Pickup Truck Accessories
They didnt have to drill any holes in my silverado for my rhino liner
I love mine works great have had it for over a yr
Ryan
From what I have seen, the speedliner is the toughest, but retains a much better grip than line-x.
The colors look great, and they really don't have a fade problem. I am thinking about color matching my Forest Green. I have had a quote for $325 for black or the dark green to match. This is for under rail.
The only drawback I have seen is to do over the rail is hard to find. Some shops will do it, but don't guarantee it. The main reason they say this is because it tends to get picked and pulled at over the rail.
Thanks for the help,
Jeff
Soft Cover: I just took an Extang Black-Max off my truck. Looked good standing still, handled winter weather great, but I couldn't stand all the whipping around in the wind. Drove me nuts!. Snaping and unsnaping was a pain, but that's not as big a deal with a hinged cover. My dealer tells me Extang and TechStyle are the best for soft hinged. Looked at samples of both and TechStyle looks lighter than the Extang; which I already have a problem with. Ordered an Access soft roll-up. Bows roll with the cover and it's fully tension adjustable with an over center latch at the rear that doesn't interfere with the tailgate. True soft cover look, unlike Pace-Edwards and Roll-Top. Don't have it yet, so can't comment on how well (or not) it works. Showroom sample/demo was impressive.
-- Don
Hans
Since then I've had "Access" roll up covers on my last two trucks, and they are great. They get completely out of the way, look good, last well (my son still has my first one -- 7 years old and in perfect condition still), and stay drum-head tight in all seasons. Water is shed to the outside without tubes/drilling/etc needed on the Pace-Edwards design. No sliding tracks to fill with dirt/debris.
Hans
Scott
-- Don
For now, one question: when using a rubber bed mat, is the mat fastened to the bed? Lot's of folks talk about ease of removal, but I'm not clear if that includes removing a few screws or if the mat is heavy enough to just sit in the bed without any fasteners at all.
Then as respects a rubber mat for the tailgate, I guess that definitely requires drilling and screwing...right? or maybe some kind of velcro arrangement, but I would wonder about how well that would hold-up.
One question: if I'm reading the web info correctly, it appears that if you have a lockable tailgate, the Access cover gives you a fully locked bed. Is that correct?
-- Don
BTW -- If anyone's interested in a cheap, slightly used Black Max Extang for a S/B Silverado please let me know.
-Eric
John
Gulfguy
01 GMC 2500HD Crew Cab
8.1-Allison-3.73 locker
Black/grey leatehr
Help. Getting a cover and spray in bedliner before winter (I HOPE)
Truckchic
'01 GMC Sierra K1500
No snaps, velcro instead. Rolls up towards the cab. Great for cold weather. Had one on my Ranger.
How water water tight is the Fold a Cover?
Scott-o-rado
The Fold-A-Cover is not water tight. The only time I get water in the bed is when I take my truck through a car wash. It comes in between the tail gate and the sides. This is not the fault of the cover but i wouldn't put anything in the bed that is water sensitive like computers or fine furniture.
Truckchic
Steve.
Rick
-- Don
They will be put on a WAAG Sportster center grille guard.
John
piaa
The Merg
P.S. I gotta say though that I do like the Access Roll-up cover. The two downsides I see with it is the velcro closure and the price ($400+).
- The Merg
Things to look out for: First, it will be a pain to work with in very cold weather, just like any soft cover other than those hinged ones. Either leave it on or off all winter, because when it sinks below 40 you might as well not even try to get it on. The fabric will shrink, making it hard to snap on. Tiny tears have formed around a couple of the buttons because the tension on the cover is so great in cold weather that it overstresses the fabric. However, like I said, they haven't gone all the way through the fabric and though its been tough to use at times, its been useful through two winters.
Also, the rubber insulation strip underneath the bar that goes over the tailgate will eventually work its way loose. They say you can open the tailgate whenever you want without removing that bar and have no problems, but eventually the repeated rubbing pulls the insulation off, especially if you have a tailgate protector. Youll have to get some strong rubber cement and put it back on. To avoid this in the first place try to lift that bar up an inch or so when opening and closing the tailgate or take it off completely.
I dont know whether the manufacturer claims it to be water tight, but I've checked underneath after some pretty heavy rain storms and I couldn't find a drop in the bed.
I do wish the support bows locked in place like Ive seen on other covers. They just slide onto brackets bolted to the sides of the bed but don't have a locking mechanism. They've started to slide out of place on occasion on hard starts or stops. If they locked they would also be sturdier for holding heavy grocery bags or luggage in place.
You're lucky you got an under the rail cover. Mine is over the rail. That's what came with the truck, and I like having a liner and didn't see any point in going to the expense of getting rid of it and finding an under the rail version. So it took about twice the normal time to install my cover because the liner had to be notched so the c-clamps to hold the rails in place could be attatched to the bed. It also doesnt look as clean as trucks with an under-rail liner/soft cover combo do. I paid about 60 bucks over the price of 200, but I think it was worth it just because of the difficulty of making those cuts.
Overall, the Extang has done the job well, keeping cargo dry and proving in the process to be very tough and durable. The three-year warranty is a very big plus. It's the convenience of use that is sometimes a problem. Its a pain in the [non-permissible content removed] in cold weather and all those snaps take awhile to button, so I leave it on the truck almost all the time unless it absoltely has to come off.
Next time I'll probably either get a hard cover or, more likely, a hinged soft cover so I get the best of both worlds...easy all-weather use but the versatility of a soft cover. Im not a fan of caps... I think they make it look more like an SUV when I want it to look like a pickup.
PS: Hehehe no offense intended to all you guys with caps!=)
I don't have an under-the-rail liner. My spray-in is over-the-rail. Will the Extang still work (i.e. - will the rails seal to the bed rail still even with a liner) with the over-the-rail liner. According to their website, the cover works with bed liners, but it does not specify over-the-rail or under-the-rail.
The Merg
Not sure about spray-ons. Don't think you can cut those... once they're on theyre on for life See the crucial thing is that little lip that protrudes inward from the top of the bed rail because that's where those clamps are fastened. Can you still see the lip on yours or is it completely hidden by the liner?
Yeah, the bed rail lip is still there. The spray-in completely molds to the contours of the bed (it's only about a 1/4" thick). My concern was mostly if the frame of the bedrail would seal to the bed rails if there was a liner there...
- The Merg
-- Don
ed
See what cap dealers are in your area, as to what brands they carry, and go from there.
Good luck,
Bob
