Honda Odyssey: Problems & Solutions:(1995-2004 Models)
1102103105107108126
  • vonnie1vonnie1 Member Posts: 2
    We've had our 2000 Oddy since it was just a baby and have been happy with it in the overall scheme of things. Problems here and there, nothing that hasn't been covered in these forums and I've read some about what I want to discuss.
    We were on vacation when our emissions systems light came on. I mistook it for the "maintenance req'd" light, because I knew THAT light would be coming on and had already scheduled our 90K mile service. When I took the Van in for service the next week and then picked it up I didn't see the light on 'till I'd left the lot. I called and asked what was the deal and they said "it was on when you brought it in"..... alrighty.... I'd just spent $460 for a 90K mi service and they didn't address an existing issue. Needless to say I got a little snarky then called my husband to please talk to them since I was on overload. In the end I brought it in the next day and they checked it, found the problem to be a leaky gas cap and changed the gasket all at no charge. That made me happy. Unfortunately the happiness was temporary. Around a week later the light came back on. Once again (yes we did try these the first time after I'd noticed the light after the service) I tried all of the tricks to get the light to turn off and on the advice of the service lady drove 10 -12 trips (she said the 3-6 trips don't always work to turn off the light). To no avail. $104 and 4 hours later they replaced the existing gas cap (with the replaced gasket). (Cost of cap... $10! uggh!).... Light was off. Here we are another week or so later and the danged light is back on. Tried all of the tricks again and the 10-12 trips. It's scheduled to go in again tomorrow. Husband is going with me.
    What I wonder and what I'm most frustrated about of course is the cost of all of this. Exactly how many times should *I* have to pay the danged labor costs (parts cost not withstanding) while they figure this out? Especially if it's found to be a faulty gas cap. They said it was a _ _ _ _ code (can't remember the #... probably on my paperwork) and that amounted to a gas line leak(or something like that) which added up to my gas cap being replaced. Am I or should I be responsible for this ongoing issue if it's something along the same lines but should've been diagnosed as something MORE than the gas cap in the first place?
    I guess my real frustration is that I can understand if it takes MY Dr. several times and many tests to diagnose something odd going on with me.... BUT I don't have a computer in me that spits out codes that gives the Doc a diagnosis. So I really don't understand the ball being dropped here.
    Any insight? Am I off base being so frustrated? Am I right on? Am I in left field speaking a totally foreign language? LOL!
    Thanks for any advice you can offer.
    Vonnie
    Oh yes... I have searched the archives and found "some" on this but nothing specific enough and hope no one minds me burning a new thread here.
  • coolridecoolride Member Posts: 1
    hello! just got my new odyssey a week and a half ago. loving it, but a problem arose today. there is a rattling noise coming from the left rear corner. it sounds like empty tin cans being tossed around back there and especially makes it when you turn sharply or go around a curve. anyone else had this problem? the dealership said to bring it in but I'm waiting for them to start fixing the new recall item at the end of the month and will then go rather than making two trips...any insight to this problem would be greatly appreciated! oh, also, just curious -- i read the above post about the 2005 odyssey being the worst ever -- do you guys think that's true? hope i didn't make a bad choice... :confuse:
  • stickguystickguy Member Posts: 54,778
    2 things that have cropped up:
    1) rear liscensce plate loose (odd but has happened).
    2) more common, the nut that holds the spare tire and/or jack in place is loose. SInce the spare is in the left rear, a likely culprit. Open up the tire cover, and make sure that everything is tight.
    3) One of the kids left a soda can under their seat, and it is rattling around (hey, you never know!)
