Subaru Crew Problems & Solutions
18889919394385
  • Of the tires you mentioned, I have experience with the Michelins and the Coopers. The Michelins were mounted on a Prizm and the Coopers were mounted on a V6 Camry.
    Michelin X-One: Great all around tire that wears well, but is expensive. The traction is decent wet or dry, and it performs well in the snow. I look at this tire like it's a middle-road tire...not a snow tire, not an all-out performance tire, but somewhere in between. The tire should meet your MPG expectations, will provide a smooth ride, and will surpass 50,000 miles (as long as it's not 50,000 miles of hard cornering).
    Cooper Cobra GTH: The positive trait with this tire is the price. It's one of the least expensive H-rated performance tires you can find. However, the tire's performance probably will not meet your expectations. My set wore prematurely, I only made it to about 2/3 of the warranted tread life. Wet-road performance was poor, and snow handling was downright scary. Dry-road performance, cornering, and noise levels were decent, but certainly not legendary. Personally, I wouldn't purchase this tire again.
    Another alternative to think about: Continental CH95. I just mounted these tires on my 2000 Legacy GT Limited a few months ago, and have been pleased with them. Aggressive handling on dry and wet roads is superb, and snow performance is also good for this type of tire. I live in Utah, and have been able to test the tire's perfomance in a number of conditions. The price is par for the course and the warranty is long. I've been extremely happy so far with my choice, and I wouldn't be afraid to say otherwise if I wasn't. One warning, though, is that the actual treadlife typically is shorter than than warranted treadlife. You could expect 40,000 miles from this tire.
    I wish tires weren't such a gamble, but every tire handles differently on each type of car, and even different batches of the same tire handle uniquely on the same car. With tires you just have to roll the dice and see what comes of it. Good luck with yours!
    Ty
  • kevin_nckevin_nc Member Posts: 7
    I have a 98 Outback Ltd with manual five-speed transmission with 57,000 miles. I recently took the car in to have an oil leak repaired, which required disassembly and reassembly of the clutch. Since then I have noticed a pronounced "jutter" in the clutch at the friction point, during both up- and down-shifting. I told the service manager and he said that there was nothing they could do about it, it was harmless, and was due to a rough clutch plate, not any maladjustment during reassembly. I am concerned that this condition is bad for the clutch and will lead to problems in the future. Am I overly concerned? Is it fixable? Anyone else ever experience this problem?
    Kevin
    Colin said that 1200rpm launches were one suggestion. I tried it and sure enough the starts are smoother with those low revs. Try it out.
    -juice
  • kenskens Member Posts: 5,869
    Tires: You may also want to expand you search into "Touring" tires as Tire Rack calls them. Ty mentioned the Continentals which fall under this class. Others that come to mind are Bridgestone Potenzas, Yokohama Avid Touring and Michellin MXV4 Plus. Typically, these tires balance a smooth ride with performance.
    Also, I've always found Michellins to be good tires but pricey. My favorites have been Yokohama and Dunlop.
    juice: Ironic, isn't it? The makers of Rain-X gets to capitalize on new, repeat and exiting customers!
    Kevin: So you experienced no chatter before the repair? Were you on your original clutch? You may want to let the dealer know right away so that it's documented. Sounds like there might have been a problem when putting it back together.
    Ken
  • locke2clocke2c Member Posts: 5,038
    thanks for bringing that back up Juice-- I did remember to pay more attention to what I was doing but forgot to post about it.
    I barely touch the gas at all as I start to engage the clutch. Once the vehicle starts moving then I slowly feed in more throttle. Only after the clutch is all the way up do I give it any real throttle input. (often to the floor, hehe.)
    -Colin
  • Clutch shutter is usually the result of three things, any one of which can cause the problem:
    1. Oil or another lubricant on the clutch plate
    2. Glazed clutch plate (from being overheated)
    3. Worn springs in the clutch plate
    If the clutch was shuttering before you took into the shop, I would suspect the plate was either glazed or the springs were worn. However, since the condition didn't exist before the transmission was pulled, I'm guessing they exposed the clutch plate to some grease and didn't thoroughly clean it off before reassembly.
    I wouldn't except the shop's excuse that there is nothing that can be done about the shutter. Be sure to emphasize that the problem didn't exist before you took it in. Ask them to see their written documentation showing the problem existed before they began work; I'm guessing they don't have it. Every shop should do a preliminary test drive before dropping a transmission and note problems like that.
