I have a 2005 Pilot and it vibrates at speeds between 70 and 75. 4 new tires, special alignment, 8,000 miles and it still vibrates. I test drove many 2006 models and ALL vibrate at this speed. PLEASE PLEASE PLEASE - before you buy this car - make sure you have test driven at highway speeds. There is definitely a design flaw that HONDA is not fessing up to.
You say you replaced your tires..which brand did you buy? What were the original tires on your Pilot?
PS: Document everything.
If the glove box door has a squeak that distracts the driver, does that make it a safety issue? How about a radio with too much static? Be reasonable. The minor steering vibration problem we're talking about here can certainly be annoying and Honda should fix it. But if you make this a "safety issue" then you can make ANY car problem a safety issue.
- Mark
Will
Will
Did anybody experience a similar thing with their Honda Pilot? We already tried to reset the alarm, but it still wouldnt work. We are not locking the car doors anymore, and still, the security alarm goes off. So last night, my husband unplugged the battery to make sure the alarm doesnt go off in the middle of the night again and wake the neighbors.
I just thought I'd ask here first before we take the car back to the dealership.
Thanks for any/all of the advise you can give us.
a) Misalignment which MAY, or MAY NOT be a safety issue.
b) Lack of re-inforcements on the body/frame of the car.
c) Lack of re-inforcements on different parts of the car.
d) Bad parts / wrong parts
I know that you are probably very annoyed by this issue since it is very uncomfortable to drive with a vibrating steering wheel. It is also unsafe because if you drive on a pot hole, you may not realize it since your steering wheel was already vibrating.
Please PLEASE contact the Honda headquarters to make sure they are aware of this problem people are having with their cars. They will have to investigate this if you let them know. There isn't any other solution to this right now so the best thing would to be to contact them. You wont loose anything from it. They may not even know about this problem. Please repsond. Thanks
Also, airleaks on the driver's side window.
Dealership stated 18 miles per gallon. I'm lucky to get 15 mpg.
Calling it in to Honda is appropriate AFTER you've gone through the process you agreed to under the warranty when you bought that car - work first with the dealer to get it fixed and if you can't get satisfaction, escalate to Honda Corporate. If they can't eventually fix it, then you can start looking at lemon law proceedings.
You'll have better luck getting satisfaction if you follow the prescribed process - it's in the OM. You're just wasting your time if you call Honda as the first step.
- Mark
Then what's your knowledge base on this issue? I AM a long-term owner of a Pilot and have monitored this and other Pilot forums for years. It's probably the #1 Pilot complaint.
"But I don't think that anybody has complained."
Hundreds of Pilot owners have escalated the issue to corporate Honda. Beleve me, they know all about it. Since they haven't made any major design changes, they apparently feel the complaint rates are acceptable and want to deal with the issue by the typical measures - wheel alignment, tire replacement, wheel balance, etc. This may not be acceptable to all owners, but it's how Honda is dealing with it.
While we're solving problems with phone calls, let's all call Chevron and ask that they drop gas prices. It would do just as much good.
- Mark
Wind noise above 40 mph can be solved by installing vent shades on the windows. That is what we did and it really is worth the money.
Gas Mileage was poor for the first 5k miles then got better. We currently get 17 around town and 20-22 highway on trips. So not too bad.
One of my biggest gripes has been the inside door pillers getting beat up by the seat belt buckles. At 2000 miles they looked like they had been there for 80-90k miles. the dealer was good about replacing them (only once) and then I covered them with clear 6" wide packing tape. The tape takes the beating and can be changed. The dealer made it clear that he would only change them under warrenty once.
So far I have not had the smoking CD player, poor door sealing, watyer leaks, alarm going off or other problems I have read about here.
Woody
Anyone has the similar problem?
Thanks for the ventshade tip. I was wondering if that would help. I'm trying to cover all the bases before I buy.
I'm curious--do the seat belt buckles beat up the inside door pillars when you unbuckle them, when you close the door on them, or in some other way?
Will
One more thing. After installing the door visors did you find that your field of view or peripheral vision was diminished at all? Also, were they HONDA shades?
Will
We bought the Vent Shade brand of shades. They carry 2 models for the Pilot. One style tucks into the weather strip channel and uses double-sided tape to hold it there(this is the one I bought) and the other style uses double-sided tape to tape it to the out side of the door, just above the window channels (my brother-in-law has this type on his pilot). Both seem to work fine. I like the type I have but it did tighten up the weather stripping where the window goes into it.
The vent shades do block a little more view at the windshield piller, noticable but you do get use to it. I dislike the thick windshield pillers on new cars these days, but realize it is for safety so you have to live with it. They do not block the view of the mirrors.
The seatbelts beat up the inside of the door pillers as you un-buckle them and release them. It appears to me that the metal buckle knicks the plastic. The dealer suggested to me to hold on to the buckle as it retracted so that it would not hit the piller hard. This requires a person to change his/her habit of un-buckling the belt and letting it retract by itself. My biggest problem with the seatbelts is that after a few thousand miles the inside of the door pillers looked as if the car had several thousand miles of use, due to the pillers being knicked up all over the place. The tape had really helped and it does not knick up as bad as the plastic.
It just really bothers me that there is these minor problems on a +$30k vehicle. The CR-V we traded in didn't do this. Nor did it have any vibration problems. Heck I have a 68 chevy C-20 truck with big M/S tires and 16" wheels all around and it does not vibrate at 70-80 mph.....
Woody
Incidentally, right after that drive, I test drove a 2002 Acura MDX with the same mileage. No such problems. Smoother, quieter. But not worth the extra cost IMO.
twiced at a speed of around 15-20 mph
the suv has almost shut down or come to a complete stop at the same time a lot of grinding or growling sound then the VSI and ! lights come on. This SUV has been to the dealership twiced for this problem. My concern is it's a major safety problem -- pulling in traffic then the SUV would (twiced) bog down - almost stop. DOES ANYONE HAVE ANY IDEAS?
THANKS
WBOTENN
If the problem occurs in normal driving, sounds serious, and I'd push the dealer, escalating as necessary. What is the dealer sayiing? Are they fixing anything?
If the problem occurs when you're hammering the gas while turning, it could just be doing its job - it grinds and growls, brakes selective wheels, and chops the throttle to keep you from spinning the car.
- Mark
Turning normal and has happened while going straight
Dealership has had the SUV about a week and can't find the problem
THanks
- Mark
Sorry for long post. It's been quite an ordeal for me.
- Mark
