He now thinks that the fins on the water pump are starting to go and that a new water pump will be needed. Today, she said that on the way to work and again on the way home, the gauge would stay in the middle, after about 20 minutes of driving go up to the next line and then come back down to normal. The Legacy has about 80k miles and the mechanic said that he normally changes timing belt and water pump at same time.
What are your esteemed opinions on this situation?
Serge
-mike
Mike,
Unless the head gasket is the problem.
Dave
In fact I just did both (at the same time) on my Miata.
There was one more thing, though, a "radiator switch"? I think? Something like that.
I had to go back a 2nd time to have that replaced, even after the t-stat and water pump were changed, it was still running hot.
Not to say your mechanic is lieing, but, I find it hard to believe that it was preventing that much flow. Unless you physically tried to flush it yourself and it didn't flow, I'd be very wary of a mechanic that says they swapped the rad due to it being gunked up and not flowing.
Then again they charge a ton for doing a rad swap. Once we did one outside the lincoln tunnel on a street in manhattan in about 20 min on an RS
-mike
I checked some of the parts websites and did not see anything about a radiator switch. When you get a chance, could you check your paperwork on that and get back to me for the part...thanks...have a capirinha on me
Serge
Low fluid level, that created a bubble in the top of the engine (the first time we did a 30k service we had this problem 4 consecutive times after flushing, til we learned to back-fill the engine from the upper rad hose)
Bad T-stat -If the T-stat stays closed there is no flow and the coolant in the engine is warm, and the rad icy cold
Bad water pump -The pump isn't circulating the coolant same effect as above
Bad head gasket -creates the same problem as #1 above (low fluid level, bubble in top of engine)
Never saw a radiator sooo clogged up that the car would have an ice cold radiator or even an overheating problem.
-mike
-mike
Funny how these co-incidneces arise. Ran into a friend with a Subaru who mentioned he had the same problem in a mid 90's Liberty (Legacy to you). Replacment radiator is procey so he took it into a radiator shop which repaired very easily.
Might be worth enquiring if the radiator is repairable
Cheers
Graham
I guess people are trading in their SUVs for Subarus, that's the only way I could explain it.
Forester sales up a whopping 66%. :surprise:
Of course that's why no incentives will appear for me.
It says, literally:
"BWD AUTOMOTIVE Radiator Fan Switch"
It's not the same as the T-stat because they had changed that out previously. The Miata was still running hot so it went back in a 2nd time, and that's what it was.
Mark
Are you on stock springs, mike?
I was quite suprised that the Hawk HPs pads held up extremely well even during 2 30-min sessions that I ran back to back. They didn't fade on me at all and didn't leave me really begging for more braking, although more is always better, for a nearly stock (except for the tires and SPT Catback) the car performed outstanding.
-mike
Colin complained about fuel starvation way back when, on his RS. Seems like that's still an issue now!
I've been wanting to purchase a new Forester but circumstances mean I'll probably have to wait quite awhile yet. In the meantime I've enjoyed following the saga of your new Forester and in a virtual way shared your excitement and anticipation while waiting for delivery. I think my reactions would be exactly the same. I realize it's not going to be your daily driver but I've been reading the blogs looking forward to your comments, feeling, thoughts when you do drive it. I hope you will share those thoughts.
Jim (In Yooper Land)
http://townhall-talk.edmunds.com/direct/view/.ee99548/30228
"The combination of progressive pedal action, no brake fade and good tire grip means you can go deeper into a corner with the Legacy STi S402 than just about any sedan we've tested before."
"The S402 might be the first-ever Japanese sedan with a brake package that actually feels overengineered."
"This car is plainly built to be punished with speed."
"...even at a price tag of $53,000. It's the kind of Subaru that should come to America."
How 'bout a limited production run of these for Subaru's 40th Anniversary in the US, SOA? This is a halo car. Think of the all the resulting good press that could be a quite timely build-up to the release of the next-gen Legacy.
They should try to package it right at $39,995, but keep the important stuff.
-mike
-mike
I pretty much agree here—especially the comments about the styling.
Bob
I just sold my Subaru race car and my 240sx. Time to start modding the 05 LGT Wagon now
-mike
Bob
How was the drive in the parade?
-Brian
http://grassrootsmotorsports.com/project-cars/1967-volvo-122s/
I'll go out and snap a couple
What does your better half think of it?
-Brian
We have no money though, so finding a similar "weekender" will have to wait. Plus, we have a 4 year old, and this car's back seat is now a roll cage. So we'll just have to sit tight until the right 122S wagon (Amazon) comes along :shades:
today is our last day with it. It's early in the morning and no one is out yet, so I think I'm going to plunk my daughter in the passenger bucket and take her to the local patisserie for brekkie..... I know I know it's illegal and unsafe, but she's in love with this thing, and I think back to when my Dad let me sit on his lap while he steered.... Wife is still asleep, so we're going to slip out by ourselves.
http://www.muzeum-motoryzacji.com.pl/photo/Fiat%20600%20Multipla.jpg
http://en.wikipedia.org/wiki/Fiat_600
Bob
