Honda Odyssey: Problems & Solutions:(1995-2004 Models)
16768707273126
  • My main point was to praise Honda (the company, and my local dealer) for doing the right thing, and handling the whole situation with style and grace. We are really going off topic here, but I feel compelled to reply, as you asked.....
    No, Allen, it was more than just that. The '05 T&C Touring is equipped pretty much 1:1 with my '02 Ody EX. Include the stow&go & power liftgate, trip computer, and you could say maybe even better equipped. The problem (and I speak as the former owner of a '97 Dodge GC) is really that it seems time has stood still for them.
    The front seats still lack support in critical places, steering is vague and slow to respond, suspension wallows with or without a load, cornering limits are low (and yes, the morning of our trip I topped off the tire pressure @ my house / digital gauge). The power doors kept getting confused and had to be reset multiple times. Fit and finish was iffy, inside and out.
    Stow&go is a neat idea, but not well executed. First off, they become very uncomfortable is a few short miles. You have to put the headrests at full to get them out of the center of an adults back. They had to move the spare tire carrier up under the dash area to make space. It hangs down too low, reducing ground clearance. The step in height seems to have been raised as well. Parked side by side, our Ody looked to have a lower floor, yet more ground clearance. Oh, and they had to route the exhaust around the seat tub - looked rather nasty on that side.... And just like on our '97, the A/C could not keep up in 85'F weather if you sat parked for more than a minute or two. The capacity on either the Ford or Honda units seem to be much higher.
    Things we did like - power liftgate is particularly handy when you have your hands full dealing with kids. Split rear bench stows nicely, but unfortunately was not as comfy to sit in as it looks (better in ody). It is a bit quieter, and maybe a little smoother (but what it gives up in handling was too big a trade-off for either my wife or I). Front seat cushion is longer, and fits American thighs better than Honda seat. His/Her HVAC controls reminded me why I liked my old Dodge.
    So there you have it. I had no real complaints about either my '97 Dodge, or our '00 Windstar. I just expected a lot more from a supposedly 'new' DC product. Maybe it is that they tried to graft too much new into a well used platform without going to a true 'clean sheet' design. Maybe the '08's will be better????
    Beth was excited when they rolled out the rental. She had been talking about one of these as her next van. A day in it was enough to make her consider trying out a Sienna or an '05 Ody.
    Steve
  • gunturguntur Member Posts: 19
    This has been a recurring problem with my Ody. When you pull the lever up the fuel tank door normally pops out but this pop up action gradually dies to the point you need to pry the fuel tank door to open it. It happened once and dealer adjusted it and it was fine for a year or so. Now it is on its way out, i.e., the door pops out only a tiny little and needs a gentle pry to open it. Is it possible to adjust it yourself without having to take it to the dealer ? Appreciate any suggestions. Thanks,
  • Your problem is probably one of two basics - either the cable operated catch is not retracting fully, or the spring/hinge is not moving smoothly enough to allow the door to pop out.
    Have someone pull the lever while watching the catch retract. Lube it (WD-40, or the like), to make sure it pulls in and pops out fully. Move the door by hand while your partner keeps the lever pulled. Is the door just reluctant to move, or is it hanging up on the catch? Most likely the hinge and spring need to be cleaned and lubed to restore the 'pop out' operation. A lithium based spray grease is best used here.
    Hope this helps,
    Steve
  • jscottkellerjscottkeller Member Posts: 4
    It took 4 trips to my local dealer to convince them my '01 LX had the EGR problem. With only 28k miles on the van we were experiencing the hesitation, jolting, etc. The first 3 trips they said they didn't notice anything unusual. Finally on a long road trip, the check engine light came on and I brought it back - low and behold they said we had a bad EGR.
    They did the fix, but here's my problem. It seems like we are getting terrible gas mileage since the fix. We just took a trip to the outer banks from NJ and barely got over 20 mpg. I used to get about 25 mpg on all highway drives. Has anyone else experienced this? If so, any suggestions?
    Thanks in advance for the advice.
    Jeff
    O2 sensor?
    Excuse my ignorance, but is the O2 sensor related to the EGR valve?
  • msibillemsibille Member Posts: 275
    Could be a bad, or more likely, not properly connected EGR.
