CR-V vs Escape
1457910167
  • suvshopper4suvshopper4 Member Posts: 1,110
    When discussing 4-cyl vs. 6-cyl, it is not just upfront costs that matter. To get the whole picture you also have to factor in the cost to operate them, which would include fuel. And insurance is often higher on a larger-engine model (all other things being equal).
    For some people, the extra cost of operating a 6-cyl is worth it. For others, it is unnecessary additional cost.
    As usual, it comes down to priorities.
    This is the way I see it. Keep in mind, I'm comparing whole cars and not just the engines.
    The V6 has the advantage in acceleration. Yes, the CR-V has bested the Escape in several 0-60 runs. 0-60 is the standard for the industry, but it's not the best measure for your average buyer. As a result, the Escape will certainly "feel" more aggressive. Is it a significant difference? Well, that depends on your driving style. I obviously think it's no big deal. Both will giddyup when you need them to.
    The V6 loses the comparo when it comes to fuel efficiency. A difference of a few gallons (2-3) isn't much, even over a long period of time, but real world reports suggest that the difference is more like 4-7 mpg. That's borderline significant in my book. This gives the CR-V an edge in the daily driver category.
    The V6 also falls short when it comes to emissions. Not that the Escape is a dirty, smoking, toxin making machine. It's an LEV, which is good enough for most folks. However, the CR-V takes it a step further to meet LEVII standards, which are actually closer to the current ULEV levels. Is this significant? Probably not. It'll only matter to the real green folks or the technology hounds.
    Towing is another area where the Escape's V6 shines. Add the towing package available through Ford and the Escape can tow twice the weight that a CR-V can haul. To be fair, the CR-V is under-rated here in the states (in other countries it's rated for a more reasonable 2,000lbs), but it still doesn't match the Escape's total of 3K. Does it matter? IMHO, not much. People who tow are almost as uncommon as people who go off-road. The CR-V can handle small boats, jet skis, and even small campers. That's all that most people will try to tow with a vehicle labeled "mini-ute". Anyone looking to haul something larger will probably go for a mid-size even if all they need is something like the Escape. Still, it's an advantage for the Escape if anyone does frequent towing or falls into the rare category of persons hauling a big load with a small vehicle.
    The "un-category" category: Or anything else that people might notice. Based on reviews I've read, I have to give the CR-V the edge in smoothness, both during acceleration and while at idle. Honda did a heck of good job making a large pot, four banger purr like a kitten. Power delivery is likely to be pretty even in both vehicles. I'm told that the Escape can be kind rough at higher rpms. The CR-V has a nice flat torque curve with it's peak at the midrange, while the Escape just has gobs of torque period. With it's peak in the high part of the rev band, I'd guess that the curve isn't as flat as the CR-V, but it's still cranking out more twist at both high and low.
  • scape2scape2 Member Posts: 4,123
    You forgot to mention the CRV tested was a 5spd and not an automatic in the 0-60 comparison.. Plus I don't buy Edmunds test, did my own 3x with a CRV and the Escape won everytime..
    Keep downplaying the advantages of the V6. "Real world" whos world? My MPG average is 21 others at escapecentral are getting 21-23.. Tow rating on the Escape is 3,500lbs not 3,000. You will find out real quick what added HP/Torque will give you when your CRV is loaded down and the A/c is on and you try to go up a steep hill or pass on the freeway. The V6 is in no way loud, its 24Valvs purrr..
    Wanted to break this up. At my daughters soccer practice today I bumped into another father who has been working for Ford for the last 25 years! He is a master mechanic at the largest Ford dealer in the metro area. (I live in the NW and I live in a large city). He admitted Ford over the last 2 years has stumbled in quality/reliability. He said the Focus by far was the worst. However, I asked him about the Escape and he said "they do get Escapes with problems, but they are usually squeaks and rattles nothing major". I asked about this stalling thing.. He knew about it and has had a few, reprogrammed PCM as Ford says to do and they don't come back. Overall he said "The Escape has been doing pretty well". This guy has been around the block. In no way did he defend Ford and admitted Fords screw-ups. Nor did he try to play up Ford or the Escape. I just found this interesting, since the Escape has this reputation with some as being unreliable and bad quality..