    Tell the shop you're aware that grease on the clutch plate can cause this problem, and suggest maybe they accidentally got a little on it. See where that takes you.
    Just for future reference, if you ever have the manual transmission of any vehicle dropped for any reason, and the clutch plate hasn't been replaced in 50,000 miles or more, consider having the plate replaced even if it's running just fine. Clutch jobs are almost all labor, so having a new plate thrown in will save you money down the road. That's just my opinion, of course.
    Ty
  • danjaecksdanjaecks Member Posts: 54
    I have the Michelin X-Ones on my 96 OBS and our mini-van. I think they are great, but may not have the sporty feel of the Dunlop SP2 or Bridgestone 950. I noticed a drop in cornering power when I switched from the Potenzas to the X-Ones on the OBS, but you may not notice the difference on the taller Forester. Suffice it to say my 96 OBS with X-Ones corners WAY better than my 02 Forester S with Yokos, mostly due to body roll, the OBS corners like a go-kart. (The 96's were lower than later OBS's.) My daughter now drives the OBS year round with the X-Ones but on our 2WD mini-van we switch to Arctic-Alpins in the winter. The X-Ones are clearly better than the Yoko's in the winter but not as good as the Arctic-Alpins. Hope this helps.
  • subaru_teamsubaru_team Member Posts: 1,676
    Suggestion - call us (1-800-SUBARU3). Ask the Rep. to start a case and let them know that I'd like to look at the repair order for the work the dealer did. I'd hate to suggest Colin's trick - despite it sounding like a lot of fun (I think I should try the technique so I can accurately comment on it). Reasoning? Because I'm safety conscious ;~} Also, I'd hate to see you do something that will confuse a repair issue with an issue that may then appear to have been caused by a self remedy attempt.
    Patti
    Patti--
    I wasn't meaning that as a solution to shudder in lieu of service in this case, I was meaning that the method works well for me to avoid shudder. I haven't felt it in some time.
    I was kidding about the wide-open throttle.
    -Colin
    Good Afternoon! I did review your case. It appears that the Representative you were working with is trying to help you. Also, his manager has been trying to reach you but the phone number we have may be wrong (busy signal). If you do not hear from them today, please give us a call back.
    For other Edmunds participants - unfortunately, it can take our Reps. 24 to 48 hours to get information on some issues. If you have a repair problem, please make sure you are working with someone in the Service Dept. to address your concerns. The Sales Dept. is not always kept informed on repair issues and they are not always equipped to respond correctly.
    Sorry about the problem, Martin, but it does appear that they are on the right track for a resolution.
    Patti
  • oclvframeoclvframe Member Posts: 121
    Patti,
    Where do we stand with the case I started regarding the lack of service at Troncalli? I also have some suspicions of previous service visits I would like to discuss with you. Please let me know what to do next.
    -r
    I just replaced the cabin air filter on my 01 Bean...at 23000 mi. Probably waited too long but, airflow was still good. (Filters filter better when dirty provided you can still get air accross them).
    What I found was a total surprise. The filters may be much better than not having anything there at all, but, there is so much space for air to bypass the filters that a lot of the really small stuff can get by. The filter media is not sealed to the frame at the edges (which means there is an air gap there) and the sides where the filters mount inside the box have no seal either...there are a couple of refrigerant lines passing through the box right where the filters seat so there is no way to seal that end nor the two access doors. My Odyssey has a spongy seal all the way around the filter so that no air can bypass the filter. IMHO this is a poor design. The filters should be re-worked so that the media is caulked to the frame on all sides (right now it can slide like an accordian) and there should be a 'track' for the filters to slide into with no air gap any where around the filters...otherwise you are totally defeating the purpose of the filters.
    The good news is that they are still better than nothing. They were pretty dirty but not as dirty as I expected them to be considering I keep the outside air open most of the time.
    -r
  • jimg12jimg12 Member Posts: 7
    Check engine light, inaccurate fuel guage, funny idle...
    All these things are connected somehow. Was having the same problems last fall, but they went away after I replaced the copper connections in the starter solenoid. I was having intermittant starting problems due to scoring and wear on the connections. The starting problem has not come back, but just recently all three other problems showed up again. The fuel guage reads half-full when it is nearly empty, the idle seems to jump around a lot and sometimes stutters when pulling up to a stoplight with the clutch in, and yesterday, the dreaded CEL came back.