    I think worst ever is a bit strong. There have been some unfortuneate teething pains, probably a combination of a new design + new plant and workers. SHouldn't happy, but it does. Quite likely tht the '06s will be more "hondaish".
    i'm not sure i can offer much, except if the system is generating a code indicating there is a gas line vacuum problem which leads them to believe they need to change the cap, then i would think after a few attempts, the problem lies in the gas line itself, or the sensor / sensor wiring that does the detection in the first place...
    why don't you calmly suggest that with the cap seal replaced once, and the cap replaced, perhaps the real root cause lies elsewhere, but results in the same code.
    i have to ask - you are properly tightening the cap so you hear at least three clicks right? ;)
  • dansgirldansgirl Member Posts: 14
    3 days in the shop, and still no resolution.
    I am picking up my vehicle today because they say there is no risk in driving it, and they have ordered parts that will not be here until some time next week. They have been working with Honda Tech Support, and are only 70% convinced that the parts they ordered will fix the issue...makes me feel so reassured. Anyway, they think the solution is to replace the front and rear engine mounts. I'll let you know if this fixes the problem next week.
  • jodiebjodieb Member Posts: 4
    We had a whistling noise on the driver's side from the day we drove it home. It was determined to be an air leak due to a defective cowling. The cowling was replaced and 3 clips were broken. The windshield wouldn't seat right on the passenger's side, so more clips and retainers were ordered. Then 2 clips came loose & several were missing, so they were replaced. When that didn't fix it, the dealer had to have a glass shop reseal the windshield. Thank goodness the windshield never cracked or came out.
    I just posted my windshield situation for someone else. The bottom line - things kept breaking, and after 4 months, my dealer finally sublet to a glass shop to reseal the windshield.
  • johnmvjohnmv Member Posts: 1
    I also have a 2005 Odyssey that gets about 14.3 mpg in town and 21.2 on the road. My dealership said it was normal and would improve after it broke in.
    At 2980 miles I took it in for an oil change and asked them to check it. They found nothing wrong and claimed that was the mileage that the vehicle gets. I mentioned the sticker mileage and they said that they were not responsible for those estimates 20/28 and must report those numbers. Testing is done by EPA. The national customer service was no better. Please contact me if you have similar results or improved mileage. I am going to pursue this as best as possible.
  • bostongardenbostongarden Member Posts: 25
    Sorry to be cynical about this, but (smile), I have a 2001 EX with 42K miles and no extended warranty. An O2 sensor needed replacement (code P0141) and the dealer listed "goodwill repair" and no charge for the part and did charge me for labor. I was very happy to see that the final cost was much less than the specified cost indicated before I approved the repair.
    I am aware of goodwill repairs authorized by Honda where the charge for the total job is $0.00. Now the cynical question: Is it reasonably conceivable or likely that Honda authorized the goodwill repair and paid the dealer for the entire job (that is, part and labor, although, understandably less than what the dealer would typically charge for the job) and that the dealer elected to not "pass along" the entire goodwill "value" to me? Or, do other types of goodwill repairs exist, for example, just for the part, or those provided by the dealer (without any interaction or authorization from Honda)? Marketing effort by the dealer?
  • uncletreeuncletree Member Posts: 1
    proud owner of first 2006 on the block. Touring model really not much different from 2005.
    anybody have this problem? the range "miles to empty" keeps showing zero miles. it doesn't change no matter how much gas i have. Anybody know how to kick it so it will work? Everything else works on the multi-info display!
    Less than 3 days with the 2006 and already there are problems!
  • dukebxrdukebxr Member Posts: 1
    Have they fixed this issue to your satisfaction?
    Here's my nightmare story: I picked up my new Ody last Saturday and brought it back to the dealer on Monday to resolve the whistling noise. Dealer said they can't locate exact problem and will work with Honda tech line. It is now Friday and no resolution. I have asked the Dealership to keep it and give me my money back. We'll see what happens.
  • attilauyattilauy Member Posts: 32
    We experienced some noise from left back portion of the van. It was a loose nut and bolt that was supposed to hold the spare tire in place, in effect, the tire was banging the wall everytime we accelerate or decelerate. You may have the same problem.
  • oohaypuoohaypu Member Posts: 7
    I had mine for a month now with 1700 miles.
