Subaru Crew Cafe
1123124126128129343
  • c_hunterc_hunter Member Posts: 4,487
    Yeah, best to have the dealer look at it, I'm drawing a blank -- many possibilities, nothing specific to point a finger at. Did you smell anti-freeze?
    Craig
    Best thing (or maybe worst, keep reading) I did was to build a loft in our garage. I have 15 foot ceilings in there, so there's a ton of wasted overhead space. I made a 4foot x 17foot loft against the back wall, and have plans to do a bigger loft right over the garage door if needed.
    What kills me is that my first loft is out of level. My dad had given me a bunch of tools when we moved in, all very desirable (including pneumatic nail guns). He also gave me a 4foot level, which was apparently way out of whack. I used the level to line up the support against the back wall, and then also used it to level the main beam in the front of the loft. Clearly, I flipped to different sides of the level for each, because the back of the loft slopes one way, the front the other!! (and neither is right) I built the whole damn loft before noticing. When finished, I stepped back to admire my work and almost bugged my eyeballs out. It's off by 2" over 17 feet, and the combination of the two different slopes front and back is just lovely. I grumble everytime I look at it. You'd never know I was trained as a carpenter by looking at this thing! If anyone notices, I just tell them the house is crooked but the loft is level....
    Craig
  • fibber2fibber2 Member Posts: 3,786
    I love it! Next time I am down in Williamsburg, I will have to come over to see your level loft and the crooked house.
    Gee, hope you point the rockets with more precision..... ;-)
    Which way is Mars, anyhow???
    Steve
  • p0926p0926 Member Posts: 4,423
    Joybell- I'm completely befuddled by the burnt mitten smell. And you're right, If the engine was really only idling for 3-5 minutes, it should've just been starting to warm up. For it to get that hot that quick leads me to think that the coolant wasn't circulating at all. Could something have frozen in a line somewhere? But that seems unlikely since as Pat pointed out, Canadian cars have excellent antifreeze. You've never had to add coolant/water have you? The only thing else I can think of is an air bubble somewhere in the system. In any case, let us know what the dealer finds and good luck!
    -Frank P.
    I love my car port, but it still only covers 2 of our 3 cars. The Miata was covered in snow, but this time I brushed it off, because last time a coat of ice formed over it when I didn't. Took a couple of weeks to melt off!
    My ideal house? A 5-car garage with a small loft where I could sleep. :o)
    Oh, and a private track out back.
    -juice
    Juice- Better not let Lana read that cause it sure sounds like a bachelor pad to me!
    -Frank P.
    Oops, forgot to add the walk-in closet and her very own seperate bathroom.
    There, all happy now.
    -juice
  • Would love being able to wash and dry the car no matter the temperature.
       Cheers Pat.
  • nygregnygreg Member Posts: 1,936
    funny, there is house in my town that has just that - about 3 or 4 garages below the living area. The garages are about 3 times the size of the living area. Wonder if there is a Subie in one of those spaces.
    Greg
  • grahampetersgrahampeters Member Posts: 1,786
    G'day
    Saw the ideal houxse recently. Big house upstairs and parking for ten cars underneath. The guy who owns it is happy!
    Cheers
    Graham
  • large garage and a small house would be just right:-)
      Cheers Pat.
    More Honda truck(s)?
    http://www.autoweek.com/cat_content.mv?port_code=autoweek&cat- - - - - _code=carnews&loc_code=index&content_code=09639487
    Looks like the rumors may be true. The all-new Acura RL will have 300HP, AWD, and may be a hybrid!
    http://www.autoweek.com/cat_content.mv?port_code=autoweek&cat- _code=carnews&loc_code=index&content_code=01990871
    If that doesn't shake up that luxury market segment, nothing will.
    Bob
    For Honda, it's too early to tell. Remember, Toyota got a lot of criticism when the T100 came out for being a half-hearted effort.
    Honda's will be more car-like, but it's unchartered territory, who knows what will happen with the SUT. As long as they don't have to invest too much, it could be successful.
    RL will be interesting to watch. The rear axle needs to get power in a full-size luxury car, otherwise it'll be a niche vehicle at best.
    -juice
    http://www.wkjeeps.com/early.htm
    Too little, too late?
    Bob
    Utterly unimpressive. It looks like an inflated Malibu Maxx.
    -juice
  • lark6lark6 Member Posts: 2,565
    More than a little bit of Honda Pilot from the windshield back in that new Grand Cherokee.
    Ed
    reportedly will have a IFS, like the Liberty. They may also offer a stretch model with 3rd-row seating.
    Bob
    It actually looks more like the Grand Cherokee from 2 generations ago, they went back to the square look. Toss on Land Rover lamps, and call it new again.
    Their 4WD needs an overhaul so it doesn't whine annoyingly when cold.
    -juice
    They dropped AWD, though. Even though only 3% got it, DCX used to have a full line of minivans, now they don't any more.
    GM also dropped AWD from their vans. Another mistake.
    I'm sure Toyota will happily pick up that lost market share...
    At least DCX has a spare, even though it's a donut. Sienna has run-flats.
    -juice
    to have an electric motor powering the rear wheels, as there is no driveshaft to worry about. That motor could be located where the rear differential would normally be.
