CR-V vs Escape
1116117119121122167
  • cpickcpick Member Posts: 21
    The 2005 2wd and 4wd CRV was tested for the first time in the Dynamic process (moving) and did NOT tip up during the evasive maneuver. The CRV got an 18% chance of rollover too. Only a couple marks more than a Subie Outback. Otherwise got what look to me like perfect safety scores as well.
    Guess which Ford SUV did tip up...unfortunately, its easy, because it looks like all of them did, even the Escape. Ford just doesnt seem to care about rollovers!
  • mphxazmphxaz Member Posts: 27
    If you are going to quote test results, you might want to post the actual numbers.
    When I look up the results on the NHTSA site, the 05 Outback got a 15% chance of rollover, the 05 CR-V's a 19% chance (not 18) and the early 05 Escape/ Mazda 20% (4wd) 23% (2wd). There are no test results for the later 05 builds of the Escape / Mazda twins.
    The CR-V and Escape/Tribute rank at the lower end of rollover possibilities for all SUV's ......
    :shades:
  • dromedariusdromedarius Member Posts: 307
    According to Safercar.gov, the four-wheel drive Escape had a 20% chance of rollover (23% for two wheel drive), while the CR-V had a 19% (both models) chance. The main difference between the two, however, was both Fords tipped, while neither Honda did, and the Honda got five stars for frontal impact for both the driver and passenger, while the Ford got four stars.
    "According to Safercar.gov , the four-wheel drive Escape had a 20% chance of rollover (23% for two wheel drive), while the CR-V had a 19% (both models) chance. The main difference between the two, however, was both Fords tipped, while neither Honda did, and the Honda got five stars for frontal impact for both the driver and passenger, while the Ford got four stars."
    The 2005 CR-V has standard stability control as standard equipment. Do the Mazda/Ford twins have this feature?
    No the current Ford/Mazda/Mercury siblings do not have stability control available. I believe that Ford just introduced that option recently on the Explorer. I would imagine that it will be available on the triplets in the not too distant future. Could be the 1% needed. :)
    Actually, I believe the side crash tests are done with the vehicle being tested at a standstill. I could be wrong, but I'm pretty sure only the ram is moving. In this case, the diffference in rollovers would be larger than the gap showed in testing.
    The NHTSA's side impact test is totally different test than NHTSA rollover test. They are two different tests. As you mention the side impact test has a ram impacting the vehicle on the side while it is at a standstill.
    In the rollover test, the vehicle is moving and attempts an evasive maneuver. In any case, it all depends on how environmental conditions and the skill of the driver. In my opinion, 1% is not that big of a deal. This is quoted from the NHTSA's safercar.gov site, Rollover FAQ:
    3. Are SUVs the only vehicles that roll over?
    No. A rollover crash can happen in any type of vehicle. SUVs, like pickup trucks and minivans, typically ride higher off the ground than passenger cars and have higher centers of gravity, and thus are more susceptible to rollover if involved in a single-vehicle crash. See the vehicle class comparison chart. But while vehicle type does play a significant role, other factors such as driver behavior and road and environmental conditions also help determine whether or not a vehicle rolls over.
    Even a five-star vehicle has up to a 10% risk of rolling over in a single-vehicle crash. In fact, certain five-star vehicles, such as sports cars, may have a higher number of rollovers per 100 registered vehicles than certain three-star vehicles, such as minivans, due to the aggressive way in which the vehicle is driven and/or the age and skill of the driver.
  • dc_driverdc_driver Member Posts: 712
    That is very useful information, and I truly believe that drivers are the greatest risk for a rollover. Not to discredit stability control (I wish my Tribute had it), but I have watched way too many drivers in DC try to maneuver 20-30mph turns going 50-60mph in a vehicle (especially SUV's)! To me, aggressive driving is the greatest risk of causing a rollover.
    I have also read many posts where owners override their stability and traction control systems because it "takes away" from their control of the vehicle. The one thing that Ford/Mazda did do was improve the rollover cage and side airbag systems of the 05 vehicles, which should reduce injuries and deaths during rollovers.
    "I have also read many posts where owners override their stability and traction control systems because it "takes away" from their control of the vehicle. The one thing that Ford/Mazda did do was improve the rollover cage and side airbag systems of the 05 vehicles, which should reduce injuries and deaths during rollovers."
    Well, I was interested that they added VSC to the CR-V at all. My 2003 is probably one of the most stable vehicles I've ever driven in a turn. Very solid, never any feeling of tipping or nearing out-of-control. But I always keep in mind that it has a high center of gravity.
    Of course, I've never owned a BMW...
