Unless I'm mistaken, fully-assembled Subarus containing specified levels of all fluids are driven, not pushed, from the end of the assembly line to short-term storage. From there they might be transported to the port of departure, but then they're driven onto the ship. Upon arrival here, they're driven off the ship at the port of entry, configured with port-installed accessories, and then driven onto trucks for transport to dealers.
The initial reponsibility for filling the transmission (to enable driving it before it ever arrived at your dealer) rested with Subaru/Fuji Heavy Industries in Japan. The dealer prep process certainly should have checked and caught a low-fluid situation, but they didn't create it. Some damage may already have occurred before they even got it. They should get a share of the blame, but certainly not all of it.
-mike
For instance the interior cargo space provided by a mini-van is far GREATER than SUVs. Safari has the same interior room as a full-size SUBURBAN!
Just cause your SUV has a higher floor, doesn't mean it has more room or clearance. As for getting through inclement weather, there are several AWD minivans out there.
So tell me a situation your SUV provides better than an AWD mini-van could? This all stems from your original statement where you say you don't want it to look like a mini-van...
-mike
In over the year or so reading posts on this forum, I seem to recall a number of times that dealers overfilled, under filled, mis-diagnosed, offered bad advice, and even broke.
I wonder if Subaru should pay more attention to the competency of their dealer’s service departments. Some of them are giving the manufacturer an undeserved bad rap.
About the only functional advantage would be a bona fide requirement to tow really heavy loads - exceeding two tons, say. And even then, if the need is infrequent, a suitable tow vehicle can be rented for the occasion, rather than driving a sub-20-MPG behemoth all year long with one or two people aboard most of the time.
Bottom line, a high percentage of large SUV purchases are motivated by their alleged style/coolness factor and nothing more. And given that they're a menace to everyone else and playing into the hands of foreign oil producers, that is incredibly selfish and superficial.
-mike
-mike
3 strikes, they're out. That's the lemon law. If they try to fix it twice, and it still fails a 3rd time (within the first year), it's a lemon. If you must, have a lawyer call them, but hopefully you'll be able to work it out with SoA directly. It'll take less time and aggravation by far.
opus9: now I'm raising all kinds of red flags. First of all, at 50k miles, that might have been a warranty item. I'm not sure, but I would have called 800-SUBARU3 and worked with them, people here seemed to have obtained favorable results that way.
And yes, rear bearings were an issues with those, up to the 2001 model year. The 2002 design is more fault-tolerant.
Another red flag - usually when those are replaced, they used Legacy bearings, which were more robust. So maybe the "fix" was not done properly last time.
I would certainly call Subaru and work this out with them, you should not be paying for a 2nd set of bearings after just 20k miles!
-juice
Steve
The SOHC uses regular plugs with 30k changes.
Recalls a story I mentioned before: my '83 Rabbit GTI specified very expensive Bosch "silver" plugs. When I changed them, the originals were plain ol' Champions! 8~P
Jim
http://www.endwrench.com/current/Current6/03/WhBearRep.pdf Might bring it to their attention.
George
I'm close to the 60k mark and starting to collect the parts needed. So far I have the air filter, PCV valve, fuel filter, gear oil, motor oil, and oil filter.
Belts are already done, timing belt is only due for inspection at 90k, change at 105k. I'll probably change that at 90k.
I figure I still need an O2 sensor (is it just one, and where?) and plugs. What about plug wires? Should I swap those out now?
That plus I'll flush the coolant. Anything I forgot?
-juice
It'll run rich for the first tank, so mileage will be poor for that tank. It'll learn and entirely new program starting from scratch, hopefully without that hesitation.
It could be something like condensation in the gas lines. For that you could try DryGas, it helped Kate's problem with stumbling.
Al: statistically I think you're right - head gaskets are most likely. Pistong rings are far less common with Subies.
-juice
Or you could just do like me (who was also facing the 60k maintenance) and swap out Sandy for a new XT! (nudge nudge)
-Frank
-juice
Mike
Also Murphys law usually comes into play in removing plug boots that have not been removed in a long time.
Cheers Pat
-juice
Cheers Pat.
I never said I preferred one of the huge SUV's - the anti SUV sentiment here seems to be mostly about bashing Excursions et al. I'm assuming that a 7 passenger Subaru would be in the size range of the 'old' Durango, or the 'new' Explorer - this is going back to '00 when Juice and others first discussed the fact that one was on the horizon, and were comparing it to the current Forester. Also, my Explorer gets pretty darned near the same mpg as the Outback does, within 2 mpg in fact, but I also have a manual transmission on both so that factors in.
