CR-V vs Escape
1129130132134135167
  • drive62drive62 Member Posts: 637
    Since this seems to be going over people's heads let me spell it out (which in itself is fairly ironic).
    Honda makes a vehicle called the CR-V. I am already aware of what the letters stand for.
    Some people here (and elsewhere) refer to a CRV. I would like to know what exactly that is.
    I know I'm being anal (and tongue-in-cheek so take this with a grain of salt please) but I'm pretty sure most people prefer to have proper names spelled correct. Otherwise we might as well write about the Sivic, or the Fuzion or as I mentioned, the Eskape.
  • scape2scape2 Member Posts: 4,123
    How about "Combustable Recreational Vehicle"? ;)
    Every one of someone's previous messages have been torn apart as being full of half-truths and mistatements and that's the best they can come up with. Pretty sad.
    Ford isn't going anywhere. As much as many of you want an American Icon to go away, its not. Ford is on its way to rebuilding itself, just as Nissan did and Chrysler is doing. It is obvious you know little about what else Ford is into, business wise. Honda makes about 1/4 the cars/trucks/vans Ford does.
    Besides, Honda sales are DOWN worldwide and have been shrinking for the last 3 years. The ONLY place Honda sales are up is here in the U.S. and only by less than 5%. The 500 is selling fine, as soon as the new 3.5 V6 is put in next year it will do even better. The Fusion/Zepher/Milan are going to do pretty well too. I have yet to read a bad review on these cars. I'm getting way off topic.
    I read somthing about a Ford "Edge". This may be the replacement for the Escape? anyone know?
    I dont' understand your logic of thinking. The CRV/Honda are supposed to be superior in every way to every small ute out on the road, according to the Honda clan. Why is it no ok to question then, why after the engines were rotated did Honda have all these fires/smoking/smelly issues? Why did you Honda CRV owners who knew this informaion keep this from this forum?
    My understanding is oil drips onto the exhaust area? why then doesn't Honda in all its greatness and superiority in engineering come up with a simple fix? Like a shield of some sort? Why if other manufactures have also oriented their engines the same way doesn't the Escape catch fire? or the Subaru Forester? or the Hyundia Sante Fe?
    " Why is it no ok to question then, why after the engines were rotated did Honda have all these fires/smoking/smelly issues?"
    scape: The first thing they teach in statistics is not to confuse conincidence with causality. In other words, having two things occur at a similar time doesn't mean that one caused the other.
    If the mechanics had checked for the gaskets, there would not have been one fire.
    Don't bother explaining.
    It's not a matter of being able to understand. Scape chooses not to understand. If he admitted to having comprehension of the issue, he couldn't continue bringing it up.
  • me3me3 Member Posts: 30
    The "-" in CR-V is a hyphen... also referred to as a dash. In this case, the "-" indicates that there is a dashboard in this particular vehicle. The Escape on the other hand has no "-" hence, no dashboard.
    However, the Escape has its own special key on the keyboard (not dashboard). The key, fittingly enough, is used to abort all current efforts and bail out while you're ahead.
    The "-" can also be called the "minus" key indicating the low amount of money to be paid for such a superior product and the significantly less amount of gas used to beat an Escape to 60 mph. ;)
    Just having fun guys, just having fun.
    Note to Escape owners... you really do have a dashboard. Its right there behind the steering wheel.
    Hmmm.. looks like I am mistaken on that. The vocalist for Dead or Alive is Peter Burns (not Brian Hugh Warner aka Manson) and he appears to a dead end. So, I must be thinking of someone else entirely.
    varm liked his cr-v so much, he ditched it. i had to edit to put in the minus sign
  • dromedariusdromedarius Member Posts: 307
    Some people are just choosing not to understand what happened to the CR-V. It could have happened to the Escape being shipped overseas as well. It's a matter of comprehension. It also explains why the questions are always coming from the same source, but in turn, that source never answers questions. If said source did, they could explain how you stay in a vehicle whose seatbelts fail, the back hatch flies open, the steering wheel flies off and the accelerator sticks. I've gained a new sense of respect for people who can drive such a vehicle and "Escape" to talk about it.