    The van pulls to the right side most of the time.
    Dealer swapped front tires but the problem was still there.
    They re-aligned the van second time with some adjustment to left, but that didn't fix the problem either. :(
    The dealer told me that this is the driving feature of Ody and I am not the first one to notice that but it is not a problem.
    Is that true?
    Also, there is a paint deffect and the dealer installed full nose mask and spash guard as a treat.
    I am not fully happy with the Ody as I had a accord before w/o any problem for the first 8 years.
    However, with my experience on other car and SUV, this is not too bad.
  • shopaholicmomshopaholicmom Member Posts: 5
    Hi! Has anyone noticed a brushing feeling when you accelerate your odyssey?
  • oddproddpr Member Posts: 1
    I picked up my 05 touring on sunday and noticed the same problem. Took it to Fuller Honda in Chula Vista. Frank in service showed me a memo from Honda that the van was designed to drift to the right on level ground one lane in six seconds. I hate it you have to apply constant pressure to the wheel to keep the car straight. I took it on thursday to the best alignment shop in town and they said the front alignment is perfect. I'll keep barking at Honda until they come up with a solution.
    Perry....
  • protraderprotrader Member Posts: 3
    Dansgirl and others...
    We have at 2005 Odessey Touring... beautiful... 3400 miles... all the sudden we have a small tremor when driving and a bit of a whining sound. Can only tell because the car was so quiet and smooth to begin with.
    Took it in to the dealer... 20 days and counting later... NO RESOLUTION!!!
    First the replaced the drive shafts on the driver side
    Second the replaced the ball bearings
    Third... ready for this... BRAND NEW TRANSMISSION!!!
    Fourth... Engine mounts
    Fifth... Tires!!!
    Sixth... Monday they will replace the rotors!!!
    We have started mediation talks with Honda and contacted a Lemon Law attorney as this car is now officially a lemon. WOW I can't believe it!!!
    Question to this community... My wife and I both love the Honday Odd. I am not a fan of minivans but this one... I love. What would you do? Get another one? Or move on to a different minivan family?
  • Took it in to the dealer... 20 days and counting later... NO RESOLUTION!!!
    Fifth... Tires!!!
    I think they have no clue! A new dealer may be in order! Mine has 5000 miles without a hiccup. can't believe that they changed the Tranny without knowing for sure. Thats not a good sign.
    Actually the dealer has not done ANYTHING on their own execept the drive shaft.
    The dealer has been directed by Honda's Tech Service out of California to make all of these changes. In fact the dealer states that he car is too new for their own mechanics to pinpoint the issue hence Honda Tech is directing all the repairs.
    At one point they were going to send out an engineer to look at it. But God knows what will come of it.
    After reading though this message board... I am becomming quite perturbed about our purchase. We are a family of Infiniti's have owned them since the wife graduated MedSchool. This is our first Honda and well the CAR itself is what I expect of a 40K car when they replace the transmission and they still don't know why the noise is comming... what do you do???
    Any lemon law experts know if this would qualify?
    20 days... one visit
    6 repairs, 3 major ones
    same problem persists
  • driverbri3driverbri3 Member Posts: 5
    Just got my 05 EX-L. Everything okay so far, although I'm not pleased with a few design quirks:
    Dashlights are quite bright, even when lights are off, so driver is not prompted to turn lights on at dusk.
    You need a screwdriver to retract the plus-one seatbelt back to the roof. (???!!)
    Power sliding doors driving me crazy, but I'll probably get used to that.
    Anyone else frustrated with these items?
  • ilmh497ilmh497 Member Posts: 1
    We have a 1999 Odyssey with about 84k miles
    which has been running fine until last Tuesday 08/23 when the check engine light/TSC(occasionally) came on and the van started to run rough. I read the owners manual and it said to check the fuel cap and if ok, advised to take it to the nearest dealership to have it checked. I did that and the diagnosis indicated misfiring of 5 of the 6 cylinders. The EGR according to the dealership was fine. The service dealer mentioned that there was fuel contamination and recommended to remove fuel and clean system and a throttle body cleaning and refill with premium gas. This option would cost about $1058.- We don't know if this would solve the problem. We took the car back to see if we could get a second opinion and see what other options we have. Has anyone experienced the same problem with the engine and if so, was there a solution?
