Dodge,Ford,Chevy------who wins?
Most people would agree with my two cents.
I disagree with your two cents. Automatics have a torque converter that allows for slippage between the motor and the rest of the driveline, which means you don't get about 15% of your engine's power. Most new auto's have a lock up torque converter which means once your up to highway speed, the torque converter locks solid with the drive gear, just like a manual clutch would. Manual transimissions are usually built a little heavier duty than automatics. If you pull with automatics, you have to be careful because all the stress caused by pulling will make your transmission fluid become much hotter than normal, reducing its viscosity, and reducing its protection. that is why many trucks have posts on them telling you not to pull in overdrive, but in 3rd gear. this mainly gives the engine and transmission more rpms so more transmission fluid is circulated.
automatics are not built for pulling. if you are a serious load puller, and plan to put lots of miles pulling, i would go with a manual. it will last much longer, and you will enjoy 100% of your engines output, instead of 85%, which also translates into better fuel economy.
I posted message 55 and I read your response.I
have to disagree with - not that I know much about
it, but I use to be an eighteen wheeler truck
driver before I went to Medicine (and during as well). I also pulled a travel trailer all over Europe(and believe u me, there are up to 16% grades and hairpin curves that u will not believe! In terms of power, control, efficiency and most of all - I'm used to it. Cdean put it in
a professional lingo, I "speak from my heart"
.At any rate, what about the rest Of my previous post, any comments?
TIA
Isaac(from Israel).
I was aware of slippage and yes, a manual would actually hold up longer if one was pulling 1000lbs. My point is that automatics are far easier to drive when pulling without concerns of the clutch. Lets face it, not many people check out the weight they are pulling and most have half-tons to begin with.
Take for instance: two identical 98 F-150's
Both of these trucks have the 4.6l V-8 triton motor. Both have have 3.55 rears and both are super-cab, 4x2 short-beds. Every thing is identical with the exception being the transmission. Now let me share the statistics from Ford themselves on maximum trailer weights for limits:
The automatic: 11,500 max and 7,000 reg
The manual: 7,800 max and 3,300 reg
I agree that the manual would last longer but I go by actual expierences. My conclusion is that for John Doe,who only needs a half-ton, generally tows maybe five times a year with his two kids and wife. He shouldn't have to worry about the weight or jerking his trailer back and forth as Johnny Jr. is pulling his sister's hair.
Not everybody in this world buys Superdutys. We can banter all day long about the virtues of the stick and I do agree with you on those numbers that you thoughtfully put up. I'm curious how many of you out there have an auto and pull regularly. Please let me know. I might be alone in my thinking.
Manufacturers all rate the autos higher. Are you gonna risk your warranty?
Any response to my post (55), PLEASE ?
Thanx, Isaac, From israel.
Thanx for the comment.
True, I will not do much of roading.
About the short bed - since I do plan to take trips for a few days at the time, I wonder if the
short bed will be enough(that is why I need the shell), but I guess it's easy to find out.
Thanx again, Isaac.
Ford F-series 770 k
Chevy C/K 560 k
Dodge Ram 350 k
GMC 170 k
The thing that stands ou to me is, over the last 3 years, the large increases of both Dodge and Ford compared to the near-stagnation of Chevy and GMC. Ford is clearly outselling GM as a whole now, and it should be the same in 1998, as GM can't compete with the heavy duty models from Ford and Dodge. You're looking at solid-axle (4x4), heavily-sprung V10 and medium-duty-diesel powered F's and Ds, against the GM trucks with IFS/torsion bars, weak diesels and an inefficient 454. If Daimler can slide Chrysler a few bucks for another Ram plant, Dodge can catch up to Chevy in terms of sales, and probably have room to add the crew cab a lot of us Rammers have been waiting for.
If you're still curious about the Ram reliability, I have a 96 Dodge Ram 4x2 that has had me in the shop too many times to count!
Here are a sampling of some of the problems:
Rear leaf springs were making a very loud
squeeking moise and had to be replaced, under
warranty at 15,000 miles.
Rear shocks went at 30,000 miles and were
replaced under warranty.
Power stearing tank sprung a leak and left me
stranded...wheel wouldn't even turn. 35,500
miles and replaced under warranty.