    Scape2 - At the risk of repeating the first 180 posts in this forum, the auto CR-V has also bested the Escape in the 0-60 run and in a head to head comparison at that. So it's not just the 5 speed model.
  • phillyguy3phillyguy3 Member Posts: 88
    I've been reading both your posts.as well as others, for a while. I just decided on the CR-V.
    1.Compared EX auto with XLT. CR-V better value.
    2.Compared reliability issues. CR-V more consistant.
    3.Compared economy. CR-V wins
    4.Compared comfort. CR-V narrow winner
    5. Compared styling. Escape wins(actually liked TRIB better).
    6. Compared resale. CR-V wins.
    7.Towing not a factor for me.
    8.Compared creature comforts. Escape wins narrow.
    The clincher was I was able to negotiate $800 off MSRP! And,for me piece of mind that I will have less problems during ownership.Just my personal opinion.
  • carguy62carguy62 Member Posts: 545
    I don't need a V6. Why can't you accept that some people don't care about a V6 engine? My vehicle with its 160 hp engine has no problems getting me where I'm going. I'm not towing, racing, etc. and as varmint constantly points out neither are the vast majority of buyers in this category.
    If I wanted a V6, towing capabilities, etc. I wouldn't have looked at small SUVs. A V6 in these small utes is overkill. I'm starting to think you got the engine to justify the vehicle.
    Hop over to the CR-V thread and tell us what you're getting (trim line, color, etc.).
    I've written at least a dozen posts about reliability and then Phillyguy sums it up with six words.
    "Compared reliability issues. CR-V more consistant."
  • metalshoppermetalshopper Member Posts: 1
    It sounds like Honda should build the Escape, quality AND features, then we'd all be happy.
  • bessbess Member Posts: 972
    So all of us Escape owners who don't have any problems with our vehicles (which are the overwhelming majority of Escape owners) didn't have to compromise at all. We have quality, value, and features.
    Sorry, but the quality 'gap' between the Escape and the CRV is not as wide as the 'die hard' CRV fans here indicate..
    From what I see most folks on this thread are happy with their choice. Both vehicles are great options in this class. The difference in price between the 2 are very close. Someone claimed the CRV is a better value.. I compared the CRV EX to the XLT choice2, and there's about $400 difference in real world price between the 2.. But the Escape has the V6, power seats, and 16" wheels.
  • tomsrtomsr Member Posts: 325
    I rented an Escape before I bought my CRV and
    thought 200 HP was a little too much for the
    size if in the wrong hands.I am an older driver
    and think power is great if used wisely.Young
    people tend to be overexuberant about use of power.When I took off from the rental store
    the tires were squealing which will get you a ticket most places.I also have an Acura 3.2TL
    which has lots of power but is very confidence
    inspiring.If I had more $$ I would have gotten the MDX.Next time.
    Please link me to where an automatic CRV bests a V6 Escape.
    Just not going to happen my friend. 200HP/200ft/lbs of torque vs 160HP/160ft/lbs of torque and the CRV has only a 170LB advantage. It just doesn't add up. Honda owners can keep on downplaying the V6 in the Escape but every review I have read has given this vehicle rave reviews on performance, agility, road manners, suspension you name it. The V6 is just one of the Escapes advantages. Honda owners will find out real fast when their CRV's are loaded down with 4 adults, and filled with gear. Then try to pass on the freeway or go up a steep incline, then you will be wishing you had a V6.
    Price advantage/value - The Escape offers a V6 for the SAME price now as the CRV. Honda owners keep justifying in their minds they have the most reliable vehicles. I can see why when Honda hides TSB's from the public, take a look at www.alldata.com. visit other sites around the net you will find many ticked off Honda owners who expected perfection....
    OUCH@@!! did you take a look at the Editors rating of the CRV right here at Edmunds.. they rated your perfect CRV's at a 7@!! LOL..