    Any information on a similar issue would be greatly appreciated!
  • sebring95sebring95 Member Posts: 3,241
    It is a goofy design. I just leave my headlights on all the time, they turn off automatically a few seconds after you shut the drivers door. The Touring has real auto-headlamps, it's apparently a luxury feature on Hondas books.
    Not quite. Just use the seatbelt latch, it fits in the gap to release the other latch.
    A little more detail could help! What's driving you crazy?? I have zero complaints with mine, can't imagine not having them.
  • jipsterjipster Member Posts: 6,302
    I would keep the van if I were you . Eventually the dealership will have replaced every single part of your van... AND viola....new van!
  • windowproblemswindowproblems Member Posts: 3
    oh my gosh! you are right! why do they do that? I guess it doesn't really matter, just good to know I am not cracked, but you would think the dealer could have come up with that answer.
  • rn9rn9 Member Posts: 3
    This is my first posting here.
    I have this problem with my 2000 Odyssey EX. 68K miles.
    When I turn on the A/C it blows cold air for a while and then after sometime it starts blowing the hot air. I reduce the A/C by a degree or so, the A/C starts blowing the cold air again. Then after sometime it starts blowing the hot air. The cycle repeats. It doesn't matter what the outside temp it is, day or night, etc.
    But during all this, the rear controls is not affected and continues to blow cold air through out.
    Has anybody experienced anything similar to this? Any help would be appreciated.
    I hate to go to a dealer without having any clue what the problem might be.
    To those of you who have been participating in this forum for some time, could you summarize the "likely" problems a Honda Odyssey buyer might face, or would have had to hassle with to get fixed when he/she bought the van?
    In other words, what's to watch out for on this van--problems, defects or quirks that you have noticed turning up again and again in this forum?
    thanks!
    Shifty the Host
  • kstanleykstanley Member Posts: 1
    hi,
    the 3rd row seat strap got stuck after the seat is folded down onto the floor.
    now..no way to lift the seat back up without any leverage...so the seat seems
    stuck, and I can seem to lift it back up without the strap...any suggestions?
    thanks alot!
    Thank you for your reply. It does indeed turn out to be a problem further up the line. It's under the hood some part (which I fail to recall the name of it at this moment) near the battery. When their mechanic stopped and listened to the system, apparently, he heard a leak. Called the tech line and they advised him to wait 'till the engine was cold and start it up then and listen and check something more/else (?). So we left it over night and in the A.M. he was able to confirm it was the problem he thought.
    The part will be here mid week this week as far as we know. 'Till then they've given us back our van and ok'd us to drive it telling us no damage will occur. They've been very kind and helpful and we've been pleased so far with the way they're handling all of this. :)
    I do appreciate your insight and trying to help. I do always tighten my gasp cap so I hear it click a few times (more than 2 or 3 times) every time...since the first time THAT was what it was years ago! :blush: LOL!
    Thanks again.
    Vonnie
  • dsrtrat2dsrtrat2 Member Posts: 223
    Try some thin strips of plywood with the edges and corners sanded off as levers. Stick them down between the seat and the rear ledge of the well. Pry up a bit, then put another strip in to get a new bite on the seat, repeat.
  • grandtotalgrandtotal Member Posts: 1,207
    You can open the seat using the hand hold in the back of the seat, it's not as easy as with the strap, but you can do it. If you really cannot then it's just possible that the seat is stuck because it has not quite been completely folded down. If that's the case apply pressure (or your weight) to the back of the seat until it clicks into the fully down position then lift it with the hand hold in the back of the seat.