    I can't figure out how all these things are connected. I am going to change the spark plugs and wires and see if that helps. Anybody got any ideas?
    98 Outback wagon, 5-spd, 42,000 miles.
  • Hmmm...Bad spark plugs and wires could cause the funny idle and check engine light to come, but I can't see how it would affect the fuel gauge.
    I'm afraid I have more questions than answers right now.
    When was the last time the spark plugs were replaced? If they haven't been replaced yet, now would be a good time. The wires should still be in good shape at 42,000 miles unless they've been subjected to unusually high heat. You can test those with a multimeter before you replace them.
    Have you had the computer codes read yet? Since the CEL came on, there should definitely be codes stored in the OB's memory. If you did have them read, what did they report? If not, you should have them read before continuing with your investigation.
    Is the vehicle still under warranty?
    Ty
    Just under powertrain warranty. Don't think plugs have ever been replaced.
    Last fall when I had the same problems the code for the Idle Air Control valve came up. The dealership replaced it for free due to the fact that the problems began immediately after I bought the car (used).
    The problems continued. A local shop pulled the code for the speed sensor ( I think), but once I replaced the starter contacts, everything magically disappeared.
  • subearusubearu Member Posts: 3,613
    does replacing the starter contacts require the battery to be disconnected? that would 'reset' the computer, which could have been acting up or using poor previous data for the engine mappings, etc.
    just a thought.
    -Brian
  • jkinazjkinaz Member Posts: 5
    My Haynes Repair Manual cites four OBD-I modes, including the user friendly "U-check Mode." But I can't find the test mode connector (to disconnect it) for entering this mode. Haynes says it is under the driver's side dash, but I've spent a while there upside-down and uncomfortable with no luck. Any hints? Any suggestions on acquiring equipment for accessing the other modes? Thank you!
    could be the intake manifold gasket. we have some troopers with that problem and the fix is a new intake manifold gasket.
    -mike
  • jfljfl Member Posts: 1,399
    I've seen it mentioned on i-club that poor grounding is a potential culprit for these types of electrical problems.
    Just a thought...
    Why not bring to to the dealer? The fuel guage thing sounds like a different issue (fuel sending unit maybe??). I can't hurt to have the dealer check it to see if anything may be covered under the powertrain warranty.
    Let us know?
    Patti
    Sounds like the type of problem that may require trying several things (plugs, plug wires, fuel filter, injectors, ECU, etc.). Since you're under warranty, I'd head to the dealer.
    -juice
  • The first thing I recommend doing is performing the 30,000-mile maintenance service. Since the plugs haven't been replaced, I'm guessing this hasn't been done. In this service the plugs will be changed out, a number of fluids will be flushed, and most of the filters will be replaced. This may or may not help with the current problems, but it will definitely prevent future ones.
    Once you've performed the 30,000-mile maintenance service, have the dealer complete an engine diagnostic, as Patti and Juice recommended. They'll read the computer codes, and they'll check the electrical and mechanical components for proper operation. Use that remaining powertrain warranty for everything it's worth.
    Brian brought up an interesting point about disconnecting the battery terminals. As long as it doesn't erase the computer codes, you could try disconnecting the battery before taking the OB into the shop for a diagnostic.
    I suspect that the there's an electrical short or ground somewhere, but I'm not sure of that. Unfortunately, electrical problems are difficult to trace, and are best left to professionals. I had some electrical problems with a V6 Camry a number of years ago, and found a shop that specialized in electrical systems. They had specialized tools and skills to track the problems down and either fix them or work around them. Definitely worth the money.
    As Juice eluded to, the other option is to start replacing parts and hope you find the right one. That gets expensive, so try everything else first.
    Keep us updated. I'd like to know how things work out.
    Ty
  • I've been trying to understand how replacing the copper connections on the starter temporarily resolved the problems you were having. When you replaced the connections, did you happen to move any of the wire bundles around?
    I'm wondering if maybe one of the bundles had a short and was partially grounding out on the engine block or somewhere else. Continuing with this logic, then when you moved the wire bundle you could have moved the short away from where it was grounding out. Now, the wire bundle has settled near a place where the short is grounding out again. Just a thought.
    Out of curiosity, has the OB ever been in an accident or been flooded (even before you owned it)?
  • fibber2fibber2 Member Posts: 3,786
    Begin quotation:
    DIAGNOSIS OF VALVE LIFTER NOISE
    Just as there are numerous causes of lifter noise, the exact nature of the noise can also indicate the possible cause.
