Entry Level Luxury Performance Sedans
1185186188190191435
  • brightness04brightness04 Member Posts: 3,148
    I certainly agree that mid-range passing accelearation, or for that matter a 5-60 running test, would be more relevant to real life driving. That "real life" driving capacity is something that all of us, including soccer moms, can make good use of, without resorting to the boy-racer antics of revving the engine sky high and then dump the clutch to produce the best 0-60.
  • blueguydotcomblueguydotcom Member Posts: 6,249
    5-60 = when is this ever done?
  • kyfdxkyfdx Moderator Posts: 271,448
    I think the idea is to approximate the acceleration from 0-60, without the revving and clutch dump.. More of a real world number.
    Some cars react well to the rev and dump, but most owners would never do that.. By measuring 5-60 (which means you are basically idling), you get more of an idea of how the car will react in a normal situation..
    It is a Car & Driver test..
  • circlewcirclew Member Posts: 8,666
    Yes..here is one for an Implala SS.
    C/D TEST RESULTS:
    Zero to 60 mph: 5.6 sec
    Zero to 100 mph: 13.9 sec
    Zero to 130 mph: 28.5 sec
    Street start, 5-60 mph: 5.8 sec
    Standing ¼-mile: 14.2 sec @ 101 mph
    Top speed (drag limited): 154 mph
    Braking, 70-0 mph: 172 ft
    Roadholding, 300-ft-dia skidpad: 0.81 g
    So, you can see the time differential from a standing start vs. 5 mph roll through th e 1/4 mile trap.
    OW
    Here's the 2007 C&D test for the '07 335:
    3-SERIES COUPE
    Vehicle type: front-engine, rear- or 4-wheel-drive, 4-passenger, 2-door coupe
    Base price: $35,995-$41,295
    Engines: DOHC 24-valve 3.0-liter inline-6, 230 hp, 200 lb-ft; twin-turbocharged and intercooled DOHC 24-valve 3.0-liter inline-6, 300 hp, 300 lb-ft
    Transmissions: 6-speed automatic with manumatic shifting, 6-speed manual
    Wheelbase: 108.7 in
    Length/width/height: 180.3/70.2/54.1-54.2 in
    Curb weight: 3400-3600 lb
    C/D test results (335i):
    Zero to 60 mph: 4.9 sec
    Zero to 100 mph: 12.1 sec
    Street start, 5-60 mph: 5.6 sec
    Standing ¼-mile: 13.6 sec @ 105 mph
    Top speed (governor limited): 144 mph
    Braking, 70-0 mph: 160 ft
    Projected fuel economy (C/D est):
    EPA city driving: 20-21 mpg
    EPA highway driving: 29-30 mpg
    This car should take care of the mid-range advantage one might seek in the ELLPS vs. most family cars. Perhaps one can eek out some fun/satisfaction if equipped to suit ones needs and indeed, if one fits into the cockpit comfortably.
    Even the Impala would be about 5 car-lengths behind the 3'er at the end of the 1/4 mile. Should also blow all DGC'c and typical S.M. entrants into the weeds!
    OW
  • edwardsfedwardsf Member Posts: 190
    Eggsactly. The A4's backseat is (reputedly) very small. As I mentioned, I never get back there myself and have very few passengers (I am a single guy). I am 6-2 and have a long torso and I fit in the A4 better than any ELLP. While the TL and the G35's entire cabins seem bigger, they balance the space between front and back, thus leaving the front smaller than the A4. Also, because of the rakish front windshield design of the TL and G35, instead of looking out the window, I am looking at the visor. The IS and TSX have the least leg/head/nose room of all and the Bimmer is in between. But the Bimmer, even more than any other ELLP, seems to be built for a small person. I fit okay in the 3 series, as it is designed very well, but everything is close to me and I feel too snug.
