Visitor Agreement.
Then the customers want it fixed under warranty.
Matt
It's good news to hear that your paint has not faded or oxidized and is a year older than mine. Thanks for the feed back.
Rotors can be warped by over tightening the lugs nuts. The tire techs or service techs get in a hurry and over tighten the lugs with air guns/wrenches. This happens a lot.
You can use aftermarket non OEM (original equipment mfg) rotors. I am not sure what brand would be better than what Honda uses.
I used to buy ATE and Brembo rotors when I was racing production based FWD cars.
That is not uncommon with repaint jobs, as they are not always applied and dried under proper conditions, and often with incorrect or cheap paint.
The dealer replaced the egr valve (recall/warranty) and told her she was good to go. Just found out that our dealer didn't get the service bulletin on the transmission till sep 03. I am deploying to the gulf at the end of the week and would like to know that my family would be safe in our odyssey.
American honda says that because we are now over a 100k they won't do anything. AHonda said that after calling local dealer that records only showed that we brought it in for the check engine light and that it was fixed by replacing the egr value, and we have no proof that there was a transmission problem. So, my wife continued to drive the van as is after being told that the van was good to go. The dealer never checked the transmission. After disscusions with AH for a long time I was told that "We won't do anything for you. Thanks for calling, have a nice day. CLICK "
Used to be a loyal honda customer.
Hi Steve or anyone:
Does anyone have the delivery checklist. I am picking up an Odyssey today.
Thanks in advance,
Emil
"Honda Motor Co has decided that a defect relating to motor vehicle safety exists in certain 2002-04 Odysseys and 2003-04 Pilots." (Certain Hondas but they don't know which ones). "Certain operating conditions can result in heat buildup in the transmission second gear and may lead to gear tooth chipping. In very rare cases, gear breakage can occur. Gear failure could result in transmission lockup, and a crash could occur without warning."
Anybody out there have this problem?
I've bought two Odyesseys: the first one was traded at 90,000 miles. The only problem I ever had was a check engine light. The second one now has 36,000 miles with no problems other than a leaky windshield.
that Odyssey had very high miles and a huge trailer hitch. It had been WELL used.
They have to use words like **can occur** and **could occur** in recall notices.
Get it inspected when you get a chance.
Any thoughts on this?
thanks.
Steve
It took two sets of digital images to get it cleared from Honda, but the new (I assume rebuilt...) unit has been ordered. Given the delivery time and dealer workload, they expect it to take a solid week. Fortunately, Honda and our dealer (Friendly Honda, Poughkeepsie, NY) is handling the situation with customer satifaction as job 1, and put us in an Enterprise rental Chrysler T&C van (fully paid, including supplemental insurance).
Nobody wants to have to contend with problems, but it is good to see a manufacturer and the dealers stepping up to the issue and handling it professionally.
PS: If you want to read my comments about Chrysler Stow-&-Go seats, see "Ody: Future Models" post 2048).
Steve
Replacement tires: I put 2 sets of Goodyear Aquatreads on my 2000 Ody and they were pretty good tires. They didn't last more than about 40K miles, although they have a treadlife warranty of about 70K I think. In any case they were way better than the crappy Firestones that came on my 2000 LX, fairly quiet and handled well. I put the second set on right before I sold the 2000 for an 04 EX-L. They are very resonably priced at Tirerack.com, where I have now bought 5 sets of tires, always awesome service.
Compare the Harmonys vs. Symmetry on www.tirerack.com
I do notice a "Kink" sound when going forward after backing up. Honda tell me it's the brake calipers making that sound. Has anyone else experience this.
Much Appreciated.
Chris
Note in the example in the Maine AG link, if you put 90,000 miles on your Ody tranny in two or three years, Honda is probably off the hook if it fails.
http://www.maine.gov/ag/?r=clg&s=chap6#6.6
rockycow33
I looked at the door myself and determined it was the latching motor/mechanism which needed to be replaced. This mechanism draws the trailing edge of the door into the door opening so that the door is flush (and latched) with the body.
Honda wanted to charge us $700+ to fix door (at about 55,000 miles). I stressed that I felt this was a safety issue which should prompt a recall by the NHTSA. The long and short of it is that Honda paid for the entire repair.
The doors on our Odyssey have accounted for virtually all of the problems the van has experienced (hopefully). We've probably had the van in 7 or 8 times for door issues BEFORE this past incident. Other issues have included the several recalls, Firestone tire balance problems, and a radio problems. So far (knock on wood) we've not had the transmission problem.
The van has 80,000 miles on it now. We tow a pop-up camper a few hundred miles every summer (tranny cooler installed) and everything seems to be holding together well and working (now). Occassionally we'll encounter a problem with the door open alarm going off on the sliders, but it is easily corrected by wiping the electrical connectors off with a piece of cloth to clean them.
FIRST TIME POSTING...
LOOKING TO PURCHASE UNUSED CROSSBARS FROM ANYONE WHO HAS FOUND THEY AREN'T USING THE CROSSBARS THEY PURCHASED ORIGINALLY WITH THEIR ODYSSEY...I LIVE IN LAS VEGAS, NEVADA...AND AS I DRIVE AROUND TOWN, I KEEP NOTICING ODYSSEYS WITH CROSSBARS THAT APPEAR UNUSED OR BARELY USED...WILL GO THE EBAY , ROUTE, TOO...JUST WONDERING...
THANK YOU...
I now have a 03 Ody and it's been hesitating and stumbling along for some time. No CEL or Fault Codes, though. Brought it in to my friendly local Honda shyster service this morning for the tranny recall and mentioned the stumbling and the TSB.
Service writer looked it up and told me that, since I have 56k on the car, it would not be covered under warranty and they woould charge $90 and change just to diagnose the problem. Repair would be extra.
I told him "No Thanks" and just ordered the part from from an on line source for considerably less than a hundred bucks.
At least Honda remains consistent.
Today I was standing outside of the van leaning over the passenger seat when I forgot (again) to be careful, and the door slammed into me, shoving my shins into the door opening. I'm going to have some really nasty bruises for sure. So I'm finally going to call today to see if they can do anything about the hinges.
Anybody else have this problem?
CURRENTLY I AM GETTING UNDER 15MPG IN TOWN AND 23 TO 25 HIGHWAY AND MY DOORS DO RATTLE VERY UNSATISFIED WITH VEHICLE
I also noticed that when I press the brake there's a squishy noise. The dealership tells me that's normal in a new van! Has anyone else experienced that? This being our first van, I don't know any better..
We were on our way out of town for vacation (prepaid resort stay), but Honda and our dealer (Friendly in Poughkeepsie, NY) extended the Enterprise loaner to cover the entire 10 days. Needless to say, we were extremely pleased.
Side note - even my wife, who has never really warmed up to the Honda, was very pleased to get back into it after 1100 miles in an '05 Chry T&C.
The new unit is quiet and shifts well. A bit smelly for the first week (some spilled ATF), but it seems to be diminishing.
Steve
Of course. Rental or loaners are almost always stripped, bottom of the line units.
My son's 2002 GC Sport is quieter and rides better than his bother's 2001 Ody EX.
