Invoice on a Sport+Ent is found here http://consumerguideauto.howstuffworks.com/2008-acura-mdx-2.htm
It's about $43,500 + destination charge which might be higher in Hawaii so it's hard to tell how high it will really be.
Generally though I don't think that's a very good deal, but Hawaii is a weird market when it comes to car buying.
Also, having driven in Hawaii extensively I don't know that I see the benefit in the sports suspension, you would probably be able to work a better deal on the TECH+ENT model.
Thanks, Kevin. srad911@aol.com
I have the same problem on my wife’s 08 with 1900 miles, and what I would like to know from you is if it has also affected your radio preset memory and also the settings for bass, treble etc Every time the radio lights go out all radio settings default back to the factory settings. For ex; all FM stations go back to 87.1 and sound settings default back to center (“C”). And yes just like you it doesn’t happen all the time, it is very intermittent and the last time the lights went out was interesting.
Was driving for about 30 mins everything working, stopped for gas and of course shut off the engine and pulled the key. Got back in, started the engine and the radio lights were out. After about 10 mins of driving hit a slight bump in the road and the radio lights came back on. Another thing, how is your Bluetooth, does it cut out often? Mine does and since it is tied into the radio I wonder if this is all the same problem.
Since this is our second MDX, had a 2004 that the 2008 replaced I have a pretty good rapport with my service advisor so I called him. He told me that he hasn’t had anyone else complain about this problem yet, so lucky me my MDX will be the first one that my service department will get to troubleshoot with this problem. He said that it sounds like a lose wire that is sometimes not making contact, or maybe a bad ground and will also check the Bluetooth when I bring it in. I haven’t taken it to the dealer yet, and probably won’t have time until maybe next month, but will post what the out come is.
I think it is a computer/control problem that controls the lighting for day/night adjustments. Remember there is a photo-electric sensor that is centered on top of the dash that controls when to switch between your day-time running lights that are below headlamps- then at night the car switches to head lamps and fog light only.
And also switches inside control lights on wheel and all of the dash to either- Off for day ,dusk they are dimmed or bright for night-time visibility(all sensor controlled)
For a brand new car I just don't want a non-experienced tech to pull apart dash on a quessing game to put back and take apart and put back and then later find scratches and rattles from broken clips and pins! They add all the fancy electronic goodies to make it luxurious but do they really train mechanics in electronics to repair them when they mal-function or will I have to take it to RADIO SHACK?
Calling the dealer now. Good luck
"Since this is our second MDX, had a 2004 that the 2008 replaced I have a pretty good rapport with my service advisor so I called him. He told me that he hasn’t had anyone else complain about this problem yet, so lucky me my MDX will be the first one that my service department will get to troubleshoot with this problem"
If I had a dime for every time I heard my service manager say "I've never heard anyone else complain about this" I'd be.....well......I'd have a few dimes.
I think they're trained to say this whether they heard the complaint 100 times or not.
Luckily, we haven't had any electrical problems in our '07 but if we did, it would be parked right in front of the service bay with the horn honking. :P
So, after seeing the picture, the dealer contacted Acura. They then replaced the radio panel and I havent had that problem since then.
How long has it been since the replacement with no problems? Did the dealer do nice clean work taking apart dash and putting it back to new?
Thanks for posting,
Kevin.
up and down. Dealer said it's normal. Local auto shop said we could oil it but would streak - what do the wise people here think, what's the solution?
Window glass rubbing against seals can squeak and if oiled would tend to streak, etc. (This would tend to go away over time as the glass and the seal "wear in")
Window mechanisms can also squeak and can be lubricated/greased without streaking the glass. Hard to tell which is which unless you can see it or take the door apart.
I was told I had a computer virus, which I found interesting. There is only one way to infect a car that I am aware of . . . at the factory. I use the bluetooth, but I use a blackberry platform, so it is highly unlikely that had anything to do with it and no one at Acura has said anything to that effect.
They reset the entire computer system (what a pain to reprogram everything) and replaced a bad amplifier in the stereo. It seems to have done the trick, for now. It took 10 days to get the part. I have no additional information on the computer virus, but again they seemed to have fixed this most recent problem and I have had only one minor problem since then. The sensor telling me the gas cap was open indicated it was open when it was not. But it only did it one time. And, before you ask, yes I had turned it past at least 3 clicks. It came on after 150 miles of driving after the fill up, so I am confident it wasn't "user error".
I wrote a long letter to Acura and heard promptly from them. I had two concerns, the repeated problems and the issue of the rear crash test results (see that thread if you are interested). A very nice person called me. She reminded me that they have fixed everything that broke on the car, which is true. I just want them to send a factory rep out to look at my car carefully. My dealer has been fantastic, but this is an Acura problem, not a dealership problem. They don't seem too interested. The response I continually got was "we will continue to honor the Acura Limited Warranty that came with your vehicle". I am sure it was written on the page in front her and she isn't allowed to say anything else, but you would think they could be a little more creative in responding to a customer who just spent a lot of money for a vehicle that has too many problems. I am confident that if an Acura big shot had taken my car to drive, he/she would have returned it a long time ago and picked up something else. I don't have that luxury. So, for those of you who are interested. Acura customer service is very prompt, very friendly, and very useless.