    A couple of other advantages of the A4. Quattro is better and more affordable than AWD on other ELLPs. The A4 has the best gas mileage of the group, although the 328 and the TL are close. (The G35 is awful). I am going to be ordering an Avant (an ELLPWAG?) and only the thousands more 3 series has a wagon. I am replacing a Saab 900S with its cavernous hatch and the only other similar vehicle is a Mazda6 hatch. SUVs while often having headroom, are obnosious climate changers in my view so I won't consider them.
  • gordonwdgordonwd Member Posts: 337
    RE: 1) manual transmission, 2) RWD, 3) excellent handling (usually comes with the RWD), 4) space to store my bicycle inside the vehicle, 5) something resembling luxury, 6) decent fuel mileage & 7) stone solid reliability/longevity
    I think that my E46 325i fits all of these, and I have carried both my road and MTB in it with the seat down. Plus, it has built-in mounting points that I can quickly attack my Thule roof rack to for carrying multiple bikes. I get 25mpg around town and 30 on the highway, and the other "requirements" go without saying (including #7!!).
    edwrdsf, what do you think about the X3?
    OW
    Bingo!
    This, by the way, is why the 3 is at the top of my list. I gave the TL a shot because #7, even though it's last, is certainly nice to have. How many miles does your car have on it? Did you buy it new?
    If you're leasing, #7 becomes almost irrelevant. The only factor then is the PITA involved with dropping off & picking up the vehicle as it endures repeated warranty maintenance "issues." Oh, and whether the dealer supplies loaner vehicles.
    Interesting input. Thanks.
    I also spend 99.5% of the time in my car solo, and vastly prefer a vehicle that recognizes that preference.
    Sadly, many people evaluate rear-seat room with the front seat moved as far back as possible, regardless of whether anyone in the family would actually put it there. I currently drive a car that I would defy anyone to fit into with the front seat moved all the way forward. It doesn't go so far back as I would prefer, but when it is all the way back (that would be 100% of the time), the nonexistant person behind me has plenty of leg room.
    I developed a Jones for Audi 5 or so years ago, after driving several rentals in Europe. Your post helps keep it alive. If I opt to trade RWD for other factors, Audi is right in there.
    You mean not all BMW dealers offer loaners?
    OW
    Many add the caveat that the vehicle must have been procured (leased/bought) from the servicing dealer. ED done through a smokin'-deal East-coast dealership, with the car picked up there & driven back home leaves the driver open to this sort of thing, for example, when it comes time to get serviced in Arizona.
    Grrr. The X3looks like the perfect vehicle for me but it is indeed an SUV and gets pretty poor gas mileage. This gets my goat, because the X3 is based on the 3 Series, which gets good gas mileage. Why car makers can't make a high clearance sport wagon with good mileage, I don't know. The Mazda CX(?), Legacy XT, the RDX and the X3 are really what I want but I require 25 mpg, not 20. This is for emissions reasons, not cost. I only drive around 7000 miles a year and use the car for road and camping trips, not commuting.
    SUVs are allowed higher emissions per mile, so the pollution is not just correlated with the gas mileage. The only SUV I would consider is the Escape Hybrid but it is the four letter f word: F-O-R-D.
    I am curious why you did not get the 325 wagon. I can stash two MTBs in my Saab hatch and think I would grumble if I had to cram my bike into 325 or A4 trunk. I do remember getting flack when I had a Subura Legacy wagon ("where's the babyseat?") but the utilty seems worth the American mindset that Sedan is sporty and salon is dorky.
    Not really. Only a total butt dealer would say no to a loaner of some kind. They want your business - as even a non-sale car will generate revenue for them.
    May have something to do with high-ground clearance + AWD not being condusive to high milage. Subaru certainly tried staying true to the wagon formula as long as they could.
    F-O-R-ghedaboudit! Stick with the A4!
    OW
  • scottm123scottm123 Member Posts: 1,501
    The new Infiniti EX35 is also an option for the small SUV platform, but I doubt it'll fall into your MPG needs.... since it's using the same 3.5-liter V6 setup with a five-speed automatic tranny.
