Mitsubishi Outlander
nuf said...
The attached letter give no date, just "this fall."
:shades:
As for things new for 07: a lot of things:
>bigger engine 3.0L V6 MIVEC, much more horses under the hood
>bigger cabin space
>more seating options
>flap-fold tailgate
>new HDD based navi system
>6 speed gearbox, sportronics mode or auto
>paddle shifters in xls for those want to drive semi-manual (I do), for other models, you can do it via stickshift
>ASC, auto skid control, to help you navigate slippery winter roads, covered in ice or snow. this feature not much discussed.
>safety improved a lot, side airbags up to 2nd row seats, dual 2 stage front air bags
>2wd, 4wd, and auto 4wd modes
>keyless entry
>standard tire pressure monitoring across all models
>and of course as you've mentioned, the all new dash display, almost similar to what rally drivers get.
... and that's just about a few of the notable changes
now compare that to other small SUVs and see if you can get the same features for the same price.
Also try to look at their warranty and compare.
If it's significantly cheaper than the RAV4, I'll probably go for the Outlander.
So 07 Outlander pricing is cheaper by about 2-3K$ by estimates. Lets now look at what kind of warranty Toyota is willing to give you. For a new RAV4 07: Basic-36mo/36,000 miles, powertrain-60mo/60,000 miles, rust through- 60mo/unlimited miles
For the new 07 Outlander: Basic-60mo/60,000 miles, Powertrain-120mo(10yrs)/100,000miles, rust through-84mos (7yrs)/100,000miles. Plus 60mos(5yrs)/unlimited miles Roadside assistance.
So I guess that'll help you decide which is a better choice.
And as further proof of its success, PSA Peugeot and Citroen will have SUVs based on the Outlander 07, manufactured by Mitsubishi by OEM contract, for the Europe market.
1) Change the tires. Stock tires are too hard and bounce off the pavement exaggeratedly promoting break pad rattles. I now have Good Year tires which have much better road feel and softer manners (and being wider... look much better to!). You may buy any brand you prefer but... stay away from steel belted tires!!!
2) Change brake pads AND clips. Buy pads that come with metal shims that are glued to each pad (shims are chromed and have a peel off label to expose the adhesive), you just press the shim and pad together.
3) When installing brake pads use brake pad grease in all metal to metal contact areas (caliper, clip/pad contacts, etc).
I bought the brake clips set at a local Mopar store (these are original manufacturer - OEM).
I bought tires and pads at Western Auto store, where you may also find the break grease. It comes in a small black plastic tube for about $1.00, ask for it at the service counter.
Hope these tips helps. I know how anoying it can be.
If someone else had the same problem and different solution please let us know.
The new models come to NZ in Japanese spec. They are all 2.4 litre motors with CVT transmission. The XLS get 18” mags, 6 CD stereo and all the other things you would expect. One thing that is missing here though is cruise control. This is a pity because the vehicle needs it. The 2.4 motor is surprisingly powerful and the CVT transmission sensitive to little pressure on the throttle. As a result the speed of the vehicle can go from 110km/h (our legal limit is 100 with a discretion of a further 10 km/h) to 120 or 130 without you even realising.
The handling is quite exceptional. My last company vehicle was a Ford Mondeo which was ranked in handling terms with the Peugeot 406 and Audi A4. The Outlander loses very little in terms of ride and handling in comparison to the Mondeo. I hope the extra weight of the V6 doesn’t affect the level of handling I am enjoying
My vehicle only has 5,000km on it so far so the engine is quite tight still. Fuel consumption is improving and Mitsubishi here reckon the Outlander is good for 8.6l/100km. Sorry about the measures, but you may be able to find a conversion.
The other SUV options were all a bit expensive here in NZ. The Suzuki is too small. The RAV4 wnt up in price dramatically with the new model as did the Hyundai. I am really pleased with the Outlander. It is the sort of vehicle that I find myself making excuses to take it for a drive.
Product features: Outlander Concept
* Outlander Concept sports an eye-catching Red Metallic body finish using silver accent coloring for the grille, roof rails and other elements to give a sporty dash to the overall appearance. The car rides on 20-inch 6-spoke alloy road wheels that give the lower body a tauter look as well as leaving no doubt as to Outlander Concept's on-road SUV personality.
* The powertrain mates the 2.0-liter 16-valve DOHC direct-injection diesel engine that produces maxima of 103 kW and 310 N-m and powers the Europe-market Grandis sedan to a 6-speed manual gearbox. Outlander Concept uses a diesel particulate filter (DPF) to meet Euro-4 emission standards.
* The driveline uses an electronically-controlled 4WD system developed from Mitsubishi Motors' All-Wheel Control (AWC) approach to deliver optimum drive torque for any particular situation or driving conditions and realize economy and go-anywhere performance that do justice to an all-round SUV.
* All-round independent suspension delivers responsive and accurate handling with a pliant ride. The aluminum engine hood, as used on the Lancer Evolution, reduces roll to improve road holding and increase stability.
* In-car entertainment is provided by the same 650 Watt 9-speaker Rockford Fosgate Premium Sound System™ acoustically tuned to the interior of, and well-received on, the Japan market Outlander.