Spark plugs were replaced during my 30,000 mile
tuneup and I was back to the dealership twice
after the initial tuneup because they kept
misfiring. Finally they replaced the hoses...
under warranty.
I've had a problem with the stearing column
since about 20,000 miles. The problem is most
evident when going over small road bumps at
lower speeds and also when cornering. It feels
like the steering column is loose and the road
vibration travels up through the column. The
first time I brought it in for repairs the
service department replaced the "box" (pointing
to the base of the column). It was fine for
about 1,000 miles but the problem slowly came
back. The second time in they replaced the box
and the column, informing me it wasn't a recall
but a bulletin with the Rams. It's been about
500 miles since they replaced the column and
the problem is coming back again!! I have
another appointment tomorrow for this problem.
The least the dealer could do is make up a
personalized coffee mug with my name on it!
Ohh yehh the windsheild cracked and I just had
it replaced the other day. I was lucky to have
witmessed the repairman remove the exterior
rubber molding and with the lightest push from
the inside the windsheid came out. The glass
wasn't even glued in!!! The installer said in
his 20 years on the job he has never had a
windsheild poop out like that. Gee I wonder
why the glass cracked in the first place!
At this point I'm ready to get rid of the truck...
and am I a complete idiot for looking at the
Durango??? Sorry about the long post!
Then again, any manufacturer can produce a lemon or two. But if it were me, I'd think twice about running right back for a Durango. Granted it's not the same chassis as the Ram, but still...
If you do insist on the Durango, at least get the "bumper-to-bumper" warranty!
looking at the S10 and the Ranger.
I will not be carrying much weight.
I will not be doing any towing.
I am leaning toward the S10 on looks alone.
Also, the S10 comes with 15" tires rather than
the 14" on the Ranger. Everything else seems to
be equal.
Any opinions? Any major problems with either?
(I never owned a PU.)
Seems to me your choice is made.
Maybe some other owners of S10s will join in here and give you some feedback on what their experience has been with them.
I got the sales figures out of Popular Mechanics magazine, last month, and I saw the same figures in what i think was "4-wheeler" magazine, (i was in a waiting room). I saw the '96 sales numbers next to the '97. i was a little off when i predicted them earlier somewhere. the '96 numbers were
ford 700k
chevy 550k
dodge 240k
gmc 220k
gmc dropped off 50k this year and dodge increased about 110k.
I agree with kcram about GM stagnating mainly in the heavy duty market. I still see lots of chevy's being bought in fleets in one ton and 3/4 HD being used for personal/company all purpose trucks. but i've seen a growing trend over the past 2 years of Fords mainly being bought in the Superduty (1 1/2 ton) class with tool beds and utility beds, delivery load trucks, etc. GM hasn't changed anything in years, while Ford and Dodge have pretty fresh stuff, which is just more appealing. (as long as they're trouble free.)
Some of the numbers you have there are 1995 numbers - in 96, Dodge sold 370K, they actually dropped 20,000 in 1997, partly from the 97 Ford intro, partly from the engine strike.
My hometown's public works department is gradually switching from GMC to Ford as trucks "die off" - I don't think they were happy with the GMC 3/4 and 1-ton trucks at all.
The S-10's are notorious for loud noises in the cab especially with the third door. Check out any review of this model and you will read what I have read. The S-10 does look better but it also scores lower in safety in both gov't and insurance tests. Seriously reconsider the Ranger. Remember that Toyota also makes a damn fine small truck.
kcram,
My town is doing the same type of changeover to Ford and Chrysler has a plant right here in Newark,DE!! Dodge guys are everywhere here plus a GM plant is five miles away. Even patonizing the local economy can only go so far.
I would appreciate any info or advice.
If you definitely need a crew cab, grab an F450 crew cab - much higher payload, oversize (19.5") wheels, and a beam axle up front.
However, before we go tooting the Ford horn too loud, it sounds like the rear ends may have played a role. The Ford had the 4.10 with the Powerstroke. The Dodge with the Cummins had a much higher rear end (maybe the 3.55?). Doesn't the Dodge offer a lower ratio?
They said that the Dodge got a little better gas mileage, but certainly not enough to compensate for the performance difference. There was no contest between the two vehicles. It's hard to tell how much of the performance difference can be attributed to the higher torque Powerstroke and how much can be attributed to the lower ratio. I suspect the rear end difference had a lot to do with it.