    Car looks awesome though.
    2008 Infiniti EX35
  • pv2pv2 Member Posts: 37
    I haven't seen any AWD/4WD vehicles whose MPGs are as good as their FWD or RWD counterparts; there's just too much friction loss in the additional drive wheels. One example, which doesn't look like too much of a difference is the current Infiniti FX35 which comes in RWD and AWD versions:
    EPA City/Highway: RWD 17 mpg/23 mpg; AWD 16 mpg/21 mpg. Looks like highway mileage suffers more.
  • xrunner2xrunner2 Member Posts: 3,062
    AWD in a entry lev lux perf vehicle seems like an unnecessary feature in some parts of US such as LA, Vegas, Frisco, FL, Gulf States, etc. Wonder what sales there are for AWD vs snow belt states.
    For reasons beyond comprehension I see Xis and Quattro vehicles in So Cal all the time. Talk about a major waste of money, gas, fun.
    I think Quattro actually improves the handling of the Audi A4, which is FWD otherwise...especially in the manual-transmission models.
    But, for RWD cars, I agree.. adding AWD means less fun.. even here in the snowy Midwest..
    Get some winter tires!!
    Um, er, I live in SoCal and am getting a Quattro. The reasons are: 1- A4 wagons are only offered with Quattro (and are thousands less than Bimmer wagons), 2- Kdfyx points out the very real difference in handling between Audi Quattro and FWD, and 3 - Gas mileage is still better than almost all in its class (22-31 for a Quattro Sedan vs. 22-30 for 328i RWD).
    That said, I agree with your point but it is not just limited to cars that offer FWD or RWD. You point applies to all SUVs in L.A. or Florida. Why do you need a 5000 lb. 4WD vehicle? Because they can... status of course.
    Bear in mind that the vast majority of SUVs are NOT 4-WD, because that's significantly more expensive & most people can't tell by looking whether you've got it or not.
    As nearly as I can tell, the SUV craze is driven (pardon) by people who want to sit up higher in a heavy vehicle that's well thought of by others (as opposed to, say, a minivan). Nothing in there about actually using it for anything.
  • habitat1habitat1 Member Posts: 4,282
    "Bear in mind that the vast majority of SUVs are NOT 4-WD"
    Are you kidding? :surprise:
    The VAST majority of SUV's do not even offer a 2WD version - at least not the mid to higher end models. American made Ford Explorers Chevy Suburbans, and some of the mini-utes, maybe. But nothing that I have ever looked at seriously from Japan or Germany that was a mid to full size and mid to upscale SUV comes in a 2WD version. The closest I recall was the Honda Pilot when we were MDX shopping, but the largest dealer in the DC area claimed to have never seen a 2WD one at his dealership.
    I'd be willing to bet in my neighborhood of DC, you would find 100 4/AWD SUV's before you'd find a single 2WD one.
    No argument about socal and status. Most SUVs are just tall station wagons. They serve no purpose for most people beyond allowing someone to say, "we've got an suv!"
    A4 wagon, in my eyes is more expensive, but then I wouldn't buy a BMW off the lot - save for the M3. I prefer Audi's FWD to their intrusive and easy-to-bind AWD system. Like BMW's xDrive, I think Quattro makes driving a chore.
  • texasestexases Member Posts: 11,190
    True, the vast majority of high-end imported SUVs are 4wd, but the majority of all SUVs are domestic, and here in Dallas, that means 2wd.
    Are you kidding?
    Uh, no. When we bought our Pathfinder a few years ago (2004, the last year it was made in Japan), the Nissan stores here in AZ (where there are lots of off-roading opportunities that surely demand 4WD) were full of 2WD versions -- I'd say there were maybe 20-30% of the Xterras & Pathfinders with 4WD.