    Also, for baggs (who CAN comprehend what I'm writing... ;) ), those numbers were compared to last years October sales. I don't think dropping or adding a vehicle should add into it the equation. Shrinking is shrinking, whatever the reason is.
    although this discussion does get a bit edgy at times, it's still ok.
    drom... explain why the cr-v (see i remembered the minus sign) is the only vehicle to have this problem (swelling oil filter gaskets) that we know of. lots of vehicles are transported across the ocean(s) to our continent.
    The problem was with the gaskets. They were manufactured incorrectly. This caused them to stick when the oil filter was removed. When the service person didn't notice this, the gasket was in between the gasket of the new oil filter and the seating. This caused oil to leak, which then caught on fire. It has absolutely nothing to do with the engine being rotated 90 degrees. While funny, that assertion is absurd.
  • baggs32baggs32 Member Posts: 3,229
    That's right. But I wasn't implying that the Ridgeline caused Ford's sales to drop. There's no way that could happen I'm sure we can all agree. I was implying that Honda's sales are inflated right now due to the addition of new models that didn't exist last year. Jeep should be another good example of this in the coming months as they just added another SUV to their lineup.
    I probably should have typed that more clearly so I apologize. Work and/or kids often get in the way of my posts for some reason and I have to stop short sometimes. :confuse:
    "cr-v" (see i remembered the minus sign)"
    Close but no cigar. Maybe it's because you don't use caps but the correct spelling is "CR-V".
    On another thread they ask what should be changed about the CR-V for the redesign. I say the name. It's caused confusion from day one.
    Again, this is tongue-in-cheek but care should be taken when spelling proper names.
    "varm liked his cr-v so much, he ditched it."
    This is probably the last time I'll respond to your trolling, so pay attention.
    I did not "ditch" my CR-V. After 6 years and 115,000 miles of flawless service, I traded in for a larger vehicle. Not because of any problems with the CR-V, but because my wife and I added a daughter to the list of critters we are responsible for. Our family (which also includes dogs and ferrets) simply got bigger than a small SUV can handle.
    Without even looking varmint, let me guess. You traded the V in for an MDX? :P
    Congrats on the kid! We're adding boy #2 in February and I've been looking to unload the Escape (yes again) for an XC90, Explorer, Pilot, or MDX. So far I'm not seeing the numbers I want to see though. :cry:
  • lemmerlemmer Member Posts: 2,689
    Pete Burns isn't dead, he just looks like an old lady now.
    drive... since you and others are able to interpret my posts, i don't feel the need to use caps. it is only a car.
    at least it is better than my penmanship. ;)
    varm... i was just having a little fun with you.
    congrats on your daughter. hope she lets you get some normal sleep.
    i hope the mdx is big enough with all that stuff you are going need to haul around. :)
    Yet another spin.. "I choose not to understand". This is good. Someone else mentions other vehicles being shipped from overseas not having this "gasket" problem. Hmm.... Yet I choose not to understand?? I see that you Honda folks choose not to ask questions, blindly follow the silver "H". The rotation of the engine? Noone in the Honda group has answered me why they didn't inform the rest of the group of this change? I am finding other folks in other chat rooms that also didn't know of this change, why? I just hope noone gets hurt or killed by this cover-up..
  • bshelbshel Member Posts: 232
    what rest of the group? The changes are well known, and if some folks in some chat room didn't know, and they own a CR-V, that is their responsibility to be fully informed. If they have access to a chat room, they have access to the internet.
    I think you are joking with all your babble.
    I'm sure people are getting killed by the dozens due the engine rotating like it does in the Escape. People have been getting killed in Escapes for years. It's probably why the steering wheel falls off in Escapes all the time. I am one of the lucky ones, I have to admit. I got my first oil change, and the car didn't blowup. I'm still nervous to see if the steering wheel falls off, though.