I think it also depends where you live, we live in upstate - and I mean the 'real' upstate, not just north of the city - New York. Our two snowstorms so far this year have dumped 18-24 inches on us each time. We do cross country ski and flyfish, and drive into some pretty questionable spots. Would an AWD mini-van get us in and out? Don't know.
Yes, a mini-van has a good amount of cargo space, but not the heavier duty suspension to load it down as I often do the Explorer. We also tow, nothing monstrous, but more than I think a van would handle, unless you went to a big engine, etc.
Honestly, an extended cab pick-up with cap would make the most sense given what we use the vehicle for, but it wouldn't solve the kids with friends issue and I wouldn't put animals - especially injured or otherwise compromised ones - in the back w/o climate control for transport.
I certainly respect all of the opinions here, but the statement I made and what I still wish, is that a company that I like the products of, would make a larger vehicle that fits what we need, simply my own opinion -
As far as whether a minivan is the best choice for you, that's for you to decide. But I've got in-laws who live near the Tug Hill Plateau and they have a 1980s Chrysler FWD minivan that's never gotten stuck in the snow so an AWD minivan should do fine. In regards to the other major categories, here's a comparison between the Toyota Sienna AWD and the Ford Explorer 4WD XLT:
Sienna / Explorer
Max Cargo capacity: 149 / 82 (Cu ft)
Max payload: 1325 / 1411 (lbs)
MPG: 18-24 / 15-19
HP: 230 / 239
Towing capacity: 3,5k / 7k (lbs)
As you can see, the Sienna gets significantly better gas mileage (20% better) and has a huge advantage in the cargo carrying dept (45% more). The payload is pretty much a draw (Explorer has 6% more) as is horsepower (Explorer has 4% more). The Explorer's only real advantage is when it comes to towing (50% more). Still, I would think that the Sienna's 3,500 lbs is adequate for most people.
-Frank P.
-mike
PS: my dad gets in and out with his Legacy L + snow tires no problem :
I've read at the other forum that NGKs are better performing than Bosch.
Ken
Jon
-Colin
Of course my parents didn't drive vans, they had wagons and lead sleds. So maybe I don't have the feeling that I'm driving my parents' cars.
Still, I hope Subaru can combine these best characteristics of minivans in a fun package, if so I'll be first in line.
-juice
Greg
But back to your normally schedule program...
-juice
Jon
I think it might actually be a little less, but check the dipstick.
-juice
DaveM
Finally, at 35K miles with the waranty about to expire, I wrote SOA. I tried to be reasonable and persuasive rather than ranting and raving. Within days I got a call from my dealer saying SOA had notified them that they would authorize replacement of my clutch as a 'good faith' gesture, not as a warranty item (meaning no follow-on warranty on the new clutch) if I wanted it on those terms. After a little thought I said 'OK'.
Glad I did. New clutch operates smoothly after about a month and 1,500 miles - no problems. Just got back from a Xmas trip to Jackson Hole, Wyo. where it was near zero F at night, not much warmer in the daytime - perfect behavior from the car. Its very clear to me that the original clutch was defective, or at least was not spec'd properly for the car.
I think the key in my getting a positive response from SOA was that in my letter I stressed that I was otherwise happy with the car, that I'd made every reasonable effort to deal with this through my dealer, and that if they did take care of it they MIGHT just keep me as a customer.
And now, in fact, I WILL be looking at the new Legacy's when they come out - I may wind up with an Audi, or? but I definitely will give Subaru another chance to sell me a car. If you have one of the early WRXs with the clutch shudder problem I would urge you not to give up on getting Subaru to replace the clutch.
-juice
Patti
I'm glad it worked out okay!
Patti
Be glad to drop the whole SUV/van thing, my issue was never with one or the other, but rather being accused of not having the intelligence or spine to choose what I prefer based on driving experiences and needs rather than worrying about what others think - last you'll hear on it here.
We live north of Albany, toward Saratoga, parents where we spend a lot of time live north of Utica/Rome, have a camp in the southern Catskills, spend a lot of time bopping around most of the state for rescue work and pleasure.
Juice, thank you for your usual sound advice and input on the clutch thing - heading off again -
Jeannette
http://AZPInstalls.com/48hrs-04
Also I have a place about 40 min west of Saratoga.
-mike
I've enjoyed reading the posts on this board, and have learned alot - hope someone might have some suggestions / perhaps a similar experience. Thanks.
Sorry about the problem, but I'm sure we can figure it out.
Patti