    In snow country I'm sure 4WD is more common, but the all-up old-school (shift the transfer case yourself into 4WD hi or lo range) SUVs I see around here (as well as most pickup trucks) are RWD. BTW, I'm not talking full-time AWD here (with a center differential), but 4WD that's used only when you ask for it (that shouldn't be used on dry roads).
    I disagree. This car is just a blast! I might not know half as much as others with formal track experience and driving acumen, but the xi is is no chore from my perspective.
    OW
    Understanding the need/rationale for an AWD in snow regions of US, seems like AWD would be a hinderance in warm climates. Extra weight to lug around, potentially more complications and repairs, marginally less gas mileage (still should be important for entry lev lux). If AWD were so great on dry pavement, then why don't we see it on F1 and IRL cars. These cars have evolved from front engine RWD to mid-engine RWD over last 4 decades. Ultimate lux "cars" such as Mercedes and RR don't even offer AWD.
    Porche does and so does Bentley and Audi.
    The xi is not a hinderance, IMHO.
    Also, the RS4 and RS8 are pretty good examples of the way this technology is finding it's way into the more exotic pure breds.
    By the way, my car is awesome in the wet summer days when fresh rain raises the oil from the pavement.
    OW
    "Ultimate lux "cars" such as Mercedes and RR don't even offer AWD."
    Really? http://www.mbusa.com/byo/frameset.jsp?trackingApplication=mainsite&trackingModel- =S550V4
    Hmmm, could'a fooled me.
    Best Regards,
    Shipo
  • fedlawmanfedlawman Member Posts: 3,118
    Not all AWD systems are created equal. Some are strickly snow/ice traction aids, while others are designed for high performance on dry pavement.
    Lamborghini's seem to perform OK with AWD...
    I would guess Porsche's AWD system are acceptable as well. Here is a comment regarding the '03:
    The C4S offers all the plus factors of the more expensive Turbo but without the added hassles of the auspuffer. The 3.6 liter's power output of 320 ponies is more than sufficient to merge in any kind of traffic, and three-digit cruising on the right roads is where a thoroughbred like the C4S feels most at home. The main selling point of the C4S comes down to one simple point: The handling characteristics are nothing short of phenomenal. For a car the size and weight of the C4S to perform in the manner of a Lotus 7, and do it in comfort, is a huge achievement. After all, we live in a world where all-wheel drive is more of a catchy sales slogan and falls empty with what it promises. Not the C4S. The all-wheel drive makes a strong case that all 911 variants should send power through all four wheels.
    Probably not the purest, but OK for a daily driver.
    OW
    Paging Mark of Cincinnatti. Mark has had 19 Audis and is religously against Audi FWD in favor of Quattro. I have owned 2 FWD (Non GM!) Saab Turbos with a lot of torque and thus a lot of torque steer. I owned an Audi 4000, which was a delightful FWD but it was a low powered, light car. But with 212 or 232 lb. of torque, the A4 FWDs will pull a bit. The Quattro, however, eats that torque up. How one who has driven both hard (as I did yesterday in test drives) can prefer FWD to Quattro, is baffling to me. The Quattro only weighs around 130lb. and diff in MPG is about 2 mpg. But both cars' MPG is way higher than competitors anyway (besides the 328i).
    "The Quattro only weighs around 130lb. and diff in MPG is about 2 mpg. But both cars' MPG is way higher than competitors anyway (besides the 328i)."
    What competitors, besides the 328i, are you referring to?
    I had an Audi A4 3.0 Quatro for a loaner car last summer and the gas mileage was terrible. On a mostly highway 250 mile roundtrip that I was doing at the time, I only managed 24 mpg with the Audi. My Acura TL 6-speed averages 28-29 and my 911S Cab averages 25-26 on the same route / conditions.
    I am referring to the 2.0, not the 3.0, which of course is not sold anymore. As has been covered ad nauseum here, I think the A4 2.0 is entry level but I don't think of the A4 3.2 and the 335 as entry level. I am looking at fueleconomy.gov for my estimates, not trip computers, nor even fillups. You can coast in neutral and do 57 mph and I can roar down hills and average 70 so why bother with anecdotal? That said, I just looked back and you are right, the TL is pretty close to the A4 2.0. I had looked at the TLS, which is clearly worse. But no, the TL ELLPS does not get better mpg than the A4 ELLPS.