  • rambo5rambo5 Member Posts: 37
    CU no longer recommends the Escape apparently because it tipped in one of their tests. Any comments from Escape diehards? Will the 2006 MY have stability control? This really has spooked me and without some reassurance this car/truck is off the list.
  • bigeauxbigeaux Member Posts: 46
    rambo5,
    All SUVs have an increased risk of roll over when compared to your typical car because of the higher center of gravity. As mentioned in the posts above, there are a lot of variables that influence whether or not a vehicle rolls over during a particular maneuver. Taking account of the vehicle's limitations and inherent risks in your driving style will reduce your chances of a rollover considerably, regardless of what you buy.
    For me personnally, I was also a little spooked by the note from Consumer's Reports about the Escape/Tribute, but I got over that enough to give it a test drive. It's your call, but I don't think the increased risk with the Escape/Tribute, relative to other vehicles in class, is great enough to reject it out of hand. I opted for the CR-V instead, but not because of any worries about roll overs.
    I think your approach is the smart one. Test drive all of the vehicles you are interested and then write down the pros and cons for each vehicle. The fact that the Honda offers VSC is obviously an advantage, but the rollover tests show that the Escape/Tribute have only a slightly greater chance of rollover vs. the CRV.
    I visit quite a few Tribute/Escape message boards, and I have never heard of any owners complaining of rollover/tipping issues. I just do not know how big of an issue this really is, and I would be more concerned about front and side crash ratings on the vehicle.
    I personally hope that that future Escape/Tributes will offer VSC as standard equipment since it is the best selling small SUV, and other companies such as Honda and Hyundai/Kia are starting to make this standard on some of their SUV lines.
  • baggs32baggs32 Member Posts: 3,229
    There are a lot of variables controlling those scores too. So don't take them too seriously either. Use them, but don't live by them. No pun intended. :P
    FWIW Ford did make it's AdvanceTrak with RSC (Roll Stability Control) standard on all of its SUVs except for the Escape. Why? I don't know, but if they do offer it on the Escape it will virtually "one-up" the CR-V and others simply because of the RSC. That system was developed by Volvo for the XC90 and actually helps prevent rollovers. All of the other stability control systems, such as Ford's AdvanceTrak and Honda's VSC, only get you out of a skid (and even that isn't guaranteed). A lot of skids can lead to rollovers but you still do have to induce a skid for those "skid only" systems to react. Ford/Volvo's RSC will help you out of a rollover without a skid.
    I bought the CR-V because I preferred it over all above the Escape (in 2003).
    However, were I shopping today, I would not exclude the Escape just because of the "tippy" issue. I would just realize that the driver has to be more cautious. All SUVs are top heavy. If you want a sporty SUV, buy a BMW X3 or X5.
  • snowmansnowman Member Posts: 540
    "Taking account of the vehicle's limitations and inherent risks in your driving style will reduce your chances of a rollover considerably, regardless of what you buy."
    Finally, an intelligent approach...
    Good point...I stand corrected. I was looking at the graphics and misread the percentages...but in any case the tip up factor was and is important to me.
    The English show called Fifth Gear, a video car magazine (see Speed Channel) had a feature on rollovers. They did a test which showed a mid 90s Range Rover tipping and rolling in the same maneuver the NHTSA is doing now. The RR went tumbling at only 40 mph with no impact at all.
    Guys, this thing is real. You can say that a car will roll too....if it hits a curb...if its poorly loaded etc. But all SUVs have greater risk and now the tests prove it. There are, however, huge differences between the various models. I suppose that my anti-Ford bias comes from the years they devoted to fighting these dynamic tests.
  • scape2scape2 Member Posts: 4,123
    other auto chats around the net that include Escape/Tribs. I have yet to read one rollover in the 4years I have been visiting these rooms. Funny how a 1% difference in a rollover in an Escape can out weight a possible fire in a CRV!
    Fact is these vehicles are not race cars nor made for the slalom course. They are ALL top heavy and will roll when pushed the wrong way BY THE DRIVER.
    I read in an auto news blurb, (I will try to find it again on the net) that Ford is going to put a stability control system on the Escape/Mariner/Tribute but not until its totally new redesign in the 06/07 year.
    I have driven both (Pre 2005 Escape); the CR-V is less prone to lean on the curves. Not that the Escape was especially tippy, in my opinon, but Honda engineering emphasizes performance over comfort. Very similar to the original Mercedes handling and road feel. One gets more road feel with the Honda, and the suspension is tighter.
    At least on the Escape I drove, and the CR-V I drive daily.
    FWIW past tests by professionals concluded that the Escape out-handles the CR-V in the slalom, skidpad, and braking tests. Not by much mind you, but the Escape has always been the better road handler. "Tippy" or not.