* Outlander Concept uses the same split tailgate as the Japan market model with separate upper and lower sections that facilitate loading or unloading of different sizes and weights of luggage. It also uses the same fold-and-tumble second row seats and occasional-use third row seats, normally stowed under the floor, to produce a cavernous luggage compartment or to provide seating for seven as required.
Full press release here: http://media.mitsubishi-motors.com/pressrelease/e/motorshow/detail1526.html
-MMC
Looks very sporty to me.
Color Selection: http://www.mitsubishi-motors.co.jp/outlander/color/index.html
The color variety for the american market can be seen here (though not clearly for some colors) :P
Outlander ES 2WD - SOHC 24 Valve V6 MIVEC (3.0L/6ST) $21,370.00 6-Speed Sportronic(R) / 2WD
Outlander LS 2WD - SOHC 24 Valve V6 MIVEC (3.0L/6ST) $22,410.00 6-Speed Sportronic(R) / 2WD
Outlander XLS 2WD - SOHC 24 Valve V6 MIVEC (3.0L/6ST) $23,650.00 6-Speed Sportronic(R) with Paddle Shifters / 2WD
Outlander LS 4WD - SOHC 24 Valve V6 MIVEC (3.0L/6ST) $23,770.00 6-Speed Sportronic(R) / 4WD
Outlander XLS 4WD - SOHC 24 Valve V6 MIVEC (3.0L/6ST) $25,010.00 6-Speed Sportronic(R) with Paddle Shifters / 4WD
See here: http://media.mitsubishicars.com/detail?mid=MIT2006100939007&mime=ASC
-rcpax
To those ends, we will be shutting down the general make/model discussions and work exclusively with specific issues. This requires us to populate the make/model subsections with relevant, interesting and timely topics. Rather than having the hosts simply create boilerplate topics for each make/model, we feel that you, the owner, the make/model enthusiast and the prospective buyer can best judge what those topics should be.
You can help by adding a discussion (it's easy!) or suggesting one here.
To add a discussion, click on the last link in the "You are here" line at the top of this page. That will take you to the topic page for this make/model. Review the list of topics and click on the "Add discussion" link when you've decided what topic you'd like to add. Follow the directions and you're done! Feel free to add more than one. Just avoid duplicating existing topics and try not to make it TOO specific!
Your help and continued participation in the Forums is greatly appreciated! Thanks.
Referring to the NZ model brochure, apparently the Australian versions will be higher specced and will include a VR and VR-X. More details to follow....
Mitsubishi is currently focusing on manufacturing a particular model in their country of origin only, and exports them to various markets. Example: Outlander in Japan, Triton (L200) pickup in Thailand, Eclipse in US.
Also, finally real owners reviews on Edmunds New Cars. Mostly positive.
07 RAV-4: Overall: GOOD http://www.iihs.org/ratings/rating.aspx?id=654
07 Sta Fe: GOOD http://www.iihs.org/ratings/rating.aspx?id=697
Honda CR-V: GOOD http://www.iihs.org/ratings/rating.aspx?id=736
Goes to show, safety is the way to go for new vehicles.
He said he was never informed about the 30K required maintenance and the local Dealer told him it was HIS responsibility to read the contract.He called Mitsubishi and they confirmed what the Dealer told him. So after another 2K he will be on his own. Doesn't sound right to me
Any comments?
As far as the other add-ins referenced by the notes you mentioned, when I bought the Saab, they sourced it from another garage and it came with paint protection, pin stripes and window VIN etching at a cost of around $1000 for the package. I told the dealer the pin stripe looked horrible and to take it off and I didn't want the VIN etching, so he was free to swap out all the glass
Mop and glow often costs $400 and up, and is basically a $20 wax job. Modern paints don't even need wax unless you like the glamour look. I'm in sunny Boise and I rarely wash my cars, much less wax them - but they're aren't Ferraris either. :shades:
He knew up front that I was just looking and since it was a slow day took his time with me. This was a black XLS with beige interior and had everthing, luxury, nav ,S & S. I thought the interior was nice, not cheap at all, in fact looked very good. Leather was good quality. I have trouble getting in and out of sedans thats why I have a van but it was easy to get in and out of the Outlander. Lots of storage. Witah the power seat full back i saat in the second row in back of the driver and had adequate knee room.
I liked the car. Definitely on top of my list. Ahead of the CR-V now. Just not the time to buy now.
Have been really pleased with the ride and comfort.
One small problem, very wet around Vancouver the last couple of weeks. Has anybody fitted mud flaps to their vehicle. Cannot find a supplier so far. Any help would be appreciated.
I will be getting my 07 on monday.
You are right here, it is just extra profit for the dealer, same as window etching, fabric protector, paint protectors, etc. In the end you can apply Scotch guard or good wax yourself (same effect) and take your family for a road trip with the money you just saved.
I agree that rustproofing is important in place like Toronto. Too much snow/slush/salt.
As far as the Outlander is concerned, I don't think Mitsu dealers in Toronto have this service. I will have to shop around. I want the car sprayed at delivery but not injected with oil and wholes drilled into the body.
So will pick it up on monday around lunch hour. Cant wait. Had insurance arranged and am all set to go.
Could have had it last week or so if I didnt change my color choices every minute. :P From the time I gave them my final choice it was day before yesterday. They located one in markham and is on its way.
Hi missvic, could you please elaborate on the heated mirrors? Heated mirrors are not listed in the spcs sheet for 07 Outlander.
