman who will sell you some 3M brand clear tape for $20 or something. Probably better off just buying some yourself from your auto parts place, or Lowe's/Home Depot. Any clear tape should do the trick, but getting it on is the hard part.
Just my .02. Good luck!
IOW, use judgment.
- Mark
By the way, contrary to some postings here in the Pilot areas, the 04 Pilots 2nd row seats do adjust forward and back on the rails. This was a change from the 03.
First impressions driving it around are very good, No rattles, no noises, etc. It is the nicest car I have ever driven off the lot. (I usually buy used when I can.)
In any case I decided on the Pilot because it was roomier than the Highlander. So far it feels very sold with no rattles to complain about.
I would be curious if anyone's Pilot, with over 20K on the odometer, still feels solid. I know my 2000 Acura TL exhibits a lot of twisting sounds when driving unto a curb. But, not the Pilot so far - I hope it stays that way.
It sounds like the Pilot comes with a number of power outlets but all of them are off when the ignition switch is off. Is there no way around this?
Barry
Also, I occasionally tow a Sea-doo (single trailer) - I don't have any of the additional coolers, etc - you shouldn't need it for that light weight.
THANKS IN ADVANCE
It's possible...I hope so, but I've heard nothing of this.
The system is great, so is the picture quality, the speakers are crap, though. They only match AM radio sound quality (FM sound improved a little after my speaker switch), far below MP3, CD, DVD sound quality.
Power outlets switch to always on
Be aware of your power consumption with the always on, the battery in the Pilot is not very good (not high capacity). One time, I left one internal light on (the light in the 2nd row grab handle) over night, and the battery was dead next morning. It was not damaged, however, after a full recharge, everything's cool.
You may recall the good old days when there was a lot of profit to be made in the car industry. Now there’s just a lot of recalls, period. The latest comes from Japanese automaker Honda, which is calling back 600,000 minivans and SUVs in the U.S. and Canada.
The reason? They may be equipped with faulty transmissions. Most of the cars affected – the 2002-2004 Honda Odyssey minivans, the 2003-2004 Pilot, and the 2001-2002 Acura MDX - were made at the Honda complex in Aliston, Ontario.
The company warns insufficient lubrication has been shown to cause a heat buildup and broken gears in the vehicles’ transmissions, which could lead to the entire mechanism locking up. If you hear noises coming from your transmission, the gears may already have broken.
So far, Honda has confirmed only 10 instances of the mechanisms actually failing, and there have been no reports of accidents or deaths due to the defect – and they want to keep it that way.
As usual, the repairs will be free and notices will go in the mail at the end of April. Nearly 49,000 cars in Canada are believed to be affected.
Does anyone know if they fold down completely flat in the 2004?
You'll need to remove the headrests first, then
pull on the latch on the side of the seat and push down on the seat. You might need to adjust the forward position.
I do know they fold down, but I was asking if the fold down COMPLETELY flat, like the 3rd row seats do...
Thanks again! MB
Wondered if anyone out there has a list. Thanks in advance!
Anyone have any ideas about what this could be? The Pilot has fewer than 100 miles on it, although we're planning a long drive today, with lots of highway miles; should I be very worried -- as in don't make the trip -- or only mildly concerned and just call the dealer on Monday?
Move the Pilot away from the spots. Touch and smell the bagel size spot. Open your hood and compare the smell & color to the other fluids. Oil will be dark/brownish, coolant--green, transmission fluid will be reddish. But try to go by both color and smell. If it is power steering fluid it's not too unusual and it should not prevent your driving today. Just check it today while you're out just to be safe.
But do take it when the service dept is open. Make a stink about it cause I would sure be mad if my brand new car were leaking...anything!
Good Luck
Open the hood and check all of your fluid levels.
Stuff happens, even with the best of cars.
Thanks to all for the feedback.
Stuff happens, even with the best of cars."
But stuff leaking out of car can mean that the occupants of said vehicle can quite literally get bent all out of shape over it. Even our beloved Honda and its exemplary (at least the ones I've personally dealt with) dealers will eventually make a very serious mistake.
