Mitsubishi Outlander
Hopefully the article at the above link paints a cheerier picture...
Mitsubishi: Can This Brand Be Saved? (Inside Line)
As for the sticker, it is not a marketing ploy. It's there to tell you what equipment is on the car. If something was listed on the maroney sticker and was false, the company could get in trouble for it. So there is no reason to not believe the OD stated on the sticker.
Again, drive your car and notice how there are 3 distinct shifts and then a drop in rpms once you are done accelerating.
Nevertheless, I'll enjoy it on the weekends until it comes time to sell. :shades:
JCSM
Mitsubishi's Product Plans Set Through 2007 Despite Losses (Inside Line)
Does anyone have any comments on the 2003 - positive or negative?
Thanks :confuse:
Having said that, I would really recommend getting a 2004 for the more powerful engine.
You recommended the '04, what about the '05. Are there pictures and info out yet on the '06?
Do you have any concerns about the demise of Mitsubishi? I have to admit, I am a little leary.
Peugeot Citroën and Mitsubishi Sign SUV Deal (Inside Line)
In terms of the tires. My '03 AWD has the Yokohama Geolanders on it. I just hit 30K on mine, and my tires are wearing great. I rotate them every 6K miles (every other oil change). They appear to have at least 20K left on them before they get to the wear indicators. I live in southern North Carolina, so I have yet to have any snow to drive it in.
I live in the NY metro area. My tires look shot to me and handled very poorly last winter ('04 AWD). They are Yokohama 16 inch tires but not sure of the exact model. I also rotated them on schedule and they have worn evenly. My tech says to wait as long as possible before replacing...I will probably replace in October with Goodyear.
Some other good news is that you can expect the brakes to last a long long time. My tech says he has yet to have to do a brake job on an Outlander...including the 03's.He guesstimates about 90k miles before the pads need replacing...give or take depending on your driving habits. I think that is awesome for an SUV AWD.
In terms of the brakes, that is awesome. I have never gotten more than 45K on front brakes on any car. With regards to the tires, I asked "Connor at the Tire Rack" over in the Accessories forums which tire he would reccomend. He said the Bridgeston Turanza LS-H was a great tire for the Outlander. If you scroll back about a week in the posts, you will see my question to him, and his response.
I have a 2005 Outlander LS AWD with the 5 speed manual transmission.
At my last fill up I checked the mileage 30.9mpg, I could not believe it either, had my wife do the math also, same mpg. Does anybody think
doing an oil change with synthetic oil might help a little also?
Also I had the tweeters installed at a local car audio store. They supplied the labor, tweeter speakers and crossovers for $65. Sounds real good!!
Thanks again earlshoes
Jerry
The crossovers were put on the wire about 6-9 inches from the speaker, then the wire from the crossover was connected to the Outtie wiring. The items all came in a kit, the techs did the most amount of the wiring on the bench, then came over and connected to the car. I asked what the little square items were , both techs said they were crossovers. Two very skilled techs worked on my car and were done very quickly. Hope I answered your questions.
That's a very good tip-- just driving (leadfoot) I get right at 22 mpg combination.
Mitsubishi Plots Comeback With New Outlander SUV (Inside Line)
Maybe. I use to own a Dodge product before buying my Outlander. I will never buy another. Sure their designs look good, but I have found that my local Dodge dealer's service department leaves a lot to be desired. They also seemed to always want to get out of fixing anything under warranty (which was only 3yr/36,000mi) by trying to explain to me that it wasn't covered. Took a lot of haggling to ever accomplish anything. My Mitsubishi dealer has been totally the opposite - they are wonderful to deal with. Based on my past experiences, for my money I will take the longer Mitsubishi warranty and the better dealer experience anyday.
