CR-V vs Escape
1159160162164165167
  • scape2scape2 Member Posts: 4,123
    "It was determined that the Honda fires were caused by gaskets left on when the oil filters were changed. You seem to imply a cover up on Honda's part, do you have any evidence"
    Yeah, and this is why the oil filter location has changed and was changed the next model?? Honda covered this one up in grand style! :surprise:
  • blueiedgodblueiedgod Member Posts: 2,798
    If Honda changed the filter location, then I would have believed you that it was a cover up on Honda's side. But, the defect was in a maintenance item, oil filter. There is no need to change the filter location, or anything else, as long as the new oil filter has a gasket that does not stick, or the oil changer makes sure that the old gasket has come off.
    By the way, if you ever changed the oil on your dearly departed Escape, you would have known that the oil filter on the Escape is right above the HOT exhaust manifold connector/joiner part. The hottest part of the exhaust system. If Ford had a bad filter supplier, it would have had a higher chance of catching on fire than CR-V.
    Every time I change oil in the Escape, I have to wipe the oil off the manifold to make sure that it does not catch on fire when I start her up. It smells like burnt oil for a week or two, while burning off oil embedded in the manifold. Talk about engineering disaster...
    Instead of spewing misinformation on the web, get under the cars you talk about, at least once in a while.
  • baggs32baggs32 Member Posts: 3,229
    Very true. I'll add that our '96 civic and several other I4 engines I've changed oil on were laid out the same way though. Ford is not the only manufacturer guilty of this mind you.
    I was actually guilty of leaving the gasket on after an oil change on the Civic. The gasket was fused to the filter spindle and I never noticed it. Needless to say, oil spewed all over the road and the bottom of the engine that day. I think I made it about 2-3 miles before the oil light came on and I had to pull over. Kind of scary but I've never had that problem with any Ford or Toyota engines I've changed the oil on. Maybe Honda needs to cool their engines down better across the board? In the Civic you needed to be above 3500 RPM to go anywhere so the oil and engine were always boiling.
    Instead of spewing misinformation ...
    That's a bit harsh. We can certainly disagree with each other but kinder gentler is the preferred approach. :)
    SUVs and Smart Shopper
    Yeah, let's swap "spewing" for sharing?
    Let's also do a little research before posting things we may not know about.
    I imagine some readers take what is posted here as gospel as opposed to what it really is, so let's be a little respectful of them. (It really is a group of car junkies of varying degrees who like to discuss and debate different vehicles, their problems, and solutions to those problems, IMO).
    Agreed. But let's not scare them off with harsh rhetoric. :)
    BOO!
    I'd rather not call it "harsh rhetoric." Let's call it verbal intimidation. LOL
    Tongue-in-cheek, of course.
    Good evening, all.
    Thegrad
    All right, I am sorry. I may have chosen rather harsh words, but... certain someone keeps harping on and on about a "design defect" when his "infallable" Ford is just as guilty of the same design. Yet, he chooses not to mention it, or is competley unaware of the fact.
    The fact it neither the Escape or CR-V fires were caused by design or part flaws. Both were/are caused by installation mistakes. Misplacement of a protective cover for the Ford and over-tightening an oil filter for the CR-V.
    Humans put these things together so I personally don't find it surprising that things like this happen. Thousands of dollars would be added to the price of these things if the manufacturers were to inspect each one for defects, fix those defects, and therefore almost guarantee perfection from the factory. I can honestly say I'm OK with the way things are done currently.
  • kyfdxkyfdx Moderator Posts: 271,390
    CR-V oil filter problems weren't caused by overtightening. It was a bad batch of gaskets that had a greater propensity to stick to the engine than normal. That is definitely a flawed part. This was compounded by techs not diligently performing their duties (checking for stuck gaskets).
    Hmm, that's not what I've read. Do you have a link to that info or is it just heresay like the info I referred to?
    We had a whole discussion about it, but it seems to be lost in the archives...
    Here is the best link I can find..
    Washington Post article
    Well I stand corrected.
    It seems the WP doesn't necessarily believe Honda's excuse which is reasonable IMO. As I said previously, I had a gasket stick on me during a change and didn't notice it. The filter with the gasket that stuck was installed by a quickie lube place and I doubt it stuck because of the chemical makeup of the rubber or else we probably would have heard of it.
    Kind of funny you mention this. Yes, I did change my oil in my Escape, yes I did drip oil on the hot manifold. Yet.. For some strange reason my Escape never caught fire!! :confuse:
  • dromedariusdromedarius Member Posts: 307
    These Escapes are catching fire after a few years. You only had yours long enough to put on 75,000 miles before you had to get rid of it. Hardly long enough to prove any sort of durability of any kind.
    That was 75,000 miles which equates to about 6 years. At what point can you make a definitive statement about durability? :)
    ...that got this forum shut down, aren't we? Re-hashing the SAME issues, even when a brand new CR-V is out, as well as at least an updated Escape. Can't we talk about the NEW cars?
  • bdymentbdyment Member Posts: 573
    Amen to that idea!
