Chevy Silverado
This is the place for discussion of all things Silverado!
Time to get on with life.
Just a reminder that our Town Hall chat happens on Wednesday (5-7pm Pacific/8-10 pm Eastern).
This week the topic is Social Issues and the Automotive Perspective
http://www.edmunds.com/townhall/chat/newsviews.html
PF Flyer
Anyone with a "soft" tonneau uses that 303 protectant on it? I'm interested to know the results after a rain as it seems the protectant vanishes with the rain leaving vertical streaks on the quarter panels and tailgate as it departs the truck. Oh what a feeling....
havent 303ed it yet
I also have been using paint protection products from zaino bros. This familiar name offers quite the shine and may also contribute, in my case, to less streaks from 303.
Yup this forum is real quiet... Since the topic is Silverado I am just waiting for the Toyota boys to chime in with their comments.
I used to spray it on lightly and wipe it off but it didn't give that "new" look. Either way though, a good rain will wash it off almost completely. Thought that to be a bummer cause at $25 a quart stuff isn't cheap. Then again, maybe its designed purposely to wash off easily.
So, I'm guessing it got a little ugly. Too bad I wasn't here to watch the battle.
Always a day late....dang.
On the good side, I'm celebrating 13 months without a shop repair.
So the question is are you lucky enough to not have the Vortec Knock or Are you lucky enough to have the Vortec Knock ???
The question sounds redundant because GM says either engine is normal, LOL, so which do you have ???
I now have 29k knocking miles but love everything else about this truck. Gotta get them sunvisor extensions though the ride home is a killer with the sun low in the sky and out of reach of standard visor. GM designers were asleep at the wheel on this one.
Ray T.
This place is quiet, civil, and free of Silverado-envy. Pretty cool.
2) After market shocks ( Bilstein-Edelbroc-Rancho 9000 ) ? - 2000 rado ext 2x4 5.3 SB BFG velvet shackles w/ride control and rear air bags.
(2001, 1500LS, X-cab, 5.3, 3.42, shortbed, 4x2, 13k miles)I am planning on installing Air Lift or Firestone bag springs to the rear. Then I could independently adjust pressure to correct lean. Plus I could keep the front tires on the ground during firewood season. Wanted a 2500HD but needed to drive to work every day too.
BTW, been averaging 19 mpg on my daily 80 mile commute. Very happy with that.
-- Don
-Mark
Richard
Get it wet and it will wash off with plain water. Seems to me for $25 dollars a quart it should last a little longer. I guess it along with a lot of other things aren't what they are advertised to be.
Obyone, did you spray it on, wait ~ 5 minutes and wipe off the excess? I do that, and don't have any problems with rain, dew, etc. Maybe it's because we have low humidity most of the time (dry California, not the Northwest or the coast).
Mike L
Thanks for your cooperation and participation
PF Flyer
anyway, i'm at 57K on the 00', and after having the tranny serviced (pan was clean) the problem that comes and goes(delayed 1-2 shift)is coming more often........anyone know of a TSB for this?
thx
mike
That's the listing I got from the old geocities site back in July 01. That site has been shut down now. Try http://www.alldata.com they give the list for free but you gotta pay for the full text. 1 yr. subcription is around $18 (I think)for full text.
Geo.....
Hey my 2500 Silverado didn't make the CR list of least reliable woohoo!
July 26 first trip to Ontario for this year and then again in August. Just bought brand spankin new Fleetwood Pioneer 28' travel trailer, got tired of that little ole 18 footer, now to give this truck a workout....Sacandaga here we come!
Ray T.
File In Section: 07 - Transmission/Transaxle
Bulletin No.: 01-07-30-023A
Date: November, 2001
TECHNICAL
Subject:
Harsh 1-2 Upshift, SES, MIL, or CEL Illuminated, DTC P1870 Set
(Replace Valve Body)
Models:
1996 Buick Roadmaster
1996 Cadillac Fleetwood
1999-2000 Cadillac Escalade
1996-2000 Chevrolet Camaro, Corvette
1996-2000 Pontiac Firebird
1996-2000 Chevrolet and GMC Light Duty Truck Models
1996-2000 Oldsmobile Bravada
with 4L60-E Automatic Transmission (RPO M30)
Built Prior to January 15, 1999 (Julian Date 9015)
This bulletin is being revised to update the Parts Information. Please discard Corporate Bulletin Number 01-07-30-023 (Section 07 - Transmission/Transaxle).
Condition
Some customers may comment on a harsh 1-2 upshift and the Check Engine Light or Service Engine Soon indicator is illuminated.
Diagnosis
Typically, these vehicles will have been driven more than 32,000 km (20,000 mi) before this condition occurs.
The scan tool may show a DTC P1870 set as a history code.
A harsh 1-2 shift or DTC P1870, caused by wear in the control valve body, may be difficult to duplicate when the transmission temperature is below 93°C (200°F).