    Back to the Escape for a second, I think Ford should be forced to acknowledge all the recalls for this particular vehicles on the sticker, since it has been recalled such a high number of times. People really have no idea of what they are getting into when they buy this vehicle. The internet is filled with posts on this ongoing deception. Why didn't anyone tell me Escapes' seatbelts don't work and the steering wheels fall off before I went cute ute shopping? Why the constant coverups and conspiracies?
    This is a link to a website every potential Escape buyer should see. In one word, SCARY! Why didn't anyone let me know this information before I test drove this vehicle??? Why the coverup?
  • blueiedgodblueiedgod Member Posts: 2,798
    It has been said time and again, that rotation of the engine has nothing to do with the fires. The oil filter has always been on the same side as the exhaust. Whether it was the B20 in the Gen 1 or K24 in Gen 2, the oil filter is above the cat.
    You chose not to understand the difference between a faulty rubber compound that bakes on to the enngine block, and what Honda did with the K-series engines.
    Why does anyone have to inform anyone? The information is public, you want to get, go and get it. The question is,
    WHY DIDN'T YOU INFORM ME ABOUT ESCAPE'S HATCH FLYING OPEN WHILE DRIVING, THE REAR WHEEL FALLING OFF, STEERING WHEEL COMING LOSE, AND THE STICKING GAS PEDAL?
    I had to go out of my way and research that information, why didn't you inform me about ??
    Bingo. Been looking at them for years.
    I'm surprised the Freestyle isn't on your list. Next to the new Mustang, I think it's the best vehicle Ford has put on the road in recent years.
    escape recall info:
    The 27 NOV 2000 recall involved 51,022 Escapes and 24,000 Tributes. Of those, 27,516 Escapes and 12,500 Tributes had already been sold.
    To all the CR-V owners for "Piling on"!
    I mean, the Escape is not THAT bad...
    don't worry, escape owners know that. ;)
    I know it is not, I HAVE BOTH!!! But Cr-V is better. How many on here can do their own in-the-driveway comparison???
    To the one boasting about Escape's Torque, we had to borrow a neighbor's Silverado to pull a stomp, all that "puffing and huffing" in the Escape could not even move it. Escapes develops its 200 ft. lbs at like 5000 RPM. With the tranny, in gear, it never got to 5000 RPM. That torque is good for nothing.
    Since the Escape is the wife's vehicle it's her choice. I think the Freestyle is a great vehicle too but she hates it's station wagon looks. No matter how many times I tell her it's based on the XC90 she still won't budge.
    Oh well, we had a chat about this just last night and I think we're going to keep the Escape until we actually outgrow it (which might be next spring :) ). I don't like the MDX or the Pilot, I'd rather have an Odyssey to be honest, so I need more time to work on her anyway. ;)
    my wife came out of a 42k saab wagon, and loves her escape. one of my kids is lobbying to get it handed down. i think it really needs some different tires. :confuse:
    an escape is not a stump puller. a silverado is a much heavier vehicle with a much more powerful engine, but everyone already knows that. not sure of the point you are trying to make.
    I hear you on the Odyssey! We really liked it, but we just had our first child right after we bought our CR-V (a few months ago), and we couldn't justify the extra expense. It's about a 95% certainty an Odyssey will be our next vehicle, after a couple more kids.
    It makes every bit as much sense as the other things being said in here...
    We can't justify the expense right now either. That stupid employee pricing really killed the resale on our Escape and even leasing something larger is going to cost more than what the Escape costs per month to buy. At least we aren't in desperate need of a larger vehicle but having to haul two kids and their gear around might help us change our minds though. The Escape can handle it, but can we? :sick:
    On that note, my sister-in-law carts her three girls around in their 2001 CR-V SE and has been doing so, with all three kids, for two years now. It's tight in the back seat but they get by somehow. That IS their largest vehicle until it's paid off next September, and after seeing what they go through I promised my wife I'd never let that happen to her. I know, I know, I'm the greatest husband ever! :P
  • vg33e powervg33e power Member Posts: 314
    Blueiedgod, you either are a CR-V owner, work for Honda or smoking crack.