    Keep in mind that this applies to pre MY05 Escapes and CR-Vs. 2005 Escape numbers haven't changed much from past models but the CR-V did add bigger wheels/tires for MY05 so things might be different now. I haven't had the interest to look the numbers up.
    "Very similar to the original Mercedes handling and road feel...."
    I wonder what MB engineers say about this...
    "I wonder what MB engineers say about this..."
    Unfortunately, there are no MB engineers anymore, only DC engineers. The product is worse for the merger, in my opinion.
    BTW, I stand by my assessment of the comparative driving characteristics, also in my opinion.
    I too read over and over again how well the Escape/Tributes handle and how great their road maners are. I do have to say, owning both a Tribute and an Escape, the Tribute has more of a sporty feel. :)
    "I do have to say, owning both a Tribute and an Escape, the Tribute has more of a sporty feel."
    Well, that's a possibility, maybe the Tribute handling is more like the CR-V.
    Steve,
    When I was shopping for SUV's in November, I had the V6 S AWD Tribute ranked #1 in handling and fun-to-drive factor (comparing to CRV, Rav4, Tucson, Escape, Outlander). The CRV was up there though, and I had it ranked right behind the Tribute/Escape. The CRV obviously had some advantages of its own, to include overall interior space, and gas mileage (not to mention those stereo controls on the steering wheel for the CRV SE. I love that feature) :)
    Took this review of the 05 Mazda Tribute from both Edmunds and New Car Test Drive:
    " Mazda markets the Tribute as the Miata of SUVs, and the claim isn't far off the mark. With a wide track and powerful V6, the Tribute handles better than most SUVs on the road, driving more like a sporty car than a truck."
    and
    "Driving Impressions:
    The Mazda Tribute is an agile and powerful little SUV. It handles better than other sport-utilities. Its sharp steering allows the driver to guide it precisely. At high speeds, the Tribute is supremely stable. Handling response is relatively taut, without that mushiness that characterizes SUVs with big off-road tires and long-travel suspensions. Tribute handles better on the road than a Jeep Liberty, and it's more fun to drive than a Honda CR-V or Toyota RAV4. Noise, vibration and harshness levels are low when underway.
    Steering response is direct and accurate without a big dead spot in the center. There's enough feeling in the steering to give the driver a good sense of control. The tires provide respectable grip in paved corners. The Tribute offers surprisingly good transient response in left-right-left lane-change maneuvers. The suspensions on front-wheel-drive (2WD) and four-wheel-drive (4WD) versions are identical, so there's no ride-quality penalty with 4WD.
    The Tribute's ride quality is smoother and more sophisticated than that of the other compact sport utilities. It offers firm damping and a good control of body motions. The 2005 Tribute benefits has increased spring rates and a larger front stabilizer bar. "
    I think that Mazda engineered the Tribute to be sporty as part of their "Zoom, Zoom" campaign. I really did find the Tribute to be the most fun-to-drive small SUV in its class (well, except for the Subaru Forester Turbo), and I almost prefer driving it to my 2002 245hp Nissan Altima SE. Sure the Altima is much faster, but the Tribute really moves, and handles extremely well... I now have close to 6K miles on my Tribute, and I have just recently started to open this vehicle up more and it is sometimes scary how much power this little SUV has...
    Mazda Tribute has different and more advanced suspension system than Escape. This is also indicated in mazda's web site.
    After 55,000 trouble free miles my Escape went and did it... I failed me..
    I am going to sell it right away and buy a Honda. Yes, a Honda it will be much more reliable, more of everything..
    The small squeak from my stearing wheel when I turn is what I am talking about! This is terrible quality, terrible reliabitliy that all the Honda folks talk about. I will never, ever buy another Ford again! :P
  • mikefm58mikefm58 Member Posts: 2,882
    Did I miss something? What's the point of your post?
    I think it's called sarcasm. Some can deliver it better than others but it's often used when one has run out of serious debating points. :)
    I also think it's best to stick to the facts and straightforward discussion of the issues.
    Can someone comment on which car better handles road noise. I recently test drove a CRV and at 75mph it was quite a racket (wind/road noise). Does the Escape do a better job at highway speeds?
    In regards to sarcasm, it is the lowest form of wit and difficult to pull off in writting.
    Guess I won't try to be funny again any time soon.... :lemon:
    With the increasing price of gas, Ford put themselves in a good position with the Escape/Trib/Mariner. It's a big enough in size, gets decent economy and seems to be holding up pretty well. So is there any updates in the future? With a supposed new CRV on the horizon (06 debut as an 07 model) Ford would be foolish to allow the current one to languish without update (DT3.0 to new DT3.5, 4spd to 5, updated interior). They got the jump in 01 a year before the V and I haven't heard anything about a new one for 06, once again a year before the new Honda.