The trannies may have had something to do with it too - if the Ram had the slushbox, the automatic downgrades the Cummins pretty far, while the Ford uses the same output.
What kind of engine does Ford offer for the F-450? I would consider the powerstroke but am more familiar with the gas engines. Does the F-450 share the same frame of the F-350?
A lot of people never knew that the F-Super Duty of the old body design really was an F450 internally to Ford all these years.
I think that the two diesels are very close in performance. The Ford will accelerate faster For sure. It takes the Cummins a little longer to wind up. Once up to speed the Cummins may be a little stronger. Its so close though, all boils down to personal preference I guess.
By the way, my dad has a 97 F-350 Powerstroke. My dad didn't tow his fifth wheeler up to Alaska this past month. He picked up a 24 foot pull behind from a dealer in Elkhart and delivered it to a dealer in Anchorage. Normally, these dealers pay for the service, but my dad wanted to use the trailer to pick up my sister's household goods in Seattle and bring them to Alaska since she is moving up there. A guy in Anchorage has asked him to tow a trailer with a classic car on it down to Yuma Arizona later this summer. The guy is going to pay my dad's gas and a little extra. I think my dad is enjoying his semi-retirement.
Does your dad usually tow in O/D? Sounds like he likes to drive...
one small flaw with your last thought. You said more smaller cylinders, referring to the V8 over the six. But if you check the cylinder size, you'll find they're not that far off. The Cummins has 59.8 cube cylinders, the Nav is 55.5 cubes. Tbat always surprised me because with so much more displacement, one would assume the Nav should destroy the Cummins is output, but they're pretty much equal there.
I'm bad at exact meanings. Horsepower by itself is worthless? Could you explain. I'm not being a smart-[non-permissible content removed], just a dumb one.
horsepower can only be a really useful figure when you are comparing engines with similar torque figures. like two diesels, or two 5 liter engines, etc. the equation is Hp=Pi*rpm/(30*550)
the shape of an engines torque curve determines what its max horsepower is at. if and engine has peak torque at a high rpm, horsepower will peak high also and probably (not always) be higher, than a engine which peaks at lower rpms. even though the engine can't do any more actual work than one that peaks at lower rpms, it does it at higher rpms, thus the hp number is bigger.
you can take any engine and increase it's hp output on the dyno by letting it rev up another 1000 rpms. i wouldn't reccomend this, if you at all like your engine.
a good comparison of horsepower is when chevy went to the vortec engines. the 350 went up only about 10 ftlb in torque, but went up 55 horsepower. now engine was doing the same given amount of work, and it was doing it 30% faster than the previous model. now its a useful number. it shows a vast improvement in engines with similar torque curves.
to me, a true measure of an engines overall power, is how fat the torque curve is.
When comparing the Cummins and Nav, do you have the bore and stroke numbers? For example, I believe a Chevy 350 is just a 305 with a longer stroke. I know in off road motorcycles, a longer stroke generally means more torque given the same cylinder size. Does the Cummins have a longer stroke than the Nav?
Diesel mechanics I talk with consistently rate the Cummins higher than the Nav. They say the Cummins is easier and cheaper to repair. They also say the 12V Cummins should have the valves adjusted every 25k miles but the new 24V Cummins only needs the valves adjusted every 60K miles. I don't believe the Nav. ever needs the valves adjusted.
Dodge, Ford and Chevy all have their good and bad points. Dodge can nickel and dime you to death on little irritating stuff but everyone loves the Cummins.
Ford has had front end alignment problems on pre 1996 pickups but those with heavy towing/hauling requirements love their powerstrokes.
Chevy has had transmission problems for those who abuse their trucks but Chevy seems to have the most loved gas engine in the vortec 350 and their extended cab is the biggest of the three.
The Dodge and Ford diesels are tops. Chevys 350 consistently gets high ratings. Chevy has the biggest ext. cab, lowest 4x4 height and best 350 size gas engine. Dodge has the diesel with the best fuel mileage and almost the most pulling power and the diesel cheapest to repair. Ford has the biggest and most powerful and most expensive to repair diesel.
Dodge, Ford and Chevy all win in at least one catagory depending on what you want and what you are willing to live with.
