-mike
I stopped by Wally World and checked their stock of both Cristy & Heet (the two main sellers). They still market both a methyl ($0.45) and isopropyl ($1.29) formulas. I noticed that both now claim to be safe for fuel injection, but I still would stay with isopropyl.
Years ago Nissan had a TSB advising dealers to replace damaged fuel pumps once and warn customers not to use methanol. Deny the claim if it happens again. Today they probably have replaced rubber seals with neoprene or other chemically resistant synthetics, but isopropyl is just better stuff.
Steve
KarenS
Owners Clubs
-mike
Ross
Good to know that our praise hasn't been lost in cyberspace. Thanks for forwarding our comments.
Ken
Sorry to risk being redundant, but does anyone know if there is something that can keep the tranny from warming up "normally"?
What I don't like is the sense that we just don't have real braking power. It takes a lot of effort to convince the car to get serious, and you never really feel negative g's. I want the car to bear down and stop NOW, if I ask it to.
I've been poking around for a while now on various boards, and have about decided to go with SS brake lines and possibly performance pads when we hit 30k.
It's sometimes hard to know if others on these boards are seeing a real difference or are just into "buying presents for their cars", if you know what I mean. No offense to anyone intended, by the way. This all assumes that the Forester just has softer brakes than I like, and that I haven't had a problem from the getgo (no change from when the car was brand new, and I'm pretty sensitive to this stuff, so I think I'd notice even a gradual change).
Comments ? Recommendations ?
-mike
regardless of how new it is at 30k miles a bleed may be beneficial.
but I've always experienced the sensation you describe while trying to stop an automatic transmission vehicle. I don't row through the gears while I'm stopping a manual, but I do decelerate in gear for the first little while.
the soft brake pedal though is by design-- fire off your emails to subaru.com asking for a firmer pedal and maybe they'll switch back to a single stage booster. the current (97+) dual-stage booster is quite squishy for the first 1" or so of travel. you might find that braided steel brake lines would help the initial feel... I think they help, and run about $130 plus installation.
-Colin
-mike
In "hard" breaks, the immediate resistance might induce timidity and an undesired backing off instead of "going for the floor."
Just my 2 cents.
Interesting that you mentioned the 98 Forester S braking performance. I've noticed that brake feel did get a lot softer from 99. I can feel the difference between my 98 and my friends 00. I don't know if this is just sampling error, but mine feel a lot more responsive. Brake rotor diameter did go down a smidge between 98 and 99 (0.1") but I doubt that has anything to do with it.
One thing you can do to improve braking performance is to have the dealer put in the Legacy/WRX rotors up front. These are larger by about 1" so they should improve braking distance. They'll fit in your 16" wheels and are compatible with your existing calipers. As for brake feel, you'll probably need to swap out the brake booster to do that.
Ken
I had occasion to find out how good today when some effin eedjit.(Irish for idiot when you are mad) ran a red light dead in front of me.
I thought sweet Jesus a Tee bone coming up and we are both dead I was doing about 60 miles an hour, I got on the brakes and stayed on them, hauled to a stop.
I have no doubt had this been any of my Honda,s I would have been buried in the side of this halfwit.
Cheers Pat.
Frank
paison: It's true I'm not used to a vehicle with ABS, but I don't see why that necessitates a softer pedal, although from Subaru's point of view it might make sense for the reason you describe.
Colin: Our Forester is a 5MT, my wife's car and the MPV were both automatics. My wife's earlier car was a manual Tercel. I don't think it's the transmission type. I don't row the gears either (brakes are cheap to fix and easy to get at, clutch plates are none of the above) when stopping, in fact I rarely engine brake even when cornering.
We're at 22k now, so I'm just planning ahead for the 30k service. Between now and then, I want to have some plan of attack for fixing this that's reasonably affordable.
The thing that's curious is the measured stopping distance growing from '98 to '00. Tires were the same and the track conditions were probably pretty similar (hard to know, but it is the same test track anyway...). The '00 is slightly heavier, but 15' farther ? Sounds to me like they changed something - different pads I suspect.
I've looked into alternative pads, thinking that semi-metallics might help, but all I've found are (very expensive and not very long lasting) performance pads so far.
Going to bigger rotors had occured to me as well, but I'd need bigger pads to see a difference I think, no ? It's also a lot of $.
Pat: Glad to hear you're OK. I'm afraid I'm not confident that my Subie would have made that stop.
unless other groups found similar results, I'd say that CR's data is misleading. tires and test conditions are the only thing that have changed-- as Ken pointed out there's no real hardware change between 98 and 00. the press vehicle itself could be the biggest variable... if they got a fresh one in '98 and a well-shagged one in '00 that could be a factor.
I follow autocross discussions on the iClub quite a bit and used to autocross myself. You might get a tad more initial bite from a set of Hawk HP+ pads but the stock pads are very good and offer some big advantages: lower dust, lower noise (nearly noiseless), less rotor wear and they're much cheaper too.
Anyway, you could have glazed your stock pads but I doubt they're worn much at all at 22k. I have 41k on mine plus about two dozen autocrosses and they have about 3/8" left. I don't drive in high-speed stop&go though and brake conservatively at all times, unless it's an emergency.
-Colin
Craig
Craig
I was going to post this question on the Ody board, but figured you guys might know more about this. I have not been terribly impressed with the knowledge depth over there.
Steve
I sampled the opposite in a rental Chevy Cavalier. The brakes were so touchy that after a while my wife and I were feeling car sick. You barely touch the brakes and full pressure is applied. That plus hard braking was very poor.
