Toyota Corolla Basic Maintenance Questions
in Toyota
Specifically I'm looking at the Zymol Japon wax in a starter kit from the autosport catalog. Also any opinions on how long I should wait to wax the car. I've heard from some sources that there is a curing time on new cars. I think I heard something like 3 months.
As for wax type....have you looked at Zaino?
http://www.zainobros.com/
I have some and will be putting it on our black Matrix soon....supposed to not leave any white residue.
just my $.02.
my 0.02 cents
Hope it isnt too overwhelming. As of this moment there are only 3502 messages.
And for all other brands: Store Bought Waxes
KarenS
Owners Clubs
The Vibe manual says that the break in period is 300 or 500 miles, and has no speed limitation (it says not to stay at the same speed for long).
If I go 55mph on the captiol beltway, I'll be killed.....
How religiously should I follow the Toyota break in? Can I subsitute the Vibe one instead?
I've managed to get over 375,000 km on all my japanese vehicles (all I've done is use a synthetic oil at 5000 km intervals religiously.
As for break-in of your engine, just drive carefully. Do not allow your engine to lug and do not tow heavy loads. Also, do not drive at constant speeds for long times. Most importantly, make sure you keep changing the load on your engine on a continous basis. Toyota's 1600 km break in is based on how much engine break-in is done during DVT (dynamic vehicle testing)at the assembly plant. GM plants always seem to cycle more during DVT, hence they call for a shorter break-in. I'm sure Toyota would rather err on the side of running a longer break-in. This is why Toyota car's last longer, they don't take as many risks as GM
I tend to believe that these recommendations may have been valid at one time, but modern engine and oil technology have made them obsolete, unless you operate an oil change business.
Since I believe that Toyota has a strong interest in preserving their reputation and knows best what their engines require, I plan to follow their recommendations.
The largest percentage of wear occurs during start up. While cabs start and shut down frequently (or in some cases just keep at idle when stopped), the regular public parks their car's while at work or over night when home. This allows most of the oil to flow down into the lower extremities of your engine. Thus you don't have the same amount of protection as a car which is run at frequent intervals. Also remember, oils main job is to keep foreign particles away from mating engine parts. Shut your engine for a long periods of time and you'll allow these particles to settle where they can do damage.
In my opinion, I just don't understand why anyone would want to take risks when there's only $20 at stake. Whether someone wants to spend $0.006/mi or $0.004/mi on oil is all up to them. Just remember frequent oil changes reduce the amount of time foreign material stays in your engine.
Good luck!
We must all remember to enjoy our vehicles (afterall I don't want to believe that you and I paid good money to [non-permissible content removed] foot the car around), and that sometimes means driving them hard for short periods of time.
I just got my Matrix (5-speed, base) about a month ago, and I am having a problem which, I suspect, is related to the clutch.
About a 10 days ago, after I started driving the car, I could smell something like burning rubber. I asked the dealer about it and they told me that I probably burned the clutch and that I should stop riding the clutch. The problem is - I don't. This is not my first manual transmission vehicle and I never had this problem before. Ever since that time, once in a while I can smell burning rubber while I'm driving. Called the dealer - the same story: don't ride the clutch. Am I doing something wrong with the way I change gears (doing lots of city driving), or is there a mechanical problem with the clutch (or something else)?
Any answer will be much appreciated.
What are your driving habits (how you drive, how you engage the clutch, etc)?
I brought the vehicle back to the dealership and they looked over the clutch and brakes, both checked out fine. This weekend I smelled the odor for the third time while backing up. I plan to bring the vehicle back and get the dealership to look it over and document the problem once again.
There are several comments regarding this same issue over at MatrixOwners.com; http://www.matrixowners.com/modules.php?name=Forums&file=viewtopic&p=6502
so far on my 03' corolla, no smell yet. just picked it up last week.
do any of you find the engine noise on the 03' corolla is a bit loud, specially during warm-up? sounds like an old car!
Engine noise is fine.. a lot more quiet than the Cavalier it replaced.
I do have an annoying little creek coming from the rear trunk area. Anyone else noticed this?
about the engine noise, i guess i'm just used to the sienna's silky smooth v6 so i find the corolla a bit loud.