    Also, your claim that a CRV can best an Escape is done. The Escape reaches its 201HP at 5900rpms, and its 200ft/lbs of torque at 4700rpms.. the CRV reaches its 160HP at 6000RPMS!!! talk about having to wind up your 4cyl engine, and reaches its 162ft/lbs of torque at 3600rpms. I knew this was bogus garbage when I read the 5spd CRV bested the automatic Escape...
  • altoonaltoon Member Posts: 64
    You said:
    "You will find out real quick what added HP/Torque will give you when your CRV is loaded down and the A/c is on and you try to go up a steep hill or pass on the freeway."
    You have said similar things several times. Have you tried this in a CR-V? I have nearly 5,000 miles on my 2002 CR-V (manual). I have taken long trips with four passengers and the back loaded. I had NO problems with inadequate power at any time. Obviously the Escape's 6 cylinder is going to deliver more power, but that doesn't mean the CR-V's is inadequate or under powered. Honda has done a marvelous job of building an efficient yet powerful 4 cylinder vehicle. I have yet to experience a situation where I wished for a larger engine.
    Bess - Now, this is going to be one of those "overblown" posts that you have a problem with. You might want to skip it. Note, however, that I am only responding, in kind, to the same sort of thing from our buddy Scape2.
    Scape2 - TruckTrend, 5th Anniversary Issue, with January/February listed as the month. The article is titled, "SUV Lite", and it starts on page 28. The article is a comparison of the RAV4, CR-V, Feelander, and Escape. Skip to page 37 and you'll find the performance stats spelled out in nice clean print.
    The Automatic CR-V scoots from 0-60 in 8.93 seconds. The 200 hp, V6 Escape does the same in 9.0 seconds. FWIW, the Freelander takes 10.5 seconds and the 5 speed RAV4 beat everybody with a score of 8.90 seconds.
    Now I'll be the first to say that the CR-V was slower off the line. The Escape has the best score for 0-30. The Escape also had a better time for the 1/4 mile at 16.7 vs. 16.9 seconds. But the fact of the matter is that the differences in these scores are not significant. In other words, it looks like an automatic CR-V can run with the V6 Escape.
    Alright, now let's take care of a few other things...
    5900 rpms vs 6000 rpms. You're kidding, right? A whopping 100 rpm difference!
    Meanwhile the CR-V's torque output peaks at 3,600 while the Escape's doesn't peak until 4,700 rpms. Hmmm... maybe a little math is in order... Oh, yes, that 1,100 rpms lower than the Escape. Another way to write that would be the difference is eleven times the 100 rpms you were worried about with the hp peaks.
    And you think that the CR-V is a high revver? ROTFLMAO!
  • phillyguy2phillyguy2 Member Posts: 27
    Why don't the two of you meet somewhere and "duke it out " on the track? This childish bantering is just a waste of time for most of us who use these forums to get VALUABLE information & input. We're not comparing Vettes & Porsches here. It's your $$$ so put it anywhere you like and enjoy the ride. I have expressed my OPINION and since I have now commited to the CR-V, I will be hopping over to that board. No need to reply.
    Even your beloved consumer reports rates the Escpae V6 at 8.5 from 0-60, others like Motor Trend and Automobile and many other auto reviews rate the Escape V6 from 8.1 - 8.3 for 0-60 times.
    You folks really need to get out on the net to Epinions and the many other reviews coming from real owners of Escapes/Tributes. Thousands upon thousands of happy owners with NO PROBLEMS..
    Did you know the Duratec has a dual timing chain, NOT a belt.. like your CRV....
  • beatfarmerbeatfarmer Member Posts: 244
    '02 CR-V now uses a chain too.
  • baggs32baggs32 Member Posts: 3,229
    It depends on where you live and what you call a hill. On our test drive (three in the CR-V) we went up and down several large hills because you can't avoid them in Western Pennsylvania. It seemed to be struggling to get up the hill every time. It was dropping gears on and off while the transmission searched for the right one. It never really did find it. The Escape doesn't do that nearly as much, which is always a very large factor in my decision process. That's just the way I like it, and some people (like my wife) don't care, or don't even notice it.