  • drive62drive62 Member Posts: 637
    The article states specifically that the seals were "missing or incorrectly installed ". I think it is a fair assumption to say they are are referring to when the vehicle was built. That's a bit different than when some oil change jockey left a gasket on when he changed a filter.
    The gaskets in question on the CR-V were installed in the factory. Again, same thing.
    75,000 miles is not the bar for durability, at least not in my social circles. 150,000 is nothing to brag about. You get to 200,000 miles and some of the people I know will care. Heck, my parents 1988 Crown Vic had 180,000 miles on it when they got rid of it, albeit the transmission had to be rebuilt at 130,000.
    Is going to be a non-issue in a couple years if Ford can't find a way to make a profit. I read the other day FMC lost over $12 billion in '06. They had to take out a loan for 23 billion to try and turn things around. Ford had better start turning out updated models a LOT sooner than every 8 years (or 20+, in the case of the Ranger), if they hope to compete with the Japanese. Of course, that's not going to happen when the company can't pay its bills. That's what happens when you think only short term. It seems to me the only thing Ford cares about is "Quality is Job 1" for their F150. Everything else was overlooked, so now the bottomline, and its product line, are showing it.
    That works out to about 15 years and I'll concede that you will know much sooner that if the vehicle is not durable. :)
    For people like my parents, that'd equate to less than 7 years! My dad traded his 2005 Accord in Novemeber 2006 for a 2007 Civic Sedan. it had 69k miles on it in less than two years (got the Accord around Christmas 04), so you can see why some of us think 75k is a drop in the mileage bucket.
    I'm saying I don't know people who brag about cars with even 150,000 miles on them with no problems. Certainly not 75,000. I put over 70,000 miles on my 2nd car, a '93 Dodge Shadow, after buying used with 39,000 miles. My little brother now uses it as his college car. None of us have ever had to stick a dime into it, even though it has been badly abused since I passed it on a few years ago. I'd still never claim Chrysler is a reliable brand because of my ONE experience with one of their products.
    On the other hand, my '03 ZX2, which I hastily traded away at 18,000 miles a couple years ago, was ALREADY having problems with its transmission. Despite the fact that I've known several people who have logged heavy miles on little Escorts, I suppose I could say all Escorts are garbage. But I won't. :blush:
  • explorerx4explorerx4 Member Posts: 21,053
    to me, driving that many miles in a short time makes no sense. i don't want to spend that much time in a car.
    i have made sure i live not too far from work.
    have any guys bought a new cr-v? the escape plays to a wider audience.
    The folks live 13 miles from work, and ride together (work at the same place). It's not that far really, by my standards (I drive 14 miles to school 4 days a week). Having had a condo 300 miles away on the gulf coast meant they were driving the 600 mile trip every other weekend since 2004, hence the rapid mileage buildup.
    We bought our 2005 CR-V new. Why does that matter?
    don't have a vacation home, but wouldn't want to live that far from it either. ;)
    Well, it is my parents' dream to retire to the gulf coast, so they bought one when they could afford to (before the prices inflated to double what they were when they bought it). In Birmingham, a vacation, other than going to the lake/river, is always at least 3 hours away. The bright side, is that Mountains are 350 miles (Gatlinburg, TN) and the beach is 290 miles (Gulf Shores/Orange Beach, AL), so you are between two very different locales.
    Yet, the fact that mine has not caught on fire means nothing to you??
  • twaintwain Member Posts: 185
    I am looking for a $20-24,000 SUV and I recently test drove the 2008 Escape XLT and a 2007 Honda CRV.
    My wife and I recently bought a 2007 Mercury Mariner, the same vehicle as the Escape. It's the Premier model and stickered at 26k. We're both around 50 so ride, entry/exit and comfort are important to us too.
    As for ride, it's very smooth on smooth roads but can get a little "jouncy" on bumpier pavement. It's only a 103" wheelbase.
    Entry/exit... our last vehicle was a 2003 Saturn Vue and it was excellent for entry/exit. One of the best SUVs in that regard. The Mariner is a little higher to step in and out but still not difficult.
    My main complaint with the V6 Mariner is MPG. I'm sure the CRV would have it beat. The Mariner/Escape should have a 5sp auto but only has a 4sp. The 4cyl Escape with a 5sp manual gets decent MPG if that's an option.
    Unless an SUV type vehicle is a must, there are other alternatives for comfort, space, mpg and ease of entry. The Mazda 5 and the Kia Rondo to name two.
    Nope, not the same. The gasket in question on the CR-V remained behind on SOME CR-Vs when the oil filter was changed. Operator error on the part of the oil changer.
    The Escapes issue was incorrectly installed or missing gaskets at the point of manufacture. Completely different.
    The cause was, according to the article posted earlier, a gasket that was manufactured incorrectly and had a higher probability of melting and sticking. ALL of them were installed in the factory making this problem a build problem. i.e. they built the vehicles with a bad part.