    The EGR is used to recirculate exhaust gas as a virtual "inert gas". The internal combustion engine theoretically uses a the expansion of a heated gas to push the piston, turn the crank, and output mechanical energy. The gas is heated (internally) by the combustion of the fuel. Traditionally the gas was 100% (atmospheric) air. However, the air/fuel ratio must be within certain limits to promote combustion and limit temperatures. This means to completely fill a cylinder with a charge of "gas", one has got to input fuel in a fairly well defined amount. By using an "inert gas" to be heated instead of just air, you can limit the fuel, by limiting how much of the gas charge is actually fresh air. This allows the reduction of the amount of fuel to a level that would normally raise temperatures excessively and result in knocking.
    If the EGR valve doesn't actually open, or does so insufficiently, the charge will have extra air (at about 1/5 oxygen). This will precipitate a knock, unless the sensors (O2 sensor or the knock sensor) detect excessively lean conditions, and adjust the rate of fuel injection. So, you may be burning a bit more fuel because of a reduced amount of EGR.
    OTOH, I suppose it's possible that you were running excessively lean/hot before, but that probably would've shown up early on as a fault in the engine malfunction codes, triggered because the system was unable to bring the system back to conditions preventing knock or excessive 02 in the exhaust.
    I had bad oxygen sensors several times on my last van and they caused power loss and lousy mileage. Hesitation is another symptom, which made me wonder if it really was the EGR.
    Oxygen Sensors 101
    But since the techs diagnosed the EGR, Msibille's explanation makes more sense.
    More opinions can be had in the Got a Quick, Technical Question? discussion.
  • nolterdnolterd Member Posts: 7
    Any comments from anyone on this question. See 3566 for more detail.....help
  • bill9bill9 Member Posts: 2
    Just bought a 04 LX and start noticing water droplets (forming a pool) coming out of the muffler after driving. Is this normal? Thanks.
  • dave594dave594 Member Posts: 218
    If your engine hasn't warmed up it's normal to have condensation. Once it's warmed up there shouldn't be any.
  • tbrennatbrenna Member Posts: 1
    How did you find out the code?
  • hondaownerhondaowner Member Posts: 1
    My wife and I just purchased a 2004 Odyssey in July that just went over 3000 mi. We went on a trip last weekend (about 500 mi roundtrip) and towards the end ot the trip we started to notice a whining sound which has persisted. I'm scheduling an appointment this week to take it in to the dealership. It sounds to me it could be the transmission because of the nature the sound. Honda just dropped in my book. I owned a 2002 Accord before this and never had any problems. Looks like I should have kept it.
  • dgorendgoren Member Posts: 1
    I have hesitation and stumbling only when the pedal is held steady between 45 and 55 mph. Is this the EGR problem?
    Thanks Steve. Followed your suggestions and confirmed that everything was working properly. I fixed the problem by simply bending the latch on the door slightly inwards by couple of degrees so that it allowed the retractable catch to retract completely when the lever is pulled. This in turn allowed the door to be kicked out open by the spring switch which facilitates the sliding door to lock when the lever is pulled. Thanks for your help.
  • hondageorgehondageorge Member Posts: 1
    My power drivers seat seems to be "loose".
    It rocks left and right in turns and forward and back when stopping/starting.
    Has anyone else had this problem? or had it fixed?
    I was hoping that some adjustment could be made or a simple worn out part could be replaced. Otherwise, it will probably be quite expensive to fix.
  • Guntur,
    You are most welcome! Funny thing - a few days after I posted to your question, my wife mentioned problems opening the fuel door! Sure enough, it took fingernails to catch an edge. I lubed the hinge, and now it pops out about 2".
    Steve
  • koller1koller1 Member Posts: 7
    I have a 2004 Odyssey EX with about 8,000 miles on it. The other day when I pulled into the garage (my wife drives it) I noticed the Odyssey leaning a bit to the left (leaning towards the driver's side). I checked the tire pressure which was correct, the seats were all in, and my garage was level. I took a tape measure and measured the height from garage floor to the middle of the body over the tire. Just as I suspected, it was leaning almost a full inch lower to the left. Has anyone else run into this? Am I being overly critical? It's not a huge thing but it is slightly noticiable from behind the van. Also - FYI: it is the same regardless of a full tank of gas or not.
  • rsmbobrsmbob Member Posts: 13
    Hi all,
    I have a '99 Odyssey with about 115K miles on it and the last few weeks the air conditioner has been very intermittent/sporadic in any mode. THe fan keeps operating but often times blows only hot/humide air instead of the good stuff. When we had it in for service at the dealer, they found no problem and said the coolant level was good and there were no leaks, etc. THey could not replicate the problem. Of course, right afterwards we went on a 500 mile trip, and you guessed it, it was a non-air conditioned on for the most part, and not by choice.