  • diploiddiploid Member Posts: 2,286
    "You folks really need to get out on the net to Epinions and the many other reviews coming from real owners of Escapes/Tributes. Thousands upon thousands of happy owners with NO PROBLEMS.."
    The potential for fake Epinions reviews to favor the Escapes/Tributes is just as high as fake ones that trash the Escapes/Tributes.
    Perhaps there are some circumstances where the additional power of a 6 cylinder would be advantageous. After putting nearly 5,000 miles on my CR-V and having no problems with insufficient power, I doubt I will experience those driving conditions very often. My experience is that the CR-V is a peppy little car that likes to get up and go (especially the 5-speed which I have).
    Yes, and that is why a test drive is so important. Magazine articles and stats can't give you that kind of information. You need to feel it for yourself.
  • oregonboyoregonboy Member Posts: 1,650
    I've noticed Varmit's postings on numerous boards, he's an intelligent, reasonable guy. He never gets into prolonged arguments with the Subaru Crew... so why does he persist (and persist and persist..) in attempting to refute scape2's inflamitory statements? It's not worth the effort.
    The one thing that I most remember from Psych 101 (many long years ago) is that you encourage desirable behavior with positive reinforcement and you discourage undesirable behavior with NO RESPONSE. IF you ignore it... it will eventually get bored and quit.
    No offense intended to Scape. It's just that we have heard the same old song too many times. Yes the Escape is a powerful SUVette. I think it's good looking too. And in a drag race against a CRV, I'd bet on the Escape. But, right or wrong. I would not buy one, simply because of questionable quality, poor fuel economy, and (I'm guessing here) low resale value.
    If I offended anyone, just ignore me. (joke)
    -james
    why are you in this room then?
    Questionable quality? how? please link me to this? If you are talking the 1.5 year old recalls that only affected certain build lots and dates you are way behind the times, oldnews..
    So, I guess you wouldn't buy an Odessey either with its bad quality record and numerous recalls??
    Low resale?? How can you judge resale when the vehicle is only 2 years old? Don't assume what you don't know anything about..
    The V6 is just one of the Escapes huge advantage over the other SUV's in this class. This give the Escape towing power, pulling power, hauling power, passing power, better acceleration. I wouldn't call this the same old story....
    Scape2 - Yep, and other sources have ranked the CR-V (5 speed) at 8.4 and 8.5. Given the variations from test to test, it's best to use head to head data.
    FWIW, I'm not interested on proving that one is faster than the other. I'm just saying that the Ford V6 doesn't have a significant advantage in terms of speed. There are many reasons why and all have been documented back at the beginning of this thread.
    Oregonboy - You need to go to the archives from three years ago and read the CR-V vs Forester threads. The debates were just a "colorful" coming from both sides. It was a great way to learn about both vehicles, though. I have a tremedous amount of respect for Soob thanks to those debates. Nowadays, we just quote old arguments like chess moves.
    You changed your point... You said an AUTOMATIC CRV outran the V6 Escape.... Nice dance...
    Once again... There are several reviews around the net that have the Escape at anywhere from 8.1 up to 8.5 0-60 times. And when people test drive them they will see the true advantage of a V6..
    Just keep downplaying the advantages to a small V6.. Facts are facts.. the V6 is a huge advantage over the 4cyl CRV. Tows more, hauls more, pulls more, just plain does more. And at only a 1-3MPG difference.. Cost of maybe 1-2 dollars each fill-up....
    "the V6 is a huge advantage over the 4cyl CRV"
    In the words of Tim Allen - More power! aarh aarh :)
    The DEGREE of advantage for the V6 is in the "eye of the beholder." I don't need the V6. The 4 cylinder CR-V has plenty enough power for my use. Why pay more (in terms of gas) for power that I don't need and do not want. If you need more power or simply want more power for whatever reason, then the V6 is a good choice. That does not make the CR-V a bad choice for the rest of us.
    The V6 only goes faster and tows more if it's NOT BROKEN. The Escape/Trib thread on compaints keep growing. Meanwhile, there is NO complaint board for CR-V. Since CR-V sales are up 14% & Escape down 28%, don't you think the public has voiced their opinion and are losing confidence in Ford? I,for one, would have bought the Trib if it wasn't for the mounting problems, and I am not even taking into account the recalls.
