-June 2024 Special Lease Deals-
GM Engine Knock
Nick
Dallas
I talked with a GM powertrain engineer.
He stated that they did tighted the clearances on the piston to bore clearance. The pistons all have a polymer coating on them, apparently there is a slight change in the engines now being produced.
GM Powertrain refers to the psiton slap as a Engine tick. He explained why the tick would go away after the famous de-carbonizing. He also stated that there are some motors with other problems that are being incorrectly diagnosed as piston slap. Generally a very helpful person to talk to .
Walter (Gator36)
99-06-01-003 APR 99 Engine Bearing Knock Noise
week. We had the Bass Masters fishing
tourney. 6.0 , 8.1s crews, excabs.
Listened to each one every morning and
asked the guys about cold start knock.
All the guys had the fuel rail and injector
tick at idle. Only one guy who lived in
Northen Canada complained about cold start
knock in the winter only..summer its gone
he says..I said me too !
Out of 18 rigs and fancy fishing boats
5 fords and 1 mopar......geo
Comment from lab: "You can see your metals improving as it passes through wear-in stage. Copper and tin both dropped to within-average levels, and silicon decreased as well. Although none of these elements is at the universal averages quite yet, we suspect they will get there within the next two or three oil changes. We did not find any unusual moisture, antifreeze, or fuel in the oil. Insolubles were average at 0.4%, showing good filtration. It looks like this is going to be a nice engine for you."
FYI, am using Mobil 1 and Pure One filters. I may wait an oil change or two before submitting another sample. I am trying to be a little less compulsive as I get older, and decided with this truck to wait until the Oil Life monitor tells me it's time to change rather than using an arbitrary number, but I don't know if my conscience will ever let it get to be much over 7500 mi.
tep
tep; Interesting. I've had similar comments from Blackstone. Is that the lab you're using?
-David
It certainly remains to be seen if indeed this is going to be "a nice engine." I plan on driving the thing into the ground. Hopefully the ground comes sometime after 10 years and 150k miles or so!!
tep
Their site is where I first heard of by-pass (off-line) filtration which I plan to install on my truck at the next change. Though they don't sell them, yet are very high on them, I think it's fair to conclude there must be some benefit.
Given your conscientious attitude about care, you should have no problem meeting your mileage goals. Lots of vehicles get there with less.
-David
I also decided to relax and just let the oil life monitor tell me when it is time to change. I was a complete fanatic before - Once - during a vacation trip - pulled into a Jiffy Lube with 2,999 miles since last change - I was only 250 miles from home.
So far the 99 Z-71 wanted a change after 137 hours and 3,400 miles 4.5 months; 132 hours and 3,300 miles about 4.5 months; 135 hours and 3,600 miles about 5 months; 128 hours and 4,800 miles 3 months. (Obviously the 4,800 miles included a long highway trip).
Tahoe light came on after 157 hours and 3,800 miles 5.5 months.
Some would say I am wasting $$ changing this often (M-1 should go at least 5K) but I say what the hell I change it myself and for a little more than $20 it gives me peace of mind.
My Z-71 has 3,300 miles and 130 hours since last change - so I guess it will light up any day now.
The engineer refers to what we have used blanketly or more accurately the dealers have, Piston Slap, as an engine tick.
From what we discussed, the general negative connotation at the dealerships leads to some engines being mis diagnosed as having piston slap or the "engine tick".
The tick is caused by a buildup of carbon, not on the crown of the piston, but on the side. Now I cannot remember if it was between the top of the piston and the first compression ring or between number one and two compression rings. However this buildup is what is causing the the tick upon startup. When they de-carbonize the motor, the carbon is not there to interfere.
In my case, I have it warm, cold, on a hill, pretty much all of the time. There are documented cases where there are other problems. It is my belief that the engine tick is the most common problem. Yet no one can say this is exactly what it sounds like. There is speculation that I may have a wrist pin knock. Yet try to get the dealer to look at it after all of the corporate bs and tsbs from gm.
The engineer also aluded to a few engines with an o-ring that was torn on installtion of the oil pickup tube.
I hope this helps.
I will say this. I had piston slap on my 97 GMC 5.0l and it was running fine at 150K miles when I sold it. It did not burn oil (or at least as far as I could tell) and I definately was not a grannie on the gas pedal... The piston slap on the 5.0 GMC was not the noise I have in my current 5.3.
Walter (Gator)
Thanks for your help.
-David
I have not had it done... Others have reported on this board that they had theirs done and it worked for several thousand miles....
From what I have read about the proceedure. It requires 2 oil changes a special solvent and from what I understand a tool to load the solvent into the cylinders. It is possible for the initiated, yet you will need a delivery method to get it into the cylinders.
After a soak, they evacuate the cylinders and change the oil. They suggest a short drive to clean out the rest of the solvent and the remaining carbon. Then one more oil change to clear out the remaining solvent...
This is what I read once on a TSB with the proceedure for this process....
Walter
What I will be doing before the 3/36 runs out is purchase an extended warranty from Warranty Gold (GM won't get my money for theirs) to cover everything for the next 7 yrs/100k, by then I'll sell it and buy another new. I have lost my faith in GM's products as far as reliability goes since the knock issue inflicted my 5.3 and their take it or leave it attitude. They very well may have sold me my last GM product, time will tell when I'm ready for another new truck on what brand it'll be.
