Chevy Silverado
http://www.gmpistonslap.cjb.net/
My 2002 2500HD has the G80 Eaton Locker from the factory. Once it locks, there is no "limited slip". Here is Eaton's brief description of the locker's operation.
We'll start by pointing out that the Locker is a speed sensitive design. That is, it reacts to wheel slip by sensing when one wheel is spinning substantially faster than the other.
So, when you're cruising along on clean dry pavement, the locker operates like any regular open differential.
But, as soon as wheel slip happens, going forward or reverse, the locker immediately kicks in. Here's how.
The differential is set up with a flyweight governor that responds to differences in wheel speeds, and disc packs that are mounted between the side gear and the case.
Whenever one wheel is spinning substantially faster than the other, the governor spins rapidly, causing the flyweight to open. That flyweight then catches on a latching bracket and the lockup process begins.
During lockup, a self-energized clutch system causes a cam plate to ramp against a side gear. This ramping action compresses those disc packs mentioned earlier. The ramping continues until both axles - and therefore both wheels - are spinning at the same speed. This is full lock, and it prevents any further wheel slip. (Note: Axle lockup can only occur at speeds below 20 mph.)
The entire lockup process takes about a split second, and is virtually unnoticeable by the average driver. When both wheels regain traction, unlocking occurs and things go back to normal.
I own a 02 1500 HD, do you adjust the front torsion bars the same as you do the an 00, 01.
I am also starting to feel a little rattle through the steering column, has anyone else experienced this?
The steering column rattle is not normal in the 1500HD and 2500HD and GM has recognized this. Here is a link to GM's TechLink for July. You will need Adobe Acrobat to read it. When the article displays, click on Steering Column Rattle in the left hand bookmark column. The fix is a new bearing in the steering box.
http://service.gm.com/techlink/html_en/pdf/200207-en.pdf#dst01
Mike L
-David
Also, a note about Bilsteins on 2500HD's. There's a very noticeable improvement over OEM, but I'm not sure you couldn't do the same thing with something less expensive (longevity aside).
Anyone out there seen or have one?
First, the SUV's use different suspension and are driven more like cars than the pickups are.
Second, the SUV's weigh more empty, and are more likely to have weight added up high, where the PU's have more weight added right on the bed. When PU's have campers added, usually they get an aftermarket sway bar to help control the mass.
Mike L
that explains it!
with black fender flares. Looked ok !
-- Don
Please excuse the run on sentences and one long paragraph for I am a product of a public school!
Squeaky steering wheel (when making turns)
Remove steering wheel and airbag
Disassemble steering wheel column upper
inspect for rubbing noise
lube steering shaft support bearings and pivot points (about a yr and a half ago i had the steering shaft replaced)
reassemble
Ill be darned but the steering is once again TIGHT. No looseness whatsoever and the noise is gone feels much better cant even believe it feels like a brand new truck again
As for the throttle body they just replaced it under warranty (part #: 17113665). Can definitly feel a difference in the pep of the motor.
I now have 33k and getting ready to buy the 7yr/100k Warranty Gold Diamond Plan. I know the tranny won't last till 100k, since I bought the new travel trailer, but I'll have the truck for 10 years. I don't trust GM to cover the engine either even though I got the garbage component extension warranty from them. If they won't fix it now why would they honor it later. Did here a odd high pitch sound coming from underneath the truck when I got back from Canada on Monday, don't know what it was and it's gone now. Engine still makes a hell of a racket on start up, especially after Iv'e been towing the trailer, after sitting over night, it has definately gotten louder but gone in a minute or two after start up. Well when I sell it down the road I'll just have to make sure it's warm before anyone hears it or tell them it's a Duramax wanna be 5.3. LOL
Ray T.
Click here!
http://www.edmunds.com/townhall/chat/townhallchat.html
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I have a little over 30K with very minor problems (knock on wood).
What a great truck!