I haven't heard from Darlene, but the dealership owner was in a finanfial mess, so she couldn't get parts from Subaru. It's a shame, really.
-juice
Dennis
Ed
Frank
Ed
edit: More info: "Yes, I have 4 plugs, from the passener side across to drivers side. Most of the oil was on the first, the least on the fourth (driverside), but the first 3 were drenched with oil, Up to the threads. The very last just a little on the bottom".
-Chevy Chase
Did this just happen out of the blue?
Does it smoke... it MUST smoke with that much oil. Did it just start smoking?
It must run like crap, has it run like crap for very long?
Has this thing been beaten?
Has it overheated?
How much oil is it using?
There are probably another 20 questions to be asked, but if a few hundred dollars is his trigger, he might want to start picking out the color for the WRX... unless the demise of the Honda is due to neglect, in which case he can't have a WRX.
Frank
~107,000 miles
Happened out of the blue. No smoke.
Has always ran smooth.
Driven hard, but oil changed every 3K.
Never overheated.
Started burning oil lately (first sign of a problem. He thought it was just from driving hard).
He may buy a beater Nissan from his gf's mom until he's ready to get a Sube.
-Dennis
I would bet it is in the head, probably valve seals. They have probably dried up and turned brittle. If that is it... no guarantees... it might not cost too much to fix it, although it is a Honda.
Frank
I haven't yet heard a reason from you why this Honda can't be driven until he's ready to buy a Subaru. Unless the oil consumption is high?
Put new plugs in it and watch the oil level. Don't drive it hard.
-Colin
The car died on the highway the other day. He had it towed to his g.f.'s and then he changed the plugs. Car started and ran for 5 min. and died again. After that, it would turn over ok, but not start.
-Dennis
I made this adjustment to my driving last winter when my car started displaying the same behavior. It's been much better since then, just needed a little practice to avoid the chatter.
You can also search the iClub's transmission forum for clutch shudder or chatter and you'll find it is pretty common. Not as common to be covered under warranty though, some folks are able to get it done, others not.
It is definitely worse when the car is cold and so is the weather.
-Colin
Ken
Brian
-Colin
The mechanic called me over and said he couldn't find a problem. The car hadn't moved so I was wondering how he checked for a vibration when shifting at 3k or higher.
He showed me what he was doing, and it was checking for chatter. He was very slowly letting out the clutch in 1st while giving it no gas. My Forester smoothly moved forward, the best he had seen, he said. When I told him that was great, but not why I was there, he said oh, that's usually what the customer is complaining about.
That is apparently how he has been instructed to test for what is acceptable. If it can't be done without stalling, it's not smooth enough and needs attention.
Frank
Dealership (Somerset Subaru) could'nt duplicate on a warm engine, so they let me leave it overnight and voila.
BigFrank3: I remember that you purchased your Forester (or was it 2 Foresters) from Metro now Somerset Subaru. Everytime I go into a dealership, I keep in mind what the service personnel have to deal with with the average customer. It seemed they were amazed that I knew where the water pump was!
-Tony
He looked at me funny and said he never shifts that high so he didn't know what it should feel like. He definitely could feel what I was talking about, though. We went back and drove a brand new one, since I told him I never felt it when new.
He agreed that the new one didn't have it, and felt that I did have a problem. He tells the Service Manager (nice guy, Joe Papa if I remember) who then calls Subaru for technical guidance. They tell them to drive another one with a few thousand miles on it, they all have it.
No one could explain why its smooth as silk when new but rough after a few miles. At least I got it documented. I still think it has a bad throwout bearing, but there is something to be said about not letting people touch the vehicle unless necessary. It could end up worse. It might come back with chatter!
Frank
-juice
Frank
Questions -
1. besides letting SOA off the hook so that my widow can't sue them if the airbag deploys improperly in the future is there any point doing this?? Its 1 1/2 hr labor according to the dealer so they can check for any bad codes associated with the airbag system.
2. is this something any shop with the right equipment to check codes can do? of course this lets SOA off the hook too
I'm probably going to get rid of the car when the 03 WRX comes out or better still, the STi, so I don't really want to do this. But now that I have discussed it with the better half she has me paranoid that the airbag will suddenly deploy one day on its own in the next few months and kill me or worse!
Your personal safety and passenger in the car is your call. The 2003s won't be out until later this summer (STi is even further out)so that's a significant chunk of time.
I personally wouldn't skimp on something like that, but that's just me. At the very least, you might want to call a Subaru dealer to find out what the 10 year maintenance costs and entails.
Ken
In spite of everyone's assurance and Consumer Reports reliability ratings on the Forester, I am becoming concerned about long-term durability. Problems, so far, have been covered by Subaru, but the drivetrain warranty will run out in about 1500 miles. So far, Subaru has spent what would cost about $3000 US at retail to fix problems with my '98 Forester.
Problems have included:
Replacing clutch assembly.
Replacing rear wheel bearing and axle shaft.
Repairing oil leak at valve cover.
Repairing oil leak at rear engine seal.
Repairing oil leak at oil pump.
Replacing alarm system.
Replacing brake master cylinder (recall)
I have always loved driving the Forester, and I planned to keep it a long time. But now I am not so sure. Mine was, however, bought early in the first US model year, so it may be a bit unusual.
Were I in your shoes, I too would be concerned about long-term reliabilty. Maybe you should consider traing in for a new 2003?
-Frank P.
Patti