    Scape2 - Read again. I never posted that the automatic CR-V is faster than the Escape (except in that one test). That's an assumption you keep putting in my mouth. What I posted is that the auto CR-V is competitive with the Escape. IOW, it runs a good race against it.
    I also posted that you are using data that is not head to head (different testers, different test conditions, and possibly different methodologies). If you're going to bring that sort of data to the discussion, so will I. Hence the 5 speed times.
    Phillyguy - There have been "problems" boards for the CR-V in the past. Each time, they've died from lack of activity.
    FWIW, the '02 CR-V is experiencing its share of first year issues. Though, not as many as the Tribape (and, no, I'm not counting recalls, either).
    What are the 02 issues? Have they been taken care of from Honda? Do I need to address any when mine comes in in July?
    Go check the Honda TSB's if you want to find out. Oh wait a minute, I forgot that you can't. varmint, tag you're it!
  • daveghhdaveghh Member Posts: 495
    I was at a light in my '02 CRV automatic with my girlfriend in her v6 automatic! We dragged, the first time it was neck and neck. Second light CRV had a slight advantage. After that there were no more lights, so we ended up at 40 mph next to each other and on the count of three with our hands we gunned it, they were neck and neck until 50 mph then from 50 to 60 the crv won!!!
    Could have been the driver I suppose....
    that said there is no significant advantage having the V6 unless you want to tow something slightly larger or want slightly worse mileage.
    Why in God's name are you people racing factory SUV's. No wonder SUV insurance premiums are high. My old ZX2 (and any current ZX2 with a 5 speed) would blow the doors off of both of them with its 130hp four banger. Racing SUV's and comparing their 0-60 times is futile because even most little econoboxes will beat them any day at any time. Period. Let's concentrate on using them for what they were intended to be used for, and thus compare those useful stats. I'll bet she had no problem stopping in a shorter distance, right?
    First of all, we didn't speed at all, we accelaerated quickly to the speed limit. Guess what? No law against that, and it doesn't necessarily hurt anything except for my mileage. And I generally don't accelerate fast so mileage isn't an issue with me.
    SUV insurance is only higher because of 4 wheel drive... so if you have a two wheel drive crv or escape you will pay the same as a civic or whatever the escape is based on.... or close to it (if, and I say if they both retail for the same amount).
    "Why in God's name are you people racing factory SUV's."
    I don't know what your definition of racing is, but 0-60 in 8 seconds (or even more) is hardly racing. Most people have to do that just to merge onto the highway from an exit ramp (at least in NJ, anyway).
    Phillyguy - Here's the rundown for you.
    When the CR-V was first released, there was a recall for the front seat belt. That's been fixed.
    Recently, a number of owners began reporting an issue with the check engine light. Seems that the chip programming was too sensitive and was registering an emissions problem when there wasn't one (the code points to the O2 sensor). It only happens under freakish circumstances, so it was hard to track down. Honda has a fix for it, but, since the issue involves emissions regulations, the fix needs to be tested by the US gov't. I'm told it should be approved by May.
    Then there has been a problem with the front seat "rocking". This is a problem with the bushings under the seat. The TSB for this is number 02-017 for US models. Canadians have a different numbering system. It was issued on 3/17, so units built around that time already have the fix.
    Basically, the only known issue you "might" have to deal with is the CEL. The others have been fixed. When the regulators have their chance to test the new programming, Honda will issue a TSB. Until that time, they cannot.
    Diploid - Muscle cars from the 50's and early 60's were lucky to run 0-60 in less than 9 seconds. I remember reading a comparo where some vintage street racers were compared with a Honda Odyssey. The Ody kicked bottom in acceleration handling, and braking.
    Depends on your perspective.
    Honda owner response - "When the V6 is not broken".. Pretty old, pretty lame.
    Right, you HOnda owners will never know what is wrong with your CRV's because Honda doesn't allow TSB information to flow freely. www.alldata.com... go take a look, or should I say, don't look???