By the end of this week I'll have the front end completed on some modifications, bumper cover, speed grill and grill shell being painted....I'll see if I can learn how to post pictures here and put out a couple.
GMPP is one of the easiest warranties to use at the dealership... The dealership has a $400.00 markup on the cost of the ext warranty.
A 4yr 100,000 Major Gaurd (everything except trim) zero deductable is $2,240.00 on a 2001 Chevrolet Silverado 1500 4wd. Dealer cost on this is $1,840.00. This is again 4 years from the date of purchase. I got mine for $100 over dealer cost.
I asked about the 7yr, 100,000 zero deductable warranty and it runs basically $5,000.00.
The dealer will also set up direct withdrawl on your checking account to make payments over a period up to 18 months.
gator36
Assuming you're a low mileage driver, what you've just stated above is that you paid $1,940.00 for an additional year of "piece of mind". How does that work for you?
Last truck I had I made sure the warranty paid in spades...
You are the exception by getting the major gaurd for free..
Just remember an AC control head is over $600.00
Almost one issue with the trans will pay for the whole thing.
A atarter? How much is one of those?
How about having to replace a component in the front drivetrain?
Walter
Wonderful Southern California driving. We go everywhere.... From San Diego to Northern CA al the way to Dallas Fort Worth...
2000 CHEVROLET 2500
8 cylinders
Rear Wheel
32000 miles
Plan: New Diamond
Years/Miles Amount
5 - 100 $1180
5 - 150 $1604
6 - 100 $1204
7 - 100 $1254
These prices are paid in full with a $50 deductible. This price will be
valid through the end of the month.
Here's the link to the company, they supposedly offer the best aftermarket policy out there. http://www.warrantygold.com
Ray T.
Also, Warranty Gold is rated #1.
The coverage by Lithia and First Extended Service on a failed transmission is to replace with a used unit from an auto wrecker. Not repaired. Used unit replacement. I was, and still am not, positively impressed.
Bottom Line. Don't be surprised. If the used unit gets you down the road the same as the original, I guess it's all good.
I have that TSB in word format and can send it to you
1999-2000 Chevrolet and GMC C/K Pickup Models (Silverado and Sierra)
Condition
Some customers may comment that the 3rd or 4th door is hard to close when cold.
Cause
There was a change to an internal bumper in the latch and the removal of the primary door seal internal plug.
Correction
Verify proper alignment between the upper and lower striker before proceeding to the next step.
Replace the upper and lower latch assemblies using the part numbers listed below. Refer to the Doors sub-section of the Service Manual.
Remove the primary door seal internal plug across from the lower latch assembly.
Parts Information
Part Number Description
15057687 Latch Asm - LH Upper
15057688 Latch Asm - RH Upper
15063698 Latch Asm - Lower
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation Description Labor Time
B4650 Latch and/or Wedge, Rear Door -Replace (Right Door-Upper and Lower) 0.6 hr
B4652 Latch and/or Wedge, Rear Door -Replace (Left Door-Upper and Lower) 0.6 hr
We're looking into the 2003 2500HD with Duramax/Allison and the sticker on those babies is SCARY. They are $6-7 thousand over invoice. I refuse to pay that amount.
$500 over invoice is availble on the gas trucks at a motivated dealer.
Good luck-Chevy quality is way down.
Just got back from a short road trip (600 Miles) - but had to complete with a rental car.
I have a 2002 2500 HD with 6000 engine and the 4 sp auto. Purchased last October with 10,400 Miles.
Going down I80 Sunday nite with Cruise set @ 75 MPH and all of sudden the Truck red lines. I shut the truck off and coast to the shoulder. Start it up with no problems, but when I put it in drive - nothing - no reverse either. Tried in 4 high & low.
Had it towed (Roadside approved & then canceled tow) to Yemm Chevrolet (51 miles) in Galesburg @ my $$$$. Called the dealer Monday Morning and was told that it doesn't move - must be a problem with the trans (DA). Tuesday afternoon they push it in the garage - still don't know what is wrong - have to follow Chevy's procedure - has not taken it apart.