Ray T.
Nick
Ray T.
Ray T.
Nick
Nick
-David
He was? Did they put a hit out on him or something?
Ray T.
Webmaster Dan
I still have not heard of any performance issues or engine malfunctions due to any engine noise (i am not talking about oil consumption either)
to quote someone "if it aint broke why fix it?"
-David
Ray T.
You have done an excellent job with the NEW site, thanks for keeping up the good fight.
My Y2K knocker still knock'in after almost 35k miles to date.
No adverse effects (other than it sounding like it wants to be a diesel) so far but time will tell.
Ray T.
Mine did sunday morning and hasnt since (today is tuesday).
Ray T.
I would have to say all the rattles in the cab drive me more crazy than the engine knock. I am just baffled
haha
hmmm dash has been apart, pass side door was apart, rear seat was taken out, both rear door panels taken off, etc
I have to say taking the pass side door off and adding a strip of 3m tape in one spot stopped that rattle
I think the main reason for the rattles is the weather. Lots of up and down temps. During the day its 50-70 and at night 20-40
1. I switched to Mobil 1 oil in the heavy weight (15W something) in the summers and use 10W-30 during the winter months. The owners manual says to not use any oil heavier than 20W something, so I figure 15W should be ok...either the change in brand (Mobil) or oil weight did help just a bit by reducing the perceived noise upon cold start cranking. I ran the cheap Valvoline oil before switching to Mobil 1 synthetic, and it was definately a louder nose the engine produced, especially after a fresh oil change. I've also noticed that the more miles on the oil change, the less the noise. A fresh oil change seems to make it more noticeable for a week or so. When using the 5W-30 Mobil 1, the noise is back, so I think the cold start cranking viscocity is not good for eliminating the noise. Using the heavier weight oils helped reduce the engine noise, but did not eliminate it completeley.
2. Upon cranking the motor, I immediately put the transmission in to reverse (or drive) as I back out of the carport. There is no ticking sound if the motor stays at a "lower than idle" RPM in my truck. This has helped more than anything to eliminate the ticking noise. It is normally completely eliminated.
3. I also let the engine warm up a bit before hitting the road. My driveway is about 100 yards long, so i just let the truck idle down the drive. Upon turning onto the road, I give it about another 100 yards of idling until picking up speed.
I know it sounds like a pain, and it is, but it's the only way I've found to keep the motor from making the dreaded ticking or knocking noise. I like the truck otherwise and have no other complaints, otherwise I would trade it in for something else. I do have the 100K mile extended warranty, so if the motor blows or otherwise tears up, so be it...i'll probably go with a diesel for my next truck purchase anyway...
my .02 cents worth........
YMMV....
My biggest complaint with the condition will be during resale since it is a deterent when selling a vehicle to have the engine knocking no matter what warranty you have .
I just purchased an Extended Service Plan that covers me on everything till 100k then I move on to another truck.
Ray T.
Engine Knock or Lifter Noise (Replace O-Ring)
#02-06-01-038
4.8, 5.3, 5.7 or 6.0 V8 Engines...
Ray T.
http://service.gm.com/gmtechlink/images/issues/archive.html
Ray T.
2001-2002 Chevrolet Camaro
2001-2003 Chevrolet Corvette
2001-2002 Pontiac Firebird
2002-2003 Cadillac Escalade, Escalade EXT
2000-2003 Chevrolet Suburban, Tahoe
2001-2003 Chevrolet Silverado
2002-2003 Chevrolet Avalanche
2000-2003 GMC Yukon, Yukon XL
2001-2003 GMC Sierra
with 4.8L, 5.3L, 5.7L or 6.0L V8 Engine (VINs V, T, Z, G, S, N, U -- RPOs LR4, LM7, L59, LS1, LS6, LQ9, LQ4)
Condition
Some customers may comment on an engine tick noise. The distinguishing characteristic of this condition is that it likely will have been present since new, and is typically noticed within the first 161-322 km (100-200 mi). The noise may often be diagnosed as a collapsed lifter. Additionally, the noise may be present at cold start and appear to diminish and then return as the engine warms to operating temperature. This noise is different from other noises that may begin to occur at 3219-4828 km (2000-3000 mi).
Cause
The O-ring seal between the oil pump screen and the oil pump may be cut, causing aeration of the oil.
Correction
Inspect the O-ring seal and replace as necessary. Use the applicable part number listed below. Refer to the Engine Mechanical sub-section of the appropriate Service Manual.
Parts Information
Part Number
Description
Qty
12557752
Seal-O/Pmp (O-ring)
(F and Y Cars)
1
12563963
Seal-O/Pmp (O-ring)
(C/K Trucks)
1
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Usage
Labor Time
J1060
Pickup Tube and Screen - Replace
F Car
3.7 hrs
Y Car
4.3 hrs
C Truck
1.3 hrs
K Truck
2.1 hrs
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
This is the first reported failure I have heard of with the Chevy Knockerado's.
Gator, thanks for the full lsting on that TSB for our knockers.
Ray T.
