Your owner's manual actually has instructions on how to do it. Mine does. I have 01 Outback. Where in CA are you? It seems there are a lot of CA people on these posts. Maybe we should get together some time. I don't have a scanner or else I could scan my instructions and send them to you! Sorry. It is really easy though. Just remove a few plastic clips to to remove the plastic shield. That is done so that you can access the filter. And that is it. I did my first oil change at 3K.
Anibal
Anibal, I'm located in Pleasanton/Dublin. My Forester is a Sedona Red Premium with a yellow splat... you may have seen me around if you're in the Walnut Creek area:
Karin in California
Thanks again,
-Greg
I don't know for sure why Subaru uses a hydraulic tensioner instead of a spring. I know that they had a manual tensioner before...
-Colin
Any comments? Is this normal?
By the way... must say this car is the quietest, most comfortable & enjoyable car that I have ever owned. I am really glad I opted for the H-6.
So far I have been averaging 20 mpg of mixed driving & I can't complain with that. Certainly better than any SUV in my opinion.
Patti
P. S. - I double check about the spring/hydrolic tensioners. I know we have both but I can't remember which is in each engine. Since we tore down the 2.2, 2.5 and the 3.0, I just can't place (from home) which was which. I'll post info. later.
Patti: I would be interested on info regarding the pretensioner. Thankyou.
Love this stuff,
-Greg
Do you work out there? What do you do? There are a lot of Subies in W.C. But who knows maybe I have seen you. I like all this info on the timming belts. I have just never done one and can't exactly picture all these things like ligning up the cams. I think the 01 OB is a SOHC. Is that correct? Half of you people should be mechanincs. I would use you. Should we open up a Subaru service station in the Bay Area???? With reasonable prices?
-mike
Sorry to ramble,
-Greg
The second is a paint/primer problem on the Blase' Yellow... err, Blaze Yellow cars. Apparently the fenders are not primed properly resulting in a slightly paler color (it's pale to start with...) and it might affect the door handles and hood scoop too. Read about it here.
-Colin
-mike
BTW, anyone knows the cost to replace the windshield? I see there is some heating wire attached on the bottom of windshield glass and that may require to get the part direatly from Subaru dealership. I guess it would cost a lot and I am just curious to ask.
Rgds,
Jack
Patti
My '99 Forester "S" took a stone in the windshield when it was about 9 months old. I replaced its windshield under glass coverage, and had to insist on the original equipment windshield with the heating wires at the bottom. It cost (the insurance company) about $900 US.
It may be a good idea to get the stone ding "repaired" right away if you don't have glass coverage or want to postpone replacing the windshield. I waited a month and the ding turned into a crack. The spot repair doesn't weaken the glass as far as I know. Good luck.
John
re: windshields
Many of 2.5RS owners have had lots of trouble with stonechips in the windshield. I got my first one within a month of owning the car, second one about 4 months ago, and a third just recently. They are small but noticeable-- no threat to spread to the rest of the window IMO.
I've also noticed that the entire windshield is heavily pitted, no doubt from all the dust, sand and salt here in Kansas.
Nevertheless none of my previous vehicles have had this sort of trouble-- the pitting bothers me the most-- and some of them had a much less inclined windshield or were older cars.
-Colin
How big is the ding? If it's fairly deep, it might pay to have it filled in by a local auto glass shop.
I had my windshield replaced on my 98 Forester (no heating elements in glass) after 2.5 years when a rock created a 12" long crack. The cost to me was $150.
I too have noticed that the Forester windsheild is quite susceptible to getting chips. This topic has been discussed to some extent. Some feel it's the upright position of the windshield while some think it might be the glass itself.
Ken
What do you think, should I go for it or go to independent mechanic? I have Subaru currency (accumulated from Subaru MBNA card) to pay for the service, but still -- $99.95? Grrr...
An oil change ranges between $20-25, tire rotation runs about $20 and the balance which represents about 45 minuts of a preventive check accounts for the rest of the dollars. Do what makes you comfortable.
Don
$100 is a bit high for what's recommended for a 7.5K mile service interval. I personally only take my vehicle in for the "big" ones like 30K, 60K, 90K etc. You can get the oil change and tire rotation done for about half that amount at any auto shop.
On the other hand, Santa Cruz Subaru has very good service and I'm sure they'll do the job right. I would take it to them if I had some other warranty related question.
Ken
-Brian
Patti
Hydrolic - all 2.0, 2.2, 2.5 and 3.0
Better overall for the vehicle to keep the belt on right
Spring - 1.8 - Loyale (remember those) only. Not on Impreza 1.8's.
Hope this helps.
Patti
Here's a list of what's done at the dealership I use for the 7,500 mile service:
Change oil and filter
Install BG MOA (?)
Rotate tires
Inspect brakes
Check all hoses and belts
Adjust tire pressure
Replenish fluid levels as needed
Inspect exhaust system
The cost for the service is $79.95 plus tax.
I hope this gives you some more ideas.
Don
PS: If you find out what BG MOA is, let me know!
Beware of what you sign when you drop the vehicle off.
Daniel
"Buyer Beware" is never more true than here.
Bob
Ken: The ding is very small at passenger side and not very noticeable. But it still hurt my heart a lot seen this car is the first one fully owned and choosed by me. (I had a very old Ford Escort which was given by my sis, which doesn't had anything except a sterring wheel and 4 wheels... eg:no power sterring, no air conditioning etc). So, where do U go for the replacement? (I thought it's very hard to find(& expensive) to have replacement coz Forest is not as popular Honda & Toyota.) Any noticeable diffence without the heating element?