The dealer and Customer assistance is blaming each other and not providing any answers (or commitment for rebursement).
Has any one heard of this problem?
Should the complete trans be replaced?
Do I have to worry about the engine with the high RPM's?
Any information on the process for the "lemon Law" in Illinois?
Loved it before the problems, but ?????
K2: 2000 Silverado Ext.Cab 2500 LS 2wd - $500 under inv.$26500 w/tx/title etc., ordered thru a dealer in nearby Connecticut. See my profile for how I equipped my truck.
DonJ: You payed for a tow with the 3/36 warranty still in effect??? Wrong thing to do! As you now know cause your fighting to get your money back for a covered expense! Then again the warranty covers a tow to the "nearest dealer", 51 miles sounds like you passed by a few GM dealers but maybe I'm wrong. More then likely you will get a rebuilt tranny from GM (they take it to a shop or have the tranny brought to them to replace, or if your lucky they give you a brand new one outta the crate). There should be no engine problems since you shut the truck down immediately as you should have. Illinois lemon law? go to your State Attorney Generals Office webpage to download the forms and see whats involved. I don't think this one incident will qualify you for the lemon law.
Ray T.
In my mind, this is not right and it should be taken care of. Also, the dealer mentioned nothing before about neutralizing it, just clay barring it. IF I let this go (if they don't neutralize/buff it), will this cause sheet metal problems or just cosmetic (white truck)?
Thank You
My 94 GMC Yukon died in Alex Bay NY and
Gm flatbedded it to Fulton NY GMC dealer
where I bought it(over 100 miles) no charge !
And I didn't ask them too either ??????
.....geo
I would just go out and buy a bar of Mother's and clay the truck myself and add a couple of coats of wax. Isn't that hard to do vs. banging against the wall trying to get GM to do it.
Just my opinion.
Mine seem to close on my 01 1500 Ext Cab, however, they don't always completely latch. They look latched and the door panels line up, but, if you don't get it fully latched - with the front door still open - you can pull on the upper section of the door (near the upper latch) or sometimes the lower section of the door (near the lower latch) and if not fully latched, you'll be able to pull the door away from the latch about 1/4 to 1/2 inch - tugging aggressively. If it is fully latched, neither the top or the bottom of the doors will budge. I think this has been getting worse over time, especially on the driver's side rear door since I open it about 4 times a day.
Is this similar to the cold latch problem? Is there any adjustment that can be made?
Also, I'm trying to nail this down for sure, but I think that if I hit significant wash-board bumps, or go over man-hole covers just right, I'm pretty sure that the upper latch on the rear driver's side door unlatches - going into the same state as what I explained above. Still trying to verify this for sure. Sure seems like the doors are all getting looser, not latching as tight, and going over bumps, I hear lots of bad rattle noises from them - as if not fully shut - not just the crap inside rattling. Just don't think it's well designed. Anyone else noticing this?
Last point. My brother just bought a new GMC 1500, and as I opened his door, there was a lot more un-latch force on the door handle. As if it latches much tighter than mine. Is there a way to adjust this to make the latch hold the door tighter - this is regarding the front doors mosttly?
I have an automatic trans. that makes a clunking noise whenever the accelerator is quickly depressed and then released. Is this normal?
Any comments are welcome.
Canayjun64
Last year they sold 1200 trucks and only 70 cars.
Very easy to deal with and a very good reputation.
Last year I bought my Impala from them and after finding out that there was $1000 dealer cashback that the other dealer had not told me about.
Marchant not only told me about it, they had "$1000 cashback" painted on the windshield!
After I bought the car i found that there had been some paint work done on the driver's side door at the factory. I went to talk to them about it, and they had another car sitting there for me in case I wanted to change!!! I decided to keep the car I had because of the later build date.
www.marchantchevy.com
Ravenel, SC.