  • rblmsrblms Member Posts: 1
    we got our 2005 honda odyssey ex model 2 days back and when we drove back home and while driving yesterday, both my husband and me got a bad headache and kind of motion sickness, some sort of smell also but we thot its new car cloth smell. So today I tried to keep all windows open, still didnt help much !
    any idea what it could be ? or someone else had a similar prob ?
  • odsyodsy Member Posts: 1
    Hi There,
    Any luck on the solution to this problem yet? My Ody 2000 left door has the same exact problem.
    Please Help!
  • rockycow33rockycow33 Member Posts: 76
    I'm not certain if you A/C is functioning correctly, however, according to an A/C engineer in Texas, when the A/C if off the 60 degree mark, some hot water is circulating in the cooling system. I would try putting your A/C on 60 and adjusting the fan to see if this might help. I don't recall having our A/C blow hot air though.
    Hope you find a fix.
  • Remember that the front system is thermostatically controlled, while the rear is not, so you cannot compare operation front to back.
    With the back system, you really can only control the fan speed, and whether it comes out the ceiling (a/c) or floor (heat). You have no control over the absolute temperature of the air.
    The front system uses a cabin temp sensor to control the vent air temperature. I have never worked on a Honda system, but it probably is much like others. Typically, both freon is flowing thru the evaporator, as well as hot water thru the heater core under the dash. A set of air doors direct flow between the 'cooler' and 'reheater'. In addition, valves control the flow of freon (cooling) / antifreeze (heating) thru the respective cores.
    On my '02 EX, when you first select a temp with the fan control on auto, the air will blow cold until the sensor says the temp is reached, at which point the fan will slow, but the air usually remains somewhat cool to maintain the setting. I don't think the air is as cold (probably some warm air is been mixed in), but I cannot remember feeling it actually go warm. If you dialed the temp down a degree, the fan will speed up, and the air will get colder, until the cabin reaches the new temp.
    I suppose the air could conceiveably get considerably warmer if say you went from bright sunshine into deep shade, like a tunnel. If this is not the case, perhaps you have a sticking valve on the heater core hot water line, or an air door isn't responding right? Or the temp sensor itself (or receiver unit) is screwed up?
    Steve
    Thanks for your reply. What I have noticed in my EX, for the rear control - there are two controls in the back - behind the driver seat on the roof - (one is the fan - to control the speed of the air flow, and the other the temp control - to reduce or increase the temp). Ofcourse on the front dashboard I see only one control for the back - just one to adjust the temp.
    Now, for the front side A/C, I live in Florida, where currently the temp is in 90s. I set the temp at 85, blows cold air for a while, and then switches to hot air. I don't think its any leak in the Freon. Because if so, even the rear A/C would have had the same problem.
    I am thinking there are might be two sets of controllers (one each for the rear and front). And possibly my front controller has gone bad. And to me this controller is something which regulates the cold air and hot air in the van depending on the temp settings I have made using the dial on the dashboard. This is my theory.
    Does my Controller theory make sense? Also do you think I might damage the entire A/C system by driving around like this?
    Thanks guys.
  • rorrrorr Member Posts: 3,630
    "Ofcourse on the front dashboard I see only one control for the back - just one to adjust the temp."
    Actually, I think the dash controller only adjust the rear fan speed, not the rear temp.
    The problem may be that you've set the temp too high (at 85) coupled with the location of the in-cabin temp sensor. After blowing cold air for a while, it may then detect that the cabin air is too low (82 or 83) and then switch to warm air to bring it back up to 85. You might try either a lower temp to see if the same problem occurs or use the system in manual rather than automatic mode.
    If we're talking '05+ non-touring models, from what I've gathered, the rear air temperature is controlled by the drivers temp setting. So it will send the same air temp to the rear as it sends to the drivers front. You can control the fan speed for the rear as well. I would have preferred the full 3-zone system of the Touring (as I was used to that in my previous SUV) but I've been satisfied with how this system works. No complaints in the rear, I just usually start bumping down the rear blower when auto system starts cutting the front blower.