    BTW, I think the TL is a great car - fast, reliable, great tech. This conversation was related to Bluedotcom and xrunner's contention that Quattro makes a car more expensive and my response is, well not than other ELLPS it doesn't.
    It adds expense and weight, while removing power and fun...that to me makes it an expense I will not tolerate.
    You already said that and I already er, explained how you may have been off base. Shall we do this again? Sure, why not. It is 130 lbs. heavier. You are correct on one out of three sir. However, the car is not more expensive than its competitors (IS 250, 328, TL, G35) -especially when leasing. The quattro is only $800 more than a FWD but that is countered by higher resale/residual. As confirmed by people on this forum that have driven the two cars, the Quattro handles better due to: 1) its grip - even on dry pavement, and 2) its elimination of torque steer. My understanding is that in certain race classes, the racing organization has prohibited quattro due to some advantage it gives over other vehicles.
    You may be a member of the lighter is always better church and that is understandable - my 1973 Capri was more tossable than today's cars. But if you go out and do a long test drive with both, if you are like most driving aficionados, you will certainly like the quattro more than the FWD.
    No, it's more expensive than a FWD A4. That's how it's more expensive. I don't give a hoot what the IS, G or BMW cost with AWD...
    That's the same ludicrous argument people use for adding any option to a car. You add $1400 for leather, you're lucky to get back $800. Automatic is about the only option that holds its value well. Even then, like Quattro, AT detracts from the enjoyment of the car.
    Driven both of them too. I loathe Audi's AWD system; ditto BMW's horrific xDrive; one more time for Subaru's nasty system. I've not touched a Lexus/Infiniti with AWD, so I won't comment on those. But the Audi/BMW/Scooby systems bind and interfere with the performance of the car in a way I don't enjoy. They make driving a chore.
    I don't agree; been there, done that and I'd rather walk than drive a hamstrung AWD Audi or BMW. I'm not going to pay extra for extra weight, less involving driving and poor gas mileage. Gas mileage drops from 23/34 to 22/31 with Quattro (a difference of $160 a year in gas expenses). For me, the choice is lighter, less complex, more efficient, more fun.
    Comparing resale of quattro or AT to leather is well, creative.... Quattro indeed retains its value perhaps even more so than the cost. But it is in the residual that this can be confirmed. So "ludicrous" is really not an explanation of the argument but of your own baseless conclusions.
    Now, you did get me on point - gas costs. I am sure that you, like most other Americans, makes a decision on a $35,000 car based on $160 per year.
    Given that a huge majority of the posters here and most car mags find exactly the opposite driving experience than you, one can only conclude that your strong opinions are clearly based on an opinionated philosophy - "the choice is lighter, less complex, more efficient, more fun," not driving experience. Again, I urge you to actually drive these cars or put your money where your mouth is and buy a 1969 2002.
    The only chore I find driving my xi is trying to break the damn tires loose! The thing sticks like glue!
    BTW, the gas mileage is OK for me. My Lincoln LS got 19. This gets 22.
    OW
    2005 A4 with FWD and 30k miles = 21116 private party
    2005 A4 with Quattro and 30k miles = 21826 private party
    Cost of a 2007 A4 with FWD = 28,240
    Cost of a 2007 A4 with Q = 30,340
    $2100 difference in price and 2 years later the Quattro car only enjoys a 700 price advantage?! Seems like $1400 out the window. Add in the worse gas mileage ($320 over two years) and now I'm down $1700. Will that remaining $400 disappear by the end of year 3? Most assuredly.
    I have driven the cars. I'm not a fan of either vehicle (A4 FT/A4 Q) but I'd take the $2100 savings and the car that's lighter, more fun and more efficient.
