HU <-> Blitzsafe HON/AUX/DMX V.1 <-> DVD player
I am able to get it to work only if I wiggle the Blitzsafe adapter at the 14-pin end. Once it's working I can switch between the CD and CD/CDC with no problem as long as I don't leave it in the CD mode for longer than 15 sec. If I did it will not switch back to the CDC mode. To get it to work again I have to wiggle the adapter again. This is the second Blitzsafe adapter that I have tried. This is really strange!!! I am hoping that anyone else has experienced the same thing here and give me some tips to make this work. Thanks!
Otherwise, give me an update.
I am on my 4th DVD player, as the previous 3 had some sort of issue or other and were replaced by Best Buy.
I plan on picking it back up this morning as it spent all of yesterday in their shop getting all new hardware except for the player. The story on that one is: When the 3rd player went bad by refusing to play discs, I brought it in and they replaced it with a model that looked similar to yours (if you remember the pics, mine was much different looking, though same mfg) but, they did not replace the IR eye that goes to the unit so with the new player and remote, I could not get the remote to work with the old eye. They were not able to order just the eye so I had to wait 3 more weeks for them to order an entirely new kit, headrests and all. That is why it's in the shop yesterday. But it gets better....
The new kit they got in had all new stuff as well as a single rather than two a/v boxes under the seat which meant they had to replace both headrests as well since the connectors are different. That was the good part, get new clean screens after having the old ones for almost a year. But, the new player that came with the kit that they were going to put in was DOA. DOA!!! I couldnt believe it. Amazing that a retailer as large as Best Buy can have so many issues with a supplier. SO...they said they'd leave my current one in there for now but have ANOTHER kit on order in the event it dies on me. Also, they changed my mounting location to under the stack from under the seat where it used to be. I went back and looked at your pics to see how I'd like it and feel it will be ok. Do you have any issues with it being there? I do change discs fairly often and with all the issues I've had I guess it's good to have it close.
I did tell the installer to make it easy in themselves when they install it because they will probably be replacing it often...I can't believe you havent had any issues...your setup is working perfectly?
So maybe with your location changing to the bottom of the radio stack, it will help. More temperate for the dvd player in the winter time. I remember that our units were different. But I can't think that Best Buy, at this point, is happy with the multiple failures of the unit they sold you. They have by far lost money in labor by now. I'm sure it was nothing malicious as they have stood by their warranty to you.
Whether in the end the move to the bottom of the radio stack would be so helpful, we'll never know (hopefully!). Because if there are no problems from here on out, then you won't know whether it was finally a good unit given to you, or the change in location. That's why I said hopefully we'll never know!
If I had to gripe about anything, it would be a slight slight ignition noise. But that is only if you are sitting completely still, with the windows rolled up, and the stereo cranked up pretty loud with the dvd on pause. Then.....you can hear a slight slight ignition noise when you revv the engine. But take the dvd off pause, and start driving down the road with the windows still up, and you can't hear it.
But that, luckily so far, is it.
As far as the position, yes, it is easier to put a disc in there vs under the seat. And to date, I haven't missed the loss of space that the dvd takes up.
Well, we'll keep our fingers crossed that FIFTH time is a charm on this dvd player for you. And I agree....nice new screens might take the edge off all your extra efforts to date.
Keep me posted........
Joe
Go to Best Buy or Circuit City and tell them the car that you have. They will be able to reference the compatability and use various face plates to make the radio/cd look almost factory.
Is it possible? Thanks.
Or, should I buy custom mats online for more money?
I don't want to pay the full 125 for them at the dealer, and the custom ones are 140 online.
What would you do? Make offer at dealer? I was thinking of 90 since that's how much they are on Ebay. Thanks.
They are selleing it for $83.30. I just ordered mine from there.
I can tell you that I'm not very happy with it. Due to the factory alarm, the only way to operate it is to unlock the doors with the remote before starting the car. So I strongly suggest going with a whole new alarm/remote start that will eliminate the factory alarm altogether.
I had tonnes of discussions on this previously with some members in years past. The posts should answer all your questions. Good luck!
The Dealer's price of $500 + includes cooling fins for your transmission and power steering in case you pull a 4500 lb boat, which I will never do.
I just bought 05 Pilot EX-L. I'd like to install the running board bought from CheapestHondarPart.com. I wonder if the running board can be installed from home without any special tool. Greatly appreciate your expertise. T
It would seem that simply replacing the 4 door speakers and leaving the sub and tweeters as is can make a huge difference.
The Pilot head unit does, however, have an extra input that can be used from a CD changer, tape player, XM, or Sirius radio. In addition, the XM sound can be feed into the radio via an FM modulator.
The official Honda solution involves installing a special XM receiver in the center stack and running the sound in via an FM modulator. This runs over $500 just for the parts, labor is extra. This unit will not fit in the stack if you have the Nav or RES.
Your other choices are to buy an XM receiver like the Roady2 or to replace your entire radio head unit with an XM ready one.
Sorry for the bad news.
I do have the RES, so the official Honda solution wouldn't work for me anyway. The funny thing is that my dealership did not even offer me this solution - they just told me to go to Circuit City and figure out what I needed with them!
OK, so my next question is...my husband has a Sirius subscription in another car. Since it sounds like I am basically starting from scratch in the Pilot, do I HAVE to go with XM, or can I go the Sirius route and become a second subscriber under his account?
I would suggest you NOT go to Best Buy or CC. Find a 'high end' car audio store and go there. You will pay about the same for the sat. hardware and you might pay an extra $20-50 for the install over the chains but you have a much better chance of getting a quality job done. IMO.
Both are 9" widescreen models, with the DVD player a part of the ceiling mounted screen.
Further, with a good install the trim ring is not needed, and it almost does not imede vision (so I am told).
In my area we have a few very good CC places (by size and volume) - so install is a good deal and not an issue - I am told.
So, 2 questions:
1. Is this model - sorry I have little info on it, a good one?
2. What else is needed and what is the lingo in obtaining it - such that the buyer does not get hosed. I think I want the modulator so we can all hear it, but I can also use the wireless, and allow for radio/cd at the same time the dvd is playing? And, I want the kids to be able to attach a video game system - so, do I need an upgrade/extra in order to do that - and what would it be called?
I will be putting this in an 05 Pilot EX.
I spent 20 minutes on the phone today with Honda Customer Service, and found out exactly what I had been told on this site (in a much faster time!) I then called my Honda dealership and spoke to the Sales Manager (felt like I had been a little misled by their explanation of what XM Ready was.) He told me that the XM option is $850.00!! - and was trying to tell me that, yes, I COULD have this installed in my Pilot with RES...Sounds like I am not the only one out there who is confused...
Doesn't matter - can't get it on my car anyway.
If you want to see some photos I have posted them here:
www.hondapilot.org/forums/showthread.php?s=&threadid=11081
Total cost was ~$330 including a custom mounting bracket made to fit the Commander just under the seat heater switches.
If you are in North Chicagoland I can point you to Tweeter in Gurnee...1st class job and not that much more than Worst Buy or Short-Curcuit City
-D
Couple questions - in case anyone has a similar unit or experience.
1. Is it connected to anything other than the headliner? Seems the headliner is sagging a tad - but could be me, as the car is new - and my experience with the headliner is well - there is no experience with it.
2. The screen seems to shake or vibrate because of the pivot design of the screen/frame.
But, maybe they all do this a bit.
Anyone have the Sony or Panny (both were 9" widescreen types.
If anyone has any input, I'd appreciate it.