    I am not an expert on how the AC systems work but to me it sounds like some kind of loose or defective sensor...the fan kicks on but the compressor doesn't push out any cool air.
    Any advice is appreciated.
    Bob in RSM, CA
  • bren3bren3 Member Posts: 23
    I'm sorry to say that my '03 (32.5K)had the same symptom. I've just had the transmission replaced at the dealership, but won't be able to pick it up til Friday due to my schedule. They tell me the whining is now gone. I sympathize with you. This is our 2nd Ody. The 1st was an '01 which we sold to our neighbors with about 38K on it. They have close to 90K on it with no problems.
  • jessica2jessica2 Member Posts: 4
    My new 2004 Odyssey has 400 miles on it. It has already been recalled for a fuel pump problem. Has anyone heard of this recall yet. Also, my Odyssey whines alot. Its lounder at low speeds and I notice it when I put my foot on the gas pedal. I think my car was built in June 04 - could it still have transmission problems. Once in a while I get the hesitation, but not all the time. The last thing is sometimes when I first put my foot on the brake it doesn't feel tight - it scares me at first. It only lasts a split second. What is that all about. I traded my windstar at 44,000 miles because the gas tank cracked and being alone I can't take the chance of breaking down. When I had Honda service drive the car to listen to the whine they said that is normal on all Odyssey's. It not real loud, but its loud enough. Are they telling me the truth or should I be concerned. Any help you can provide will be so very appreciated, because I have to take it back for the recall fuel pump repair and should address the other problems again with them if you think they are really abnormalities.
    I just noticed a story about it in the news today - few details.
    Reuters
    From a July 6, 2004 Article:
    Honda, Japan's third-largest automaker, said it would also fix a faulty fuel pump.
    The affected vehicles include 9,784 Inspire and Saber sedans produced at Honda's U.S. plant and 3,270 Lagreat minivans made at its plant in Alliston, Ont.
    The remaining 56,966 vehicles were produced in Japan and include Odyssey, Avancier station wagons and Inspire sedan models, Honda said.
    The vehicles were produced between Aug. 26, 1999, and June 2 this year.
  • konfrstkonfrst Member Posts: 1
    We had the same problem. It's the EGV valve. We had a friendly service rep who told us about it, but apparently Honda is hesitant to make an issue of it. It happens on some 2001-2002 models.
    Once the EGV valve was replaced, the hesitation went away.
    They may tell you there is no problem (which is what the first dealer told us), but insist they address the issue. We had warranty issues with this, took it to Honda Corp and they covered half the cost since the car was ever so slightly out of warranty.
    BTW - Dealing with Honda Corp is a nightmare - this will probably be our last Honda.
    I hope you can answer before I take the Odyssey to Honda today. When I put my foot on the brake and hold it sometimes all of a sudden the brake peddle no longer holds and goes down a little before it catches again. Does this make sense-its hard to explain.
  • wpalkowskiwpalkowski Member Posts: 493
    Your description is bit sparse. But from what you're describing it could be a symptom of a problem with the brake master cyclinder. Could have a small internal leak. Loses pressure momentarily , but will come back if you pump the brakes. Have it checked out.
  • auburn63auburn63 Member Posts: 1,162
    Basicly they all need inspection for water damage on the connector. If none is present then dielectric greese isput on and your done, if damages then connector and possibly fuel pump replacement depending on amount of damage
    The service manager rode with me and I finally got him to hear the whining sound. They diagnosed a power steering problem and must order the part to repair it. They could not find anything wrong with my brakes. Then as I was backing out of the dealership after leaving my car with them all day Friday I heard the weirdest sound in the back of the van. I have no idea what it is. Today when I backed out of the garage I heard the sound again. I guess I'll take it back again Monday. I told them since my van only has 400 miles and it has a power steering problem and the fuel pump problem I want them to give me a different new van. Of course they are not willing to do this, but this van was broken when they sold it to me and as I explained to them I could have bought a rental house for what it cost me to purchase the van.
  • dealmadedealmade Member Posts: 5
    I have a 2004 Odyssey (color sandstone),have a couple of chips/scratches on the van. Bought some touch up paint from honda but doesn't match worth a darn, any suggestions?...Thanks in advance.
  • 2004_odyssey2004_odyssey Member Posts: 1
    I just purchased a 2004 Odyssey and notice that when I am braking, especially from about 30-40 miles an hour, the the steering wheel shakes and vibrates more than what I would expect. Almost as if the car is shimmying? (sp). The car only has about 400 miles on it so far. Any thoughts ??? Has anyone else experienced or heard of anything like this???