If my car is in the shop 10 days more in the next 5 months, it will be a lemon under my State's lemon law. If it breaks again, they can have it. If not, well maybe they fixed everything and it will be a good car. Or, maybe they factory workers were training the day they made mine.
The sad thing is that I have taken my wife's cars the last three times when she has needed new ones (for various reasons) and this was my first "new" car since 1996. I was so excited. What a complete dissapointment. I am still reasonably hopeful that it will serve me well for a few years.
I know there are couple of people who are diss'ing the MDX on this thread. For the record, I am not one of them. I really love(ed) this car and was very excited to buy it. I just want it to work without having to wonder every time I start it what will break today. I think it is a great platform and the engineers did a fantastic job making a 4,000 truck drive like a sport's sedan. But, at least with mine, there was just NO quality control when it was constructed.
Kevin L.
I called the dealer and they are being absolutely non-cooperative.
They say they have to be able to duplicate the problem....
:lemon:
In my opinion the 08 TL Type S is just a much better put together machine than the new generation MDX. Note I said the "new generation". We have an 05 MDX and it has been bullet proof. The new MDX while technologically more advanced than the previous version, is just not put together well and plagued with a plethora of issues some of which I consider major ones. From looking through this forum I think a lot of other owners would agree. Too bad, this SUV has potential but Acura corporate needs to get its act together and listen to their customers instead of being so arrogant and condensing.
Then the Engine Mounts broke, $900 repair.
Then the buttons on the overhead light broke. $300 unit replacement.
Now the driver door won't open, even though it's unlocked. Neither the interior nor exterior handle will get it to work so I have to climb in & out of the passenger door. Looks like my "accentuator" might be out too. I saw a Google posting on the same problem and in that case, the dealer couldn't fix it so he sent it to a body shop to have the door sawed off and the entire handle assembly replaced.
The MDX is a nice ride but the headaches aren't worth it. My other car give me much fewer problems and guess what... it's American made.
I am looking for a reliable shop/mechanic(preferably Acura Certified) to work on MDX, someone i know who took his MDX for the 15000 miles service and was given a estimate of $900, i was wondering if someone knows of a place in Plano/Richardson/Allen TX area ? Also for the oil change do the quick lube shops use the "crush washer" that the dealership puts so much stress on when doing oil change ?
Comments please.
Jack H.
It is 3 months and the radio channels have preset 4 times. It is extremely annoying. I called the dealer to inquire about the fix and they now tell me that it may take upwards of 6 months to diagnose the problem. I think this sounds way too long.
Is there some law as to how long they can take in finding a solution? Also, does anyone have access to the Acura T-Line and look up that reference number?
However, I am still loosing my radio presets AM & FM and all sound settings (bass, treble, subwoofer etc) default back to center (“C”). The service department has been great but is puzzled. Now they think it may be a problem with the remotes because most of the time when we lose the radio settings it is when switching between the Driver 1 & 2 remotes.
For example, I will use my remote all weekend without a problem. Come Monday morning my wife will use her remote (#1) and all settings will reset. When I go to use my remote (#2) again later in the week (Thurs, Fri) 9 out of 10 times all settings will reset again. This process repeats itself over and over.
I think I may “unlink” the remotes to the MDX and only use the memory buttons on the drivers door for a while to see what happens. My thinking is if all presets stay to what I set them to in the memory 1 & 2 presets then it’s the remotes. If all settings reset even though the remotes are not linked then who knows.
I am going to mention the Acura T-Line reference #255821 to my service department to see if this helps.
Good Luck!
No resolution though
link title
I finally traded the 07 MDX - Couldn't stand all the noises on a $40K + vehicle. Acura will tell you it is a normal characteristic. It is horrible - sounds like the suspension is about to break apart.
In my opinion the new generation MDX is a :lemon: .
The entry on the warranty service ticket was "install chassis ear to pinpoint location of noise" code 311099
Hope that helps. If they don't know what you are talking about, call Acura, but I am betting that won't do much good. The National Customer service is useless.
All other power seems to be fine. Headlights, windows, locks, heater, dash lights. Everything seems okay and the car is drivable. They only thing that appears to be affected is....
GPS screen is off
Radio does not power on
12 V power on dash and in center console glove is not working.
The little red security LED on the radio still blinks though. Seems like this is more than a fuse, but what electrical links all of these? Some relay blew out or something?
I have a Blitzsafe auxiliary input wired in, so I'm guessing that could be the issue. Will know more tonight after I get behind the console.
I am also experiencing a thumping sound or rattle in the rear left when I go over some bumps, but not always. I noticed some forum members had mentioned this. Is there a known fix that I can suggest to my dealer?
You're the man!
Also, what about changing the trip computer and odometer from miles into kilometers?
