my 1993 blazer has antifreeze in the oil now at 115K, so I was looking for commonality of this problem when I saw your problem, Last year mine had a whine in the front axle when i was on the highway, At first I thought it was the rice burner next to me, there is a device which engages the front differential to the passenger axle which when using 4 wheel mode, is controlled by a vacuum switch in the transfer case, mine was bad and it was partially engaging the axle when I was in 2 wheel mode, the switch cost me $19 at AutoBarn
Not sure what to do. Anyone have any advice?
changed fuel filter, fuel pump, throttle position sensor, sending unit and fuel pump relay, checked release valve at engine (pump is pumping fuel)....how much pressure? I dont know, but it is enough to squirt out when i push in the nozzle valve.
Is there a fuse for the injection assembly I can check before digging any further...also dont have alot of confidence in the sending unit (aftermarket)
PLEASE HELP!!!
PLEASE HELP!!!
Check that first.
One end of it is connected to the PRNDL indicator in the dash. The other end of this cable just clips to the right side of the gear select housing drum which is on the steering shaft, just behind the wheel. The housing drum moves with the gear select lever and pulls the cable, which in turn moves the indicator on the dash.
If you find it and it's not broken, just clip it back onto the right side of the housing, roughly in the 3 to 4 O'Clock position.
You can adjust it by moving it's position on the housing until all your gears are indicated properly on the dash when you move the shift lever.
My blinkers work, until I go to shift from park to drive. As soon as it moves through the reverse spot, the fuse blows. All my hazards work, as do the lights. Weird. I'm guessing a short somewhere, but any ideas?
Next problem, my heat works sometimes. This just started two days ago. I can turn my car on, and the blower fan may go on, or not at all. If I turn off, then on, it may or may not work. Weird. Last problem for this post - my temp gauge does not work. ?? Digital dash, about 130k miles, 93 s10 blazer tahoe any suggestions.. Thanks
Any ideas?
Thanks for any help!