    My gosh - you're also having problems with your 400 mile Odyssey. So am I and as I mentioned in my previous post mine also has 400 miles. My Odyssey was built in Lincoln, Al.in June 2004.Where was yours built?
  • oddster1oddster1 Member Posts: 3
    My 2003 with 22,000 miles has a similar issue - have had the EGR valve replaced three times and the problem is still there. I am afraid there is a trans problem with mine that my dealer is hesitant to diagnose. Anyone else experienced a similar problem?
  • scmelvin1959scmelvin1959 Member Posts: 13
    My 99 Ody has the Honda installed CD player. It can no longer play a CD past the first 2-3 tracks without major skipping. Obviously I need to replace the CD player ... what should I do? Get another Honda one (not my first choice) ... or is there another brand I can get that will work with the steering wheel controls?
  • cooldad24cooldad24 Member Posts: 163
    Your description sounds like pre-mature disc worn and need to be re-surface. This could came from poor installed caliper and malfunctioal spring and pad touch all the time from one side and barely touch on the other. Go back to dealer and have them to inspect the brake system. Ask them to fix as warranty. Any wear in 400 miles should be regards to manufacturing problem not regular wearing which is not covered in the warranty.
    Just a silly question: Have you ever tried cleaning the CD player?
  • dryanfldryanfl Member Posts: 1
    I have a 2002 EX with 31k mi. We have been dealing with the engine hesitation problem for about 18 months now. We have had the EGR replaced about 3 times in the past 6 mo. The most recent visit to the dealer they told me that they were using the wrong style of EGR valve in the past and that is why they have not fixed it. This time they used the "new" on but it didn't make any difference - same problem.
    The symptoms are consistent, when cruzing anywhere between 35 - 75 mph in either 4th or 5th gear you can feel the van bucking like the engine is hesitating or baddly missing. Then it will simply go away.
    On rare occassions, the engine will momentarily stall under acceleration and then pick right up and continue accelerating.
    This issue is very disappointing since we are happy with the van otherwise. I'm considering my legal options under the "lemon law" if the dealer can't fix this issue shortly.
  • ashton0999ashton0999 Member Posts: 1
    I am having the exact same problem of hesitation and stumbling with my 2001 w/52K miles. I can easily reproduce the problem on a flat stretch of road with the pedal held steady (again at 45 to 55 mph). Also curious to know if it is consistent with an EGR problem.
  • nissanfannissanfan Member Posts: 15
      My brother in law just bought, a week ago, a brand new 2004, Navy Blue EX with DVD. One week into his ownership, the back area/cargo area has this annoying and LOUD squeak. You hear the squeak while driving or when you have the van parked, open the tailgate and push down on the bumper or over the bumper where the cargo area starts. As the van bounds up and down you hear this loud squeaking and creaking and the van is only ONE WEEK OLD! Can someone explain if they have encountered this and what can be done? Thanks!
  • jaegerjaeger Member Posts: 1
    The 2004 Odyssey has a 20 gallon gas tank, yet I am only able to put at most 14 gallons of gas in my tank. I am also only getting between 200 and 300 miles for the entire tank of gas. I brought it to the dealer twice and they replaced the fuel pump which did not fix either problem. I opened a case with Honda corporate. They said the tank has a 5-7 gallon reserve and was revised in the 2003 model in response to complaints regarding heavy loads & towing. In essence even though my gauge indicates the tank is empty, Honda claims there is still between 5 and 7 gallons in the tank and I could drive 130 miles on empty. We find this extremely annoying and are constantly having to refuel. Is anyone else having this problem?
    I have an '03 and have also owned an '01. I too notice the fuel light comes on when there is still plenty of gas in the tank. I have just gotten use to it. Not sure why it is designed this way. I wondered if it had to do with the Japanese being more conservative. Anyway, I set one of my odometers to zero and keep track of the mileage. I don't let it get too empty as I do not want to damage the fuel pump.
  • jmellenbjmellenb Member Posts: 35
    I have a 2004 Odyssey with exactly the same symptoms you described about the fuel gauge. I previously had a 2000 Odyssey that had an accurate gauge. I was going to have the dealer look at it, but I assume they will have to pull the fuel tank & I don't want to have them do that. I agree though that it's very irritating.