    I know this is off topic, but varmit is right. There was an article in last Months Motor Trend about the Civic Si, Sentra SER, Subaru WRX, Ford Focus SVT I believe. All these cars were quicker from 0-60 than many of the well known muscle cars of the 60's and early 70's. I couldn't believe it myself! At the same time these cars weigh quite a bit less and it proves how far technology has come in cars..
    phillyguy, I am well aware of sales numbers. Anyone who follows new introductory of redesigned vehicles knows the first year is always the best year. Plus, I would be willing to be many of the CRV buyers are trading in old ones and buying new ones....
  • npaladin2000npaladin2000 Member Posts: 593
    Can it be? Varmint and Scape2 actually AGREEING on something? Next thing you know Isreal and Palestine will make peace! :)
    Seriously, it looks like the Ford Escape and Honda CR-V are just really destined for different markets, even though they're both mini-utes. The CR-V seems more like the "Soccer-mom" mobile, made for carrying around people and a bunch of vacation stuff, or that sort of thing, if you get my idea. And no, I'm not insulting "soccer-moms"...they just tend to need particular things in a vehicle.
    Then you have other owners, who look for power, towing capacity, height, and a little extra off-road ability. That's the Escape, with it's stiffer (though still unibody) body, and extra horsepower, and the like.
    Basically, the Escape is closer to the "truck" end of the mini-ute market, while the CR-V is edging toward the minivan part of the mini-ute line.
    Just my take on the subject, of course. Quality issues aside, and recall issues aside, the first priority for a car shopper is going to be whether a vehicle meets their needs, not which one is "better" or has "the best quality." The best quality in the world won't help you if the car that has it doesn't meet your needs.
    I must say that this board has been helpful to me while I shop for my next vehicle...I've been following it closely. Unfortunately, after test driving, neither of these vehicles made the final cut, but it wasn't for quality issues on the Escape side, and it wasn't power issues on the CR-V side. After test-driving both, I found that I didn't like the handling and suspension on the CR-V, and it felt too long, especially for it's lack of height. The Escape got the nod for power, but it felt incredibly wide while driving, and I don't like some of the MPG figures I've been hearing about. That and I can't get the MP3 player in it without going to the Midnight Package which I don't want. :)
    When you line two vehicles up side by side and gun the engines to see who gets to a certain point faster, that is racing.
    SUV insurance is not high just because of 4WD. When an SUV hits something, or gets hit it causes a great deal of damage. When there's more damage, the repair costs are higher thus we pay inflated insurance premiums. Maybe that doesn't apply to these smaller SUV's as much because of their lineage, but they're just about as unstable if driven improperly.
    npaladin2000: Which SUV's made your cut?
    scape2: Sales data has shown that some early CR-V owners(97,98) have traded in for 02. Surveys have shown that these are loyal & satisfied owners who traded up to newer,improved model. Time will tell whether Ford will build a following for Escape in light of reputation which they admit has been tarnished.
    THe CR-V and Escape,although cross over occurs,each have their pros & cons,and,as I've stated,if it were not for the consistant quality issues,I would have chosen the Tribute for it's looks,power & features.
    I have also talked to many people who have traded in their Jeeps,Durangos,& Explorers for CR-V's for different reasons, not the least of which are economy,insurance and downsizing to more car like ride & handling AND reliability.
    BTW, as has been mentioned numerous times,sales are not an indication of quality,but large shifts in sales often is a result of owner satisfaction/dissatisfaction.
    Lastly, why is it that Ford always seems to react to problems only AFTER widespread issues have been well publicized(tires,engine stalling,etc.)?
    "I would be willing to be many of the CRV buyers are trading in old ones and buying new ones...."
    Scape2 - Would you please enlighten us as to why this would matter?
    Avtually, I'm running out of SUVs, since I don't want to pay a lot more than 20k. If the RAV4 has a turbocharger or a little bit more horsepower (or low-end torque, anyway) it would make the cut, but it's pricey.
    The Forrester seems to have enough grunt, but ti's got the same problem as the CR-V...it's too long and not tall enough.
