Ken
Dealer = SoA.
Like kens mentioned, call SoA and set up a case.
-Dave
I've been trying to figure the oil leak for some time, as you know I'm dead stubborn against bringing my car in. --Although this was a good experience that could change that way of thinking.
Anyway, I'd noticed the bottom of the timing cover looked like the seal was oil-soaked. I personally couldn't make out what was the problem but am glad it all made sense to them. I had an idea it was the front oil seal but didn't know the cam seals were leaking too.
Oil wasn't being consumed really, I could see it on the ground in the garage; maybe like 2 small drips per day.
Patti, thanks for the assistance. If the dealer needed any guidance from SOA whether to cover things they didn't say anything about it and just did the warranty work with no questions. I approved the billable work with the provision that it would fix the problem. It did-- put about 70 miles on tonight and no hint of the idle problem or hesitation.
-Colin
-mike
On one hand, I see the point. A car is a major purchase and that type of failure should be spotted long before the consumer gets their hands on it.
On the other, cars are made by man and when you make a few thousand engines a month every once in a while you'll have a bad one. Sounds like Subaru is doing their best to take care of the problem... You have a free rental don't you?
But never fear, Patti can help. She's amazing.
-Colin
Once again, sorry for the let down. What area of the country are you in so I can try to find your case?
Patti
Has anyone come to talk to you about the case I openned after you suggested it? I had a problem with my dealer not servicing my car properly (alignment). I am curious what the outcome of all this will be?
The service writer pretty much suggested that I never come back there (trust me...I won't) but that kind of behavior really harms Subaru especially in an area like Atlanta where there are so few dealers.
Patti
Patti
mrfixit - Thanks for the oil info.
-Dennis
Hi Richard,
Large diameter (small guage) wires are more effective conductors than small diameter (large guage) wires. (one of those stubborn physics laws you can't break ;-) ) Though small diameter compact jumper cables work (as Brian said), if I was stranded, I'd want the largest diameter wire that is practical to carry. Also, look for durable clamps.
..Mike
..Mike
Craig
emanated from seemingly the front driver's side. Noise stops when my foot is removed from the accelerator. I had a sub specialist check out the suspension, and all came back tight. Car has 50k on it, and it isn't driven hard. Already replaced rear wheel bearing at 30k. Anyone have ideas?
..Mike
May I ask, how many miles on that set of MAA's?
Do they do you well in the snow, ice and wet?
I got a set for my 2001 Forester, but snow has been almost nonexistent in the Philly area this winter. (I have the stock Yokos on now.)
Joe
Snow performance - they are ok, not as good as Blizzaks which I had on my 92 LS and still have on my 92 L. Sometimes they feel scary on ice, like you are about to lose it but you never do. They are definitely better on regular dry roads than the Blizzaks. On my 4th season with them, they seem to waer quickly initialy and then the wear seems to have plateaued.
-mike
My problems have been with Troncalli in Roswell. How do you like Voyles? That is where I bought my car but for a couple of reasons, I haven't gone there for service, just to buy parts.
I didn't make them my first choice mostly because of how run down the shop and the service area were.
-r
miles needed 5 wheel bearings since I bought it?
Is this normal for this vehicle?
-Colin
-mike
http://www.raindrop.com/subaru/wheelbearings.html
HTH.
..Mike
..Mike
front and rear. Told the dealership that I thought that this wasn't normal - got some story from the service manager that it's because of the wide tires. Tried to get them to do something about the bill - no go. Called the Subaru 800 number and no luck there either. Love the car, but think I'm going to get rid of it before the 2 right wheel bearings go. Really left a bad taste in my mouth for Sabaru. This is my second Sabaru - had a XT6 - but after this I think I'll look for
something else.
-mike
-Colin
Patti
-Dennis
The installation was a piece of cake.
1. Remove negative, then positive terminals
2. Remove retaining bracket
3. Remove old battery and clean out battery tray
4. Clean terminals
5. Plop in new battery and reverse steps 2-1. If you have the Security System upgrade, be ready to hit UNLOCK as soon as you touch the negative terminal to the battery.
6. Recycle that old core
My starter motor sounds a lot happier now.
Ken
... .1
yes, Ken?
sorry, it's a been a long day in the office :-)
--etaK
neK
Ross
Kate, too funny! You've been too quiet lately.
..Mike
..Mike
Steve
But I repeat myself (from thousands (?) of posts ago).
Thanks, Steve. Though I was a little sluggish, taking 59 minutes to respond. Please don't tell juice how I dropped the ball in his absence. Yep, the Internet r00lz!
..Mike
..Mike
Steve
tires. Last winter I drove more on snow than on blacktop...tried my hardest to spin out, but no
luck on snow-packed roads. They're ok on ice & wet surfaces, but super on snow. This winter, we've had hardly any snow, but it ain't over yet.
I put in some dry gas and premium fuel thinking it could be something like that. I was able to (I had no choice) drive back to Rochester while the CE light was still on. I brought it in yesterday to my dealer, Van Bortel.
The CE light was a misfire in cylinder 1 and changing the plug wire had no effect. So they told me they had to replace the fuel injector, but recommended I do all four at the same time. I told them to do the work (what choice do I have?) The cost came to a little over $500.
At 38000 this seems like a strange failure. I am one to admit if I did something wrong, but I am concerned because I don't think I did anything wrong! I only use brand name gas (usually 87 octane). The only thing I have never done before is put additives in the fuel tank (like dry gas). Should I be?
I was told this is not covered under the powertrain warranty. Is there anything that can be done from Subaru's standpoint, or is this 'my fault'? How can I prevent this from happening again? My wife's '98 civic has been operated from the same gas and impeccable maintenance for 4 years with no problems.
I have to pick up and pay for the car today.
Any help or advice would be appreciated!
-Howard
It sounded like a fuel problem to me and I think I would have tried draining the tank first (in case of sediment/bad gas) folowed by pulling the injectors and having them cleaned (i doubt they were total toast) .
Sorry for your problem..lets hope your repair fixes it.
You're right I can't believe that they were gone - it seemd like it would have to be a consistant fuel problem in order to do that damage. Maybe cleaning would have done it - but they even admitted to me that they don't do that at the dealer, they would have to send it out. So of course they would recommend replacing. That is why I wanted to get an opinion from Subaru ala Patti.
I will ask them to do a fuel quality test and check the fuel filter (if they have not already) before I pick it up.
Howard
We have to assume that they are competent and checked the fuel pressure which would eliminate the fuel filter and fuel pump. Unfortunately the pintle type injector are prone to clogging and and small particles in the gas can cause this type of problem.
Electrical (wires/plugs) are also a common cause ..but you said they checked that out.
The biggest problem I have with dealers is that I want to find/isolate the cause. Dealers tend to start removing/replacing parts until the problem goes away. You have to hope they stumble on it quickly cause you are paying for all the part swaps.
In this case pulling the injectors and having them cleaned sounds like it would have been a lot cheaper that R/R .
-mike
The first thing I do when I get a CEL (or MIL for your mechanics :-)) is disconnect the battery for 30 minutes. That's always worked for me but could also erase any problem codes stored in the ECM's memory.
-Dennis
-Colin
Remember when we helped Lucien figure out his intake, live?
Ken - your battery lasted longer than mine. Doesn't it start up better with more CCAs?
It's funny that we hear a lot about Subaru's bearings, while I just had to replace the bearing and the hub on our 626. It was more than $800, ouch, for a single wheel, too.
-juice
..Mike
..Mike
