Visitor Agreement.
The scenario goes something like this:
If the temp outside is <70, starter works fine, RPM shoots up to 2500+ then instantly plummets to 0.
This occurs indefinitely unless I lay on the gas and hold it at 2000 RPMs for at least 20 seconds (eek fuel injectors).
Then the car will continue to run but it idles very loudly and shudders almost constantly.
The RPM doesn’t jump around very much during these shudders but occasionally it revs itself up to 1500 at idle for 30 seconds or so.
My gas mileage used to be 27-29 highway, 25 city and now it’s closer to 20 highway, 12-14 city
I’ve tried higher octane gas and fuel injector cleaners to no avail.
I feel like I need to lead these dealer mechanics by their collective hands but I have no idea how to do it.
Thanks in advance for any ideas...
4 Recalls
Frozen motors on sunroof and both windows
Broken windshield washer fluid pump
Leaky door seals
The warranty isn’t worth it
thanks in advance to all who can offer any kind of help
To those that are looking for cars that are investments, there arn't many. In fact, it is a stupid idea in the first place. Cars are money pits. The reason you look for a car is to find one that you visually love and like the performance as well. If you like the Tib..GREAT! If you don't, find one that suits you. Nobody or no salesperson should be able to talk you into a car that you don't want. Stick to your guns and choose wisely.
Are there faster cars on the market? Absolutely. The one thing I can say is this. The Tib has a great warranty and also is a solidly built car. The safety is good and the gas mileage is decent. Go drive one and see if it works for you. If it does or dosen't, at least you know for sure.
Ever car has some issues, it's up to you to be happy. If car buying was an exact science, Edmunds wouldn't have much to write about. Also, go and price the cars...last I heard a new Suburu WRX STi was goin for about35K to 38K. An 05 Tib SE is roughly 21K to 24K depending on options. Is having a turbo worth that much more?
and maybe i'm a little crazy but does anyone think that 19500 is a bad price for an 05 tib se with 1200 miles on it already? i mean in 3 months the 06's will be out. the dealer is being really hard to work with here and from what i can gather, the particular car i'm looking at shouldn't be more than 20k. i dunno, it's just that as stated above, you know that the car was driven hard and improperly broken in. i've been pretty consistant with the price i'm willing to pay for the car and they've been pretty stiff on what they want. if i'm being unreasonable i can re-think some things but anyone have any input?
The WRX STI is a great machine but not worthy of a $30+ price tag. It doesn't even give you a stereo as a standard feature. What a rip-off! The Tib gives you a lotta fun plus an aftermarket supply of endless modifications. Go with the wise bet, not to mention, the warranty.
SO I love my car! Good luck in your purchase.
Discount auto parts sells a clutch and flywheel kit for something around $300. I know a certified mechanic that can put it in for ~$300. I'm scared this will void my warranty and the clutch part will just go bad again as it will not be the one they recommend in the TSB.
I tried calling Hyundai consumer affairs and they don't seem willing to help. They tell me to talk to my dealers service dept.
What can I do? I don't want to pay $2,000+ for a clutch replacement. I have to do something soon as I can't even drive my car anymore... I've had so many problems with this car. I had to have it towed 2 times before this due to the alarm unprogramming itself on the car while enabled; disallowing me to start it. I've also had to have the locks fixed 2 times. This is the third time may car has been disabled and undriveable. The lemon law requires the car to have the same problem 3 times making it undriveable right? Please help!
:mad:
1) Contact your regional Hyundai Rep and pleade your case to him. Make sure you tell him you've had all service done by the dealer since new.
2) Call the Hyundai customer service 1-800 # and tell them your case. Cant hurt.
3) I wouldnt go with the dealer on clutch replacement only because they are charging way too much. If you use an outside service to replace your clutch it should not affect the warranty on the rest of the car. The dealer would have to prove that the clutch replacement affected something else in order to void your warranty.
4) If it were my car I would not go with the stock clutch. I would find a heavier performance clutch (Centerforce,etc) to install.
Here's the link. I haven't looked up the flywheel yet. Tell me what you think
link title
I just purchased an 01 Silver Tiburon with a light front hit to rebuild. I've located some parts, but need more. Looking for a right side headlight and front bumper. Any one have any for sale?
Mike
1) On the right side of the spoiler, some of the protective rubber layer has moved out from between the hatch and the spoiler and is exposed.
2) When I opened the hatch, I noticed that where the two anchors are, where strings run downward to the compartment cover, that the plastic molding is developing cracks around each anchor.