  • I think you are going to find that this is a pretty common complaint across the model years. We let our '02 run about 300-350 miles or so (depending on the use conditions, that is around 15 - 16 gallons) between fillups. That sometimes means that the fuel light is on for a while, but we have developed faith that there is plenty of fuel left in reserve. A quirk, but something you get used to.
    Steve
    The Ody has a low, wide fuel tank. There isn't much play for the fuel level float to go up and down. On my 00, the light comes on with about 4-5 gallons left. Annoying - yes. End of the world - no.
  • tacpsydoctacpsydoc Member Posts: 1
    Well, for what it's worth...Driving my 2003 Odyssey (23K now) in the snow to Canada and back after it was given a clean bill of health was a white-knuckle nightmare last year. On 1 inch of slush it fishtailed horribly; it was like trying to steer a pig on rollerskates. Thank goodness I learned to drive in New England blizzards of the '70's with a Dad that taught me to drive almost anything anywhere under any condition. Other co-workers here report their Odysseys also handle poorly on snow rain or ice despite not having the same unique steering issue mine has (see below). So, it might be the tires and or a combination of the Odyssey design and the tires themselves.
    The frustrating steering problem with my 2003 Odyssey developed after an abrupt avoidance manuever caused by a woman slamming on her brakes mid-highway for a rabbit; I had to slam brakes and make an S-move around her to avoid her and since then the van steering is exceptionally loose and takes two hands to make a simple turn or to parallel park. 90 degree right or left turns require almost 180 degree or sometimes more turns of the steering wheel. Three visits to the dealer and a right with the service manger resulted in reports of 'nothing wrong' and 'it's the Honda feel.' This despite explanations that it didn't drive like that when I bought it and I've been driving Ford and Honda minivans for 10 years so I know how they handle.
      Now, frustrated, and with the notice of a possible transmission replacement or at least a modification needed, I'm torn between trying a 2005 or the Sienna (worrying too about sludge and handling issues too) since it seems unlikely Honda will ever find a fix for this one's steering issue. Unless anyone has other suggestions.
    I have a 2004 Ody as well with the same annoyance. Love the van but at 240 miles the fuel light comes on. I've just gotten used to it and drive it until 300 miles and fill up. The low fuel light is not a low fuel light to me; rather a reminder to get some gas.
    Also, my '04 seems very quiet on the highway. I can easily have conversations with anyone in the van. What's with everyone complaining about "road noise" etc.?
  • mazzonimazzoni Member Posts: 4
    I have a 2004 Odyssey that now has about 6500 miles. With off brand gas I only get around 11 mpg in town, with Shell I get 13. That's way less than my 98 Dodge GC with about the same size engine. Hwy mpg is from around 22 - 24. The dealer first told me there must be something wrong, then later said that was normal. Any suggestions, ie tire pressure, etc. I hate to use premium fuel at the current prices!
  • geosulcatageosulcata Member Posts: 3
    My 2002 Odyssey 22000 miles was working great until I took it in for the recall. They said it did not need to have anything replaced except the new part involved in the recall. Now, when driving 54mph the van jumps, or stutters. What is the problem? I want to get it fixed, but with 4 little children in car seats, I can't drop it off and get back home with the children. They will not give me a loaner van, they said their insurance will not cover it. I have the 7 year honda care warranty. Any suggestions on how to approach them about this. I am affraid I will take it in and they will say : we drove it and could not detect any problems.
    Keep in mind that Honda engines take about 10K miles before they really achieve better mileage.
    Further, in town, stop and go, short trips are the absoulute worst for mileage. We get in suburban driving about 15-16 on our 00. Long highway rides we get about 21-22.
    Personally I avoid off brand gas. Usually all gas comes from the same sources in one area - in metro Boston there is an Exxon/Mobil distribution center and an Irving that I know of. I've seen Shell trucks loading up at the Exxon/Mobil center. With the brand names, you get additives that help clean your fuel system which may improve your mileage. There is no need to jump to premium - just pay a few cents more for a brand name fuel.
  • bpdbpd Member Posts: 1
    I just had the same problem with my 03 Odyssey. At highway speeds at about 1400-1500 RPM, the car was jerky and jumpy. After three trips to the dealer and finally ripping into the service manager about their utter incompetence, they discovered that the EGR valve was sticking. In fact, Honda has issued a message to its service dealers notifying them of the problem.
  • paguy2paguy2 Member Posts: 26
    42K Miles on 2002 Ody. Engine Check and TCS lights coming on intermittently. Took it to local dealer. Dealer tells me that Fuel injectors need to be replaced for about $700. Does that sound right?