    "They got the jump in 01 a year before the V and I haven't heard anything about a new one for 06, once again a year before the new Honda."
    Honda runs on a 5 year product cycle, which means that every 5 years they come out with a completely new design. Ford runs a longer cycle. Since this will be the first update to the Escape (yes, I know they changed the sheet metal for 2005, and some mechanical components on the transmission), we don't really know when Ford will do a complete update.
    BTW, Ford did not "get the jump" on the CR-V; the CR-V 2 was introduced 5 years before the Escape. The "jump" you refer to is the 2nd generation update to the CR-V.
    Actually, scape, I agree with you. Perhaps you should look into the Honda. I'm not quite sure why a person would want to own two of a vehicle as you do anyway, owning both a Tribute AND an Escape. Instead, maybe you could get a bigger vehicle like a Suburban so you could tow houses and semis while having a baseball or footbal team on board, and on the other hand you could go with the more efficient and safer CR-V on the rare occasion when you aren't pulling houses or carrying ball teams.
  • kizhekizhe Member Posts: 242
    scape2: Guess I won't try to be funny again any time soon....
    Thats it! I'm done! [scape2]... I will never, ever buy another Ford again!
    You don't have to be funny again
    (Big Brother Host is watching)
    ... but anything could happen:
    Gloria Steinem ... got married,
    Scape2 ... sells his Ford and buys Honda CR-V.....
    This post might also be a test for sense of humor for tidester_HOST
    I did not "stick to discussion point" and "got personal" on Gloria Steinem, OOPS!
    Correction:
    Gloria Steinem retired, got married and buys Ford Hybrid (her husband is a man, Ford chief engineer is a woman and Hybrid saves environment). Sigh!
    You mentioned Ford and Honda so I guess we can say you're on topic! ;)
    P.S. Did I pass??
    ...an episode of The Good (Ford), the Bad (Honda), and the Ugly (Steinem)? :P
    Standard & Poor's Ratings Services cut its corporate credit ratings to junk status for both General Motors Corp. (GM) and Ford Motor Co. (F).
    This is a significant blow that will increase borrowing costs and limit fund-raising options for the nation's two biggest automakers.
    Shares of both companies fell 5 percent or more after Thursday's downgrades, and the news sent the overall market lower.
    "And this might be a good opportunity for bargain hunters to buy up some cheap automaker stock"
    Inside Line
    Atnother point to make is the CRV had rollover controls, Escape didn't. Escape had a 1% more chance without controls! Gee.. Wonder why they didn't test a CRV that was older like an 02/03/04 model year that doesn't have rollover controls. In my book the Escape does pretty well... :)
    The CR-V does NOT have rollover control. It has stability control which helps prevent the vehicle from leaving it's intended path. For example, when you take a curve too fast and start sliding sideways the system will do whatever it can to get you back on track safely. Some of the "better" ones will prevent that slide from ever happening too.
    Ford's RSC (Roll Stability Control), which is packaged with their AdvanceTrac stability control, does prevent rollovers. It was invented by Volvo for the XC90 and incorporates several sensors around the vehicle as well as a gyroscopic sensor that informs the rest of the system that a rollover is imminent. If that's the case the system will do whatever it can to prevent the rollover.
    C'mon scape!!!! I've typed this out like three times on this thread. Pay attention!!!!! :D
    The main point I was trying to make is this roll over test was a joke. They took a CRV that has stability controls and tested it against an Escape that does not. Why didnt' they use an 03/04 CRV that did not have these controlls? Even with controls the CRV was not that much better than the Escape! ;)
    Because you can't go to a dealer and buy one of those right now unless it's used. Testing organizations always use current models.
    One big problem with these tests is that when you hear about them on the news they usually don't mention the model year. All you hear is "The Honda CR-V scored very well in a safety test" or something to that effect. If someone looking for a used CR-V hears that they might become mis-informed because it seems like all CR-Vs are like the one tested.
    I gotcha the first time. ;)
    This is another problem with the tests. When two vehicles score so close together the results when comparing the two basically become a wash. But because of little dots, stars, colors, etc. the difference can look huge on paper. If they used some sort of bar graphs or other charting method I think we'd all see things a bit clearer.
    The Honda system is an aggressive system, meant to be used while driving in order to avoid a rollover situation altogether. The Rollover test is an extreme test, which yanks the steering wheel first one way, then another. In "real world" conditions, the Honda system is meant to correct the vehicle in order to keep the driver from panicking, which is what happens in this set of conditions. In other words, the chance of this happening is minimized with the Honda.