Jack
thank you,
robert
1) the driver-side (only driver-side) window makes really loud wind noise. We took it to the dealer 3 times and every time they did something but never reduced the wind noise. We are tired of driving 50 miles every time, so we just live with it now.
2) Check engine light kept going on and after 2 trips to the dealer, they changed the censor and it is actually FIXED.
3) One fuel injector failed while we were 250 miles away. We made it home and greatly unhappy about it. But they fixed that one too.
4) The remote key entry some times simply do not work, get this, we were standing literily right next to the car and the car simply will not get the signal from the remote. (we were really worried that we were not going to be able to get in the car.)We have not talked yet with our dealer on this one.
5) The windshield wiper system gets frozen when it reaches certain temp. We live in Wisconsin and I tell you we need those washer fluid run in the winter. We have not talked yet with our dealer.
6)Now a new problem. For the past few days there is a terrible burn smell after our driving. We are mechanically challenged people but we did check oil and it seems to be clean and full. We have not talked to our dealer on this issue either.
As you can see next time I am going to the dealer we have a list for them to fix. Our car just passed 20,000 mile mark. I am just wondering if any of you have some general ideas about the problems we are encountering and maybe we can recommend what you can provide us to the dealer. There seems to be so many good advices here.
Ellen
There are lots of shops that specialize in auto glass. You can go to any one you find convenient -- any shop can order the right glass for your Forester. Prices may vary so it pays to call around. Also, have you checked if your auto insurance covers glass? You may only have to pay your deductible if you are covered. FYI, I went to Safelite for mine. There are several in the Bay Area.
As for the heating element, it really depends on you. I'm sure you could use a Forester windshield without the heating element and save some money. Do you drive up to Tahoe in the winter? I've wished on several occasions that my Forester had those heating elements. When the temp drops below 20, your regular wiper blades become pretty useless.
Ken
I had my windshield replaced through my insurance company at an independent glass shop my agent recommended. I think they bought the windshield through a dealer though. I live in upstate New York, and find the heater elements very useful for de-icing the wiper blades and keeping them flexible in winter. That and the heated side mirrors are key reasons why I bought the "S" instead of the "L". As Ken said, if you drive in winter conditions the heater is useful, if not, you could forgo it and save money. Hope you have glass coverage. Good luck!
John
Patti
Try to use a windshielf washer fluid with a lower freezing temperature. This works for me.
My keyless works best from behind the car. See if a certain position works best for you.
I'd let the dealer work out the rest. See if you can get a loaner car, and tell them to take their time and try to resolve everything. Seems to me like all of these are fixable.
robert: the moonroof has a few points where it stops, probably because that's were it makes the least amount of wind noise/buffeting.
Jack: if your insurance cover the windshield, get a dealer to install an OE replacement. It's usually covered under Comprehensive, though you'll pay a deductable.
If not, I'd let it be. My wife had a chip on her Mazda, and when they tried to patch it, a huge crack appeared, and they had to replace the whole thing. She now has yet another chip, and we've left it alone. It has not spread (knock on wood). I've also asked her not to follow trucks so closely - since their debris is what causes the cracks.
Coleen: the AWD system is sealed and maintenance free. I suggest you check with your local Subaru and Honda dealers to find pricing for the 30k and 60k service. I bet that it's similar.
gof4: the new brake pads have more metallic content. Surface rust is normal if the car has been sitting, so a little squeek with the first application of the brakes is OK. If the squeek persists, you have a problem and I'd have it checked out.
Karin: yes, homepage.com shut their doors and my web site went with it, but I moved my photos to PhotoPoint. The catch is, now they are no longer a free service, either! So I'm going to bit the bullet and pay the $10 annual fee.
Here are oil change photos:
http://albums.photopoint.com/j/AlbumIndex?u=1400062&a=12183672&f=0
Sorry for the long post!
-juice
Thanks for any input.
Kevin
Also, there may be small differences from manufacturer to manufacturer.
Try measuring the diameter of each tire. Make sure the tire pressure is consistent all around, and measure from bottom to top. They should not vary more than 1/2", maybe even less than that.
-juice
is this normal, i would think the motor is supposed to stop when the moon roof gets tucked inside the roof.
robert
Mine is an aftermarket manual pop-up type. I'll trade you, though! ;-)
-juice
Pattim3, I assume you are with Subaru America. Thanks for taking notice. I'll gather all the information you asked for and give you a call. Should I ask for you?
I have another question about oil change. How important is it to have the dealer to do the oil change. Our dealer is 25 miles away and because of that we just take our Subie to Valvoline Instant oil change. I read somewhere on this board about some kind of special oil filter. Does Valvoline know that? Thanks again.
-juice
-Colin
-juice
Yes. If you look inside the filter you will see a sort of spring valve in the bottom center of the oil filter. I believe most of the filters now come with this, unless you are really buying cheap brands. I would imagine that Fram oil filters now have it as well. Juice did you hear the idea someone pposted, about poking a hole in the filter and allowing it to drain before removing the filter? I like that idea. I will try it next time.
As for the crush washer. I think if you get a nylon washer you will be fine too. Before crush washers I never had a leak. And I paid 1.50 for that washer.
Any news on Darlene????
-juice
-Colin
Ross
Rgds,
Jack
You can feel free to ask for me, but I can be hard to reach. If you speak to one of our C. S. Reps., they should be able to help you quickly. You can tell them that I directed you from Edmunds so that I can keep an eye on things and they'll keep me informed.
You may just want to pick up a case of Subaru oil filters and supply your oil change place with the filter you want. It can save you a bunch of hassle down the road if you run problem with the filter since we back that one up.
Patti