    The windshield was fixed to our satisfaction (just within the 4 month requirement for the lemon law). Its the laundry list of other broken parts and problems we are tired of getting fixed. We are drafting a letter to our dealer to see what our options are.
    The reason I set this at a relatively higher temp (though outside it is in mid-90s), is to get cold air-hot air process started. Though keep in mind that low 80s still cool air when outside is that hot.
    And I am trying this in Manual mode. And not in Auto mode.
    I have tried at lower temps and hot air still blows, but though after a relatively longer period. (after it has cooled the cabin and reached the low temp).
    When I have tried at say low 70s, when the hot air starts blowing in, you can feel it as really hot.
    I started noticing it a few weeks ago. I was rear ended a while ago. So I am not sure whether that caused. Try telling that to the insurance agency -)
  • huffyhuffy Member Posts: 10
    We purchased our 2005 Odyssey EX-L about 2 weeks ago. Yesterday, when starting, the ignition would click for several seconds and the lights would flicker. Then finally, the ignition would work and start the van. Today, after dropping one of my kids off at preschool, my wife went to start it and nothing. The windows, radio, etc still worked, but it wouldn't even try to start. Then the accessories seems to die off too after several minutes.
    Our Honda dealer is sending a tow truck as I write this to pick it up. I realize this will be covered by warranty but I was wondering - does this sound like a dead battery or a starter or an alternator problem? The van is 2 weeks old and only has about 700 miles on it. I hope this isn't an indication of bad things to come.
  • i_wanitfixedi_wanitfixed Member Posts: 7
    Well after about 9 days in the shop on the third visit for this problem, the car finally died while in the shop. After finally deciding to call Honda Engineering, the dealer determined that the "matrix module" which is or is part of the fuse box was defective. Supposedly, it had a pin on the connector which some how was causing an excessive drain. After 14 days, I got the car back. Will have to see if this actually fixes the problem. In the mean time the battery has been deep cycled 4 times which the dealer insists doesn't harm it.
    The dealer said the battery was dead and replaced it. They claimed that they checked and there was nothing causing an excessive drain on the battery and that sometimes, the batteries from the factory are just bad. We'll see. I was pretty pleased with the prompt dealer service - although I am still in the honeymoon period with them (I haven't been called by Honda yet for the dealer survey). They even washed the van for me and called after I got home to make sure everything was okay.
  • jcyclejcycle Member Posts: 8
    I misplaced my manual/user guide. What should be the front/rear tire pressure for 05 Ody EX-L?
  • I don't have an '05, but that information is typically included on a sticker on the drivers door pillar (B pillar).
    Steve
  • premsterpremster Member Posts: 2
    I'm having the same problem. My 05 EXL-RES is about a month old. From the day I drove out of the parking lot I started to experience a steering wheel vibration. It was bad and started at 65 and continued to 75mph. I took the vehicle back to the dealer the very next day and they balanced the wheels -- each wheel was off drastically. That same day I tested the vehicle and experienced the problem again – just not as bad. Went right back to the dealer and the service manager said the wheels zero'd out. He told me to come back a week later after he sent a mechanic out for training on the Hunter machine. Went back to the dealer a week later and this time they forced balanced the tires and found them to be 10 grams off each. The also found a service bulletin on the issue (see, we're not alone!) and the bulletin suggested a toe adjustment -- which they performed.
    Things are better now but not completely perfect. I have NO vibrations on some roads while others give me a HINT of vibration. I also adjusted the tire pressure down to 33psi from the recommended 35. So far I found the psi adjustment to make a big difference in ride quality and the vibration is down to a slight annoyance at 70mph. I'm still not happy as I don't expect any vibrations for a 30k+ vehicle but I'm going to give it some more time. I truly feel at this point that the tires are at fault and that the steering wheel is just overly sensitive for these tires. I will update the forum if I discover something new but tell your dealer to check on that service bulletin to see if that helps. Not sure if the psi fix will work on the PAX tires but check into that as well. All in all I think I would have been happier with the Toyota Siena. :cry:
  • on the roof - (one is the fan - to control the speed of the air flow, and the other the temp control - to reduce or increase the temp). Ofcourse on the front dashboard I see only one control for the back - just one to adjust the temp.