    1. Noisy when engine is first started, but quiet after running a few minutes.
    This condition is entirely normal and will cause no harm. When an engine is shut down, some of the lifters will be left holding valves open against the valve spring pressure. This slowly forces the oil out of these particular lifters, so that they can become nearly empty. When the engine is then started, the empty lifters will be noisy until they are pumped full of oil. This requires from a few seconds to a few minutes in colder weather. Although the empty lifters will clatter quite a bit until they become filled with oil, this will cause no harm to the engine. (END QUOTE)
    My question:
    While everyone seems to agree that Subaru H4 engines are 'tappy', I am still curious as to why they seem to be more so than the Nissan/Toyota/Honda/Ford products that I have owned. Silly question, but does laying a lifter on its side increase the rate of oil loss, and slow the rate of recovery (pump-up)??
    Steve
  • cliffy1cliffy1 Member Posts: 3,581
    Since you brought up Toyotas, I can tell you that some of our products do make the noise described in your quote. The Tundra in particular is susceptible to it. Your Subaru engine may just be of a design that does it more than others, like the Tundra.
  • ffsteveffsteve Member Posts: 243
    Steve (fibber2),
    That Quaker State quote sounds plausible to me.
    There may be something to lifters lying on their sides that contributes to their noise - but then again, it may be just a combination of the lifter design. I've had a number of Corvairs (also H6 engine configuration) that all had a bit of valve clatter on startup. In fact, it was just another of the car's quirks that had to be endured. One car in particular had one valve that was prone to noise, but always quieted down after a couple of minutes.
    Do the Volkswagon air cooled engines also have this trait? How about Porsches? Anyone know?
    A funny story, well funny now... I gave that last Corvair to my nephew, with the usual instructions for care and maintenance necessary for an older car. But one morning he calls me in a panic saying that the engine is sounding really really bad, it's noisy, and he's called a tow truck. Would I please meet him at his house to look over the car? So I go over and meet him, unload the car from the flatbed and pay off the tow. He's really concerned, but I just waited until the tow truck drove off, not wanting to embarrass the poor lad, and started up the Corvair. Sure enough, it sounded like every lifter leaked down over night (who knows why?). After a couple of minutes idling they all quieted down, except for the one which took a couple minutes longer. I explained to him again the facts of leaking lifters, and he learned a valuable lesson.
    I also had a Toyota Cressida with a beautiful inline 6 that sounded like a diesel truck on startup, but then smoothed to silkiness after a few minutes.
    But other cars I have owned have never exibited the trait. A Toyota Supra, with essentially the same design inline 6 as the Cressida, never had any valve clatter.
    My opinion is that some lifters are marginal, might even be defective, and thus some individual cars are susceptible to valve clatter on startup. But if it goes away quickly after starting, I would rather just leave it alone than risk having the engine opened up to replace the lifters. Of course, if it was a constant clatter that never quieted, then I would have it fixed.
    Steve (ffsteve)
    On my XT6 and on XT6s in general it's the consensus that the oil seeps down and you get the lifter noise on initial start. As it gets older the time to get rid of the valve tap takes longer and longer. Changing out the oil pump on them also seems to fix the problem, which leads me to belive it is lifter bleed down. Mine now takes almost 15-20 minutes at 2500-3000 RPMs to get rid of the valve clatter. Soon I'm gonna get the oil pump replaced on it so I don't have to endure that.
    -mike
    My brain must have been working on this question while I slept - what is the configuration of the valve train of an overhead cam engine?
    I recall a view of a Jaguar head (not mine) many years ago that would appear to have had rocker arms riding directly on the cam and the valve stems ("tappets"?). The adjustment was "solid", in that there were no hydraulic lifters as I am certain (from sad first hand experience) are in the Corvair engine, but rather the adjustment was accomplished through the use of shims.
    I have never opened up an overhead cam engine myself, is there really a form of lifter present? Subaru? Other models?
    I stated rather confidently above that this was the cause of my Toyota showing valve clatter in the mornings. But now I'm not sure.
    Uncertain Steve
    From what I understand, the 2.5L DOHC Phase I engine used solid lifters in the design. In the current Phase II SOHC engine, Subaru got rid of them.
    Here are some great articles that may help:
    http://www.cobbtuning.com/tech/dohc/index.html
    http://www.cobbtuning.com/tech/sohc/index.html
    Ken
    Good links Ken, let me help out a little more.
