Visitor Agreement.
Tell them what your willing to pay, i.e.$5.00 a check, so if your checking tranny fluid, air filter and brakes... thats $15.00. If they are not flexible then ask them how long it takes to do the work, and pay by the hour, then tell them you need a mechanic to go over your car for 4 hours, at a rate of $75/hr. then your only at $300.00
no one gets these services, most dealers don't even offer them anymore, or have brought their price down to reasonable of $350.00
I really don't want to bargain with them. Car dealerships are a pain in the [non-permissible content removed] anyways and I have a feeling if I bargain with them, their gonna bargain the actual work on the vehicle. I have no problem taking it to the Big O tire center right around the corner. I know the guy there and he always does a good job when I need something.
Have you bargained with the service dept. before? I'd be interested to hear what they did when you tried that.
are recommended. I replaced air filter and A/C filter myself. The location of air filter is not very convenient,so
it takes extra time(15-20 mins) to replace it. If you go to
Infinitihelp.com you can find information on maintenances etc.
I am in So California and some Nissan dealers work on Infiniti vehicles. For routine maintenances I just take it
to Nissan dealer in Buena Park. I usually pay $30 for oil
change including car wash. I even use Nissan service coupons
on my Infiniti G35 ! Afterall, it shares many parts with other Nissan cars such as 350Z. At 30k miles, I had coolant
service and auto transmission service for about $ 170.00
Tire rotation and balance can be done for $ 30 to $ 40
I also replaced wiper blades myself @ 25k miles.
I would make sure to visit Infiniti dealer for warranty
work before your factory warranty expires.
good luck
Also, it is past 3 months (3 months & 2 weeks to be exact) and I haven't changed my'engine oil as yet. The car has 3500 miles on it. I am planning to get this done on Monday.But hopefully, I havent done any irreversible damage ? I checked my engine oil level in the morning, the level was in the 60%.
Does the onboard computer monitor for the engine oil level too and alert you on the dashboard?
Appreciate any inputs
Sundar.
No you havn't done any damage, Oil doesn't breakdown until 25K miles. but I would never recommend going that long.
here's the section of the manual on the engine oil light
Engine oil pressure warning light
This light warns of low engine oil pressure.
If the light flickers or comes on during
normal driving, pull off the road in a
safe area, stop the engine immediately
and call an INFINITI dealer or other authorized
repair shop.
The engine oil pressure warning light is
not designed to indicate a low oil level.
Use the dipstick to check the oil level. See
ªEngine oilº in the ª8. Maintenance and
do-it-yourselfº section.
Running the engine with the engine oil pressure
warning light on could cause serious
damage to the engine almost immediately.
Such damage is not covered by warranty.
Turn off the engine as soon as it is safe to do
so.
Will replacing the regular engine oil with the synthetic one have any negative effects ?
Engine oil lasts a lot longer than you would think. It is good past 5k miles. Now, being that the car is brand new, you need to get that factory oil out of there and put synthetic in. I recommend Mobile 1 synthetic. If you go buy a case of the oil at Costco, the dealer will put it in your car for a cheaper price than a regular oil change. The synthetic oil will not have any negative effects on the engine, it will help it perform better.
As far as the engine noise, I enjoy the purr of the engine when it's up in the higher RPM's. That's the beauty of owning a performance vehicle, the power. Not sure what loud sounds yours is making, but I like the subtle, smooth rumble of my engine.
I appreciate the input, let me know if there is anything else I need to do for the 30k service. The car is immaculate and runs perfectly, I just want to maintain it so that I can keep it for a long, long time!
If they do in fact put fully sunthetic oil in the 2007's, I highly doubt it is a top quality motor oil. They wouldn't use the good stuff on that many vehicles.
Not true... that's one of those synthetic oil urban legends that's still sticking around with some people. You know, the one's like once you use synthetic you can't switch back... or you can't mix synthetic & dyno. Many vehicles now come factory filled with synthetic.
The engine in the Infiniti G has a break-in period of 1200 miles. ie, no WOT (wide open throttle), vary RPMs, ... typical break-in rules.
It does not mean, however, that your engine is 100% broken in at the moment you hit 1200 miles.
During the break-in period of an engine, there needs to be a certain amount of friction between the motor's components. The piston rings need to rub against the cylinder wall to break-in or "finely tune" the machine mating between the two metal parts.
To properly seat all mechanical components, a certain amount of friction is required between these metal parts.
Synthetic oil is just to slippery and if placed into the engine at too early a time, these parts never properly marry, which can lead to problems like poor compression.
The point where people start to disagree is on the subject of "when is good"?
I'm in other G forums as well, one which includes members who are Infiniti Techs and they all seem to be in agreement on this subject.
They have been informed that Full Synthetic is not recommended in this engine until 12-15k to allow for proper engine break-in.
Again, this all depends on the driver's habits and what kind of miles are on the engine, but for me personally, I think 3K is just too early.
Haven't even given it a thought yet.