    I'm actually considering the Matrix/Vibe as SUV's at this point...albeit REALLY short ones in both height and length. But again...not enough horses, and their max torque RPM is too high to help.
    No Suzuki, Isuzu, or Mazda dealers around here, which sucks..the nearest Hyundai is too far for me to be comfortable with warranty work, and the Chevy Tracker, while it feels pretty good as a vehicle, has REALLY narrow seats...my [non-permissible content removed] doesn't fit.
    The Aztek doesn't count as an SUV...it's a minivan. I could get by the looks, but I do NOT want a minivan. :)
    Where does that leave me, other than a Kia? (LOL!)
    I actually considered it for quite a while....it doesn't feel underpowered and it handled pretty good...very similarly to a Chevy Tracker, actually. But my uncle sells auto parts...he can't get Kia parts. And I've heard MANY a horror story about those Sportages on these boards. No thanks. Figures the vehicle that feels close to perfect might not make it from the dealer to my apartment. :)
    So, I'm waiting for the Mitsubishi Outlander to come out, and hoping it's got the right engine/tranny mix to at least give it the feeling of power. Otherwise I'm going to count the VW GTI 1.8T as a REALLY height-and-length-challenged SUV with traction control. ;)
    Sad, isn't it? So many mini-utes, and NONE of them is quite what I want. I want a short-length, tall-height vehicle with a decent amount of horses or better, and comfortable inside, with AWD, or at least FWD (Though if it's rear-drive, I WANT AWD). None of them quite fit the bill at this point.
    Too bad the Jetta wagon doesn't have VW's 4Motion deal...you have to go up to the Passat for that, and that's out of my price range. Maybe the redesign of the Golf/Jetta platform for 2003 will bring 4Motion, now that the Matrix/Vibe are available with it.
    These are not new buyers, they are repeat buyers. Buyers that are moving to a newer model of the same vehicle. Not like the Escape which has no history, has no previous owners from 3-4 years back.
    npalad - did you test drive Suzuki's? They have a pretty good selection of smaller SUV's that are every bit as good as Toyota or Honda. Take a peak into the room here at Edmunds, generally people are satisfied. Take a test drive, it can't hurt. Also try the Saturn VUE. Good luck in your hunt..
    How is Suzuki's rep for reliability?
    (I know, I could look it up...)
    Scape2 - I understand what you were saying. I'm asking why it matters. If the new CR-V is good enough to provoke people to trade it in for the new model, what's the problem?
    All this, of course, is assuming that you are correct. I do know several CR-V owners who traded up, but I don't see significant numbers to prove your theory. I see more people waiting to trade up for the Pilot.
  • freeberfreeber Member Posts: 116
    Jetta isn't slated for 4Motion in the US. (Period) That may change in the future, but for now there are no plans. There are opposing views on whether or not the Golf is going to get it in the next few years, but not next year is the consensus. If you love Volkswagen, you have to know this site: WWW.VWVORTEX.COM
    npaladin2000: Who are we kidding, all these mini-utes are mini vans, they just shape them different. I'm hoping to buy a CRV in the next 2 weeks. Look at the profile....it's a mini van. I just keep telling myself its not.
    As I said, I don't have a Suzuki dealer around, though I did test drive the Vitara-clone Chevy Tracker. The seats are too narrow, but otherwise it's a very likeable vehicle. But I simply CAN'T get by those seats...they'd be unbearable for more than 10 minutes.
    As for Saturn...there's a dealer here, but I'm not sure I like the VUE's styling, though I'm pretty curious about how a CVT feels. Maybe I will take a trip over there at some point.
    As to the Jetta not getting 4Motion...well, the the Jetta, like the New Beetle, is built on the Golf/GTI platform, so if the Golf might get it, the rest of the Golf platform stuff might get it if they stay on the same platform. But I like the Golf and GTI better than the Jetta anyway. I'm gonna have to keep an eye on that website, since I had completely forgotten about VWs until about a week ago. Apparently, so did Toyota and GM, since they claim the Vibe/Matrix are the first cars in the segment the Golf/GTI already fill. :)