    The old Subaru motor was the EA82, it was a 2 valve per cylinder, overhead valve (pushrod) 1.8L. It served for a long time. Around 1990, the EJ series debuted at 1.8L and 2.2L with SOHC and 4 valves per cylinder. The 2.2L was only available in the Legacy for the first few years as this was Subaru's rallycar, while the Impreza debuted in 1993 with 1.8L in North America.
    This engine used single overhead camshafts--two total because of the horizontally opposed layout--and used roller-tipped rocker arms to act on the cams and valves. One rocker arm per intake valve, one rocker arm per pair of intake valves. (Look at the Cobb Tuning images-- see the forked rockers, that's exhaust.) Early engines used only 1 exhaust port but sometime in the mid-late 90s they switched to a more efficient 2 port exhaust.
    In 1996 the 2.5L engine debuted to power the Outback. It used dual overhead camshafts with hydraulic lifters for one model year. In 1997 they switched to solid lifters with shims under the valve bucket.
    In 1999 the Phase II engines meant several things, but for the SOHC cylinder heads both 2.2L and 2.5L it meant revised ports and narrower valve angles. Narrow valve angles = smaller combustion chamber for a given valve area which = more efficiency. They still used the roller-tipped rockers and still rockers for each intake valve and each pair of exhaust valves.
    I'd post more but the wife unit says it's time for lunch... Gotta run!
    -Colin
    I was hoping you would jump in, Colin. :-)
    Ken
    oops, there's a typo in the above message. in the second paragraph I said there's one rocker per pair of intake valves-- I meant exhaust.
    anyway Steve... no, there are no lifters in any SOHC subaru. they all have rockers that ride directly on the cams and valve retainers.
    -Colin
    I have lifters in my SOHC H6 2.7 I think, although maybe I don't? Conf00sed
    -mike
    Ok, now you have me a bit confused. In my experience, engines without oil pressure driven hydraulic lifters have no way to take up slack when cold, or as polished ends wear. So they naturally clatter until they come up to temperature. Periodically, or when wear dictates, some mechanical adjustment needs to be made to restore OEM lash specs. I adjusted lash on my Datsun L24 (inline 6) each year, and twice on my '87 1.6 liter Corolla engine. Both used nut/screw adjusters on the rockers (cam followers?). My '90 Camry 2.5l V6 used bucket shims, but the procedure was so involved and the engine ran so quietly, that seasoned mechanics told me to ignore the 60k recommendation. Way too much disassembly (intake tract, etc.) involved. Never touched the '93 Corolla 1.8l either - always quiet. Funny, I made the assumption of hydraulics as the owners manual had no valve service listed, but I don't really know for sure.
    I understand my new Honda 3.5l V6 uses hydraulic in conjunction with VVT, but again, I do not know for sure.
    So that brings me to the '02 Outback. Back in September when I asked, I was told that there were no adjustments required. That lead to my assumption of hydraulic. I guess false logic on my part? So if true, we have a non-adjustable, purely mechanical system????? Help me here - something just does not make sense....
    It is the "assumption part" that is constantly getting me in trouble!!!!!!!!!!!
    Steve
    I saw Lash specs on the inside of my '00 Outback's hood.
    -Brian
    I can't find the test-mode connector (said to be under the driver's side dash)to enter the "U-check Mode" for check-engine light diagnosis. Any tips? Thanks!
    Walt
    Correct, there are lash adjustments required on the 2.5L SOHC. It is indeed on a badge under the hood. I think it's something like .008" intake, .010" exhaust. Mine needs to be set. ;-)
    But anyway Steve, for the DOHC subarus that did have hydraulic lifters, they used a nifty little hydraulic lash adjuster. Unless (until, honestly) a lifter goes flat they are zero maintenance.
    -Colin
  • dklavittdklavitt Member Posts: 1
    I have a 1999 Subaru Outback wagon with 72,000 miles.
    I began noticing the hint of burning oil from the engine about a month ago. Seems to be originating on the passenger side. It's now become progressively worse, and little patches of oil can be found on the ground under the car.
    It's going to the mechanic this week, but I've only had the car since October.
    Anyone having this same problem? If so, do you know what's causing it, and what should I expect to pay in getting it repaired? Is there a discussion thread somewhere about this?