So, while jumping to hysterical conclusions may not be called for, exercising due caution is wise until the facts come out.
memojo: I'm glad that your I-can't-wait trip occurred without incident. Still, I hope you are sitting at the dealer's service department right now waiting for them to find the definitive explanation and fix for the fluid loss. Take good care, fellow driver.
Thanks for your concern. That's exactly where I spent the morning, and where the Pilot, unfortunately, still sits. Soon after I left for work today the Pilot, still showing signs of the leak, started making telltale sounds of a power steering problem. So instead of heading to work, I went straight to the dealership, where they had to use dye in the PS system to find the leak source -- a connecting rod or bushing of some sort in the steering column. Unfortunately, they didn't have the part in stock. It's supposed to be sent overnight and I hope to get the vehicle back tomorrow afternoon.
And, so far, I haven't had to show anything beyond a to-be-expected level of displeasure. I understand that things don't always work the way they're supposed to [sometime I'll tell you about the 2002 Subaru Forester lemon we owned], but I also have respect for the folks who try their best to make things right, like the staff at the Honda dealership [and Subaru and the Subaru dealership, which replaced the Forester in about six weeks]. Today's experience hasn't shaken my confidence in either Honda or the dealership. Hopefully, tomorrow won't be any different.
I'm with you. Perfection would be great, but expecting it is unrealistic (see, isellhondas, I'm with you on that too!). So, given the reality that we might be the "lucky" one to buy an exception, the really important thing is what they do about it after it happens.
Honda and their dealers have tended to be really good at that follow up. Despite the why-did-they-fail-me?!? despair of some, I can't remember a reported failure that was not handled, and corrected, by Honda. I hope your is too... very soon and very well.
A car has hundreds of systems being stressed for the first time when you take it home. The first day you own a car is THE MOST LIKELY TIME for a problem to come up and anything built by humans will have some percentage of examples with problems. We could have the factory drive the cars for a hundred miles before delivery and catch the few problems, but then our cars would cost a lot more.
If the Honda dealer handles the issue promptly and efficiently (as it sounds like they are doing), then it is time to clap for Honda, not boo them.
- Mark
Buying a car is no different from buying anything new. Consumers don't expect anything to go wrong with the newly purchase item.
Getting a steam up before giving the dealer a chance to fix the problem(s) not only causes emotional and also physical harm to yourself, but rarely gives the dealer the intended impetus to bend over backward for you (when you are fiercely radiating your desire for him to bend over the other way!).
I'm not saying it isn't irritating. But, once you are there in that situation, allowing your anger to burn doesn't help at all.
Years ago a boss of mine advised saying nothing much and listening intently whenever some one came in angry. Then, when they finally sputter down to a pause, simply ask, "What can I do to make it right?"
It is amazing how few people know the answer to that question at that point. They tend to spend all their energy getting angry and assuming they were going to be "taken" that they never thought what they wanted to be done. Well, they knew that they wanted the problem to never have occurred at all. But they also knew (when talking to the willing-to-help human) that turning back time is not something realistically achieved.
A car is a complex mechanical system with thousands of systems that will be tested ONLY after the car is in a customer's hands. As I said before, these are not toasters or business suits, so expecting them to all come off the assembly line absolutely perfect is not realistic.
Go ahead and "get mad" if you want, but I think your anger is misplaced. There are lots of aspects of car ownership to get hot and bothered by - having a minor defect in a new car that could probably not be caught by an inspection is NOT one of them.
- Mark
This advice is very good. As my husband is in the service area of Acura, he gets the occasional p*ssed of person who seems to enjoy blowing up. Let 'em steam and blow and then take care of them, it's almost like therapy.
If one is lucky enough to have a dealership that takes care of their needs then that is wonderful. However, if I had just bought a brand new car and had this problem occur, I would at least expect to be priority. Sometimes just the purchasing process is so stressful, but to have to come back so soon because of car problems could be really frustrating. If your service department handles things right then all should end happy.