    I think you are trying to twist it into an installation error which is not what I was arguing. The problem originated at the factory for both and that's all I'm saying. You guys can blame the oil changers all you want but the fact still remains that Honda put a bad part on the CR-V and didn't care enough about the customer to recall them.
    "You guys can blame the oil changers all you want but the fact still remains that Honda put a bad part on the CR-V and didn't care enough about the customer to recall them."
    This is a huge double standard that exists.. some don't see it.. are refuse to see it?? :shades:
    This is a huge double standard that exists...
    Why are we continuing with this?
    Beats me. Last I checked, there were no incidents involving the 2007 CR-V, manufacturer OR mechanic related, so its relevance eludes my understanding.
    There is a HUGE difference when a maintenance item is faulty. Something that is only going to be on the car for 5000 miles, as opposed to a lifetime items such as ABS module, or the rear bearing hubs.
    Honda did issue an order for the dealers to replace all filter on the incoming CR-V's with the redesigned ones.
    Even if they issued a recall, what would it be for? Oil filter recall? By the time fires were happening the faulty filters have already been removed. I don't see logic in recalling something that has alredy been removed. Do you?
    Sometimes I wonder if logic is truly a gift only a few posess.
    The impression I got (perception is reality, right?) was that Honda was playing hide the ball on the filter issue. Reminded me of Toyota's handling of the sludge issue. The ease of access of information nowadays has forced corporations to be more open, whether they want to be or not.
    The smartest corporations, imo, are the ones who blog about all their internal goings-on; if there's a screw-up somewhere, better that we learn about it from the company and have the employees tell us what they are doing about the problem. When we know the people running the corporation, we tend to trust their actions more (and we become more forgiving of the inevitable screw-ups as well).
    And yeah, I read the recent Wired article about radical transparency the other day (link).
    GM seems to have the right idea - they did the "make your own Chevy commercial" and let the obnoxious ones stay up and their FastLane Blog is pretty well known. I don't know if Honda or Ford blogs for public consumption or not, but if they do, they need to get the word out better.
    I can see where the comparison might be drawn but I don't agree. People whose CR-V burned up were covered. I'm assuming Ford is going to cover the people whose Escapes burned up. Toyota has blamed the customer for the sludge problems. I still don't know why Toyota handled that issue they did. It was obvious to everyone there was a design flaw. I have a sludged Chevy Prizm (Corolla engine) so I have researched this issue as much as humanly possible.
    On the other hand, Honda didn't want to take responsibility for something that shouldn't have been an issue with a competent oil changer. I understand that, and it's why I don't take my car to Jiffy Lube or Wal-Mart to get my oil changed.
    I'm down with that. However seeing that they blamed the problem on a faulty part they should have owned up to it more IMO. Notifying oil changers should have only been part of the solution. Notifying owners too would have been the best action to take especially after seeing CR-Vs catch fire after the oil changers were instructed to be careful.
    I don't even know if they said the part was faulty. They said inadvertent exposure to the salty air during transport from Japan compromised the gaskets, which then made them more likely to stick. Even at that point, everyone who changes oil knows you have to get the gasket off or the next filter won't seal and the oil will drain out.
    The link the host posted said the rubber was exposed to something when it was manufactured and therefore had a higher tendency to melt and stick. It said nothing of salty sea air.
    So I read they were screwed on too tight, a host showed us where it might have been the rubber of the gasket itself, and now you are telling us it was the sea air during shipment. Which was it? Or are there more excuses that exonerate Honda and somehow excuse them from protecting their customers better? :P
    In any event, it's past history, so let's give it a rest and give Tides a break from re-reading the whole history (I'm off on holiday and don't care, LOL).
    Anyone cross-shopping lately?
    That was bound to happen soon.
    I'll still take our Explorer over any of these small utes. The gas mileage is the only weakness about it but I don't mind. It is an extremely comfortable and useful vehicle to have in the garage. I say this as a father of two. If not for that then the smaller utes are the way to go IMO.
    People's apparent allergies to first the station wagon, and then the minivan. If you need room for kids and luggage and you don't need other people's approval on your choice of vehicle, a minivan should be your first choice. Not to mention the superior safety and fuel economy. As the next best thing, it's no surprise to me that the CR-V has passed the Explorer and the Escape, since I believe a vehicles purpose is to get you from Point A to Point B:
    1) Safely
    2) Efficiently
    Honda has always gotten this. Maybe America is STARTING to catch on!
    :P
    BTW, our 2005 CR-V got 26 MPG on our last tank (all-time high is 29.5 MPG). And my 2001 Chevy Prizm got 39 MPG. My oldest knows we only drive in "Mama's car", though, although I'm willing to bet he doesn't know it's because it's the one with all the airbags.
    :shades:
    I don't either drom, but my wife drives the family vehicle so she gets to pick. We've sat in and drove minivans and wagons and she just will not own one. I really like both so it's a point of tension when time to shop for the new family hauler unfortunately.
    I'll give you the fuel economy but the safety is a toss up IMO. Especially if you live in an area that gets snow 5 months of the year as we do.