  • mortpeaberrymortpeaberry Member Posts: 69
    In early 4cyl porsche (356, 912) and VW types I, II, III; the valves are adjusted with a threaded bolt and lock nut through the rocker arm (every 3k miles and if it is not tight enough sounds like a singer.)
    On a 356 4cam motor ($1200 tune up, rebuilding costs $10k) four cams, 8 spark plugs, 2 distributors, 16 valves (i think) still manual valve lash - but 10,000 RPM RED LINE (arghh arghh)
    I hate crawling under my V-dubs to do valves! especially since I got one of dem subah-ruus.
    steve-v
  • TupTup Member Posts: 200
    While my wife was driving home last week, the speedometer stopped working, then the check engine light came on. She was close to the dealer who told her to come back the next day. Just after she left the engine started to hesitate and shake at higher speeds....computer went into limp home mode. Back to the dealer who was just about to close but had a mechanic reset the computer. It didn't go back into limp home mode but the speedometer still didn't work. They said they would order in parts in case they needed them. She took it back 2 days later and they had 3 different computer codes to look into. Two were related to the speedometer and 1 was to do with air intake or something. They took out the electronic speedometer unit from the transmission and found it to be faulty....they had ordered one so it was on hand. They checked out everyting else but could find nothing wrong that would have triggered the 3'rd warning and say it may have been a false error given the timing. So far it has been fine.
    Unfortunately, the speedometer unit was not covered under the 5yr powertrain warranty so it cost us $300.00 Canadian inc. all the diagnostics and taxes installation etc. has anyone heard of this speedometer unit going at 89,000KM's?
    On another note, our Forester is a 5 speed and I haven't driven it much lately but the last time I did I found the clutch to be very heavy to push down to the floor. I lubricated the spring on the pedal to no avail. Could this be a sign of wear or is there some other place that needs lubricating.
    it is an electronic piece of equipment, so there is always a chance it will break-down. 300can is about what $150US? That is darn cheap IMHO, here you pay $90us Diag fee for any kind of CEL light, and then parts and labor for the other stuff.
    -mike
    That burning oil smell could be the infamous Double offset joint grease leaking onto your exhaust. Apparently Subaru used too thin a lubricant and it often leaks out. This should be covered under warranty and is a known issue.
  • armac13armac13 Member Posts: 1,129
    Ross
    Is still cheap IMHO.
    -mike
  • bluesubiebluesubie Member Posts: 3,497
    My wife's OB just had an oil pump and crankshaft reseal. The oil leak was very minor compared to yours though and we never smelled oil. Are you able to tell where the oil is coming from? On my wife's car, you could see the oil dripping from around the **** cover.
    ***What's that black cover on the front of the engine again? Timing cover? :-)
    Sounds like yours may have been leaking for a while.
    Tup - I thought the DOJ leak only affected Foresters.
    -Dennis
    They said a speedo is not part of the powertrain? That's pretty critical information to have if you're actually going to be using the powertrain, no? Anyone else agree?
    $188 is next to nothing considering the amount of work that would be, though.
    -juice
    Juice,
    Just like the ECU isn't considered part of the powertrain, I'd assume the electronic speedo sender is not part of the powetrain (at least the warranty part)
    -mike
    juice-- yep, the car will only run in limp-home mode if there's no Vehicle Speed Sensor signal. but paisan is right, the 60k mile powertrain warranty is all about strictly mechanical things.
    -Colin
  • bkaiser1bkaiser1 Member Posts: 464
    My 01 OB with only 22K on it has an extremely heavy clutch compared to other cars I have driven (even other Subarus). The dealer says its normal and not related to the shuddering problem (the problem that they have yet to diagnose). Might just be a Subaru trait...I remember driving a friend's 911 in the early 90's that had a very heavy clutch, too, but that was a high performance car, not a grocery-go-getter.
    Brian
    No, not the swimming kind! Yes, a speedometer can go out at any time, just like any other piece of gear. I had one go out at 30,000 miles due to a 5 cent seal where the drive cable entered the transmission. Seal leaked allowing transmission fluid to run up the cable into the inner workings of the speedometer, causing the speedo needle to peg at anything above a walking pace, and the odometer to cycle the tenths digit without incrementing the others. Wasn't covered under warranty, replacing it cost something above $300 in the mid-80s.
    Thanks for all the info on lifter design on overhead cam engines. Kens, I haven't the time to view your links right now, will save that pleasure for later (when not at work).
    Thanks all,
    Steve