    Are you pulling those comments out of your behind?
    CR-V does not win in acceleration with its only powertrain offered...2.4L rated at 166HP. and weighs at 3389lbs
    Escape's 2.5L is rated at 171HP and only weighs 3299lbs and its V6 3.0L is rated at 220HP
    So how the heck does a less powerful much heavier vehicle win in acceleration?
    CR-V's combined MPG is 23
    Escape's is 24MPG (2.5L)
    wrong again!
    Sales volume...I do not have exact numbers, but with Ford selling all those Escapes to goverment agencies, county deals, and consumers I highly doubt CR-V wins but since I dont have facts to back it up I will give you that one.
    Interior room...OK your right.
    So you could be 50% correct but most likely 25% only
    My wife loves her Escape too. I'm the one pushing for more room because I can see the need for it approaching rather quickly. She just hasn't seen it yet and wants to wait. At least one of us is somewhat sensible. ;)
    Take her shopping for an Aztek or Tribeca. She'll warm up to that Freestyle in no time.
    Don't let Juice (I think you know who I'm talking about) hear you say that! He gets a little touchy when someone bad mouths the B9. I know that from personal experience. ;)
    Waiting until next year also gives us the opportunity to add the Aviator/Edge/CX-7 to our list. And that's a good thing.
    Duratec35, new 6-speed ATX, and some hybrid news. Hopefully at least one of these will make it into the Escape in the near future. I'm not holding my breath though.
    "Hopefully at least one of these will make it into the Escape in the near future. I'm not holding my breath though."
    I don't know, it is as if the Escape is the "problem child" that Ford doesn't want to acknowledge. They just don't seem interested in upgrading it.
    Kind of funny how I "babble" yet drom, steve, varmit and other Honda CRV owners are all right on target? Hmmm....
    You cannot be serious with the link? This is a lawyers site!@ Ya think there may be some bias and motivation here? Like $$$??
    Sure bet you didn't look at all the CRV recalls? or better yet get into other chats about engine fire issues...or visit the IIHS rear crash test on the CRV? :confuse:
    I cannot find anything about Ford/Mazda doing ANY upgrades or improvements to the Escape/Trib/Mariner in the coming years. Heck, if they just offered 4wheel disc, stability control, side air bags as standard this would be a good improvement@! What I am reading is it is sounding like Ford is going to kill the Escape after about 07 and come up with a vehicle called the "Edge"... speculation from me at this point...
    I have to admit this ticks me off. Ford is known for doing this with thier line-up. Escape/Trib/Mariner are a great start into this market segment. :mad:
    Hey, you should check out the CR-V! It has four-wheel disc brakes, stability control, and side AND curtain air bags, all standard! And, it's resale hasn't been ruined by monster rebate programs! Check it out and let me know what you think! Even if you don't like it this year, a new one is coming out for the next model year!!!
    :shades:
    Scape,
    The Edge is coming out next year, along with the Aviator and Mazda CX-7, and will be a tad larger than the Escape but a tad smaller than the Explorer. It too is a crossover but, unlike the Escape, is based on a much more solid platform (Mazda6) and will compete with the likes of the Pilot, Highlander, Murano, etc. The Lincoln version (Aviator) will compete with the R330, MDX, etc. A smaller SUV is supposed to bow sometime in '08 or '09 that will be smaller than the Escape and that may be when the Escape fades off into the sunset. All of the new crossovers mentioned above will get the Duratec35 in some form. Probably standard on the Lincoln but the other two might have a turbo Duratec23 as the standard mill.
    These are just rumors now so time will tell.
    Well, it is loosely based on the old Mazda 626 and probably will be pretty expensive to upgrade. If what I said in my previous post to Scape comes true then we'll have the smaller ute based off of the Euro Focus (CD3) (Volvo S40/Mazda3) and the small mid-sizer based off of the Mazda6. That doesn't leave much for the Escape to go on and doesn't bode well for it's future. I can't see Ford basing a smaller ute on the CD3 as well as another one not much larger.