Cause
The condition may be due to wear in the control valve body. This wear occurs in the bore that contains the TCC isolator and regulator valves, and results in poor, or no, TCC apply.
Important :
^ DTC P1870 is a type B code. The conditions for setting the P1870 DTC must occur on TWO CONSECUTIVE TRIPS (ignition cycles, with a drive cycle) before setting a P1870 history code.
^ When the conditions for setting DTC P1870 are met (first trip), the PCM commands maximum line pressure and harsh 1-2 shifts are the result.
^ This may result in a harsh 1-2 shift with no history code if the conditions for setting the DTC required for the second trip are not met, on two consecutive trips (Ignition cycles, with a drive cycle).
^ When the conditions for setting the DTC are met, on the second consecutive trip, a DTC P1870 is stored as a history code.
^ When the P1870 code is stored, the PCM will turn on the Service Engine Soon (SES), Check Engine Light (CEL), or Malfunction Indicator Lamp (MIL).
Correction
Install a control valve body with the revised TCC regulator and isolator valves. Refer to the Parts Information table below. These valves are used in all transmissions produced after January 15, 1999 (Julian Date 9015), and all of the service parts currently available through GMSPO contain revised TCC regulator and isolator valves.
Important :If all of the following conditions are true, it is not necessary to rebuild the transmission or to replace additional transmission components beyond the control valve body.
^ Transmission operation is normal before the transmission reaches operating temperature, or before DTC P1870 is set (no slips, flares, or missing gears).
^ The torque converter is not blue or overheated.
^ The transmission fluid is not burned or has no burned odor.
^ The transmission fluid pan contains no abnormal debris (clutch material, bronze, brass, or metal fragments).
Parts Information
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use the table.
this winter plowing snow. Since summer
is almost here my cold start knock has
disappeared. But most of my cars and
trucks (toys included) had some kind of
cold start knock in those frozen NY winters !
Hey if your heading up Rt.81 to Ontario Can.
My motel is right next to the 1000 islands
bridge exit 50so. My email is in my profile
maybe we can hook up and swap fishin stories !
.......Geo
Right a letter to your attorney generals office quoting the bumper to bumper warranty on this new vehicle and see if that doesn't rattle someones cage, it usually works for me. The dealer is hoping you take no for an answer and go away. GM customer service is a joke, their a sub contractor hired to say what GM wants them to say. Does the word "puppet" mean anything!
Of course then again there's that knock issue not covered under warranty too! But that's a normal engine noise requiring no fix......
Ray T.
We got a couple reports of RR pads and rotors being trashed when I worked for the brake company on the hot line, but were never able to substantiate anything concrete.
BUT, the proportioning of the rear brakes runs through the Kelsey-Hayes EBC 325 ABS modulator unit mounted under the cab of your truck on the inside of the left frame rail, and my thought is that if it is sticking internally it may allow the brakes to drag and wear out prematurly! So the worn out brake pads and rotors is simply an indicator of a more "root" problem.
The typical dealer tech does not really know enough about brakes to understand how the hydraulic system works. Oh yes they may be wizzes on the electronic drivability symptoms but the manufacturers don't have too many brake courses to keep their franchised dealer techs up to date. Have someone in the aftermarket who really knows ABS and understands how it works and affects the brake system look at it and then do the State's AG and BBB thing. You may just get GM over a barrel.
Let us know how you make out.
matthew
The GM-supplied wire harness:
Dk Blue - Trailer Brake Controller Switched Output
Red - Fused Trailer Brake Controller Battery Feed
Lt Blue - Vehicle Stop Lamp swtich to Brake Controller Input
Black - Brake Controller Ground
Brown - Brake Controller Illumination
The Draw-Tite Brake Controller:
Black - Battery +
Blue - Brake
Red - Stoplight
White - Ground -
I have my idea. Just want to bounce it and get second opinions. Much thanks.
Draw-Tite----GM
Black--------Red
Blue---------Dk. Blue
Red----------Lt. Blue
White--------Black
Brown is probably not used for that model brake controller.
-Mark
matthew
Ray T.
Sorry can't remember on the rear end change only because I think it's related to towing and not to do it until you reach 500 miles on the truck. Think the manual says 30k miles between rear end changes...not positive on that tho but is easily checked. Man am I getting lazy...lmao
Ray T.
I ended up buying tires at Walmart. They sell an ALL TERRAIN tire called "LIBERATOR" made for them by Michelin. I did not believe the guy in the tire shop so I called Michelin myself. He was right.
They are Q speed rated (99 MPH) load range D (3,305 pounds). Drive out price for 4 tires, life time balance, road hazard, stems, tax $461.00.
Mike L
I know lots of people run tires on rims they are recomended for, I won't do it. Lots of people run tires that are overloaded, I won't do that either. To me, wrong rim size, overloaded, under pressure are all asking for trouble.
Mike L
-Mark
Just stating i had one on my spare rim