    FWIW, the FT v. the Q = about 121 lbs weight difference (3428 v. 3549).
    Priorities. This is why I won't get leather on my next 335i/M3. The cost benefit doesn't play out for my personal desires.
    "I urge you to actually drive these cars or put your money where your mouth is and buy a 1969 2002."
    On no, 1972 was a better year...
  • pearlpearl Member Posts: 336
    I went for the 3 series. Lots of good choices in this segment, but nothing drove like the bimmer. Had it a week and am very pleased with my choice.
  • markcincinnatimarkcincinnati Member Posts: 5,343
    :surprise: I do not deny that part of the rise and rise and rise of cars with all wheels driven is simply "marketing." Me too, me too, etc.
    Eventually, however, one would imagine that if AWD had disadvantages that overwhelmed the advantages that sales would decline.
    Like those who favor 2 driven wheels, I used to favor and frankly be hard pressed to understand the rise and rise and rise of automatic transmissions.
    I have come to believe -- and there is ample evidence both objective and subjective to support this -- that a good automatic is, well, "good!"
    Years ago, when I got my "poor man's quattro" an American Eagle (an American Motors Concord with apparently "Jeep" underpinnings), I started to notice the obvious, "I could go when others required a tow." Then as my situation and finances changed, I noticed as I could afford AWD Audis and AWD BMW's (our first, a 1988 325ix), that I could also go in the twisties better, faster, safer and have an even bigger blast doing so than in any 2WD car I could afford.
    My boss, at the time, did have a 924 turbo that was also quite fun, but so many claimed it wasn't a proper Porsche.
    In any case, 5 driving schools later, 27 Audis and 2 BMW's later (virtually all AWD), countless articles read, etc etc etc -- I can simply advance the argument that almost all flavors of AWD are popular, are growing more popular, have been criticized (by those who are paid to write), have been less criticized and finally have been praised and ultimately virtually cherished in large measure by the paid automotive writers and racers alike.
    Audi and BMW's renditions of this technology are different. They each have their champions. If you don't like AWD don't buy it.
    AWD continues to advance, as noted, in features, function and popularity. Ultimately, I would not be shocked to find that it can cost less to insure an AWD car for its abilities to avoid "driving incidents" that would require car or human or property repair.
    AWD's racing history can be googled and it is certainly possible to discover the "best" performance and luxury cars are or can be AWD.
    Will there be an AWD M5? Beats me. A new generation RS6 -- IF it leaves the BMW in the dust -- could change even BMW's thought process on a go to market strategy for AWD in their highest performance cars.
    A couple of years ago, BMW mocked those who chose turbo-charging as a way to increase volumetric efficiency. The mantra from them used to be "there's no replacement for displacement."
    Check out the new campaigns, check out the sales figures for BMW AWD models. In some markets it has gone from nearly 0% to over 40% -- the reason, ostensibly is "go anywhere," then the reason starts to shift to "performance."
    Kook-aid drinkers?
    I don't think this entirely accounts for the rise and rise and rise in acceptance, endorsement and praise of "good" AWD almost univerally by the amateurs and pros alike.
    If you don't like it, don't buy it.
    I'd just like to show those who don't buy it, my tail lights. ;)
    Mark,
    You say it so much better than I. While the debate will continue, all I can relate is that this is my first sedan AWD and it far exceeds the performance of my previous RWD/FWD experiences.
    I also remind of the fact that a non-ZHP 330i does not handle as good as the 330xi. It is MHO, but I felt it myself.
    OW
    Is the 335xi out yet ?
    Rocky
    Dealers should be getting info this week and availability should be this month for orders.
    OW
  • kdshapirokdshapiro Member Posts: 5,751
    ":surprise: I do not deny that part of the rise and rise and rise of cars with all wheels driven is simply "marketing." Me too, me too, etc."
    Sorry Mark - I couldn't disagree more with this statement, but we all have our own views on the matter.