As for the fuel tank... that's typical, at least for Nissan.
The fuel pump is in the tank and does displace a little bit of that fuel capacity.
Also, when the fuel light comes on, you actually have somewhere around 50+ miles in the tank.
The pump is submerged, and from what I've been told, the fuel it pumps also acts as it's coolant/lubricant, so it's not suggested to run the tank too low.
For that reason, the fuel light comes on early, so you go and get gas without causing damage to the fuel pump.
US Measure: 5 1/8 qt
IMP: 4 5/8 qt
Liter: 4.9
Without changing filter:
US Measure: 4 7/8 qt
IMP: 4 3/8 qt
Liter: 4.6
The magical question is...
What's an IMP?
And don't say, about half a quart! LOL
And YES an Imperial gallon is 160oz vs 128oz for a US gallon.
There is a fuel pump in the tank, which displaces some of that capacity.
That, along with the fact that some fuel MUST remain in the tank, means that the guage and light come on while fuel is still in the tank.
Sorry if I'm not explaining this well.
Maybe someone else can give this a try.
My friend bought an Nissan X-Terra months before I picked up my G and he had the same exact finding.
They claim one capacity, but when empty, it took nowhere near that much fuel.
I used to laugh about it, and now I'm in the same boat.
All I know is that when it reads empty, I have to fill it.
Just a bummer that we can only drive on16 of the 20 gallons... really cuts down on "Miles Until Empty"
I guess it's all opinion. I put synthetic in mine right after the 500 mile mark and I drive it like it's supposed to be driven. It's a sports car, right? I love it, I drive it hard and it runs perfectly. It's just all perception and I really don't think there is a "best option" when it comes to this. It's whatever you feel comfortable with.
Thank you for your help,
Lori
ps-I feel stupid for not researching this car better!!!!!!!!
kforney@bak.rr.com
Also when I stop sometimes at a slow speed (and no it's not my drivign with this) I notice after I stop the car jerks forward especially on an incline. I just had the suspension replaced (should ahve been when I bought it used last September) about 5 or 6 months ago. Could it be going again? Any help/info is great. Thanks!
My Jeep Grand Cherokee was doing weird things like this and then the Check Engine light came on.
My mechanic pulled the code and it turned out to be a Speed Sensor in the transmission, and cost about $150 to replace, including labor.
I think we'd need more details on this to make an educated guess, but if it's jerking forward, after coming to a stop, it sounds like it's coming down into 1st gear hard... assuming this is an Automatic transmission... so yes, that sounds like a transmission issue.
This is caused by exposure to heat, brake dust and moisture.
You can sand them down, tape them off and coat them with paint or clear if you wish.
All unpainted calipers will rust over time.
I've been looking for a paint color that closely matches my Blue Slate color, so I can paint the calipers to match.
In the meantime, when rotating my wheels, I give them a good once over... scrub and clean.
This keeps them looking nice.
What I mean is, if you get in the car and hit the start button without your foot on the brake, it turns the ignition on.
This will smoke your battery pretty quickly.
I know of a few guys who were listening to their "Studio On Wheels" system with the ignition set to On, while waxing the car.
2-4 hours later, dead.
Also, if it was an Alternator, it wouldn't just die from sitting still.
If the ignition is not set to On, then something else is causing the drain, and a tech would need to hunt it down for you.
So if the car, in this case the sedan, is one piece and doesn't have what I think of us the old "panels" of front and rear, etc, I don't get the repair concept. Say I crunch the rear corner. The salesman tells me that nothing is "replaced" it is just repaired. As in the damage is straightened and repainted But my body shop friend of ten years who is very reputable says No Way.
Any experts on the subject . . . . ? Thank you
littlea lot ridiculous?The suggested maintenance is how the dealers make their money.... more more than from sales of cars.
The $140- will buy you an oil change and tire rotation, along with the inspection of brakes, driveshaft, exhaust, steering & suspension.
I think these "inspections" are complete garbage and never fall for them.
Have them rotate your tires and change your oil... and put the other $70-$80 bucks toward a new golf club. :P
Z
I'm saying that he'll most likely be paying for more that what he receives in return.
And yeah, I've heard about those nasty scheduled maintenance prices over there at Lexus. Ugh.
The point I was trying to make (but failed to do so) was that most of these things are not even done, so No, you do not ALWAYS get what you pay for.
Some tech glancing at my brake pads quickly as he pops his head underneath and sees the exhaust is still there.... that's not worth the other $75 being spent.
If you have absolutely no knowledge of cars what-so-ever..spend the $140.
I'll get the tire rotation and oil change and inspect the other stuff myself.
Normally, I do my own oil changes too, but life is recently much busier for me and it's just easier to swing by the shop and have them do it in 10 minutes.
Tire rotations are another easy job, but the 07 G does NOT like floor jacks, as the jack points bend easily.
I'll leave that to them, as they can do it while the car's up there getting the oil changed.
agm18
I would not be worried about a 2007. You can search the arcives of these boards for additional discussions on this.