Just thought I'd let everyone know, my matrix exhibited this condition for the first few thousand kilometers. I'm now at around 1800 km (11000 mi)and the smells no longer appears. The smells been gone for a long time. I even drive hard (i.e redline whenever I can) and drop the clutch at around 4500 rpm whenever the coasts clear at traffic lights. The only concern I'm starting to run into is, my tires are wearing fast.
I think people getting ~40 mpg drive 55-65 mph on highway. May milage so far (2003 corolla s auto):
27 (90% city), 27.5 (50% city), 29.5 (80% city). I only credit the last better milage to unusually light acceleration (RPM under 2750) I used recently to test the hypothesis that milage in corolla varies widely with driving style.
Keep in mind that EPA tests milage at 55 mph (highway). I drive mine at 80-90 mph.
long (450 mile and return) trip beginning with only 100 miles on the odometer. I also
had no choice but to drive it at over 55 mph, actually 65 mph, most of the way. If I
didn't, I would have been killed on the superhighways between Dover, DE and Buffalo,
NY. I also had to maintain fairly steady 65 mph. All of this, of course, violated the
owner's manual recommendation of 55 mph and variable speeds for the first 1,000
miles -- a kind of driving which most people in urban areas simply cannot do.
Sooo, my question is -- what, if any, damage have I done to my engine? I changed
the oil and filter for the first time at 1924 miles, and plan to do my usual 3,000 mile
servicing thereafter. Have I done something which will rob me of maximum life
from my engine? Have I done something which will affect overall fuel economy,
which, so far, seems to be outstanding?
Quite frankly, I think any modern automobile engine which cannot tolerate a
long distance, steady-speed highway trip from mile number zero and give
maximum performance, economy, and reliability is somehow lacking. Am I
right or wrong? In any case, I'd appreciate someone who knows telling me if
I did my new Corolla any harm.
Having said that I broke my '03 LE in by the book. Why? I can't really say, maybe it's that aging thing. BTW the little 1.8l Yota engine responds well to synthetic oil. Aside from better protection and longer change intervals it quiets down considerably and the MPG rises. Try it. I'm glad I did and won't go back to the 3K crawl under the car regimen.
If you do not keep your cars that long, then it will not affect you at all!
OK, thanks for the recommendation. I guess what I'll do is stick with the dino oil, but make sure it's service grade SL (the highest). I'm gonna call Jiffy Lube and ask them what theirs is, and if it's not SL, out it goes as soon as I can arrange it. Since my driving is what I'd call "super severe" i.e. very short commutes and mainly city driving, I think I'll maintain the maximum 3,000 mile service interval. Oil is cheaper than an engine (or a car!). I've done this all my life, and have been criticized for throwing good money down the oil drain, but then again, I've never had a lubrication-related engine problem with any car I've owned. In fact, about the only engine trouble I've had is a bad head gasket on my '91 Taurus 3.8L V-6, which came about way after 100K miles.
i broke the 2 plastic screws holding the plastic cover! take it easy when removing those two plastic screws, very easy to break! good thing i had two spare plastic screws that fits!
next time, i know better!
Guess what. No automaker would allow their warranty to remain in effect with Mobil I extended change intervals. As the previous member mentioned, the cabs run 24/7 burning off most of the oil's impurities.
That's why the oil needs to be changed frequently even with synthetic oil if a lot of the owner's driving is short trips.
time and noticed that if I use the amount of oil recommended by User Manual (that is, 3.9qt)
the oil probe stick (or whatever they call it) shows oil level _WELL_ ABOVE the upper limit mark.
Looks like this engine actually requires 3.1qt (for oil level to be approximately in the middle between the low/high marks).
Now I wonder who should I trust - User Manual or the Oil probe stick?.....
- what type of gasket should it be (metal, fyber, other?).
By the way, that amount will include the oil in the filter, so if you just drain and refill it, the level will be too high. If you also change the filter, but do not run the engine before checking the level, it will also appear too high. You should change oil and filter, then refill, then run engine, then stop it and wait 2-3 minutes for all oil to drain back to the oil pan, then check the level. If it is STILL wrong, your dipstick may be marked wrong - they occasionally are - you can have it checked at your local dealer.
Yes, there is a drain plug gasket - it is hard rubber if memory serves. You can get a bunch from the dealer for about $0.80 apiece.