Has anyone experienced this, and what's caused it, and how was it fixed? Does the Hyundai warranty cover it?
Also, has anyone used a car buffer on the Tiburon with the black clear coat finish? Opinions on the results?
I haven't heard about any cracks on the cargo cover anchors, but I suppose if the cracks are bad enough, they can be replaced under warranty too.
http://www.alpine-developments.us/
There is no TSB on the 2003 Tib for this BUT there are two TSBs for water leaks in the 2003 Tiburon. One for the sunroof and one for general water leaks. You might point the dealer in the direction of this connector. Here are the two TSBs available at :
http://www.hmaservice.com/webtech/
Technical Service Bulletin Group
60 - Body
Number
03-60-003
Subject
Date
Water Leak at Sunroof Opening (Infinity Amplifier Wet)
06-2003
Model
Tiburon 2003
WATER LEAK AT SUNROOF OPENING (INFINITY AMPLIFIER WET)
DESCRIPTION:
Some 2003 Tiburon vehicles may develop a water leak from the rear of the sunroof opening. If a water leak occurs, it can leak into the Infinity amplifier, causing static or no sound from the audio system. Other symptoms include wetness on the C pillar trim near the seat belt holder, or a damp rear seat.
60 - Body
Number
98-60-001
Subject
Date
WATER LEAK DETECTION AND IDENTIFICATION
02-1998
Model
All Models
This TSB supersedes TSB# 95-60-002
DESCRIPTION:
This bulletin provides detection methods and repair procedures for interior water leaks.
DIAGNOSIS PROCEDURE:
First, use the customer's statements to determine the following:
Where is it wet? (near the wheel house, in the spare tire well, at the front, at the back, etc.)
When does it leak? (while parked level, while parked on a slope, while driving, only during heavy down pours)
What color is the moisture? (muddy water from the road surface, clean water from above)
How wet? (light dampness after a heavy rain, very wet while/after driving in a drizzle)
Based on the customer's statements, some determinations can be made:
Location of possible leak points near the damp area.
Dirty water usually comes from below. Check the wheel house weld seams, floor plugs, lower air vents, etc.
Clean water usually comes from upper panel surfaces. Check the trunk lid seal, around the windows, sunroof drains, door panel moisture barriers, etc.
Leaks noted only while the vehicle is parked are usually associated with water leaking in at one point and seeping to another. Damaged seals can also leak the same way but may not show visible damage.
All companies have lemons. :sick:
My Dodge Ram had 2 valves replaced at 65,000 miles and you don't see me complaining....maybe it was because I bought an extended warranty. My next buy will be an 06 Santa Fe (because I sell them and believe in them) and I wont buy an extended warranty because I have a lot of very satisfied customers that have bought Hyundai cars and SUV's and swear by them and the warranty.
I am putting my new 1 month old son in it so take your complaining elsewhere.
I even have Accord and Camry owners waiting in line to buy Sonatas or Elantras now.......go cry somewhere else.
little nervous here as well but to be honest this is my 4th new car and i have never had such a pleasurable car buying experience. not to mention the grief people give when you mention its a forgein car - to them i say sorry - at least i bought mine from retired army guys in ft. knox, ky area. great bunch - even bringing them some cold ones - that's how much i appreciated all they did. trust me, i am not an easy person to sell a car - i do research. and i must say - i'm a little scared although my V6 is automatic - anything out there regarding auto transmission?
Happy trails - JO
I have also asked here in the forum for any details on the 05 Tib's but got no bad feedback. Enjoy your trip
also does anyone know where i can find a place to buy performance internals for my car.......thanks
Problem is... I need to be able to drive it year-round. I live in Ohio at the heart of the Snowbelt and I will be going to college at the Rochester Institute of Technology in NY, where the snow levels will be just as wild as they can be here.
I have heard that the car handles beautifully in the snow with snow tires, but otherwise it's a deathtrap (which could probably be said of most cars in its class). Does anyone have any advice for me?
Mostly if it's not too bad to drive in the snow, I need to decide between Automatic and Manual, but I really want to buy a '97 or '99 FX.
Although the tib is my first choice, I'm also looking at the eclipse, celica, and a few others in that range. Last resort is a Ford Focus.
I found this is a previous post:
"BTW the tires I put on for snow were Continental ExtremeContact. They've made the Tib the best 2WD vehicle for snow I've ever had."
Any other suggestions for tire brands?
Thanks a lot!
Check it out for yourself.