    Bob
    I wonder if they'd have space for the battery.
    We'll see, it would certainly be better packaged than 3 driveshafts!
    -juice
    Someone over in the QX56 area here made a comparison between the two Nissan kissin'-cousins.
    ceric "Sneak peek at the QX56" Jan 28, 2004 3:57am
    Bob
    Bob - you knew the new PF would be body-on-frame, but did you know they shifted production from Japan to the US? Smyrna, Tenn.
    -juice
    Hmm, interesting, Ford built the beefy Bronco concept we saw on the Escape unibody platform.
    -juice
    Did you hear this? $95,215!
    -juice
    I knew that too. Frontier too, I believe. That's why I get the big bucks! :)
    Bob
    You mean you hunt? LOL
    -juice
  • kenskens Member Posts: 5,869
    Yeah, I agree with the JGC being too little too late. It used to stand out before when upscale SUVs were still far and few in between.
    I read that the Phaeton is flopping in Europe. It'll probably do the same here. People who can afford a Phaeton are not going to want to shop and deal with VW sales and service.
    Ken
    $500 dealer incentive on Phaeton already...
    I think it looks great, they just overpriced it. VW isn't leaving room for Audi above it, all this is a hang over from Piech's egotistical days at VW.
    Among european brands, VW was a big loser last year, among the worst 3 in terms of lost market share.
    Did I call it? I've been saying this all along. Sales down with 2 new pricey products? Uh-oh...
    -juice
    Just my opinion but Armada/QX56 are gross and awkward looking, especially the QX. Why such discontinuity between all three side windows? Why such ham-handed front end styling on the QX? I've seen Little Tikes vehicles with better lines.
    While I'm at it, when you say the names of Infinti models to yourself, can't you hear Marvin the Martian's voice? "Oh drat, you've made me very angry, very angry indeed. I shall have to destroy you with my Inifinti QX56 explosive space modulator."
    Thank you, I'll be here all week. Don't forget to tip your server.
    Ed
    I always tip 20%. Our kids leave a mess.
    Now I'll never look at an Infiniti in the same way again. :o)
    -juice
  • lucien2lucien2 Member Posts: 2,984
    very well done, Lark. Call me if you wanna sell those SLs!
    I think that is a shame. As much as I like our '02 Odyssey, Beth has often mentioned that she wouldn't mind an AWD GC as a future replacement (we had owned a pretty good '97 FWD GC). Especially if some overseas quality made it into the mix.
    I wouldn't have minded giving up some sidewall space in the way back to accommodate a doughnut spare. Or even consider going without (a la Sienna).
    Steve
    Good one Ed!
    Craig
    Loosh: You have something to put them on? I still do. ;-)
    Ed
  • bigelmbigelm Member Posts: 995
    Rumor has it that for the MY05, there will be a completely new interior design as many complaints have fallen on the Infiniti's G35.
    Revamps are as follows:
    -Repositioning of power control seats
    -Design and interior quality and material
    -Possible redesign of front seats (extra bolstering)
    -Some other goodies to be addressed (most likely the radio).
    Whoa Loosh, that your black XT in MTM!?
    G35 is where the Altima should be in terms of material quality. You can say that about a lot of Infinitis. Some Nissans are sub-par, IMO. The Z got a couple of upgrades after just a year, too.
    Bring Nissan to where Infiniti is, and upgrade Infiniti's materials, that'll do.
    -juice
  • joybelljoybell Member Posts: 275
    "tightened hose clamps causing leak"
    So there you have it...the cause of the temp guage rising and the smell (yes I guess it was the antifreeze and the hot engine that I smelled). Funny though, that it only happened on that really cold day. They also filled up the coolant/antifreeze and I got them to do the 6000km service at the same time, although I only have 5000km on it. And Patti, the service manager never heard of the "conditioner coolant", so maybe that's a purely SOA thing?
  • ladywclassladywclass Member Posts: 1,713
    tires in the "meet the members" .. cloth v. leather in here ... i think i had something over 30 posts in members and over 40 here today ... what debaters we are !
    Yeah guys, stay off topic, will ya? This is the Cafe! ;-)
    -juice
  • njswamplandsnjswamplands Member Posts: 1,760
  • jfljfl Member Posts: 1,399
    she's dating herself? 8~O
    I don't mind you guys knowing that if you plan the "Tour of Indiana" near the beginning of May, you can also help me celebrate my 1/2 century birthday .. (omg ... if I say it enough times between now and then maybe I'll be resigned to it by then!)
  • hammersleyhammersley Member Posts: 684
    Wow. Maybe by 100 you'll type slow enough for me and Pat to read...
    Bob: read something interesting in C&D - remember how I thought the BMW 6 convertible's rear window shape/position was odd? Well, it turns out that rises and lowers independently from the top. When the top is down, it actually functions as a wind blocker.
    Pretty clever. It still makes for an odd looking C-pillar, but I'll concede that it's functional, and therefore worth it.
    Also, when we saw it, I didn't realize that the Dodge Sling Shot was a convertible, nor did I realize it was built on the Smart platform. They really, really should have shown it with the top down! Dumb!
    -juice