    Again, if you take a good look at the labeling and functions, these rotary knobs only control the fan speed, and the mode (heating thru rear floor vents or cooling thru ceiling vents). The dash knob combines both rear knob functions into one.
    We run the front system almost exclusively on full auto, with the temp setting at 68 - 69' F. With it set this way, the system cycles as I described yesterday. If you are running the fan speed manually, it might account for why you get a blast of hot air. The system's first line of adjustment to maintain cabin temperature seems to be to reduce the fan speed from full blast to minimum when the desired tempature is reached. If you have set the fan speed yourself, the system cannot adjust this, so it's next course of action would be to switch on the air reheat function to warm the interior up. I would imagine the same thing could also happen if you had the rear fan on cold high. If you overcool the interior using the rear, the front might switch on heat to compensate.
    Try using full auto mode and see if the system acts normally.
    Steve
    See my message #5437 regarding similar problem with excessive drain leading to dead battery and honda's solution. Mine had about the same mileage when the problem first started, and it took about 5 months to get to the bottom of it. Still not sure the fix will solve the problem.
    In your case, it could be the battery, but not necessarily so. At least your dealer washed the vehicle. Mine left it out for 2 weeks and it came back dirty inside and out. Have dealer check with honda engineering. In the mean time, keep a jump start battery or cables in the car. You might need them even with a new battery if the problem is excessive drain.
    If, like mine, yours needs a matrix module, it will probably have to be overnighted in, along with some 1 use trim panels that are destroyed in order to get to the part.
    Let us know what happens.
  • rshtrsht Member Posts: 277
    Sorry to hear that both you and oohaypu are having drifting problems with your alignment... Just want to share with you that is not the case with my wife's 05 Ody, it runs almost perfectly straight with bearly any drift at all. But, the bad news is that from time-to-time we hear a CLUNKing noise from the right front suspension as the van is moving forward from backing out of our garage. It doesn't happen all the time only once in a while... I am pretty sure it not related to the bearing problems I heard from this forum as the noise came from the Spring/Struct... What a piece of 2500 mile C&@P !!!!
    My 05 Ody (spec on the door sticker) calls for 35-lbs front and 35-lbs rear when they are COLD. However, the Manual calls for 33-lbs... I would and have followed the spec on the sticker as fibber2 posted.
  • ads1978ads1978 Member Posts: 6
    I believe that the lemon law states that the car is a lemon if:
    The vehicle is in the shop for 20 days or more.
    The vehicle is in the shop for the same repair 3 or more times.
    I remember my father had a 95 Ford Windstar in 94. He had a transmission replaced at 11,000 miles, and an odd clunking noise. The dealer tried a few things to fix it, but no correction. Finally, the sent out a Ford rep to go for a ride while my father was in the car. My father pointed out the noise to the rep, and he said that there is no problem. Could you believe that the factory service rep, even while hearing the noise, said they will not fix it further.
    He took it to another dealer outside this rep's zone. A service tech went for a ride, heard the noise, and 2 days later, it was fixed, and no more noise.
    Since you are so far into this mess with the Odyssey, I would reccommend that you go ahead with the lemon law process. Chances are you wont get too far, as the dealers will usually just settle it with you before it gets to the end, as it costs them more money and more publicity. If I were you I would stick with the Honda, and find yourself a new dealership for service. :lemon:
    I haven't looked in the manual but I find 33 lbs to give a much better ride without sacrificing fuel economy or handling. 35 makes the steering wheel jittery and prone to vibrations on certain roads.
