Visitor Agreement.
However, it doesn't seem to be the pump. I have been to two other stations and have had the same problem at each. It seems as though something in my car is signaling that it is full when it is not.
Any ideas on what is wrong? Thanks
Thanks...
Barnee
I've just bough a used 2005 corolla LE auto. Every time I accelerate, I notice that the car does not respond quickly enough and it seems that it needs some persuation to move. Previously had a buick auto and it was always smooth and had an amazing pick-up. Is there some maintenance that I have do on the vehicle that would solve this problem? I have an oil change due after 500 miles.
Nash
Anyone know if the online schedule I'm reading is way off?
/Paul
The car has an unusual throttle which means flooring the car
isn't going to get you any more acceleration or power than
putting the pedal down 1/2 way. /Paul
What is the problem normally?
What can I check before go to the dealer?
How much will it cost for the problem?
Thanks a lot.
Jim
I've Toyota Corolla Wagon L-Touring 1998 with egine type 4A-FE and Mileage 136700, Now I want to change the ATF. How many ATF to use in liter for this.
Please help me
Thanks & regards
if the engine actually pulls the car along in 5th at this low speed (it might buck or shudder but the engine doesn't rev up like it was in neutral) then the clutch is holding and is okay.
Don't do this more than a couple of times.
So in that situation, how do I know if a Corolla LE 2003 has ABS or not?
If I don't see an ABS light, does it mean I don't have ABS?
Might be something for you to look into....
The timing belt was replaced about 3 months ago. Could this be the problem? Thank you in advance for any responses.
The S has exactly the same engine as the CE and LE, so it does NOT need more oil. Check your owner's manual.
recently got a 2004 ce, 5-sp. seems like the shift points indicated in the owner's manual are really low, espeically 3 to 4 and 4 to 5:
1 to 2 14mph
2 to 3 22 (24 when cold)
3 to 4 27
4 to 5 39
i've had hondas before, and to really get the most of out them, you gotta rev the engine more and shift at higher speeds.
slowly learning how to shift by sound of the engine, but it can get difficult with the windows up, and ac and radio blasting.
care to comment? any hints? thanks.
I also think the maximum speeds for each gear are listed in the owner’s manual – take a look. I think it would be somewhere around:
1st – 30
2nd – 50
3rd - 70
4th – 90
Of course, I would strike a balance with fuel economy and acceleration, so I think this is somewhere around:
1-2 - 20
2-3 - 30
3-4 - 45
4-5 - 55
Without a tach, you still have a rev limiter, so that will prevent you from over-reving the engine on acceleration. But remember that the rev limiter won't help if you downshift into too low of a gear - then the engine can redline and is toast. Hope this helps. Let me know if any other questions.
thanks for your reply. the ce does come with a tach (don't know about automatics).
i have been shifting:
1 - 2 @ 15
2 - 3 @ 24 + 2
3 - 4 @ 33 + 2
4 - 5 @ 45 + 5
doing mainly city driving, i got a little over 26 mpg on my last tank. seems low; i was getting 30+ on my civic.
the engine seems to lug if i shift from 3 - 4 at 27mph, don't know why the manual recommends it so low.
if i use the tach to shift, what rpm's would i shift from gear to gear? thanks.
I'll have to look tonight to be sure, but just take it up to 3,000 RPMs before you shift into the next gear - that should be good.