    As to the Ford not having VSA, so what? They choose not to include it. For that matter, I can't find an Escape in my area that has side or curtain airbags. Safety is not a priority, as it is with Honda. Regardless, it seems rather silly to insist the comparison be fair, as they are not equal vehicles. The Honda doesn't have a V6, but that doesn't mean you can't compare them. This seems like a rather intuitive point, but it seems necessary to point this out.
    Finally, there is one HUGE difference in this test: the Escapes tipped, the CRVs did not. I don't care that the percentage is only 1% apart, the difference between not tipping and tipping is a huge difference, especially when you are talking about the safety of your family. Granted, the Honda can't tow a semi and doesn't have a payload of a zillion pounds, like the Escape, but it does have it's advantages in areas like fuel economy and safety.
    Please, 1 percent? tipping? how much was the "tip" the system on the CRV does help prevent the "tipping" also. Can you imagine a CRV without this system? Smaller tires/wheels and taller body to boot. Your post makes the Escape sound like a death trap. When in fact it does score very well when equipped with air bags/side air bags.
    As far as the person "not being able to find an Escape with side air bags".. I can give you 11 Ford dealerships in my area that have over 60 Escapes with side air bags... The Ford Escape/Tribute are not unsafe.
    "Please, 1 percent? tipping? how much was the "tip" the system on the CRV does help prevent the "tipping" also. Can you imagine a CRV without this system?"
    Yeah. About the same as the Ford now. Check out the safety ratings of a 2004 Honda CRV, which was before the VSA system, and you'll see.
    Besides, as I attempted to explain previously, this test is a radical maneuver. As an aggressive safety system, the Honda is designed to keep this from ever happening. It's called prevention. I don't know how else to explain it.
    "Smaller tires/wheels and taller body to boot."
    You MIGHT want to check your facts. The Ford is taller AND narrower. And the wheels on both vehicles are both 16 inches. You really need to research more before making statements like this.
    "Your post makes the Escape sound like a death trap. When in fact it does score very well when equipped with air bags/side air bags."
    Never said the Escape wasn't safe. It just isn't as safe as the Honda. Honda equips EACH and every CR-V with front, side and curtain airbags, VSA, EBD and ABS. Ford's only come standard with ABS and front airbags. It can't be ordered with VSA. With the higher safety ratings, more standard safety features, and more available safety features overall, the Honda is the safer vehicle.
    You can spin it all you want but the Honda system absolutely does not prevent a rollover in any way shape or form. It prevents spins and skids such as "fish tailing".
    The ONLY rollover control system is owned and installed by Ford. Why they don't put it in the Escape too is beyond me. If you want to find out more about it go to Ford's website (I believe Volvo's site has some info on it too under the XC90's pages). The big difference between an actual rollover control system and a run-of-the-mill stability control system is basically one sensor. One ingenious sensor actually.
    I think the CR-V being lower to the ground has more to do with it not tipping than anything else.
    Nothing can "prevent" a rollover if the situation is extreme enough. It has nothing to do "spin". If you are driving fast enough, and you go down a ditch steep enough, or yank the wheel fast enough, you'll tip over regardless of what preventive measures have been put in place. However, the CR-V has something that helps prevent rollovers. The system helps to compensate when it determines the vehicle isn't following the intended path. If it didn't, the driver might over compensate, and/or cross into oncoming traffic or go in the ditch. In itself, that helps prevent rollover situations. The Ford Escape doesn't have anything along those lines. That, in combination with all the Honda safety features which are standard make it the safer vehicle. THAT was my point.
    Stability Control: Get Your Yaw-Yaws Out!
    We just happen to have a dedicated forum about it too, for your reading pleasure:
    Stability Control, are you ready for it?
    You make some excellent points, but you are also looking at this the wrong way. Perhaps Ford wanted to give users more choices with the Escape/Tribute. By that I mean that you can get a 4cyl or a V6, side airbags or no side airbags, AWD or FWD, etc.
    While I agree that VSA does help, it also costs money. Why shouldn't the consumer have that choice? I am a member of a number of Escape/Tribute forums and I have never, not once, heard of a user complaining of tipping or rolling over. I think that the media tends to over hype how dangerous SUV's can be. I feel more safe (and mine does have side curtain airbags) in my Tribute than any car I have ever owned.
    There is talk on other message boards of Ford adding the rollover system (which was developed by Volvo I believe) to future Escape's. I doubt it will be standard, but I had no problem finding a Tribute with side airbags when I purchased.
